path: root/drivers/scsi/qla4xxx
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07dma-mapping: replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64)Yang Hongyang
Replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-25[SCSI] qla4xxx: do not reuse session when connecting to different target portMike Christie
qla4xxx does not check the I_T nexus values correctly so it ends up creating one session to the target. If a portal should disappear or they should be reported in different order the driver will think it is already logged in when it could now be speaking to a different target portal or accessing it through a different initiator port (iscsi initiator port is not tied to hardware and is just the initiator name plus isid so you could end up with multiple ports through one host). This patch has the driver check the iscsi scsi port values when matching sessions (we do not check the initiator name because that is static). It results in a portal from each target portal group getting logged into instead of just one per target. In the future the firmware should hopefully send us notification of other sessions that are created to other portals within the same tpgt and the sessions should have different isids. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-06trivial: Fix misspelling of "firmware" in ql4_mbx.cNick Andrew
Fix misspelling of "firmware" in ql4_mbx.c It's spelled "firmware". Signed-off-by: Nick Andrew <nick@nick-andrew.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-10-31drivers: replace NIPQUAD()Harvey Harrison
Using NIPQUAD() with NIPQUAD_FMT, %d.%d.%d.%d or %u.%u.%u.%u can be replaced with %pI4 Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-13[SCSI] libiscsi: Support drivers initiating session removalMike Christie
If the driver knows when hardware is removed like with cxgb3i, bnx2i, qla4xxx and iser then we will want to remove the sessions/devices that are bound to that device before removing the host. cxgb3i and in the future bnx2i will remove the host and that will remove all the sessions on the hba. iser can call iscsi_kill_session when it gets an event that indicates that a hca is removed. And when qla4xxx is hooked in to the lib (it is only hooked into the class right now) it can call iscsi remove host like the partial offload card drivers. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-13[SCSI] iscsi class, libiscsi and qla4xxx: convert to new transport host byte ↵Mike Christie
values This patch converts the iscsi drivers to the new host byte values. v2 Drop some conversions. Want to avoid conflicts with other patches. v1 initial patch. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-13[SCSI] qla4xxx: return SCSI_MLQUEUE_TARGET_BUSY when driver has detected ↵Mike Christie
session error When qla4xxx begins recovery and the iscsi class is firing up to handle it, we need to retrn SCSI_MLQUEUE_TARGET_BUSY from the driver instead of host busy, because the session recovery only affects the one target. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Acked-by: David C Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-09block: unify request timeout handlingJens Axboe
Right now SCSI and others do their own command timeout handling. Move those bits to the block layer. Instead of having a timer per command, we try to be a bit more clever and simply have one per-queue. This avoids the overhead of having to tear down and setup a timer for each command, so it will result in a lot less timer fiddling. Signed-off-by: Mike Anderson <andmike@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-26[SCSI] qla4xxx: fix queue depth settingMike Christie
We want to set the queue depth to something reasonable - not the can_queue. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Cc: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] iscsi: remove session/conn_data_size from iscsi_transportMike Christie
This removes the session and conn data_size fields from the iscsi_transport. Just pass in the value like with host allocation. This patch also makes it so the LLD iscsi_conn data is allocated with the iscsi_cls_conn. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] iscsi: remove session and host binding in libiscsiMike Christie
bnx2i allocates a host per netdevice but will use libiscsi, so this unbinds the session from the host in that code. This will also be useful for the iser parent device dma settings fixes. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] qla4xxx: fix scsi command completion, lun reset and target reset codeDavid C Somayajulu
This patch contains the following: 1. when hba completion status is good, check for iscsi transport errors (underflow/overflow) prior to checking the scsi status 2. New firmware requires that one marker iocb be issued for each task management command. The patch issues marker iocb immediately following a LUN or Target reset. Signed-off-by: David C Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] qla4xxx: Add target reset functionalityMike Christie
This patch adds target reset functionalty. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Acked-by: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-03-05[SCSI] qla4xxx: regression - add start scan calloutMike Christie
We are seeing EXIST errors from sysfs during device addition. We need a start scan callout so we do not start scanning sessions found during hba setup, before the async scsi scan code is ready. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Acked-by: David C Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-03-05[SCSI] qla4xxx: fix host reset dpc raceMike Christie
The host reset callout could be starting to reset the hba at the same time the dpc thread is. This creates lots of problems because they both want to do wierd things with the firmware and interrupts, etc. This patch just has the host reset function fully shutdown the dpc thread before resetting the hba. This patch also moves the setting of the session online bit to fix a potential race with the dpc thread and iscsi recovery thread. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Acked-by: David C Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-22[SCSI] qla4xxx: fix up residual handlingDavid Somayajulu
the check in the residual case has an incorrect test of scsi_status (the logic is reversed, it should be scsi_status != 0 instead of !scsi_status. Since we checked a few lines above that scsi_status was non-zero, just eliminate this test Signed-off-by: David C Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] qla4xxx: add async scan supportMike Christie
qla4xxx has the old school startup/probe where it finds presetup sessions in its flash and then attempts to log into them before returning from the probe. This however, makes it very simple to add a iscsi class scan finished helper which the driver can use. In future patches Dave or I will rip apart the driver to make it more like qla2xxx, but for now this is a very simple two line patch which fixes the problem of trying to figure out when the initial sessions are done being scanned. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Cc: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] qla4xxx: fix recovery timer and session unblock raceMike Christie
If qla4xxx is resetting up a session and the recovery timer fires we do not want to just set it to dead, because the dpc thread could have just set it to online and is in the middle of resetting it up. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Cc: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] qla4xxx: use iscsi class session state check readyMike Christie
This has qla4xxx use the iscsi class's check ready function in the queue command function, so all iscsi drivers return the same error value for common problems. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Cc: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] qla4xxx: directly call iscsi recovery functionsMike Christie
Qla4xxx can just call the iscsi recovery functions directly. There is no need for userspace to do this for qla4xxx, because we do not use the mutex to iterate over devices anymore and iscsi_block /unblock_session can be called from interrupt context or the dpc thread. And having userspace do this just creates uneeded headaches for qla4xxx root situations where the session may experience problems. For example during the kernel shutdown the scsi layer wants to send sync caches, but at this time userspace is not up (iscsid is not running), so we cannot recover from the problem. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Cc: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-03drivers/scsi/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Acked-by: James Smart <james.smart@emulex.com> Acked-by: Darrick J. Wong <djwong@us.ibm.com> Acked-by: David Somayajulu <david.somayajulu@qlogic.com> Acked-by: Mark Salyzyn <mark_salyzyn@adaptec.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-01-30[SCSI] remove use_sg_chainingJames Bottomley
With the sg table code, every SCSI driver is now either chain capable or broken (or has sg_tablesize set so chaining is never activated), so there's no need to have a check in the host template. Also tidy up the code by moving the scatterlist size defines into the SCSI includes and permit the last entry of the scatterlist pools not to be a power of two. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-28[ETH]: Combine format_addr() with print_mac().Michael Chan
print_mac() used many most net drivers and format_addr() used by net-sysfs.c are very similar and they can be intergrated. format_addr() is also identically redefined in the qla4xxx iscsi driver. Export a new function sysfs_format_mac() to be used by net-sysfs, qla4xxx and others in the future. Both print_mac() and sysfs_format_mac() call _format_mac_addr() to do the formatting. Changed print_mac() to use unsigned char * to be consistent with net_device struct's dev_addr. Added buffer length overrun checking as suggested by Joe Perches. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-23[SCSI] replace sizeof sense_buffer with SCSI_SENSE_BUFFERSIZEFUJITA Tomonori
This replaces sizeof sense_buffer with SCSI_SENSE_BUFFERSIZE in several LLDs. It's a preparation for the future changes to remove sense_buffer array in scsi_cmnd structure. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] libiscsi: fix shutdownMike Christie
We were using the device delete sysfs file to remove each device then logout. Now in 2.6.21 this will not work because the sysfs delete file returns immediately and does not wait for the device removal to complete. This causes a hang if a cache sync is needed during shutdown. Before .21, that approach had other problems, so this patch fixes the shutdown code so that we remove the target and unbind the session before logging out and shut down the session Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-19Fix misspellings of "system", "controller", "interrupt" and "necessary".Robert P. J. Day
Fix the various misspellings of "system", controller", "interrupt" and "[un]necessary". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Change struct marker usersMathieu Desnoyers
Prior to use struct marker in the linux kernel markers, we need to clean two drivers which use this structure name. Change bonding driver types : - struct marker to struct bond_marker. - marker_t to bond_marker_t. - marker_header to bond_marker_header. - marker_header_t to bond_marker_header_t. Change qla4xxx struct marker_entry usage : - Change struct marker_entry for struct qla4_marker_entry. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Chad Tindel <ctindel@users.sourceforge.net> Cc: Jay Vosburgh <fubar@us.ibm.com> Cc: David Somayajulu <david.somayajulu@qlogic.com> Cc: James Bottomley <James.Bottomley@SteelEye.com> Cc: Ravi Anand <ravi.anand@qlogic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18Add missing newlines to some uses of dev_<level> messagesJoe Perches
Found these while looking at printk uses. Add missing newlines to dev_<level> uses Add missing KERN_<level> prefixes to multiline dev_<level>s Fixed a wierd->weird spelling typo Added a newline to a printk Signed-off-by: Joe Perches <joe@perches.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Mark M. Hoffman <mhoffman@lightlink.com> Cc: Roland Dreier <rolandd@cisco.com> Cc: Tilman Schmidt <tilman@imap.cc> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Greg KH <greg@kroah.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: James Smart <James.Smart@Emulex.Com> Cc: Andrew Vasquez <andrew.vasquez@qlogic.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16[SCSI] add use_sg_chaining option to scsi_host_templateFUJITA Tomonori
This option is true if a low-level driver can support sg chaining. This will be removed eventually when all the drivers are converted to support sg chaining. q->max_phys_segments is set to SCSI_MAX_SG_SEGMENTS if false. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-14[SCSI] qla4xxx: Fix underrun/overrun conditionsDavid C Somayajulu
On Wed, 2007-06-06 at 11:55 -0700, David C Somayajulu wrote: This patch fixes the code handling underrun and overrun conditions. Also fixed coding style as per Mike Christie's advice. Signed-off-by: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-17[SCSI] qla4xxx: allow hba to be online when initiator ip address is ↵David C Somayajulu
uninitialized This patch provides the following: 1. remove warning ignoring the return value of pci_set_mwi() 2. allows HBA to be online when the initiator ip address is uninitialized. Signed-off-by: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-02[SCSI] iscsi class, iscsi_tcp, iser, qla4xxx: add netdevname sysfs attrMike Christie
iSCSI must support software iscsi (iscsi_tcp, iser), hardware iscsi (qla4xxx), and partial offload (broadcom). To be able to allow each stack or driver or port (virtual or physical) to be able to log into the same target portal we use the initiator tuple [[HWADDRESS | NETDEVNAME], INITIATOR_NAME] and the target tuple [TARGETNAME, CONN_ADDRESS, CONN_PORT] to id a session. This patch adds the netdev name, which is used by software iscsi when it binds a session to a netdevice using the SO_BINDTODEVICE sock opt. It cannot use HWADDRESS because if someone did vlans then the same netdevice will have the same mac and the initiator,target id will not be unique. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Cc: Roland Dreier <rdreier@cisco.com> Cc: David C Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-02[SCSI] iscsi class, qla4xxx, iscsi_tcp: export local addressMike Christie
This patch exports the local address for the session. For qla4xxx this is the ip of the hba's port. For software this is the src addr of the socket. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Cc: David C Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-02[SCSI] qla4xxx: add iscsi_transport capps for fw capacilitiesMike Christie
Userspace will want to know what the driver/FW/HW capabilites when it comes to some operations like if the hardware can do discovery or if it can store iscsi info like what target was used for boot. This patch adds some new caps so userspace can tell if the driver supports hardware/fw based sendtargets discovery and if the hardware has some flash which may be holding or can contain some iscsi target info . Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Cc: David C Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-01[SCSI] iscsi class, qla4xxx, iscsi_tcp, ib_iser: export/set initiator nameMike Christie
For iscsi root boot, software iscsi needs to know what the BIOS/OF initiator used for the initiator name so this puts it in sysfs for userspace to be able to pick up. For hw iscsi, it is nice to see what the card is using. This patch adds the new param, and hooks in qla4xxx, iscsi_tcp, and ib_iser. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Cc: Roland Dreier <rdreier@cisco.com> Cc: David C Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-01[SCSI] iscsi_transport, qla4xxx: have class lookup host for driversMike Christie
We are going to be adding more host level sysfs attrs and set_params, so this patch has them take a scsi_host instead of either a scsi_host or host no. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Cc: David C Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-01[SCSI] qla4xxx: export mac as hw addressMike Christie
Export mac as hw address. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Cc: David C Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-29[SCSI] qla4xxx: convert to use the data buffer accessorsFUJITA Tomonori
- remove the unnecessary map_single path. - convert to use the new accessors for the sg lists and the parameters. Jens Axboe <jens.axboe@oracle.com> did the for_each_sg cleanup. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: David C Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-26[SCSI] qla4xxx: ql4_os.c bugfixesDavid C Somayajulu
Free memory resources after invoking free_irq() in qla4xxx_free_adapter(). QLA4xxx has two pci functions per port (Ethernet and iSCSI). When one of these PCI functions issues a HBA reset, all other functions are notified and need to acknowledge and re-initialize. During module qla4xxx_remove_adapter() gets invoked. This function needs to wait if it is currently responding to a reset from another function. Signed-off-by: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-26[SCSI] qla4xxx: ql4_mbx.c remove dead code bugfixesDavid C Somayajulu
All all inbound mbx registers for all mbx commands. Remove dead code. Signed-off-by: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-26[SCSI] qla4xxx: ql4_isr.c support for new mbx cmdsDavid C Somayajulu
Add support to log all AENs and service mbx cmd completions for QLA4032 Signed-off-by: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-26[SCSI] qla4xxx: update rev num and misc cleanupDavid C Somayajulu
Clean up and update version number Signed-off-by: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-26[SCSI] qla4xxx: ql4_init.c bugfixesDavid C Somayajulu
In qla4xxx_get_ddb_entry() and qla4xxx_add_device_dynamically() differentiate between a target which has been newly added vs a target which went offline temporarily and is online again. In qla4xxx_build_ddb_list() firmware ddb state needs to be updated by calling qla4xxx_get_ddb_entry(). Fix qla4x00_pci_config() and clean up code. Signed-off-by: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-26[SCSI] qla4xxx: ql4_fw.h add support for qla4032David C Somayajulu
Add support for QLA4032 which supports IPv6 Signed-off-by: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-26[SCSI] qla4xxx: ql4_def.h log all AENs and cleanupDavid C Somayajulu
Add support for logging all AENs and clean up Signed-off-by: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-26[SCSI] qla4xxx: ql4_dbg.c remove dead codeDavid C Somayajulu
Remove dead code Signed-off-by: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-06[SCSI] qla4xxx: possible cleanupsAdrian Bunk
- make needlessly global code static - #if 0 unused functions Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Ravi Anand <ravi.anand@qlogic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-02-14[PATCH] Scheduled removal of SA_xxx interrupt flags fixupsThomas Gleixner
The obsolete SA_xxx interrupt flags have been used despite the scheduled removal. Fixup the remaining users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Roland Dreier <rolandd@cisco.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: Dave Airlie <airlied@linux.ie> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
