path: root/drivers/scsi/scsi_logging.h
2006-04-15[SCSI] scsi_scan.c: fix compile warningsakpm@osdl.org
drivers/scsi/scsi_scan.c: In function `scsi_probe_and_add_lun': drivers/scsi/scsi_scan.c:926: warning: unused variable `vend' drivers/scsi/scsi_scan.c:926: warning: unused variable `mod' drivers/scsi/scsi_scan.c: At top level: drivers/scsi/scsi_scan.c:829: warning: `scsi_inq_str' defined but not used Fix those, tighten up the (somewhat poorly-designed) logging macro and fix some coding-style warts. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
