path: root/drivers/scsi/qla4xxx
2008-04-07[SCSI] qla4xxx: fix scsi command completion, lun reset and target reset codeDavid C Somayajulu
This patch contains the following: 1. when hba completion status is good, check for iscsi transport errors (underflow/overflow) prior to checking the scsi status 2. New firmware requires that one marker iocb be issued for each task management command. The patch issues marker iocb immediately following a LUN or Target reset. Signed-off-by: David C Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] qla4xxx: Add target reset functionalityMike Christie
This patch adds target reset functionalty. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Acked-by: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-03-05[SCSI] qla4xxx: regression - add start scan calloutMike Christie
We are seeing EXIST errors from sysfs during device addition. We need a start scan callout so we do not start scanning sessions found during hba setup, before the async scsi scan code is ready. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Acked-by: David C Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-03-05[SCSI] qla4xxx: fix host reset dpc raceMike Christie
The host reset callout could be starting to reset the hba at the same time the dpc thread is. This creates lots of problems because they both want to do wierd things with the firmware and interrupts, etc. This patch just has the host reset function fully shutdown the dpc thread before resetting the hba. This patch also moves the setting of the session online bit to fix a potential race with the dpc thread and iscsi recovery thread. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Acked-by: David C Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-22[SCSI] qla4xxx: fix up residual handlingDavid Somayajulu
the check in the residual case has an incorrect test of scsi_status (the logic is reversed, it should be scsi_status != 0 instead of !scsi_status. Since we checked a few lines above that scsi_status was non-zero, just eliminate this test Signed-off-by: David C Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] qla4xxx: add async scan supportMike Christie
qla4xxx has the old school startup/probe where it finds presetup sessions in its flash and then attempts to log into them before returning from the probe. This however, makes it very simple to add a iscsi class scan finished helper which the driver can use. In future patches Dave or I will rip apart the driver to make it more like qla2xxx, but for now this is a very simple two line patch which fixes the problem of trying to figure out when the initial sessions are done being scanned. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Cc: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] qla4xxx: fix recovery timer and session unblock raceMike Christie
If qla4xxx is resetting up a session and the recovery timer fires we do not want to just set it to dead, because the dpc thread could have just set it to online and is in the middle of resetting it up. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Cc: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] qla4xxx: use iscsi class session state check readyMike Christie
This has qla4xxx use the iscsi class's check ready function in the queue command function, so all iscsi drivers return the same error value for common problems. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Cc: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] qla4xxx: directly call iscsi recovery functionsMike Christie
Qla4xxx can just call the iscsi recovery functions directly. There is no need for userspace to do this for qla4xxx, because we do not use the mutex to iterate over devices anymore and iscsi_block /unblock_session can be called from interrupt context or the dpc thread. And having userspace do this just creates uneeded headaches for qla4xxx root situations where the session may experience problems. For example during the kernel shutdown the scsi layer wants to send sync caches, but at this time userspace is not up (iscsid is not running), so we cannot recover from the problem. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Cc: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-03drivers/scsi/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Acked-by: James Smart <james.smart@emulex.com> Acked-by: Darrick J. Wong <djwong@us.ibm.com> Acked-by: David Somayajulu <david.somayajulu@qlogic.com> Acked-by: Mark Salyzyn <mark_salyzyn@adaptec.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-01-30[SCSI] remove use_sg_chainingJames Bottomley
With the sg table code, every SCSI driver is now either chain capable or broken (or has sg_tablesize set so chaining is never activated), so there's no need to have a check in the host template. Also tidy up the code by moving the scatterlist size defines into the SCSI includes and permit the last entry of the scatterlist pools not to be a power of two. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-28[ETH]: Combine format_addr() with print_mac().Michael Chan
print_mac() used many most net drivers and format_addr() used by net-sysfs.c are very similar and they can be intergrated. format_addr() is also identically redefined in the qla4xxx iscsi driver. Export a new function sysfs_format_mac() to be used by net-sysfs, qla4xxx and others in the future. Both print_mac() and sysfs_format_mac() call _format_mac_addr() to do the formatting. Changed print_mac() to use unsigned char * to be consistent with net_device struct's dev_addr. Added buffer length overrun checking as suggested by Joe Perches. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-23[SCSI] replace sizeof sense_buffer with SCSI_SENSE_BUFFERSIZEFUJITA Tomonori
This replaces sizeof sense_buffer with SCSI_SENSE_BUFFERSIZE in several LLDs. It's a preparation for the future changes to remove sense_buffer array in scsi_cmnd structure. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] libiscsi: fix shutdownMike Christie
We were using the device delete sysfs file to remove each device then logout. Now in 2.6.21 this will not work because the sysfs delete file returns immediately and does not wait for the device removal to complete. This causes a hang if a cache sync is needed during shutdown. Before .21, that approach had other problems, so this patch fixes the shutdown code so that we remove the target and unbind the session before logging out and shut down the session Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-19Fix misspellings of "system", "controller", "interrupt" and "necessary".Robert P. J. Day
Fix the various misspellings of "system", controller", "interrupt" and "[un]necessary". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Change struct marker usersMathieu Desnoyers
Prior to use struct marker in the linux kernel markers, we need to clean two drivers which use this structure name. Change bonding driver types : - struct marker to struct bond_marker. - marker_t to bond_marker_t. - marker_header to bond_marker_header. - marker_header_t to bond_marker_header_t. Change qla4xxx struct marker_entry usage : - Change struct marker_entry for struct qla4_marker_entry. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Chad Tindel <ctindel@users.sourceforge.net> Cc: Jay Vosburgh <fubar@us.ibm.com> Cc: David Somayajulu <david.somayajulu@qlogic.com> Cc: James Bottomley <James.Bottomley@SteelEye.com> Cc: Ravi Anand <ravi.anand@qlogic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18Add missing newlines to some uses of dev_<level> messagesJoe Perches
Found these while looking at printk uses. Add missing newlines to dev_<level> uses Add missing KERN_<level> prefixes to multiline dev_<level>s Fixed a wierd->weird spelling typo Added a newline to a printk Signed-off-by: Joe Perches <joe@perches.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Mark M. Hoffman <mhoffman@lightlink.com> Cc: Roland Dreier <rolandd@cisco.com> Cc: Tilman Schmidt <tilman@imap.cc> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Greg KH <greg@kroah.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: James Smart <James.Smart@Emulex.Com> Cc: Andrew Vasquez <andrew.vasquez@qlogic.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16[SCSI] add use_sg_chaining option to scsi_host_templateFUJITA Tomonori
This option is true if a low-level driver can support sg chaining. This will be removed eventually when all the drivers are converted to support sg chaining. q->max_phys_segments is set to SCSI_MAX_SG_SEGMENTS if false. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-14[SCSI] qla4xxx: Fix underrun/overrun conditionsDavid C Somayajulu
On Wed, 2007-06-06 at 11:55 -0700, David C Somayajulu wrote: This patch fixes the code handling underrun and overrun conditions. Also fixed coding style as per Mike Christie's advice. Signed-off-by: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-17[SCSI] qla4xxx: allow hba to be online when initiator ip address is ↵David C Somayajulu
uninitialized This patch provides the following: 1. remove warning ignoring the return value of pci_set_mwi() 2. allows HBA to be online when the initiator ip address is uninitialized. Signed-off-by: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-02[SCSI] iscsi class, iscsi_tcp, iser, qla4xxx: add netdevname sysfs attrMike Christie
iSCSI must support software iscsi (iscsi_tcp, iser), hardware iscsi (qla4xxx), and partial offload (broadcom). To be able to allow each stack or driver or port (virtual or physical) to be able to log into the same target portal we use the initiator tuple [[HWADDRESS | NETDEVNAME], INITIATOR_NAME] and the target tuple [TARGETNAME, CONN_ADDRESS, CONN_PORT] to id a session. This patch adds the netdev name, which is used by software iscsi when it binds a session to a netdevice using the SO_BINDTODEVICE sock opt. It cannot use HWADDRESS because if someone did vlans then the same netdevice will have the same mac and the initiator,target id will not be unique. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Cc: Roland Dreier <rdreier@cisco.com> Cc: David C Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-02[SCSI] iscsi class, qla4xxx, iscsi_tcp: export local addressMike Christie
This patch exports the local address for the session. For qla4xxx this is the ip of the hba's port. For software this is the src addr of the socket. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Cc: David C Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-02[SCSI] qla4xxx: add iscsi_transport capps for fw capacilitiesMike Christie
Userspace will want to know what the driver/FW/HW capabilites when it comes to some operations like if the hardware can do discovery or if it can store iscsi info like what target was used for boot. This patch adds some new caps so userspace can tell if the driver supports hardware/fw based sendtargets discovery and if the hardware has some flash which may be holding or can contain some iscsi target info . Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Cc: David C Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-01[SCSI] iscsi class, qla4xxx, iscsi_tcp, ib_iser: export/set initiator nameMike Christie
For iscsi root boot, software iscsi needs to know what the BIOS/OF initiator used for the initiator name so this puts it in sysfs for userspace to be able to pick up. For hw iscsi, it is nice to see what the card is using. This patch adds the new param, and hooks in qla4xxx, iscsi_tcp, and ib_iser. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Cc: Roland Dreier <rdreier@cisco.com> Cc: David C Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-01[SCSI] iscsi_transport, qla4xxx: have class lookup host for driversMike Christie
We are going to be adding more host level sysfs attrs and set_params, so this patch has them take a scsi_host instead of either a scsi_host or host no. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Cc: David C Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-01[SCSI] qla4xxx: export mac as hw addressMike Christie
Export mac as hw address. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Cc: David C Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-29[SCSI] qla4xxx: convert to use the data buffer accessorsFUJITA Tomonori
- remove the unnecessary map_single path. - convert to use the new accessors for the sg lists and the parameters. Jens Axboe <jens.axboe@oracle.com> did the for_each_sg cleanup. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: David C Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-26[SCSI] qla4xxx: ql4_os.c bugfixesDavid C Somayajulu
Free memory resources after invoking free_irq() in qla4xxx_free_adapter(). QLA4xxx has two pci functions per port (Ethernet and iSCSI). When one of these PCI functions issues a HBA reset, all other functions are notified and need to acknowledge and re-initialize. During module qla4xxx_remove_adapter() gets invoked. This function needs to wait if it is currently responding to a reset from another function. Signed-off-by: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-26[SCSI] qla4xxx: ql4_mbx.c remove dead code bugfixesDavid C Somayajulu
All all inbound mbx registers for all mbx commands. Remove dead code. Signed-off-by: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-26[SCSI] qla4xxx: ql4_isr.c support for new mbx cmdsDavid C Somayajulu
Add support to log all AENs and service mbx cmd completions for QLA4032 Signed-off-by: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-26[SCSI] qla4xxx: update rev num and misc cleanupDavid C Somayajulu
Clean up and update version number Signed-off-by: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-26[SCSI] qla4xxx: ql4_init.c bugfixesDavid C Somayajulu
In qla4xxx_get_ddb_entry() and qla4xxx_add_device_dynamically() differentiate between a target which has been newly added vs a target which went offline temporarily and is online again. In qla4xxx_build_ddb_list() firmware ddb state needs to be updated by calling qla4xxx_get_ddb_entry(). Fix qla4x00_pci_config() and clean up code. Signed-off-by: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-26[SCSI] qla4xxx: ql4_fw.h add support for qla4032David C Somayajulu
Add support for QLA4032 which supports IPv6 Signed-off-by: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-26[SCSI] qla4xxx: ql4_def.h log all AENs and cleanupDavid C Somayajulu
Add support for logging all AENs and clean up Signed-off-by: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-26[SCSI] qla4xxx: ql4_dbg.c remove dead codeDavid C Somayajulu
Remove dead code Signed-off-by: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-06[SCSI] qla4xxx: possible cleanupsAdrian Bunk
- make needlessly global code static - #if 0 unused functions Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Ravi Anand <ravi.anand@qlogic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-02-14[PATCH] Scheduled removal of SA_xxx interrupt flags fixupsThomas Gleixner
The obsolete SA_xxx interrupt flags have been used despite the scheduled removal. Fixup the remaining users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Roland Dreier <rolandd@cisco.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: Dave Airlie <airlied@linux.ie> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-27[SCSI] qla4xxx: bug fixesDavid C Somayajulu
The included patch fixes the following issues: 1. qla3xxx/qla4xxx co-existence issue which can result in a lockup when qla3xxx driver is unloaded, or when ifdown; ifup is performed on one of the interfaces correponding to qla3xxx. This is because qla4xxx HBA supports one ethernet and iscsi interfaces per port. Both iscsi and ethernet interfaces share the same state machine. The problem has to do with synchronizing access to the state machine in the event of a reset 2. mutex_lock() is sometimes not followed by mutex_unlock() prior to invoking a msleep() in qla4xxx_mailbox_command() Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-12-06Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/pcmcia/ds.c Fix up merge failures with Linus's head and fix new compile failures. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-11-22[SCSI] qla4xxx: fix for timing issue for nvram accesses.David C Somayajulu
This patch fixes a timing issue related to nvram accesses in qla4xxx driver for some cpu/slot speed combination. Signed-off-by: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-11-22[SCSI] qla4xxx: add support for qla4032David C Somayajulu
This patch provides the following: 1. adds support for the next version of Qlogic's iSCSI HBA, qla4032 (PCI Device ID 4032). 2. removes dead code related to topcat chip and renames qla4010_soft_reset to qla4xxx_soft_reset (minor changes). Signed-off-by: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-11-22[PATCH] qla4xxx: bug fix: driver hardware semaphore needs to be grabbed ↵David C Somayajulu
before soft reset On qla4xxx, the driver needs to grab the drvr semaphore provided by the hardware, prior to issuing a reset. This patches takes care of a couple of places where it was not being done. In addition there is minor clean up. Signed-off-by: David Somayajulu <david.somayajulu@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-31[PATCH] SCSI: ISCSI build failureRandy Dunlap
SCSI_QLA_ISCSI needs to depend on NET to prevent build (link) failures that are caused by selecting SCSI_ISCSI_ATTRS. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-25[SCSI] Maintain module-parameter name consistency with qla2xxx/qla4xxx.Andrew Vasquez
Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] qla4xxx: fix double printk on loadDoug Maxey
There is a dup printk at the tail of qla4xxx_module_init(). Remove the first instance as it's before the complete success of the function. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-05Merge git://git.infradead.org/~dhowells/irq-2.6Linus Torvalds
* git://git.infradead.org/~dhowells/irq-2.6: IRQ: Maintain regs pointer globally rather than passing to IRQ handlers IRQ: Typedef the IRQ handler function type IRQ: Typedef the IRQ flow handler function type
2006-10-05[PATCH] fix qla{2,4} build errorFrederik Deweerdt
commit 0181944fe647cae18d545ac1167df3d15d393701 adds a 'extended_error_logging' global variable to qla2xxx which is defined by qla4xxx too. Trying to build both drivers results in the following error: LD drivers/scsi/built-in.o drivers/scsi/qla4xxx/built-in.o: In function `qla4xxx_slave_configure': drivers/scsi/qla4xxx/ql4_os.c:1433: multiple definition of `extended_error_logging' drivers/scsi/qla2xxx/built-in.o:drivers/scsi/qla2xxx/qla_os.c:2166: first defined here make[2]: *** [drivers/scsi/built-in.o] Error 1 make[1]: *** [drivers/scsi] Error 2 make: *** [drivers] Error 2 The following patch simply adds a qla2_ (qla4_ respectively) prefix to the variable name. Signed-off-by: Frederik Deweerdt <frederik.deweerdt@gmail.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
