path: root/drivers/scsi/scsi_sysfs.c
2008-10-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (37 commits) [SCSI] zfcp: fix double dbf id usage [SCSI] zfcp: wait on SCSI work to be finished before proceeding with init dev [SCSI] zfcp: fix erp list usage without using locks [SCSI] zfcp: prevent fc_remote_port_delete calls for unregistered rport [SCSI] zfcp: fix deadlock caused by shared work queue tasks [SCSI] zfcp: put threshold data in hba trace [SCSI] zfcp: Simplify zfcp data structures [SCSI] zfcp: Simplify get_adapter_by_busid [SCSI] zfcp: remove all typedefs and replace them with standards [SCSI] zfcp: attach and release SAN nameserver port on demand [SCSI] zfcp: remove unused references, declarations and flags [SCSI] zfcp: Update message with input from review [SCSI] zfcp: add queue_full sysfs attribute [SCSI] scsi_dh: suppress comparison warning [SCSI] scsi_dh: add Dell product information into rdac device handler [SCSI] qla2xxx: remove the unused SCSI_QLOGIC_FC_FIRMWARE option [SCSI] qla2xxx: fix printk format warnings [SCSI] qla2xxx: Update version number to 8.02.01-k8. [SCSI] qla2xxx: Ignore payload reserved-bits during RSCN processing. [SCSI] qla2xxx: Additional residual-count corrections during UNDERRUN handling. ...
2008-10-09block: unify request timeout handlingJens Axboe
Right now SCSI and others do their own command timeout handling. Move those bits to the block layer. Instead of having a timer per command, we try to be a bit more clever and simply have one per-queue. This avoids the overhead of having to tear down and setup a timer for each command, so it will result in a lot less timer fiddling. Signed-off-by: Mike Anderson <andmike@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-03[SCSI] Update the SCSI state model to allow blocking in the created stateJames Bottomley
Brian King <brking@linux.vnet.ibm.com> reported that fibre channel devices can oops during scanning if their ports block (because the device goes from CREATED -> BLOCK -> RUNNING rather than CREATED -> BLOCK -> CREATED). Fix this by adding a new state: CREATED_BLOCK which can only transition back to CREATED and disallow the CREATED -> BLOCK transition. Now both the created and blocked states that the mid-layer recognises can include CREATED_BLOCK. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-26[SCSI] Host protection capabilitiesMartin K. Petersen
Controllers that support protection information must indicate this to the SCSI midlayer so that the ULD can prepare scsi_cmnds accordingly. This patch implements a host mask and various types of protection: - DIF Type 1-3 (between HBA and disk) - DIX Type 0-3 (between OS and HBA) The patch also allows the HBA to set the guard type to something different than the T10-mandated CRC. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-06-05[SCSI] scsi_dh: add infrastructure for SCSI Device HandlersChandra Seetharaman
Some of the storage devices (that can be accessed through multiple paths), do need some special handling for 1. Activating the passive path of the storage access. 2. Decode and handle the special sense codes returned by the devices. 3. Handle the I/Os being sent to the passive path, especially during the device probe time. when accessed through multiple paths. As of today this special device handling is done at the dm-multipath layer using dm-handlers. That works well for (1); for (2) to be handled at dm layer, scsi sense information need to be exported from SCSI to dm-layer, which is not very attractive; (3) cannot be done at all at the dm layer. Device handler has been moved to SCSI mainly to handle (2) and (3) properly. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Mike Anderson <andmike@linux.vnet.ibm.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-23[SCSI] fix intermittent oops in scsi_bus_ueventJames Bottomley
Reported-by: Sitsofe Wheeler <sitsofe@yahoo.com> > BUG: unable to handle kernel paging request at e6f17fac > IP: [<c02604d6>] scsi_bus_uevent+0x1/0x17 > *pde = 2714b163 *pte = 26f17160 > Oops: 0000 [#1] DEBUG_PAGEALLOC > last sysfs file: > > Pid: 1, comm: swapper Not tainted (2.6.26-rc2-next-20080516skw #30) > EIP: 0060:[<c02604d6>] EFLAGS: 00010282 CPU: 0 > EIP is at scsi_bus_uevent+0x1/0x17 > EAX: e6f18014 EBX: e6f18014 ECX: c02604d5 EDX: e7173000 > ESI: e7173000 EDI: e7173000 EBP: e7851ca0 ESP: e7851c90 > DS: 007b ES: 007b FS: 0000 GS: 0000 SS: 0068 The problem is caused by: commit b0ed43360fdca227048d88a08290365cb681c1a8 Author: Hannes Reinecke <hare@suse.de> Date: Tue Mar 18 14:32:28 2008 +0100 [SCSI] add scsi_host and scsi_target to scsi_bus which added scsi_bus_type to the struct scsi_target device. This causes both the scsi_device and scsi_target to fire scsi_bus_uevents. However, the actualy scsi_bus_uevent() call assumes blindly that it's a struct scsi_device. Check for this and return immediately if it isn't. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-22[SCSI] bsg: add release callback supportFUJITA Tomonori
This patch adds release callback support, which is called when a bsg device goes away. bsg_register_queue() takes a pointer to a callback function. This feature is useful for stuff like sas_host that can't use the release callback in struct device. If a caller doesn't need bsg's release callback, it can call bsg_register_queue() with NULL pointer (e.g. scsi devices can use release callback in struct device so they don't need bsg's callback). With this patch, bsg uses kref for refcounts on bsg devices instead of get/put_device in fops->open/release. bsg calls put_device and the caller's release callback (if it was registered) in kref_put's release. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-22[SCSI] rework scsi_target allocationJames Bottomley
The current target allocation code registeres each possible target with sysfs; it will be deleted again if no useable LUN on this target was found. This results in a string of 'target add/target remove' uevents. Based on a patch by Hannes Reinecke <hare@suse.de> this patch reworks the target allocation code so that only uevents for existing targets are sent. The sysfs registration is split off from the existing scsi_target_alloc() into a in a new scsi_add_target() function, which should be called whenever an existing target is found. Only then a uevent is sent, so we'll be generating events for existing targets only. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-22[SCSI] use default attributes for scsi_hostHannes Reinecke
This patch removes the unused sysfs attibute overwriting logic for the scsi host attibutes, and plugs them into the driver core default attribute creation. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-22[SCSI] add scsi_host and scsi_target to scsi_busHannes Reinecke
This patch implements scsi_host and scsi_target device types and adds both to the scsi_bus. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-19SCSI: convert struct class_device to struct deviceTony Jones
It's big, but there doesn't seem to be a way to split it up smaller... Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Roland Dreier <rolandd@cisco.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: Hal Rosenstock <hal.rosenstock@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-26Revert "[SCSI] fix bsg queue oops with iscsi logout"James Bottomley
This reverts commit 4b6f5b3a993cbe34b4280f252bccc76967c185c8. bsg takes a reference to the underlying generic device, so it's impossible to unregister bsg in the device release routine. Acked-by: FUJITA Tomonori <tomof@acm.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-03-13[SCSI] fix bsg queue oops with iscsi logoutMike Christie
Delay bsg unregistration, because we want to wait until all the request/cmds have released their reference. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] add missing transport configure points for target and hostJames Bottomley
While trying to convert the SPI transport class to attribute groups, I discovered that we don't actually have any transport configure points for either the target or the host. This patch adds these missing transport class triggers. The host one is simply done after the add, the target one tries to be more clever and add it after devices may have been placed on the target (so the device configure will have set up the target parameters). Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-02[SCSI] scsi_sysfs: restore prep_fn when ULD is removedJames Bottomley
A recent bug report: http://bugzilla.kernel.org/show_bug.cgi?id=9674 Was caused because the ULDs now set their own prep functions, but don't necessarily reset the prep function back to the SCSI default when they are removed. This leads to panics if commands are sent to the device after the module is removed because the prep_fn is still pointing to the old module code. The fix for this is to implement a bus remove method that resets the prep_fn pointer correctly before calling the ULD specific driver remove method. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-11-03SCSI: add asynchronous event notification APIJeff Garzik
Originally based on a patch by Kristen Carlson Accardi @ Intel. Copious input from James Bottomley. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-17[SCSI] make supported_mode default to initiator.James Bottomley
if shost->supported mode is zero (i.e. MODE_UNKNOWN) show it as initiator (it's obviously an unconverted driver that won't do target). Acked-by: FUJITA Tomonori <tomof@acm.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-15Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (207 commits) [SCSI] gdth: fix CONFIG_ISA build failure [SCSI] esp_scsi: remove __dev{init,exit} [SCSI] gdth: !use_sg cleanup and use of scsi accessors [SCSI] gdth: Move members from SCp to gdth_cmndinfo, stage 2 [SCSI] gdth: Setup proper per-command private data [SCSI] gdth: Remove gdth_ctr_tab[] [SCSI] gdth: switch to modern scsi host registration [SCSI] gdth: gdth_interrupt() gdth_get_status() & gdth_wait() fixes [SCSI] gdth: clean up host private data [SCSI] gdth: Remove virt hosts [SCSI] gdth: Reorder scsi_host_template intitializers [SCSI] gdth: kill gdth_{read,write}[bwl] wrappers [SCSI] gdth: Remove 2.4.x support, in-kernel changelog [SCSI] gdth: split out pci probing [SCSI] gdth: split out eisa probing [SCSI] gdth: split out isa probing gdth: Make one abuse of scsi_cmnd less obvious [SCSI] NCR5380: Use scsi_eh API for REQUEST_SENSE invocation [SCSI] usb storage: use scsi_eh API in REQUEST_SENSE execution [SCSI] scsi_error: Refactoring scsi_error to facilitate in synchronous REQUEST_SENSE ...
2007-10-12Driver core: change add_uevent_var to use a structKay Sievers
This changes the uevent buffer functions to use a struct instead of a long list of parameters. It does no longer require the caller to do the proper buffer termination and size accounting, which is currently wrong in some places. It fixes a known bug where parts of the uevent environment are overwritten because of wrong index calculations. Many thanks to Mathieu Desnoyers for finding bugs and improving the error handling. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12[SCSI] fix scsi_is_sdev_device() after switch to default sdev attributesKay Sievers
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] switch sdev sysfs attributes to default attributesKay Sievers
This removes the unused sysfs attribute overwriting logic for most of the attributes, and plugs them into the driver core default attribute creation. Without this patch, at the time of the events for the SCSI LUN's, there will be no sysfs files, because their creation is delayed until the sd driver has spun up the disks, which might take several seconds. It is the last WAIT_FOR_SYSFS rule in the default udev setup which can be removed with this change. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] add supported_mode and active_mode attributes to the hostFUJITA Tomonori
This adds supported_mode and active_mode attributes to /sys/class/sys_host/hostX/ for specifying the mode that a lld supports and the currently activated mode. The output format is similar to fc rport roles: luce:/sys/class/scsi_host/host0$ cat supported_mode Initiator luce:/sys/class/scsi_host/host0$ cat active_mode Initiator The mode values uses bitmap since we would support dual-mode llds in the future like this: luce:/sys/class/scsi_host/host0$ cat supported_mode Initiator, Target The supported_mode attribute looks at a scsi_host_template and the active_mode attribute looks at a scsi_host. We would add a hook to a scsi_host_template to change the active_mode attribute dynamically. But now there is no hook since no lld supports that feature. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-21[SCSI] bsg: make class backlinksJames Bottomley
Currently, bsg doesn't make class backlinks (a process whereby you'd get a link to bsg in the device directory in the same way you get one for sg). This is because the bsg device is uninitialised, so the class device has nothing it can attach to. The fix is to make the bsg device point to the cdevice of the entity creating the bsg, necessitating changing the bsg_register_queue() prototype into a form that takes the generic device. Acked-by: FUJITA Tomonori <tomof@acm.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-19[SCSI] bsg: separate bsg and SCSI (so SCSI can be modular)James Bottomley
This patch moves the bsg registration into SCSI so that bsg no longer has a dependency on the scsi_interface_register API. This can be viewed as a temporary expedient until we can get universal bsg binding sorted out properly. Also use the sdev bus_id as the generic bsg name (to avoid clashes with the queue name). Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-18[SCSI] small cleanupsAdrian Bunk
This patch contains the following cleanups: - make needlessly global functions static - every file should #include the headers containing the prototypes for it's global functions Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-22[SCSI] kill scsi host template suspend/resumeTejun Heo
With libata converted to use sdev->manage_start_stop for suspend and resume, sht->suspend/resume() has no user left and low level suspend/ressume should be taken care of by low level driver's suspend/resume callbacks (e.g. PCI or PCMCIA driver callbacks). This patch removes sht->suspend/resume() callbacks. This change is suggested by Christoph Hellwig. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-05-05Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (87 commits) [SCSI] fusion: fix domain validation loops [SCSI] qla2xxx: fix regression on sparc64 [SCSI] modalias for scsi devices [SCSI] sg: cap reserved_size values at max_sectors [SCSI] BusLogic: stop using check_region [SCSI] tgt: fix rdma transfer bugs [SCSI] aacraid: fix aacraid not finding device [SCSI] aacraid: Correct SMC products in aacraid.txt [SCSI] scsi_error.c: Add EH Start Unit retry [SCSI] aacraid: [Fastboot] Panics for AACRAID driver during 'insmod' for kexec test. [SCSI] ipr: Driver version to 2.3.2 [SCSI] ipr: Faster sg list fetch [SCSI] ipr: Return better qc_issue errors [SCSI] ipr: Disrupt device error [SCSI] ipr: Improve async error logging level control [SCSI] ipr: PCI unblock config access fix [SCSI] ipr: Fix for oops following SATA request sense [SCSI] ipr: Log error for SAS dual path switch [SCSI] ipr: Enable logging of debug error data for all devices [SCSI] ipr: Add new PCI-E IDs to device table ...
2007-04-17[SCSI] modalias for scsi devicesMichael Tokarev
The following patch adds support for sysfs/uevent modalias attribute for scsi devices (like disks, tapes, cdroms etc), based on whatever current sd.c, sr.c, st.c and osst.c drivers supports. The modalias format is like this: scsi:type-0x04 (for TYPE_WORM, handled by sr.c now). Several comments. o This hexadecimal type value is because all TYPE_XXX constants in include/scsi/scsi.h are given in hex, but __stringify() will not convert them to decimal (so it will NOT be scsi:type-4). Since it does not really matter in which format it is, while both modalias in module and modalias attribute match each other, I descided to go for that 0x%02x format (and added a comment in include/scsi/scsi.h to keep them that way), instead of changing them all to decimal. o There was no .uevent routine for SCSI bus. It might be a good idea to add some more ueven environment variables in there. o osst.c driver handles tapes too, like st.c, but only SOME tapes. With this setup, hotplug scripts (or whatever is used by the user) will try to load both st and osst modules for all SCSI tapes found, because both modules have scsi:type-0x01 alias). It is not harmful, but one extra module is no good either. It is possible to solve this, by exporting more info in modalias attribute, including vendor and device identification strings, so that modalias becomes something like scsi:type-0x12:vendor-Adaptec LTD:device-OnStream Tape Drive and having that, match for all 3 attributes, not only device type. But oh well, vendor and device strings may be large, and they do contain spaces and whatnot. So I left them for now, awaiting for comments first. Signed-off-by: Michael Tokarev <mjt@tls.msk.ru> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-03-20[SCSI] sd: implement START/STOP managementTejun Heo
Implement SBC START/STOP management. sdev->mange_start_stop is added. When it's set to one, sd STOPs the device on suspend and shutdown and STARTs it on resume. sdev->manage_start_stop defaults is in sdev instead of scsi_disk cdev to allow ->slave_config() override the default configuration but is exported under scsi_disk sysfs node as sdev->allow_restart is. When manage_start_stop is zero (the default value), this patch doesn't introduce any behavior change. Signed-off-by: Tejun Heo <htejun@gmail.com> Rejections fixed and Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-03-15[PATCH] sysfs and driver core: add callback helper, used by SCSI and S390Alan Stern
This patch (as868) adds a helper routine for device drivers that need to set up a callback to perform some action in a different process's context. This is intended for use by attribute methods that want to unregister themselves or their parent device. Attribute method calls are mutually exclusive with unregistration, so such actions cannot be taken directly. Two attribute methods are converted to use the new helper routine: one for SCSI device deletion and one for System/390 ccwgroup devices. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: Hugh Dickins <hugh@veritas.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Oliver Neukum <oneukum@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[SCSI] SCSI core: better initialization for sdev->scsi_levelAlan Stern
This patch will affect the CDB in INQUIRY commands sent to LUNs above 0 when LUN-0 reports a scsi_level of 0; the LUN bits will no longer be set in the second byte of the CDB. This is as it should be. Nevertheless, it's possible that some wacky device might be adversely affected. I doubt anyone will complain... Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-11-22WorkStruct: Pass the work_struct pointer instead of context dataDavid Howells
Pass the work_struct pointer to the work function rather than context data. The work function can use container_of() to work out the data. For the cases where the container of the work_struct may go away the moment the pending bit is cleared, it is made possible to defer the release of the structure by deferring the clearing of the pending bit. To make this work, an extra flag is introduced into the management side of the work_struct. This governs auto-release of the structure upon execution. Ordinarily, the work queue executor would release the work_struct for further scheduling or deallocation by clearing the pending bit prior to jumping to the work function. This means that, unless the driver makes some guarantee itself that the work_struct won't go away, the work function may not access anything else in the work_struct or its container lest they be deallocated.. This is a problem if the auxiliary data is taken away (as done by the last patch). However, if the pending bit is *not* cleared before jumping to the work function, then the work function *may* access the work_struct and its container with no problems. But then the work function must itself release the work_struct by calling work_release(). In most cases, automatic release is fine, so this is the default. Special initiators exist for the non-auto-release case (ending in _NAR). Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-25[SCSI] add can_queue to host parametersJames Bottomley
Debugging TCQ issues has shown me this is a very useful parameter to be able to view. Add it to he host class parameters. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-10[SCSI] drivers/scsi: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove duplicates of the macro. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-24[PATCH] Make libata not powerdown drivers on PM_EVENT_FREEZE.Nigel Cunningham
At the moment libata doesn't pass pm_message_t down ata_device_suspend. This causes drives to be powered down when we just want a freeze, causing unnecessary wear and tear. This patch gets pm_message_t passed down so that it can be used to determine whether to power down the drive. Signed-off-by: Nigel Cunningham <nigel@suspend2.net> drivers/scsi/libata-core.c | 5 +++-- drivers/scsi/libata-scsi.c | 4 ++-- drivers/scsi/scsi_sysfs.c | 2 +- include/linux/libata.h | 4 ++-- include/scsi/scsi_host.h | 2 +- 5 files changed, 9 insertions(+), 8 deletions(-) Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-02-27[SCSI] fix scsi process problems and clean up the target reap issuesJames Bottomley
In order to use the new execute_in_process_context() API, you have to provide it with the work storage, which I do in SCSI in scsi_device and scsi_target, but which also means that we can no longer queue up the target reaps, so instead I moved the target to a state model which allows target_alloc to detect if we've received a dying target and wait for it to be gone. Hopefully, this should also solve the target namespace race. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-14[SCSI] fix wrong context bugs in SCSIJames Bottomley
There's a bug in releasing scsi_device where the release function actually frees the block queue. However, the block queue release calls flush_work(), which requires process context (the scsi_device structure may release from irq context). Update the release function to invoke via the execute_in_process_context() API. Also clean up the scsi_target structure releasing via this API. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-14[SCSI] remove target parent limitiationChristoph Hellwig
When James Smart fixed the issue of the userspace scan atributes crashing the system with the FC transport class he added a patch to let the transport class check if the parent is valid for a given transport class. When adding support for the integrated raid of fusion sas devices we ran into a problem with that, as it didn't allow adding virtual raid volumes without the transport class knowing about it. So this patch adds a user_scan attribute instead, that takes over from scsi_scan_host_selected if the transport class sets it and thus lets the transport class control the user-initiated scanning. As this plugs the hole about user-initiated scanning the target_parent hook goes away and we rely on callers of the scanning routines to do something sensible. For SAS this meant I had to switch from a spinlock to a mutex to synchronize the topology linked lists, in FC they were completely unsynchronized which seems wrong. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-12[SCSI] turn most scsi semaphores into mutexesArjan van de Ven
the scsi layer is using semaphores in a mutex way, this patch converts these into using mutexes instead Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-06[PATCH] Suspend support for libataJens Axboe
This patch adds suspend patch to libata, and ata_piix in particular. For most low level drivers, they should just need to add the 4 hooks to work. As I can only test ata_piix, I didn't enable it for more though. Suspend support is the single most important feature on a notebook, and most new notebooks have sata drives. It's quite embarrassing that we _still_ do not support this. Right now, it's perfectly possible to suspend the drive in mid-transfer. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-13[SCSI] Mark some core scsi data structures constArjan van de Ven
patch below marks a few scsi core datastructures as const, so that they end up in the .rodata section and don't cacheline share with things that get dirtied Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-06[SCSI] Fix transport class oopsJames Bottomley
There's an oops that sometimes shows up with SCSI transport classes in sysfs_hash_and_remove. The problem is that now, because of the class to device and vice versa symlinks, all classes have to be removed from visibility *before* the device is removed from visibility. The transport class trigger points violate this, so bring them back into conformance. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-09-19[SCSI] fix oops on usb storage device disconnectJames Bottomley
We fix the oops by enforcing the host state model. There have also been two extra states added: SHOST_CANCEL_RECOVERY and SHOST_DEL_RECOVERY so we can take the model through host removal while the recovery thread is active. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-09-18[SCSI] SCSI scanning and removal fixesAlan Stern
This patch (as545) fixes the list traversals in __scsi_remove_target and scsi_forget_host. In each case the existing code list_for_each_entry_safe in an _unsafe_ manner, because the list was not protected from outside modification while the iteration was running. The new scsi_forget_host routine takes the moderately controversial step of iterating over devices for removal rather than iterating over targets. This makes more sense to me because the current scheme treats targets as second-class citizens, created and removed on demand, rather than as objects corresponding to actual hardware. (Also I couldn't figure out any safe way to iterate over the target list, since it's not so easy to tell when a target has already been removed.) Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-09-15[SCSI] fix use after potential free in scsi_remove_deviceAlan Stern
2005-09-09[SCSI] fix callers of scsi_remove_device() who already hold the scan mutedAlan Stern
This patch (as544) adds a private entry point to scsi_remove_device, for use when callers already own the scan_mutex. The appropriate callers are modified to use the new entry point. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-07-30[SCSI] host state model update: replace old host bitmap stateMike Anderson
Migrate the current SCSI host state model to a model like SCSI device is using. Signed-off-by: Mike Anderson <andmike@us.ibm.com> Rejections fixed up and Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-06-24[PATCH] make various thing staticAdrian Bunk
Another rollup of patches which give various symbols static scope Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] Driver Core: drivers/s390/net/qeth_sys.c - ↵Yani Ioannou
drivers/usb/gadget/pxa2xx_udc.c: update device attribute callbacks Signed-off-by: Yani Ioannou <yani.ioannou@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
