path: root/drivers/scsi/scsi.c
2008-05-02[SCSI] add support for variable length extended commandsBoaz Harrosh
Add support for variable-length, extended, and vendor specific CDBs to scsi-ml. It is now possible for initiators and ULD's to issue these types of commands. LLDs need not change much. All they need is to raise the .max_cmd_len to the longest command they support (see iscsi patch). - clean-up some code paths that did not expect commands to be larger than 16, and change cmd_len members' type to short as char is not enough. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-29[SCSI] bug fix for free list handlingAlan D. Brunelle
commit: commit 542bd1377a963070bc4a03ff7d2690ddf3920596 Author: James Bottomley <James.Bottomley@HansenPartnership.com> Date: Mon Apr 21 10:57:20 2008 -0500 [SCSI] fix SLUB WARN_ON Fixed another problem in free list handling by moving list allocation from scsi_host_alloc() to scsi_add_host(). Unfortunately it introduced a new failure mode in that hosts can pass straight from alloc to put without going through add, leaving the free list uninitialised. Fix by checking shost->cmd_pool on the release path to see if it got initialised. Signed-off-by: Alan D. Brunelle <alan.brunelle@hp.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-21block: move the padding adjustment to blk_rq_map_sgFUJITA Tomonori
blk_rq_map_user adjusts bi_size of the last bio. It breaks the rule that req->data_len (the true data length) is equal to sum(bio). It broke the scsi command completion code. commit e97a294ef6938512b655b1abf17656cf2b26f709 was introduced to fix the above issue. However, the partial completion code doesn't work with it. The commit is also a layer violation (scsi mid-layer should not know about the block layer's padding). This patch moves the padding adjustment to blk_rq_map_sg (suggested by James). The padding works like the drain buffer. This patch breaks the rule that req->data_len is equal to sum(sg), however, the drain buffer already broke it. So this patch just restores the rule that req->data_len is equal to sub(bio) without breaking anything new. Now when a low level driver needs padding, blk_rq_map_user and blk_rq_map_user_iov guarantee there's enough room for padding. blk_rq_map_sg can safely extend the last entry of a scatter list. blk_rq_map_sg must extend the last entry of a scatter list only for a request that got through bio_copy_user_iov. This patches introduces new REQ_COPY_USER flag. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Tejun Heo <htejun@gmail.com> Cc: Mike Christie <michaelc@cs.wisc.edu> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-07[SCSI] export command allocation and freeing functions independently of the hostJames Bottomley
This is needed by things like USB storage that want to set up static commands for later use at start of day. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] consolidate command allocation in a single placeJames Bottomley
Since the way we allocate commands with a separate sense buffer is getting complicated, we should isolate setup and teardown to a single routine so that if it gets even more complex, there's only one place in the code that needs to be altered. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-06scsi: fix sense_slab/bio swapping livelockHugh Dickins
Since 2.6.25-rc7, I've been seeing an occasional livelock on one x86_64 machine, copying kernel trees to tmpfs, paging out to swap. Signature: 6000 pages under writeback but never getting written; most tasks of interest trying to reclaim, but each get_swap_bio waiting for a bio in mempool_alloc's io_schedule_timeout(5*HZ); every five seconds an atomic page allocation failure report from kblockd failing to allocate a sense_buffer in __scsi_get_command. __scsi_get_command has a (one item) free_list to protect against this, but rc1's [SCSI] use dynamically allocated sense buffer de25deb18016f66dcdede165d07654559bb332bc upset that slightly. When it fails to allocate from the separate sense_slab, instead of giving up, it must fall back to the command free_list, which is sure to have a sense_buffer attached. Either my earlier -rc testing missed this, or there's some recent contributory factor. One very significant factor is SLUB, which merges slab caches when it can, and on 64-bit happens to merge both bio cache and sense_slab cache into kmalloc's 128-byte cache: so that under this swapping load, bios above are liable to gobble up all the slots needed for scsi_cmnd sense_buffers below. That's disturbing behaviour, and I tried a few things to fix it. Adding a no-op constructor to the sense_slab inhibits SLUB from merging it, and stops all the allocation failures I was seeing; but it's rather a hack, and perhaps in different configurations we have other caches on the swapout path which are ill-merged. Another alternative is to revert the separate sense_slab, using cache-line-aligned sense_buffer allocated beyond scsi_cmnd from the one kmem_cache; but that might waste more memory, and is only a way of diverting around the known problem. While I don't like seeing the allocation failures, and hate the idea of all those bios piled up above a scsi host working one by one, it does seem to emerge fairly soon with the livelock fix. So lacking better ideas, stick with that one clear fix for now. Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Peter Zijlstra <a.p.ziljstra@chello.nl> Cc: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04scsi: missing add of padded bytes to io completion byte countJens Axboe
Original patch from Tejun Heo <htejun@gmail.com> but should use ->extra_len and not ->data_len, as we would then overshoot the original request size. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-07[SCSI] kernel-doc: fix scsi docbookRandy Dunlap
Add missing function parameter descriptions. Make function short description fit on one line as required. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-30[SCSI] implement scsi_data_bufferBoaz Harrosh
In preparation for bidi we abstract all IO members of scsi_cmnd, that will need to duplicate, into a substructure. - Group all IO members of scsi_cmnd into a scsi_data_buffer structure. - Adjust accessors to new members. - scsi_{alloc,free}_sgtable receive a scsi_data_buffer instead of scsi_cmnd. And work on it. - Adjust scsi_init_io() and scsi_release_buffers() for above change. - Fix other parts of scsi_lib/scsi.c to members migration. Use accessors where appropriate. - fix Documentation about scsi_cmnd in scsi_host.h - scsi_error.c * Changed needed members of struct scsi_eh_save. * Careful considerations in scsi_eh_prep/restore_cmnd. - sd.c and sr.c * sd and sr would adjust IO size to align on device's block size so code needs to change once we move to scsi_data_buff implementation. * Convert code to use scsi_for_each_sg * Use data accessors where appropriate. - tgt: convert libsrp to use scsi_data_buffer - isd200: This driver still bangs on scsi_cmnd IO members, so need changing [jejb: rebased on top of sg_table patches fixed up conflicts and used the synergy to eliminate use_sg and sg_count] Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] don't use __GFP_DMA for sense buffers if not requiredJames Bottomley
Only hosts which actually have ISA DMA requirements need sense buffers coming out of ZONE_DMA, so only use the __GFP_DMA flag for that case to avoid allocating this scarce resource if it's not necessary. [tomo: fixed slab leak in failure case] Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] use dynamically allocated sense bufferFUJITA Tomonori
This removes static array sense_buffer in scsi_cmnd and uses dynamically allocated sense_buffer (with GFP_DMA). The reason for doing this is that some architectures need cacheline aligned buffer for DMA: http://lkml.org/lkml/2007/11/19/2 The problems are that scsi_eh_prep_cmnd puts scsi_cmnd::sense_buffer to sglist and some LLDs directly DMA to scsi_cmnd::sense_buffer. It's necessary to DMA to scsi_cmnd::sense_buffer safely. This patch solves these issues. __scsi_get_command allocates sense_buffer via kmem_cache_alloc and attaches it to a scsi_cmnd so everything just work as before. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] fix scsi_setup_command_freelist failure path raceFUJITA Tomonori
Looks like that host_cmd_pool_mutex are necessary here. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] docbook and kernel-doc updatesRandy Dunlap
- Change title to remove "Mid-Layer" since the doc is about all of the SCSI layers. - Use "SCSI" instead of "scsi" in docbook text. - Use "*/" to end kernel-doc notation blocks. - A few other minor typo fixes. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] Add Documentation and integrate into docbook buildRob Landley
Add Documentation/DocBook/scsi_midlayer.tmpl, add to Makefile, and update lots of kerneldoc comments in drivers/scsi/*. Updated with comments from Stefan Richter, Stephen M. Cameron, James Bottomley and Randy Dunlap. Signed-off-by: Rob Landley <rob@landley.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-06Revert "scsi: revert "[SCSI] Get rid of scsi_cmnd->done""Linus Torvalds
This reverts commit ac40532ef0b8649e6f7f83859ea0de1c4ed08a19, which gets us back the original cleanup of 6f5391c283d7fdcf24bf40786ea79061919d1e1d. It turns out that the bug that was triggered by that commit was apparently not actually triggered by that commit at all, and just the testing conditions had changed enough to make it appear to be due to it. The real problem seems to have been found by Peter Osterlund: "pktcdvd sets it [block device size] when opening the /dev/pktcdvd device, but when the drive is later opened as /dev/scd0, there is nothing that sets it back. (Btw, 40944 is possible if the disk is a CDRW that was formatted with "cdrwtool -m 10236".) The problem is that pktcdvd opens the cd device in non-blocking mode when pktsetup is run, and doesn't close it again until pktsetup -d is run. The effect is that if you meanwhile open the cd device, blkdev.c:do_open() doesn't call bd_set_size() because bdev->bd_openers is non-zero." In particular, to repeat the bug (regardless of whether commit 6f5391c283d7fdcf24bf40786ea79061919d1e1d is applied or not): " 1. Start with an empty drive. 2. pktsetup 0 /dev/scd0 3. Insert a CD containing an isofs filesystem. 4. mount /dev/pktcdvd/0 /mnt/tmp 5. umount /mnt/tmp 6. Press the eject button. 7. Insert a DVD containing a non-writable filesystem. 8. mount /dev/scd0 /mnt/tmp 9. find /mnt/tmp -type f -print0 | xargs -0 sha1sum >/dev/null 10. If the DVD contains data beyond the physical size of a CD, you get I/O errors in the terminal, and dmesg reports lots of "attempt to access beyond end of device" errors." which in turn is because the nested open after the media change won't cause the size to be set properly (because the original open still holds the block device, and we only do the bd_set_size() when we don't have other people holding the device open). The proper fix for that is probably to just do something like bdev->bd_inode->i_size = (loff_t)get_capacity(disk)<<9; in fs/block_dev.c:do_open() even for the cases where we're not the original opener (but *not* call bd_set_size(), since that will also change the block size of the device). Cc: Peter Osterlund <petero2@telia.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Ingo Molnar <mingo@elte.hu> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-02scsi: revert "[SCSI] Get rid of scsi_cmnd->done"Ingo Molnar
This reverts commit 6f5391c283d7fdcf24bf40786ea79061919d1e1d ("[SCSI] Get rid of scsi_cmnd->done") that was supposed to be a cleanup commit, but apparently it causes regressions: Bug 9370 - v2.6.24-rc2-409-g9418d5d: attempt to access beyond end of device http://bugzilla.kernel.org/show_bug.cgi?id=9370 this patch should be reintroduced in a more split-up form to make testing of it easier. Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Matthew Wilcox <matthew@wil.cx> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-10esp_scsi: fix reset cleanup spinlock recursionMaciej W. Rozycki
The esp_reset_cleanup() function is called with the host lock held and invokes starget_for_each_device() which wants to take it too. Here is a fix along the lines of shost_for_each_device()/__shost_for_each_device() adding a __starget_for_each_device() counterpart which assumes the lock has already been taken. Eventually, I think the driver should get modified so that more work is done as a softirq rather than in the interrupt context, but for now it fixes a bug that causes the spinlock debugger to fire. While at it, it fixes a small number of cosmetic problems with starget_for_each_device() too. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Acked-by: David S. Miller <davem@davemloft.net> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12[SCSI] Get rid of scsi_cmnd->doneMatthew Wilcox
The ULD ->done callback moves into the scsi_driver. By moving the call to scsi_io_completion() from scsi_blk_pc_done() to scsi_finish_command(), we can eliminate the latter entirely. By returning 'good_bytes' from the ->done callback (rather than invoking scsi_io_completion()), we can stop exporting scsi_io_completion(). Also move the prototypes from sd.h to sd.c as they're all internal anyway. Rename sd_rw_intr to sd_done and rw_intr to sr_done. Inspired-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] Remove ->pid field from scsi_cmndMatthew Wilcox
The pid field is a duplicate of the serial_number field and has been scheduled for removal for a long time. A few drivers were still using it, so just change them to use serial_number instead. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-14[SCSI] scsi.c: convert to use the data buffer accessorsBoaz Harrosh
- a couple of prints, they can use the accessors Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-14[SCSI] Remove unused method scsi_device_cancelPriyanka Gupta
Removes an obsolete method scsi_device_cancel which isn't being used anywhere in the kernel. Signed-off-by: Priyanka Gupta <priyankag@google.com> Acked-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-03-11[SCSI] Make error printing more verboseMartin K. Petersen
This patch enhances SCSI error printing by: - Making use of scsi_print_result() in the completion functions. - Having scmd_printk() output the disk name (when applicable). Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-01-13[SCSI] kill scsi_rety_commandChristoph Hellwig
scsi_retry_command only has a single caller, so there is no point in having this function. Additionally the memset of the sense buffer it does is entirely superflous as scsi_request_fn already calls scsi_init_cmd_errh to perform this memset before the command is reissued. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-11-25[SCSI] export scsi-ml functions needed by tgt_scsi_lib and its LLDsFUJITA Tomonori
This patch contains the needed changes to the scsi-ml for the target mode support. Note, per the last review we moved almost all the fields we added to the scsi_cmnd to our internal data structure which we are going to try and kill off when we can replace it with support from other parts of the kernel. The one field we left on was the offset variable. This is needed to handle the case where the target gets request that is so large that it cannot execute it in one dma operation. So max_secotors or a segment limit may limit the size of the transfer. In this case our tgt core code will break up the command into managable transfers and send them to the LLD one at a time. The offset is then used to tell the LLD where in the command we are at. Is there another field on the scsi_cmd for that? Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-11-15[SCSI] fix module unload induced compile warningIngo Molnar
Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-04Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (54 commits) [SCSI] Initial Commit of qla4xxx [SCSI] raid class: handle component-add errors [SCSI] SCSI megaraid_sas: handle thrown errors [SCSI] SCSI aic94xx: handle sysfs errors [SCSI] SCSI st: fix error handling in module init, sysfs [SCSI] SCSI sd: fix module init/exit error handling [SCSI] SCSI osst: add error handling to module init, sysfs [SCSI] scsi: remove hosts.h [SCSI] scsi: Scsi_Cmnd convertion in aic7xxx_old.c [SCSI] megaraid_sas: sets ioctl timeout and updates version,changelog [SCSI] megaraid_sas: adds tasklet for cmd completion [SCSI] megaraid_sas: prints pending cmds before setting hw_crit_error [SCSI] megaraid_sas: function pointer for disable interrupt [SCSI] megaraid_sas: frame count optimization [SCSI] megaraid_sas: FW transition and q size changes [SCSI] qla2xxx: Update version number to 8.01.07-k2. [SCSI] qla2xxx: Stall mid-layer error handlers while rport is blocked. [SCSI] qla2xxx: Add MODULE_FIRMWARE tags. [SCSI] qla2xxx: Add support for host port state FC transport attribute. [SCSI] qla2xxx: Add support for fabric name FC transport attribute. ...
2006-10-01[SCSI] fix scsi_device_types overrun in scsi.cEric Sesterhenn
this overrun was spotted by coverity (cid #1403). If type == ARRAY_SIZE(scsi_device_types), we are off by one. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-09-30[PATCH] SCSI: scsi_done_q is unusedJens Axboe
It is a leftover from before the softirq completion was migrated to the block layer. Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] Remove ->rq_status from struct requestJens Axboe
After Christophs SCSI change, the only usage left is RQ_ACTIVE and RQ_INACTIVE. The block layer sets RQ_INACTIVE right before freeing the request, so any check for RQ_INACTIVE in a driver is a bug and indicates use-after-free. So kill/clean the remaining users, straight forward. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-09-24[PATCH] Revert ABI-breaking change in /procMatthew Wilcox
Some user tools parse /proc/scsi/scsi, so we can't yet change the names. Change the existing ones back to their old names, and add an admonition to not make the same mistake that I did. Andrew Morton reports that this was breaking YDL 4.1 userspace. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-12[SCSI] fix compile error on module_refcountDaniel Walker
LD .tmp_vmlinux1 drivers/built-in.o(.text+0x8e1f9): In function `scsi_device_put': drivers/scsi/scsi.c:887: undefined reference to `module_refcount' make: *** [.tmp_vmlinux1] Error 1 There are only two users of module_refcount() outside of kernel/module.c and the other one uses ifdef's similar to this. Signed-Off-By: Daniel Walker <dwalker@mvista.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-09-07[SCSI] fix up non-modular SCSIJames Bottomley
The recent change to the way scsi_device_get()/put() work broke the non modular build (we do a module_refcount on a NULL). Fix this by checking for non-null before checking module_refcount(). Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-09-02[SCSI] SCSI and FC Transport: add netlink support for posting of transport ↵James Smart
events This patch formally adds support for the posting of FC events via netlink. It is a followup to the original RFC at: http://marc.theaimsgroup.com/?l=linux-scsi&m=114530667923464&w=2 and the initial posting at: http://marc.theaimsgroup.com/?l=linux-scsi&m=115507374832500&w=2 The patch has been updated to optimize the send path, per the discussions in the initial posting. Per discussions at the Storage Summit and at OLS, we are to use netlink for async events from transports. Also per discussions, to avoid a netlink protocol per transport, I've create a single NETLINK_SCSITRANSPORT protocol, which can then be used by all transports. This patch: - Creates new files scsi_netlink.c and scsi_netlink.h, which contains the single and shared definitions for the SCSI Transport. It is tied into the base SCSI subsystem intialization. Contains a single interface routine, scsi_send_transport_event(), for a transport to send an event (via multicast to a protocol specific group). - Creates a new scsi_netlink_fc.h file, which contains the FC netlink event messages - Adds 3 new routines to the fc transport: fc_get_event_number() - to get a FC event # fc_host_post_event() - to send a simple FC event (32 bits of data) fc_host_post_vendor_event() - to send a Vendor unique event, with arbitrary amounts of data. Note: the separation of event number allows for a LLD to send a standard event, followed by vendor-specific data for the event. Note: This patch assumes 2 prior fc transport patches have been installed: http://marc.theaimsgroup.com/?l=linux-scsi&m=115555807316329&w=2 http://marc.theaimsgroup.com/?l=linux-scsi&m=115581614930261&w=2 Sorry - next time I'll do something like making these individual patches of the same posting when I know they'll be posted closely together. Signed-off-by: James Smart <James.Smart@emulex.com> Tidy up configuration not to make SCSI always select NET Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-09-01[SCSI] sd: fix cache flushing on module removal (and individual device removal)James Bottomley
The fix isn't actually in sd: it's in scsi_device_get(). I modified it to allow devices to be returned in SDEV_CANCEL, but not SDEV_DEL. This means that the device_remove_driver, which occurs in device_del() in scsi_remove_device() after the device has gone into SDEV_CANCEL is now effective at flushing the cache. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-08-06[SCSI] Improve inquiry printingMatthew Wilcox
- Replace scsi_device_types array API with scsi_device_type function API. Gets rid of a lot of common code, as well as being easier to use. - Add the new device types in SPC4 r05a, and rename some of the older ones. - Reformat the printing of inquiry data; now fits on one line and includes PQ. I think I've addressed all the feedback from the previous versions. My current test box prints: scsi 2:0:1:0: Direct access HP 18.2G ATLAS10K3_18_SCA HP05 PQ: 0 ANSI: 2 Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-09[SCSI] hide EH backup data outside the scsi_cmndChristoph Hellwig
Currently struct scsi_cmnd has various fields that are used to backup original data after the corresponding fields have been overridden for EH commands. This means drivers can easily get at it and misuse it. Due to the old_ naming this doesn't happen for most of them, but two that have different names have been used wrong a lot (see previous patch). Another downside is that they unessecarily bloat the scsi_cmnd size. This patch moves them onstack in scsi_send_eh_cmnd to fix those two issues aswell as allowing future EH fixes like moving the EH command submissions to use SG lists like everything else. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-22Merge branch 'master' into upstreamJeff Garzik
Conflicts: drivers/scsi/libata-core.c drivers/scsi/libata-scsi.c include/linux/pci_ids.h
2006-06-10[SCSI] remove scsi_request infrastructureChristoph Hellwig
With Achim patch the last user (gdth) is switched away from scsi_request so we an kill it now. Also disables some code in i2o_scsi that was broken since the sg driver stopped using scsi_requests. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-05-15[PATCH] SCSI: Introduce scsi_req_abort_cmd (REPOST)Luben Tuikov
Introduce scsi_req_abort_cmd(struct scsi_cmnd *). This function requests that SCSI Core start recovery for the command by deleting the timer and adding the command to the eh queue. It can be called by either LLDDs or SCSI Core. LLDDs who implement their own error recovery MAY ignore the timeout event if they generated scsi_req_abort_cmd. First post: http://marc.theaimsgroup.com/?l=linux-scsi&m=113833937421677&w=2 Signed-off-by: Luben Tuikov <ltuikov@yahoo.com> Signed-off-by: Tejun Heo <htejun@gmail.com>
2006-04-13[SCSI] add SCSI_UNKNOWN and LUN transfer limit restrictionsJames Bottomley
Original From: Ingo Flaschberger <if@xip.at> To support the RA4100 array from Compaq. This patch now correctly handles SCSI_UNKNOWN types with regard to BLIST_REPORTLUNS2 (allow it) and cdb[1] LUN inclusion (don't). It also allows a BLIST_MAX_512 flag to restrict the maximum transfer length to 512 blocks (apparently this is an RA4100 problem). Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-04-13[SCSI] for_each_possible_cpu: scsiKAMEZAWA Hiroyuki
for_each_cpu() actually iterates across all possible CPUs. We've had mistakes in the past where people were using for_each_cpu() where they should have been iterating across only online or present CPUs. This is inefficient and possibly buggy. We're renaming for_each_cpu() to for_each_possible_cpu() to avoid this in the future. This patch replaces for_each_cpu with for_each_possible_cpu. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-27[SCSI] Remove devfs support from the SCSI subsystemGreg KH
As devfs has been disabled from the kernel tree for a number of months now (5 to be exact), here's a patch against 2.6.16-rc1-git1 that removes support for it from the SCSI subsystem. The patch also removes the scsi_disk devfs_name field as it's no longer needed. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-27[SCSI] SCSI core kmalloc2kzallocJes Sorensen
Change the core SCSI code to use kzalloc rather than kmalloc+memset where possible. Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-05[PATCH] percpu data: only iterate over possible CPUsEric Dumazet
percpu_data blindly allocates bootmem memory to store NR_CPUS instances of cpudata, instead of allocating memory only for possible cpus. As a preparation for changing that, we need to convert various 0 -> NR_CPUS loops to use for_each_cpu(). (The above only applies to users of asm-generic/percpu.h. powerpc has gone it alone and is presently only allocating memory for present CPUs, so it's currently corrupting memory). Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: James Bottomley <James.Bottomley@steeleye.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Jens Axboe <axboe@suse.de> Cc: Anton Blanchard <anton@samba.org> Acked-by: William Irwin <wli@holomorphy.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[SCSI] turn most scsi semaphores into mutexesArjan van de Ven
the scsi layer is using semaphores in a mutex way, this patch converts these into using mutexes instead Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-09[SCSI] Kill the SCSI softirq handlingJens Axboe
This patch moves the SCSI softirq handling to the block layer version. There should be no functional changes. Signed-off-by: Jens Axboe <axboe@suse.de>
2005-11-22[PATCH] Fix a bug in scsi_get_commandMatthew Dobson
scsi_get_command() attempts to write into a structure that may not have been successfully allocated. Move this write inside the if statement that ensures we won't panic the kernel with a NULL pointer dereference. Signed-off-by: Matthew Dobson <colpatch@us.ibm.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
