path: root/drivers/scsi/qlogicpti.c
2008-02-23[SCSI] qlogicpt: section fixesAdrian Bunk
In current mainline, __devinit qpti_sbus_probe() still is calling __init qpti_chain_add(). Change occurrences of __init to __devinit to fix. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] replace sizeof sense_buffer with SCSI_SENSE_BUFFERSIZEFUJITA Tomonori
This replaces sizeof sense_buffer with SCSI_SENSE_BUFFERSIZE in several LLDs. It's a preparation for the future changes to remove sense_buffer array in scsi_cmnd structure. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] qlogicpti: convert to accessors and !use_sg cleanupBoaz Harrosh
- convert to accessors and !use_sg cleanup Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-16qlogicpti: sg chaining supportJens Axboe
2007-10-12[SCSI] qlogicpti: Add a slave_configure methodMatthew Wilcox
By configuring targets in slave_configure, we can eliminate a shadow queuecommand, a shadow scsi_done, a write to the host template, abuse of SCp->Message and SCp->Status, a use of kmap_atomic() and sniffing the results of INQUIRY. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-08-02[SCSI] qlogicpti: Some cosmetic changesMark Fortescue
Change a printk sequencing issue where <6> ... was coming up in the middle of a line when scsi_add_host was being called. Reduce the length of some printk messages and make the messages more consistant. All cosmetic but it makes it easier to read as it scrolles off the screen during boot. Signed-off-by: Mark Fortescue <mark@mtfhpc.demon.co.uk> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-04-26[SPARC/64] constify of_get_property return: driversStephen Rothwell
The only unfortunate bit here is that the name field of struct map_info is not const, so for now we put a cast on the assignment of it. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-14[SCSI] QLOGICPTI: Do not unmap DMA unless we actually mapped something.David S. Miller
We only map DMA when cmd->request_bufflen is non-zero for non-sg buffers, we thus should make the same check when unmapping. Based upon a report from Pasi Pirhonen. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-17[SPARC]: Fix some section mismatch warnings in sparc drivers.Ben Collins
Signed-off-by: Ben Collins <ben.collins@ubuntu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-14[SCSI] More buffer->request_buffer changesChristoph Hellwig
Seem like quite a few splipped through the cracks. Here's a patch to update all references I could find: Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-02[PATCH] irq-flags: scsi: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[SCSI] qlogicpti: Convert to new SBUS device framework.David S. Miller
2006-06-21Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (85 commits) [SCSI] 53c700: remove reliance on deprecated cmnd fields [SCSI] hptiop: don't use cmnd->bufflen [SCSI] hptiop: HighPoint RocketRAID 3xxx controller driver [SCSI] aacraid: small misc. cleanups [SCSI] aacraid: Update supported product information [SCSI] aacraid: Fix return code interpretation [SCSI] scsi_transport_sas: fix panic in sas_free_rphy [SCSI] remove RQ_SCSI_* flags [SCSI] remove scsi_request infrastructure [SCSI] mptfusion: change driver revision to 3.03.10 [SCSI] mptfc: abort of board reset leaves port dead requiring reboot [SCSI] mptfc: fix fibre channel infinite request/response loop [SCSI] mptfc: set fibre channel fw target missing timers to one second [SCSI] mptfusion: move fc event/reset handling to mptfc [SCSI] spi transport: don't allow dt to be set on SE or HVD buses [SCSI] aic7xxx: expose the bus setting to sysfs [SCSI] scsi: remove Documentation/scsi/cpqfc.txt [SCSI] drivers/scsi: Use ARRAY_SIZE macro [SCSI] Remove last page_address from dc395x.c [SCSI] hptiop: HighPoint RocketRAID 3xxx controller driver ... Fixed up conflicts in drivers/message/fusion/mptbase.c manually (due to the sparc interrupt cleanups)
2006-06-20[SPARC]: Kill __irq_itoa().David S. Miller
This ugly hack was long overdue to die. It was a way to print out Sparc interrupts in a more freindly format, since IRQ numbers were arbitrary opaque 32-bit integers which vectored into PIL levels. These 32-bit integers were not necessarily in the 0-->NR_IRQS range, but the PILs they vectored to were. The idea now is that we will increase NR_IRQS a little bit and use a virtual<-->real IRQ number mapping scheme similar to PowerPC. That makes this IRQ printing hack irrelevant, and furthermore only a handful of drivers actually used __irq_itoa() making it even less useful. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-10[SCSI] remove scsi_request infrastructureChristoph Hellwig
With Achim patch the last user (gdth) is switched away from scsi_request so we an kill it now. Also disables some code in i2o_scsi that was broken since the sg driver stopped using scsi_requests. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-10[SCSI] drivers/scsi: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove duplicates of the macro. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-28[PATCH] drivers/scsi/*: use time_after() and friendsMarcelo Feitoza Parisi
They deal with wrapping correctly and are nicer to read. Signed-off-by: Marcelo Feitoza Parisi <marcelo@feitoza.com.br> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-14[QLOGICPTI]: Handle INQUIRY response sniffing correctly.David S. Miller
These days, in 2.6.x, even INQUIRY commands are sent using scatter gather lists. Bug reported by Tom 'spot' Callaway. Signed-off-by: David S. Miller <davem@davemloft.net>
