path: root/drivers/scsi/scsi_scan.c
2011-06-02[SCSI] Fix oops caused by queue refcounting failureJames Bottomley
In certain circumstances, we can get an oops from a torn down device. Most notably this is from CD roms trying to call scsi_ioctl. The root cause of the problem is the fact that after scsi_remove_device() has been called, the queue is fully torn down. This is actually wrong since the queue can be used until the sdev release function is called. Therefore, we add an extra reference to the queue which is released in sdev->release, so the queue always exists. Reported-by: Parag Warudkar <parag.lkml@gmail.com> Cc: stable@kernel.org Signed-off-by: James Bottomley <jbottomley@parallels.com>
2011-05-17scsi: remove performance regression due to async queue runJens Axboe
Commit c21e6beb removed our queue request_fn re-enter protection, and defaulted to always running the queues from kblockd to be safe. This was a known potential slow down, but should be safe. Unfortunately this is causing big performance regressions for some, so we need to improve this logic. Looking into the details of the re-enter, the real issue is on requeue of requests. Requeue of requests upon seeing a BUSY condition from the device ends up re-running the queue, causing traces like this: scsi_request_fn() scsi_dispatch_cmd() scsi_queue_insert() __scsi_queue_insert() scsi_run_queue() scsi_request_fn() ... potentially causing the issue we want to avoid. So special case the requeue re-run of the queue, but improve it to offload the entire run of local queue and starved queue from a single workqueue callback. This is a lot better than potentially kicking off a workqueue run for each device seen. This also fixes the issue of the local device going into recursion, since the above mentioned commit never moved that queue run out of line. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-22driver core: remove CONFIG_SYSFS_DEPRECATED_V2 but keep it for block devicesKay Sievers
This patch removes the old CONFIG_SYSFS_DEPRECATED_V2 config option, but it keeps the logic around to handle block devices in the old manner as some people like to run new kernel versions on old (pre 2007/2008) distros. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: "James E.J. Bottomley" <James.Bottomley@suse.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Tejun Heo <tj@kernel.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-28[SCSI] implement runtime Power ManagementAlan Stern
This patch (as1398b) adds runtime PM support to the SCSI layer. Only the machanism is provided; use of it is up to the various high-level drivers, and the patch doesn't change any of them. Except for sg -- the patch expicitly prevents a device from being runtime-suspended while its sg device file is open. The implementation is simplistic. In general, hosts and targets are automatically suspended when all their children are asleep, but for them the runtime-suspend code doesn't actually do anything. (A host's runtime PM status is propagated up the device tree, though, so a runtime-PM-aware lower-level driver could power down the host adapter hardware at the appropriate times.) There are comments indicating where a transport class might be notified or some other hooks added. LUNs are runtime-suspended by calling the drivers' existing suspend handlers (and likewise for runtime-resume). Somewhat arbitrarily, the implementation delays for 100 ms before suspending an eligible LUN. This is because there typically are occasions during bootup when the same device file is opened and closed several times in quick succession. The way this all works is that the SCSI core increments a device's PM-usage count when it is registered. If a high-level driver does nothing then the device will not be eligible for runtime-suspend because of the elevated usage count. If a high-level driver wants to use runtime PM then it can call scsi_autopm_put_device() in its probe routine to decrement the usage count and scsi_autopm_get_device() in its remove routine to restore the original count. Hosts, targets, and LUNs are not suspended while they are being probed or removed, or while the error handler is running. In fact, a fairly large part of the patch consists of code to make sure that things aren't suspended at such times. [jejb: fix up compile issues in PM config variations] Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-05-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: [SCSI] fix race in scsi_target_reap [SCSI] aacraid: Eliminate use after free [SCSI] arcmsr: Support HW reset for EH and polling scheme for scsi device [SCSI] bfa: fix system crash when reading sysfs fc_host statistics [SCSI] iscsi_tcp: remove sk_sleep check [SCSI] ipr: improve interrupt service routine performance [SCSI] ipr: set the data list length in the request control block [SCSI] ipr: fix a register read to use the correct address for 64 bit adapters [SCSI] ipr: include the resource path in the IOA status area structure [SCSI] ipr: implement fixes for 64 bit adapter support [SCSI] be2iscsi: correct return value in mgmt_invalidate_icds()
2010-05-25[SCSI] fix race in scsi_target_reapAlan Stern
This patch (as1357) fixes a race in SCSI target allocation and release. Putting a target in the STARGET_DEL state isn't protected by the host lock, so an old target structure could be reused by a new device even though it's about to be deleted. The cure is to change the state while still holding the host lock. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-05-24scsi_scan.c: fix/convert functions to use kernel-docRandy Dunlap
scsi_scan.c: fix incorrectly formatted kernel-doc notation & convert documentation of 2 functions into kernel-doc. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-11[SCSI] don't kfree an initialized struct deviceAlan Stern
This patch (as1359) fixes a bug in scsi_alloc_target(). After a device structure has been initialized (and especially after its name has been set), it must not be freed directly. One has to call put_device() instead. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-01Merge branch 'for-2.6.34' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.34' of git://git.kernel.dk/linux-2.6-block: (38 commits) block: don't access jiffies when initialising io_context cfq: remove 8 bytes of padding from cfq_rb_root on 64 bit builds block: fix for "Consolidate phys_segment and hw_segment limits" cfq-iosched: quantum check tweak blktrace: perform cleanup after setup error blkdev: fix merge_bvec_fn return value checks cfq-iosched: requests "in flight" vs "in driver" clarification cciss: Fix problem with scatter gather elements in the scsi half of the driver cciss: eliminate unnecessary pointer use in cciss scsi code cciss: do not use void pointer for scsi hba data cciss: factor out scatter gather chain block mapping code cciss: fix scatter gather chain block dma direction kludge cciss: simplify scatter gather code cciss: factor out scatter gather chain block allocation and freeing cciss: detect bad alignment of scsi commands at build time cciss: clarify command list padding calculation cfq-iosched: rethink seeky detection for SSDs cfq-iosched: rework seeky detection block: remove padding from io_context on 64bit builds block: Consolidate phys_segment and hw_segment limits ...
2010-02-26block: Rename blk_queue_max_sectors to blk_queue_max_hw_sectorsMartin K. Petersen
The block layer calling convention is blk_queue_<limit name>. blk_queue_max_sectors predates this practice, leading to some confusion. Rename the function to appropriately reflect that its intended use is to set max_hw_sectors. Also introduce a temporary wrapper for backwards compability. This can be removed after the merge window is closed. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-02-18[SCSI] fix refcounting bug in scsi_get_host_devAlan Stern
This patch (as1334) fixes a bug in scsi_get_host_dev(). It incorrectly calls get_device() on the new device's target. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-02-18[SCSI] fix memory leak in scsi_report_lun_scanAlan Stern
This patch (as1333) fixes a bug in scsi_report_lun_scan(). If a newly-allocated device can't be used, it should be deleted. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (222 commits) [SCSI] zfcp: Remove flag ZFCP_STATUS_FSFREQ_TMFUNCNOTSUPP [SCSI] zfcp: Activate fc4s attributes for zfcp in FC transport class [SCSI] zfcp: Block scsi_eh thread for rport state BLOCKED [SCSI] zfcp: Update FSF error reporting [SCSI] zfcp: Improve ELS ADISC handling [SCSI] zfcp: Simplify handling of ct and els requests [SCSI] zfcp: Remove ZFCP_DID_MASK [SCSI] zfcp: Move WKA port to zfcp FC code [SCSI] zfcp: Use common code definitions for FC CT structs [SCSI] zfcp: Use common code definitions for FC ELS structs [SCSI] zfcp: Update FCP protocol related code [SCSI] zfcp: Dont fail SCSI commands when transitioning to blocked fc_rport [SCSI] zfcp: Assign scheduled work to driver queue [SCSI] zfcp: Remove STATUS_COMMON_REMOVE flag as it is not required anymore [SCSI] zfcp: Implement module unloading [SCSI] zfcp: Merge trace code for fsf requests in one function [SCSI] zfcp: Access ports and units with container_of in sysfs code [SCSI] zfcp: Remove suspend callback [SCSI] zfcp: Remove global config_mutex [SCSI] zfcp: Replace local reference counting with common kref ...
2009-12-04[SCSI] add queue_depth ramp up codeVasu Dev
Current FC HBA queue_depth ramp up code depends on last queue full time. The sdev already has last_queue_full_time field to track last queue full time but stored value is truncated by last four bits. So this patch updates last_queue_full_time without truncating last 4 bits to store full value and then updates its only current usages in scsi_track_queue_full to ignore last four bits to keep current usages same while also use this field in added ramp up code. Adds scsi_handle_queue_ramp_up to ramp up queue_depth on successful completion of IO. The scsi_handle_queue_ramp_up will do ramp up on all luns of a target, just same as ramp down done on all luns on a target. The ramp up is skipped in case the change_queue_depth is not supported by LLD or already reached to added max_queue_depth. Updates added max_queue_depth on every new update to default queue_depth value. The ramp up is also skipped if lapsed time since either last queue ramp up or down is less than LLD specified queue_ramp_up_period. Adds queue_ramp_up_period to sysfs but only if change_queue_depth is supported since ramp up and queue_ramp_up_period is needed only in case change_queue_depth is supported first. Initializes queue_ramp_up_period to 120HZ jiffies as initial default value, it is same as used in existing lpfc and qla2xxx. -v2 Combined all ramp code into this single patch. -v3 Moves max_queue_depth initialization after slave_configure is called from after slave_alloc calling done. Also adjusted max_queue_depth check to skip ramp up if current queue_depth is >= max_queue_depth. -v4 Changes sdev->queue_ramp_up_period unit to ms when using sysfs i/f to store or show its value. Signed-off-by: Vasu Dev <vasu.dev@intel.com> Tested-by: Christof Schmitt <christof.schmitt@de.ibm.com> Tested-by: Giridhar Malavali <giridhar.malavali@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-11-26[SCSI] fix async scan add/remove race resulting in an oopsJames Bottomley
Async scanning introduced a very wide window where the SCSI device is up and running but has not yet been added to sysfs. We delay the adding until all scans have completed to retain the same ordering as sync scanning. This delay in visibility causes an oops if a device is removed before we make it visible because the SCSI removal routines have an inbuilt assumption that if a device is in SDEV_RUNNING state, it must be visible (which is not necessarily true in the async scanning case). Fix this by introducing an additional is_visible flag which we can use to condition the tear down so we do the right thing for running but not yet made visible. Reported-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-13[SCSI] fix memory leak in initializationJames Bottomley
The root cause of the problem is the fact that dev_set_name() now allocates storage instead of using the original array within the kobj. That means that the SCSI assumption that if you haven't made the containing object or any sub objects visible, you can just destroy it (and its component devices) lock stock and barrel becomes false. Fix this by doing the get of sdev_dev at parent time and thus do an extra put of it in scsi_destroy_sdev() (and all other destruction without add paths). Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-05-20[SCSI] Increase default timeout for INQUIRYAlan Stern
This patch (as1224) changes the default timeout for INQUIRY commands from 3 seconds to 20 seconds, which is the value used by Windows for USB Mass-Storage devices. Some of these devices, like the Corsair Flash Voyager (see Bugzilla #12188) really do need a long timeout. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-05-14[SCSI] initialize max_target_blocked in scsi_alloc_targetEdward Goggin
This patch initializes the max_target_blocked field of a scsi target structure so that a queuecommand return value of SCSI_MLQUEUE_TARGET_BUSY will actually result in having the scsi_queue_insert blocking the device queue before requeuing the command and running the queue. Otherwise, can and does cause livelock on single CPU configurations if/when open-iSCSI software initiator's command PDU window fills. Signed-off-by: Ed Goggin <egoggin@vmware.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-21driver synchronization: make scsi_wait_scan more advancedArjan van de Ven
There is currently only one way for userspace to say "wait for my storage device to get ready for the modules I just loaded": to load the scsi_wait_scan module. Expectations of userspace are that once this module is loaded, all the (storage) devices for which the drivers were loaded before the module load are present. Now, there are some issues with the implementation, and the async stuff got caught in the middle of this: The existing code only waits for the scsy async probing to finish, but it did not take into account at all that probing might not have begun yet. (Russell ran into this problem on his computer and the fix works for him) This patch fixes this more thoroughly than the previous "fix", which had some bad side effects (namely, for kernel code that wanted to wait for the scsi scan it would also do an async sync, which would deadlock if you did it from async context already.. there's a report about that on lkml): The patch makes the module first wait for all device driver probes, and then it will wait for the scsi parallel scan to finish. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Tested-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-12[SCSI] add OSD_TYPEBoaz Harrosh
- Define the OSD_TYPE scsi device and let it show up in scans Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-02-10[SCSI] scsi_scan: add missing interim SDEV_DEL state if slave_alloc failsJames Smart
We were running i/o and performing a bunch of hba resets in a loop. This forces a lot of target removes and then rescans. Since the resets are occuring during scan it's causing the scan i/o to timeout, invoking error recovery, etc. We end up getting some nasty crashing in scsi_scan.c due to references to old sdevs that are failing but had some lingering references that kept them around. Fix by setting device state to SDEV_DEL if the LLD's slave_alloc fails. Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (45 commits) [SCSI] qla2xxx: Update version number to 8.03.00-k1. [SCSI] qla2xxx: Add ISP81XX support. [SCSI] qla2xxx: Use proper request/response queues with MQ instantiations. [SCSI] qla2xxx: Correct MQ-chain information retrieval during a firmware dump. [SCSI] qla2xxx: Collapse EFT/FCE copy procedures during a firmware dump. [SCSI] qla2xxx: Don't pollute kernel logs with ZIO/RIO status messages. [SCSI] qla2xxx: Don't fallback to interrupt-polling during re-initialization with MSI-X enabled. [SCSI] qla2xxx: Remove support for reading/writing HW-event-log. [SCSI] cxgb3i: add missing include [SCSI] scsi_lib: fix DID_RESET status problems [SCSI] fc transport: restore missing dev_loss_tmo callback to LLDD [SCSI] aha152x_cs: Fix regression that keeps driver from using shared interrupts [SCSI] sd: Correctly handle 6-byte commands with DIX [SCSI] sd: DIF: Fix tagging on platforms with signed char [SCSI] sd: DIF: Show app tag on error [SCSI] Fix error handling for DIF/DIX [SCSI] scsi_lib: don't decrement busy counters when inserting commands [SCSI] libsas: fix test for negative unsigned and typos [SCSI] a2091, gvp11: kill warn_unused_result warnings [SCSI] fusion: Move a dereference below a NULL test ... Fixed up trivial conflict due to moving the async part of sd_probe around in the async probes vs using dev_set_name() in naming.
2009-01-07fastboot: make scsi probes asynchronousArjan van de Ven
This patch makes part of the scsi probe (which is mostly device spin up and the partition scan) asynchronous. Only the part that runs after getting the device number allocated is asynchronous, ensuring that device numbering remains stable. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2009-01-02[SCSI] struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
[jejb: limit ioctl to returning 20 characters to avoid overrun on long device names and add a few more conversions] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] retry with missing data for INQUIRYFUJITA Tomonori
This patch changes scsi_probe_lun() to retry INQUIRY if the device has not actually sent back any INQUIRY data, This enables the Thecus N2050 storage device to work better. The firmware on that device starts up strangely; it sends no data in response to the initial INQUIRY, and it sends the INQUIRY information in response to the followup REQUEST SENSE. But after that it works better, so retrying the INQUIRY is enough to get it going. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] add residual argument to scsi_execute and scsi_execute_reqFUJITA Tomonori
scsi_execute() and scsi_execute_req() discard the residual length information. Some callers need it. This adds residual argument (optional) to scsi_execute and scsi_execute_req. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-13[SCSI] Add helper code so transport classes/driver can control queueing (v3)Mike Christie
SCSI-ml manages the queueing limits for the device and host, but does not do so at the target level. However something something similar can come in userful when a driver is transitioning a transport object to the the blocked state, becuase at that time we do not want to queue io and we do not want the queuecommand to be called again. The patch adds code similar to the exisiting SCSI_ML_*BUSY handlers. You can now return SCSI_MLQUEUE_TARGET_BUSY when we hit a transport level queueing issue like the hw cannot allocate some resource at the iscsi session/connection level, or the target has temporarily closed or shrunk the queueing window, or if we are transitioning to the blocked state. bnx2i, when they rework their firmware according to netdev developers requests, will also need to be able to limit queueing at this level. bnx2i will hook into libiscsi, but will allocate a scsi host per netdevice/hba, so unlike pure software iscsi/iser which is allocating a host per session, it cannot set the scsi_host->can_queue and return SCSI_MLQUEUE_HOST_BUSY to reflect queueing limits on the transport. The iscsi class/driver can also set a scsi_target->can_queue value which reflects the max commands the driver/class can support. For iscsi this reflects the number of commands we can support for each session due to session/connection hw limits, driver limits, and to also reflect the session/targets's queueing window. Changes: v1 - initial patch. v2 - Fix scsi_run_queue handling of multiple blocked targets. Previously we would break from the main loop if a device was added back on the starved list. We now run over the list and check if any target is blocked. v3 - Rediff for scsi-misc. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-03[SCSI] Update the SCSI state model to allow blocking in the created stateJames Bottomley
Brian King <brking@linux.vnet.ibm.com> reported that fibre channel devices can oops during scanning if their ports block (because the device goes from CREATED -> BLOCK -> RUNNING rather than CREATED -> BLOCK -> CREATED). Fix this by adding a new state: CREATED_BLOCK which can only transition back to CREATED and disallow the CREATED -> BLOCK transition. Now both the created and blocked states that the mid-layer recognises can include CREATED_BLOCK. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-03[SCSI] add inline functions for recognising created and blocked statesJames Bottomley
The created and blocked states are very shortly going to correspond to mixed sdev_state states. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-08-29[SCSI] fix check of PQ and PDT bits for WLUNsJames Bottomley
For IBM z series certain LUNs can no longer be accessed. This is because kernel version 2.6.19 a check was introduced not to create a generic SCSI device for devices that return PQ=1 and PDT=0x1f. For WLUNs (see SAM-3, p. 41ff) generic SCSI devices should be created unconditionally without looking at the PQ bit, so add a check for WLUNs in with this test. Acked-by: Martin Petermann <martin@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-27[SCSI] replace __FUNCTION__ with __func__Harvey Harrison
[jejb: fixed up a ton of missed conversions. All of you are on notice this has happened, driver trees will now need to be rebased] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: SCSI List <linux-scsi@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-26[SCSI] scsi_scan.c: Release mutex in error handling codeJulia Lawall
The mutex is released on a successful return, so it would seem that it should be released on an error return as well. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ expression l; @@ mutex_lock(l); ... when != mutex_unlock(l) when any when strict ( if (...) { ... when != mutex_unlock(l) + mutex_unlock(l); return ...; } | mutex_unlock(l); ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-12[SCSI] make struct scsi_{host,target}_type staticAdrian Bunk
Make the needlessly global struct scsi_{host,target}_type static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-29Remove duplicated unlikely() in IS_ERR()Hirofumi Nakagawa
Some drivers have duplicated unlikely() macros. IS_ERR() already has unlikely() in itself. This patch cleans up such pointless code. Signed-off-by: Hirofumi Nakagawa <hnakagawa@miraclelinux.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Jeff Garzik <jeff@garzik.org> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Patrick McHardy <kaber@trash.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-22[SCSI] rework scsi_target allocationJames Bottomley
The current target allocation code registeres each possible target with sysfs; it will be deleted again if no useable LUN on this target was found. This results in a string of 'target add/target remove' uevents. Based on a patch by Hannes Reinecke <hare@suse.de> this patch reworks the target allocation code so that only uevents for existing targets are sent. The sysfs registration is split off from the existing scsi_target_alloc() into a in a new scsi_add_target() function, which should be called whenever an existing target is found. Only then a uevent is sent, so we'll be generating events for existing targets only. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-22[SCSI] add scsi_host and scsi_target to scsi_busHannes Reinecke
This patch implements scsi_host and scsi_target device types and adds both to the scsi_bus. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-03-03docbook: fix scsi source fileRandy Dunlap
Fix docbook problem in SCSI source files. These cause the generated docbook to be incorrect. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-23[SCSI] add missing transport configure points for target and hostJames Bottomley
While trying to convert the SPI transport class to attribute groups, I discovered that we don't actually have any transport configure points for either the target or the host. This patch adds these missing transport class triggers. The host one is simply done after the add, the target one tries to be more clever and add it after devices may have been placed on the target (so the device configure will have set up the target parameters). Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] move single_lun flag from scsi_device to scsi_targetTony Battersby
Some SCSI tape medium changers that need the BLIST_SINGLELUN flag have the medium changer at one LUN and the tape drive at a different LUN. The inquiry string of the tape drive may be different from that of the medium changer. In order for single_lun to be effective, every scsi_device under a given scsi_target must have it set. This means that there needs to be a blacklist entry for BOTH the medium changer AND the tape drive, which is impractical because some medium changers may be paired with a variety of different tape drive models. It makes more sense to put the single_lun flag in scsi_target instead of scsi_device, which causes every device at a given target ID to inherit the single_lun flag from one LUN. This makes it possible to blacklist just the medium changer and not the tape drive. Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] Add Documentation and integrate into docbook buildRob Landley
Add Documentation/DocBook/scsi_midlayer.tmpl, add to Makefile, and update lots of kerneldoc comments in drivers/scsi/*. Updated with comments from Stefan Richter, Stephen M. Cameron, James Bottomley and Randy Dunlap. Signed-off-by: Rob Landley <rob@landley.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-11-03SCSI: add asynchronous event notification APIJeff Garzik
Originally based on a patch by Kristen Carlson Accardi @ Intel. Copious input from James Bottomley. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-12[SCSI] scsi_scan: Cope with kthread_run failingMatthew Wilcox
If kthread_run failed, we would fail to scan the host, and leak the allocated async_scan_data. Since using a separate thread is just an optimisation, do the scan synchronously if we fail to spawn a thread. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] Fix signness of parameters in scsi moduleMasatake YAMATO
In scsi module I've found some inconsistency between variable type used in module_param_named and type passed to module_param_named as an argument. Especially the inconsistency of `max_scsi_luns' parameter is a bit serious because the description text says "last scsi LUN (should be between 1 and 2^32-1)". Signed-off-by: Masatake YAMATO <jet@gyve.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] Fix async scanning double-add problemsMatthew Wilcox
Stress-testing and some thought has revealed some places where asynchronous scanning needs some more attention to locking. - Since async_scan is a bit, we need to hold the host_lock while modifying it to prevent races against other CPUs modifying the word that bit is in. This is probably a theoretical race for the moment, but other patches may change that. - The async_scan bit means not only that this host is being scanned asynchronously, but that all the devices attached to this host are not yet added to sysfs. So we must ensure that this bit is always in sync. I've chosen to do this with the scan_mutex since it's already acquired in most of the right places. - If the host changes state to deleted while we're in the middle of a scan, we'll end up with some devices on the host's list which must be deleted. Add a check to scsi_sysfs_add_devices() to ensure the host is still running. - To avoid the async_scan bit being protected by three locks, the async_scan_lock now only protects the scanning_list. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-15Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (166 commits) [SCSI] ibmvscsi: convert to use the data buffer accessors [SCSI] dc395x: convert to use the data buffer accessors [SCSI] ncr53c8xx: convert to use the data buffer accessors [SCSI] sym53c8xx: convert to use the data buffer accessors [SCSI] ppa: coding police and printk levels [SCSI] aic7xxx_old: remove redundant GFP_ATOMIC from kmalloc [SCSI] i2o: remove redundant GFP_ATOMIC from kmalloc from device.c [SCSI] remove the dead CYBERSTORMIII_SCSI option [SCSI] don't build scsi_dma_{map,unmap} for !HAS_DMA [SCSI] Clean up scsi_add_lun a bit [SCSI] 53c700: Remove printk, which triggers because of low scsi clock on SNI RMs [SCSI] sni_53c710: Cleanup [SCSI] qla4xxx: Fix underrun/overrun conditions [SCSI] megaraid_mbox: use mutex instead of semaphore [SCSI] aacraid: add 51245, 51645 and 52245 adapters to documentation. [SCSI] qla2xxx: update version to 8.02.00-k1. [SCSI] qla2xxx: add support for NPIV [SCSI] stex: use resid for xfer len information [SCSI] Add Brownie 1200U3P to blacklist [SCSI] scsi.c: convert to use the data buffer accessors ...
2007-07-14[SCSI] Clean up scsi_add_lun a bitMatthew Wilcox
This patch tidies up scsi_add_lun a bit. I rewrote the kerneldoc to match the actual parameters, moved the check for RBC and MMC REPORT_LUN devices away from the switch(), changed the setup of sdev->type to account for BLIST_ISROM, moved the check for BLIST_NO_ULD_ATTACH further down in the function, removed a bogus comment and fixed some whitespace issues. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-19[SCSI] zfcp: Report FCP LUN to SCSI midlayerChristof Schmitt
When reporting SCSI devices to the SCSI midlayer, use the FCP LUN as LUN reported to the SCSI layer. With this approach, zfcp does not have to create unique LUNS, and this code can be removed. Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: Swen Schillig <swen@vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-30[SCSI] fix CONFIG_SCSI_WAIT_SCAN=mHugh Dickins
CONFIG_MODULES=y CONFIG_SCSI=y CONFIG_SCSI_SCAN_ASYNC=y CONFIG_SCSI_WAIT_SCAN=m 2.6.21-rc5-mm2 VFS panics unable to find my root on /dev/sda2, but boots okay if I change drivers/scsi/Kconfig to "default y" instead of "default m" for SCSI_WAIT_SCAN. Make sure there's a late_initcall to scsi_complete_async_scans when it's built in, so a monolithic SCSI_SCAN_ASYNC kernel can rely on the scans being completed before trying to mount root, even if they're slow. [akpm@linux-foundation.org: build fixes] Signed-off-by: Hugh Dickins <hugh@veritas.com> Acked-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-03-21[SCSI] fix scsi_wait_scan build problemJames Bottomley
The #ifdef MODULE around the export of scsi_complete_async_scans() which is the API the scsi_wait_scan module uses is incorrect and causes the symbol to be undefined in certain circumstances leading to a build failure. Remove the defines. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
