path: root/drivers/scsi/scsi_sysfs.c
2013-01-17SCSI: prevent stack buffer overflow in host_resetSasha Levin
commit 072f19b4bea31cdd482d79f805413f2f9ac9e233 upstream. store_host_reset() has tried to re-invent the wheel to compare sysfs strings. Unfortunately it did so poorly and never bothered to check the input from userspace before overwriting stack with it, so something simple as: echo "WoopsieWoopsie" > /sys/devices/pseudo_0/adapter0/host0/scsi_host/host0/host_reset would result in: [ 316.310101] Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: ffffffff81f5bac7 [ 316.310101] [ 316.320051] Pid: 6655, comm: sh Tainted: G W 3.7.0-rc5-next-20121114-sasha-00016-g5c9d68d-dirty #129 [ 316.320051] Call Trace: [ 316.340058] pps pps0: PPS event at 1352918752.620355751 [ 316.340062] pps pps0: capture assert seq #303 [ 316.320051] [<ffffffff83b3856b>] panic+0xcd/0x1f4 [ 316.320051] [<ffffffff81f5bac7>] ? store_host_reset+0xd7/0x100 [ 316.320051] [<ffffffff8110b996>] __stack_chk_fail+0x16/0x20 [ 316.320051] [<ffffffff81f5bac7>] store_host_reset+0xd7/0x100 [ 316.320051] [<ffffffff81e55bb3>] dev_attr_store+0x13/0x30 [ 316.320051] [<ffffffff812f7db1>] sysfs_write_file+0x101/0x170 [ 316.320051] [<ffffffff8127acc8>] vfs_write+0xb8/0x180 [ 316.320051] [<ffffffff8127ae80>] sys_write+0x50/0xa0 [ 316.320051] [<ffffffff83c03418>] tracesys+0xe1/0xe6 Fix this by uninventing whatever was going on there and just use sysfs_streq. Bug introduced by 29443691 ("[SCSI] scsi: Added support for adapter and firmware reset"). [jejb: added necessary const to prevent compile warnings] Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-07SCSI: scsi_remove_target: fix softlockup regression on hot removeDan Williams
commit bc3f02a795d3b4faa99d37390174be2a75d091bd upstream. John reports: BUG: soft lockup - CPU#2 stuck for 23s! [kworker/u:8:2202] [..] Call Trace: [<ffffffff8141782a>] scsi_remove_target+0xda/0x1f0 [<ffffffff81421de5>] sas_rphy_remove+0x55/0x60 [<ffffffff81421e01>] sas_rphy_delete+0x11/0x20 [<ffffffff81421e35>] sas_port_delete+0x25/0x160 [<ffffffff814549a3>] mptsas_del_end_device+0x183/0x270 ...introduced by commit 3b661a9 "[SCSI] fix hot unplug vs async scan race". Don't restart lookup of more stargets in the multi-target case, just arrange to traverse the list once, on the assumption that new targets are always added at the end. There is no guarantee that the target will change state in scsi_target_reap() so we can end up spinning if we restart. Acked-by: Jack Wang <jack_wang@usish.com> LKML-Reference: <CAEhu1-6wq1YsNiscGMwP4ud0Q+MrViRzv=kcWCQSBNc8c68N5Q@mail.gmail.com> Reported-by: John Drescher <drescherjm@gmail.com> Tested-by: John Drescher <drescherjm@gmail.com> Signed-off-by: Dan Williams <djbw@fb.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09SCSI: Fix device removal NULL pointer dereferenceBart Van Assche
commit 67bd94130015c507011af37858989b199c52e1de upstream. Use blk_queue_dead() to test whether the queue is dead instead of !sdev. Since scsi_prep_fn() may be invoked concurrently with __scsi_remove_device(), keep the queuedata (sdev) pointer in __scsi_remove_device(). This patch fixes a kernel oops that can be triggered by USB device removal. See also http://www.spinics.net/lists/linux-scsi/msg56254.html. Other changes included in this patch: - Swap the blk_cleanup_queue() and kfree() calls in scsi_host_dev_release() to make that code easier to grasp. - Remove the queue dead check from scsi_run_queue() since the queue state can change anyway at any point in that function where the queue lock is not held. - Remove the queue dead check from the start of scsi_request_fn() since it is redundant with the scsi_device_online() check. Reported-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Bart Van Assche <bvanassche@acm.org> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Reviewed-by: Tejun Heo <tj@kernel.org> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-09SCSI: fix hot unplug vs async scan raceDan Williams
commit 3b661a92e869ebe2358de8f4b3230ad84f7fce51 upstream. The following crash results from cases where the end_device has been removed before scsi_sysfs_add_sdev has had a chance to run. BUG: unable to handle kernel NULL pointer dereference at 0000000000000098 IP: [<ffffffff8115e100>] sysfs_create_dir+0x32/0xb6 ... Call Trace: [<ffffffff8125e4a8>] kobject_add_internal+0x120/0x1e3 [<ffffffff81075149>] ? trace_hardirqs_on+0xd/0xf [<ffffffff8125e641>] kobject_add_varg+0x41/0x50 [<ffffffff8125e70b>] kobject_add+0x64/0x66 [<ffffffff8131122b>] device_add+0x12d/0x63a [<ffffffff814b65ea>] ? _raw_spin_unlock_irqrestore+0x47/0x56 [<ffffffff8107de15>] ? module_refcount+0x89/0xa0 [<ffffffff8132f348>] scsi_sysfs_add_sdev+0x4e/0x28a [<ffffffff8132dcbb>] do_scan_async+0x9c/0x145 ...teach scsi_sysfs_add_devices() to check for deleted devices() before trying to add them, and teach scsi_remove_target() how to remove targets that have not been added via device_add(). Reported-by: Dariusz Majchrzak <dariusz.majchrzak@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-08-27[SCSI] scsi: Added support for adapter and firmware resetVikas Chaudhary
Added new sysfs attr 'host_reset' in scsi_sysfs.c to perform adapter or firmware reset as suggested by Mike Christie here: http://marc.info/?l=linux-scsi&m=127359347111167&w=2 user/application can write "adapter" or "firmware" on this attr and it will call newly added function hook in scsi_host_template to call LDD adapter or firmware reset implementation. Signed-off-by: Vikas Chaudhary <vikas.chaudhary@qlogic.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-06-02[SCSI] Fix oops caused by queue refcounting failureJames Bottomley
In certain circumstances, we can get an oops from a torn down device. Most notably this is from CD roms trying to call scsi_ioctl. The root cause of the problem is the fact that after scsi_remove_device() has been called, the queue is fully torn down. This is actually wrong since the queue can be used until the sdev release function is called. Therefore, we add an extra reference to the queue which is released in sdev->release, so the queue always exists. Reported-by: Parag Warudkar <parag.lkml@gmail.com> Cc: stable@kernel.org Signed-off-by: James Bottomley <jbottomley@parallels.com>
2011-04-24[SCSI] put stricter guards on queue dead checksJames Bottomley
SCSI uses request_queue->queuedata == NULL as a signal that the queue is dying. We set this state in the sdev release function. However, this allows a small window where we release the last reference but haven't quite got to this stage yet and so something will try to take a reference in scsi_request_fn and oops. It's very rare, but we had a report here, so we're pushing this as a bug fix The actual fix is to set request_queue->queuedata to NULL in scsi_remove_device() before we drop the reference. This causes correct automatic rejects from scsi_request_fn as people who hold additional references try to submit work and prevents anything from getting a new reference to the sdev that way. Cc: stable@kernel.org Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-03-15PM: Remove CONFIG_PM_OPSRafael J. Wysocki
After redefining CONFIG_PM to depend on (CONFIG_PM_SLEEP || CONFIG_PM_RUNTIME) the CONFIG_PM_OPS option is redundant and can be replaced with CONFIG_PM. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2011-01-03[SCSI] eliminate an unnecessary local variable from scsi_remove_target()Alan Stern
Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-12-22Merge branch 'master' into for-nextJiri Kosina
Conflicts: MAINTAINERS arch/arm/mach-omap2/pm24xx.c drivers/scsi/bfa/bfa_fcpim.c Needed to update to apply fixes for which the old branch was too outdated.
2010-11-26SCSI: improve two error messagesAlan Stern
This trivial patch (as1338) makes two uninformative error messages in scsi_sysfs_add_sdev() more explicit. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-25[SCSI] Fix race when removing SCSI devicesChristof Schmitt
Removing SCSI devices through echo 1 > /sys/bus/scsi/devices/ ... /delete while the FC transport class removes the SCSI target can lead to an oops: Unable to handle kernel pointer dereference at virtual kernel address 00000000b6815000 Oops: 0011 [#1] PREEMPT SMP DEBUG_PAGEALLOC Modules linked in: sunrpc qeth_l3 binfmt_misc dm_multipath scsi_dh dm_mod ipv6 qeth ccwgroup [last unloaded: scsi_wait_scan] CPU: 1 Not tainted 2.6.35.5-45.x.20100924-s390xdefault #1 Process fc_wq_0 (pid: 861, task: 00000000b7331240, ksp: 00000000b735bac0) Krnl PSW : 0704200180000000 00000000003ff6e4 (__scsi_remove_device+0x24/0xd0) R:0 T:1 IO:1 EX:1 Key:0 M:1 W:0 P:0 AS:0 CC:2 PM:0 EA:3 Krnl GPRS: 0000000000000001 0000000000000000 00000000b6815000 00000000bc24a8c0 00000000003ff7c8 000000000056dbb8 0000000000000002 0000000000835d80 ffffffff00000000 0000000000001000 00000000b6815000 00000000bc24a7f0 00000000b68151a0 00000000b6815000 00000000b735bc20 00000000b735bbf8 Krnl Code: 00000000003ff6d6: a7840001 brc 8,3ff6d8 00000000003ff6da: a7fbffd8 aghi %r15,-40 00000000003ff6de: e3e0f0980024 stg %r14,152(%r15) >00000000003ff6e4: e31021200004 lg %r1,288(%r2) 00000000003ff6ea: a71f0000 cghi %r1,0 00000000003ff6ee: a7a40011 brc 10,3ff710 00000000003ff6f2: a7390003 lghi %r3,3 00000000003ff6f6: c0e5ffffc8b1 brasl %r14,3f8858 Call Trace: ([<0000000000001000>] 0x1000) [<00000000003ff7d2>] scsi_remove_device+0x42/0x54 [<00000000003ff8ba>] __scsi_remove_target+0xca/0xfc [<00000000003ff99a>] __remove_child+0x3a/0x48 [<00000000003e3246>] device_for_each_child+0x72/0xbc [<00000000003ff93a>] scsi_remove_target+0x4e/0x74 [<0000000000406586>] fc_rport_final_delete+0xb2/0x23c [<000000000015d080>] worker_thread+0x200/0x344 [<000000000016330c>] kthread+0xa0/0xa8 [<0000000000106c1a>] kernel_thread_starter+0x6/0xc [<0000000000106c14>] kernel_thread_starter+0x0/0xc INFO: lockdep is turned off. Last Breaking-Event-Address: [<00000000003ff7cc>] scsi_remove_device+0x3c/0x54 The function __scsi_remove_target iterates through the SCSI devices on the host, but it drops the host_lock before calling scsi_remove_device. When the SCSI device is deleted from another thread, the pointer to the SCSI device in scsi_remove_device can become invalid. Fix this by getting a reference to the SCSI device before dropping the host_lock to keep the SCSI device alive for the call to scsi_remove_device. Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-09-10block/scsi: Provide a limit on the number of integrity segmentsMartin K. Petersen
Some controllers have a hardware limit on the number of protection information scatter-gather list segments they can handle. Introduce a max_integrity_segments limit in the block layer and provide a new scsi_host_template setting that allows HBA drivers to provide a value suitable for the hardware. Add support for honoring the integrity segment limit when merging both bios and requests. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <axboe@carl.home.kernel.dk>
2010-08-06SCSI: remove fake "address-of" expressionAlan Stern
Fake "address-of" expressions that evaluate to NULL generally confuse readers and can provoke compiler warnings. This patch (as1411) removes one such fake expression, using an "#ifdef" in its place. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-28[SCSI] implement runtime Power ManagementAlan Stern
This patch (as1398b) adds runtime PM support to the SCSI layer. Only the machanism is provided; use of it is up to the various high-level drivers, and the patch doesn't change any of them. Except for sg -- the patch expicitly prevents a device from being runtime-suspended while its sg device file is open. The implementation is simplistic. In general, hosts and targets are automatically suspended when all their children are asleep, but for them the runtime-suspend code doesn't actually do anything. (A host's runtime PM status is propagated up the device tree, though, so a runtime-PM-aware lower-level driver could power down the host adapter hardware at the appropriate times.) There are comments indicating where a transport class might be notified or some other hooks added. LUNs are runtime-suspended by calling the drivers' existing suspend handlers (and likewise for runtime-resume). Somewhat arbitrarily, the implementation delays for 100 ms before suspending an eligible LUN. This is because there typically are occasions during bootup when the same device file is opened and closed several times in quick succession. The way this all works is that the SCSI core increments a device's PM-usage count when it is registered. If a high-level driver does nothing then the device will not be eligible for runtime-suspend because of the elevated usage count. If a high-level driver wants to use runtime PM then it can call scsi_autopm_put_device() in its probe routine to decrement the usage count and scsi_autopm_get_device() in its remove routine to restore the original count. Hosts, targets, and LUNs are not suspended while they are being probed or removed, or while the error handler is running. In fact, a fairly large part of the patch consists of code to make sure that things aren't suspended at such times. [jejb: fix up compile issues in PM config variations] Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-28[SCSI] convert to the new PM frameworkAlan Stern
This patch (as1397b) converts the SCSI midlayer to use the new PM callbacks (struct dev_pm_ops). A new source file, scsi_pm.c, is created to hold the new callback routines, and the existing suspend/resume code is moved there. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-05-01[SCSI] fix sdev_rw_attr macro for scsi device sysfs entriesTomohiro Kusumi
This patch fixes sdev_rw_attr() macro for scsi device sysfs entries. It seems there is no such function snscanf in the current linux kernel, so it fails to compile scsi driver when someone try to add a new rw entry. This has been unfixed for a long time probably because current scsi device has no rw entries. # grep snscanf . -rn ./drivers/scsi/scsi_sysfs.c:489: snscanf (buf, 20, format_string, &sdev->field); \ Signed-off-by: Tomohiro Kusumi <kusumi.tomohiro@jp.fujitsu.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-04-11[SCSI] don't reap targets upon device_add failureAlan Stern
This patch (as1358) fixes a bug in the error pathway of scsi_target_add(). If registration fails, the target should not be reaped. The reaping occurs later, when scanning is finished and all the child devices are removed. The current code leaves an unbalanced value in starget->reap_ref. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: PM / Hibernate: Fix preallocating of memory PM / Hibernate: Remove swsusp.c finally PM / Hibernate: Remove trailing space in message PM: Allow SCSI devices to suspend/resume asynchronously PM: Allow USB devices to suspend/resume asynchronously USB: implement non-tree resume ordering constraints for PCI host controllers PM: Allow PCI devices to suspend/resume asynchronously PM / Hibernate: Swap, remove useless check from swsusp_read() PM / Hibernate: Really deprecate deprecated user ioctls PM: Allow device drivers to use dpm_wait() PM: Start asynchronous resume threads upfront PM: Add facility for advanced testing of async suspend/resume PM: Add a switch for disabling/enabling asynchronous suspend/resume PM: Asynchronous suspend and resume of devices PM: Add parent information to timing messages PM: Document device power attributes in sysfs PM / Runtime: Add sysfs switch for disabling device run-time PM
2010-02-26PM: Allow SCSI devices to suspend/resume asynchronouslyRafael J. Wysocki
Set power.async_suspend for all SCSI devices, targets and hosts, so that they can be suspended and resumed in parallel with the main suspend/resume thread and possibly with other devices they don't depend on in a known way (i.e. devices which are not their parents or children). The power.async_suspend flag is also set for devices that don't have suspend or resume callbacks, because otherwise they would make the main suspend/resume thread wait for their "asynchronous" children (during suspend) or parents (during resume), effectively negating the possible gains from executing these devices' suspend and resume callbacks asynchronously. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-02-18[SCSI] fix duplicate removal on error path in scsi_sysfs_add_sdevAlan Stern
This patch (as1335) fixes a bug in scsi_sysfs_add_sdev(). Its callers always remove the device if anything goes wrong, so it should never remove the device. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (222 commits) [SCSI] zfcp: Remove flag ZFCP_STATUS_FSFREQ_TMFUNCNOTSUPP [SCSI] zfcp: Activate fc4s attributes for zfcp in FC transport class [SCSI] zfcp: Block scsi_eh thread for rport state BLOCKED [SCSI] zfcp: Update FSF error reporting [SCSI] zfcp: Improve ELS ADISC handling [SCSI] zfcp: Simplify handling of ct and els requests [SCSI] zfcp: Remove ZFCP_DID_MASK [SCSI] zfcp: Move WKA port to zfcp FC code [SCSI] zfcp: Use common code definitions for FC CT structs [SCSI] zfcp: Use common code definitions for FC ELS structs [SCSI] zfcp: Update FCP protocol related code [SCSI] zfcp: Dont fail SCSI commands when transitioning to blocked fc_rport [SCSI] zfcp: Assign scheduled work to driver queue [SCSI] zfcp: Remove STATUS_COMMON_REMOVE flag as it is not required anymore [SCSI] zfcp: Implement module unloading [SCSI] zfcp: Merge trace code for fsf requests in one function [SCSI] zfcp: Access ports and units with container_of in sysfs code [SCSI] zfcp: Remove suspend callback [SCSI] zfcp: Remove global config_mutex [SCSI] zfcp: Replace local reference counting with common kref ...
2009-12-04[SCSI] add queue_depth ramp up codeVasu Dev
Current FC HBA queue_depth ramp up code depends on last queue full time. The sdev already has last_queue_full_time field to track last queue full time but stored value is truncated by last four bits. So this patch updates last_queue_full_time without truncating last 4 bits to store full value and then updates its only current usages in scsi_track_queue_full to ignore last four bits to keep current usages same while also use this field in added ramp up code. Adds scsi_handle_queue_ramp_up to ramp up queue_depth on successful completion of IO. The scsi_handle_queue_ramp_up will do ramp up on all luns of a target, just same as ramp down done on all luns on a target. The ramp up is skipped in case the change_queue_depth is not supported by LLD or already reached to added max_queue_depth. Updates added max_queue_depth on every new update to default queue_depth value. The ramp up is also skipped if lapsed time since either last queue ramp up or down is less than LLD specified queue_ramp_up_period. Adds queue_ramp_up_period to sysfs but only if change_queue_depth is supported since ramp up and queue_ramp_up_period is needed only in case change_queue_depth is supported first. Initializes queue_ramp_up_period to 120HZ jiffies as initial default value, it is same as used in existing lpfc and qla2xxx. -v2 Combined all ramp code into this single patch. -v3 Moves max_queue_depth initialization after slave_configure is called from after slave_alloc calling done. Also adjusted max_queue_depth check to skip ramp up if current queue_depth is >= max_queue_depth. -v4 Changes sdev->queue_ramp_up_period unit to ms when using sysfs i/f to store or show its value. Signed-off-by: Vasu Dev <vasu.dev@intel.com> Tested-by: Christof Schmitt <christof.schmitt@de.ibm.com> Tested-by: Giridhar Malavali <giridhar.malavali@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-04[SCSI] modify change_queue_depth to take in reason why it is being calledMike Christie
This patch modifies scsi_host_template->change_queue_depth so that it takes an argument indicating why it is being called. This will be used so that if a LLD needs to do some extra processing when handling queue fulls or later ramp ups, it can do so. This is a simple port of the drivers setting a change_queue_depth callback. In the patch I just have these LLDs adjust the queue depth if the user was requesting it. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> [Vasu.Dev: v2 Also converted pmcraid_change_queue_depth and then verified all modules compile using "make allmodconfig" for any new build warnings on X86_64. Updated original description after combing two original patches from Mike to make this patch git bisectable.] Signed-off-by: Vasu Dev <vasu.dev@intel.com> [jejb: fixed up 53c700] Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-11-26[SCSI] fix async scan add/remove race resulting in an oopsJames Bottomley
Async scanning introduced a very wide window where the SCSI device is up and running but has not yet been added to sysfs. We delay the adding until all scans have completed to retain the same ordering as sync scanning. This delay in visibility causes an oops if a device is removed before we make it visible because the SCSI removal routines have an inbuilt assumption that if a device is in SDEV_RUNNING state, it must be visible (which is not necessarily true in the async scanning case). Fix this by introducing an additional is_visible flag which we can use to condition the tear down so we do the right thing for running but not yet made visible. Reported-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-10-13[SCSI] fix memory leak in initializationJames Bottomley
The root cause of the problem is the fact that dev_set_name() now allocates storage instead of using the original array within the kobj. That means that the SCSI assumption that if you haven't made the containing object or any sub objects visible, you can just destroy it (and its component devices) lock stock and barrel becomes false. Fix this by doing the get of sdev_dev at parent time and thus do an extra put of it in scsi_destroy_sdev() (and all other destruction without add paths). Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-09-15driver model: constify attribute groupsDavid Brownell
Let attribute group vectors be declared "const". We'd like to let most attribute metadata live in read-only sections... this is a start. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-21sd, sr: fix Driver 'sd' needs updating messageHannes Reinecke
If a SCSI ULD driver sets blk_queue_prep_rq(), it should clean it up itself on remove(), and not from the bus callbacks. This removes the need to hook into bus->remove(), which should not be used at the same time as driver->remove(). [jejb: fix sdkp initialisation problem due to mismerge] Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-12[SCSI] scsi_sysfs: delete extra kernel-docRandy Dunlap
Warning(linux-2.6.28-git13//drivers/scsi/scsi_sysfs.c:1049): Excess function parameter 'dev' description in 'scsi_sysfs_add_host' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-02[SCSI] struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
[jejb: limit ioctl to returning 20 characters to avoid overrun on long device names and add a few more conversions] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (37 commits) [SCSI] zfcp: fix double dbf id usage [SCSI] zfcp: wait on SCSI work to be finished before proceeding with init dev [SCSI] zfcp: fix erp list usage without using locks [SCSI] zfcp: prevent fc_remote_port_delete calls for unregistered rport [SCSI] zfcp: fix deadlock caused by shared work queue tasks [SCSI] zfcp: put threshold data in hba trace [SCSI] zfcp: Simplify zfcp data structures [SCSI] zfcp: Simplify get_adapter_by_busid [SCSI] zfcp: remove all typedefs and replace them with standards [SCSI] zfcp: attach and release SAN nameserver port on demand [SCSI] zfcp: remove unused references, declarations and flags [SCSI] zfcp: Update message with input from review [SCSI] zfcp: add queue_full sysfs attribute [SCSI] scsi_dh: suppress comparison warning [SCSI] scsi_dh: add Dell product information into rdac device handler [SCSI] qla2xxx: remove the unused SCSI_QLOGIC_FC_FIRMWARE option [SCSI] qla2xxx: fix printk format warnings [SCSI] qla2xxx: Update version number to 8.02.01-k8. [SCSI] qla2xxx: Ignore payload reserved-bits during RSCN processing. [SCSI] qla2xxx: Additional residual-count corrections during UNDERRUN handling. ...
2008-10-09block: unify request timeout handlingJens Axboe
Right now SCSI and others do their own command timeout handling. Move those bits to the block layer. Instead of having a timer per command, we try to be a bit more clever and simply have one per-queue. This avoids the overhead of having to tear down and setup a timer for each command, so it will result in a lot less timer fiddling. Signed-off-by: Mike Anderson <andmike@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-03[SCSI] Update the SCSI state model to allow blocking in the created stateJames Bottomley
Brian King <brking@linux.vnet.ibm.com> reported that fibre channel devices can oops during scanning if their ports block (because the device goes from CREATED -> BLOCK -> RUNNING rather than CREATED -> BLOCK -> CREATED). Fix this by adding a new state: CREATED_BLOCK which can only transition back to CREATED and disallow the CREATED -> BLOCK transition. Now both the created and blocked states that the mid-layer recognises can include CREATED_BLOCK. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-26[SCSI] Host protection capabilitiesMartin K. Petersen
Controllers that support protection information must indicate this to the SCSI midlayer so that the ULD can prepare scsi_cmnds accordingly. This patch implements a host mask and various types of protection: - DIF Type 1-3 (between HBA and disk) - DIX Type 0-3 (between OS and HBA) The patch also allows the HBA to set the guard type to something different than the T10-mandated CRC. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-06-05[SCSI] scsi_dh: add infrastructure for SCSI Device HandlersChandra Seetharaman
Some of the storage devices (that can be accessed through multiple paths), do need some special handling for 1. Activating the passive path of the storage access. 2. Decode and handle the special sense codes returned by the devices. 3. Handle the I/Os being sent to the passive path, especially during the device probe time. when accessed through multiple paths. As of today this special device handling is done at the dm-multipath layer using dm-handlers. That works well for (1); for (2) to be handled at dm layer, scsi sense information need to be exported from SCSI to dm-layer, which is not very attractive; (3) cannot be done at all at the dm layer. Device handler has been moved to SCSI mainly to handle (2) and (3) properly. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Mike Anderson <andmike@linux.vnet.ibm.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-23[SCSI] fix intermittent oops in scsi_bus_ueventJames Bottomley
Reported-by: Sitsofe Wheeler <sitsofe@yahoo.com> > BUG: unable to handle kernel paging request at e6f17fac > IP: [<c02604d6>] scsi_bus_uevent+0x1/0x17 > *pde = 2714b163 *pte = 26f17160 > Oops: 0000 [#1] DEBUG_PAGEALLOC > last sysfs file: > > Pid: 1, comm: swapper Not tainted (2.6.26-rc2-next-20080516skw #30) > EIP: 0060:[<c02604d6>] EFLAGS: 00010282 CPU: 0 > EIP is at scsi_bus_uevent+0x1/0x17 > EAX: e6f18014 EBX: e6f18014 ECX: c02604d5 EDX: e7173000 > ESI: e7173000 EDI: e7173000 EBP: e7851ca0 ESP: e7851c90 > DS: 007b ES: 007b FS: 0000 GS: 0000 SS: 0068 The problem is caused by: commit b0ed43360fdca227048d88a08290365cb681c1a8 Author: Hannes Reinecke <hare@suse.de> Date: Tue Mar 18 14:32:28 2008 +0100 [SCSI] add scsi_host and scsi_target to scsi_bus which added scsi_bus_type to the struct scsi_target device. This causes both the scsi_device and scsi_target to fire scsi_bus_uevents. However, the actualy scsi_bus_uevent() call assumes blindly that it's a struct scsi_device. Check for this and return immediately if it isn't. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-22[SCSI] bsg: add release callback supportFUJITA Tomonori
This patch adds release callback support, which is called when a bsg device goes away. bsg_register_queue() takes a pointer to a callback function. This feature is useful for stuff like sas_host that can't use the release callback in struct device. If a caller doesn't need bsg's release callback, it can call bsg_register_queue() with NULL pointer (e.g. scsi devices can use release callback in struct device so they don't need bsg's callback). With this patch, bsg uses kref for refcounts on bsg devices instead of get/put_device in fops->open/release. bsg calls put_device and the caller's release callback (if it was registered) in kref_put's release. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-22[SCSI] rework scsi_target allocationJames Bottomley
The current target allocation code registeres each possible target with sysfs; it will be deleted again if no useable LUN on this target was found. This results in a string of 'target add/target remove' uevents. Based on a patch by Hannes Reinecke <hare@suse.de> this patch reworks the target allocation code so that only uevents for existing targets are sent. The sysfs registration is split off from the existing scsi_target_alloc() into a in a new scsi_add_target() function, which should be called whenever an existing target is found. Only then a uevent is sent, so we'll be generating events for existing targets only. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-22[SCSI] use default attributes for scsi_hostHannes Reinecke
This patch removes the unused sysfs attibute overwriting logic for the scsi host attibutes, and plugs them into the driver core default attribute creation. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-22[SCSI] add scsi_host and scsi_target to scsi_busHannes Reinecke
This patch implements scsi_host and scsi_target device types and adds both to the scsi_bus. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-19SCSI: convert struct class_device to struct deviceTony Jones
It's big, but there doesn't seem to be a way to split it up smaller... Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Roland Dreier <rolandd@cisco.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: Hal Rosenstock <hal.rosenstock@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-26Revert "[SCSI] fix bsg queue oops with iscsi logout"James Bottomley
This reverts commit 4b6f5b3a993cbe34b4280f252bccc76967c185c8. bsg takes a reference to the underlying generic device, so it's impossible to unregister bsg in the device release routine. Acked-by: FUJITA Tomonori <tomof@acm.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-03-13[SCSI] fix bsg queue oops with iscsi logoutMike Christie
Delay bsg unregistration, because we want to wait until all the request/cmds have released their reference. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] add missing transport configure points for target and hostJames Bottomley
While trying to convert the SPI transport class to attribute groups, I discovered that we don't actually have any transport configure points for either the target or the host. This patch adds these missing transport class triggers. The host one is simply done after the add, the target one tries to be more clever and add it after devices may have been placed on the target (so the device configure will have set up the target parameters). Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-02[SCSI] scsi_sysfs: restore prep_fn when ULD is removedJames Bottomley
A recent bug report: http://bugzilla.kernel.org/show_bug.cgi?id=9674 Was caused because the ULDs now set their own prep functions, but don't necessarily reset the prep function back to the SCSI default when they are removed. This leads to panics if commands are sent to the device after the module is removed because the prep_fn is still pointing to the old module code. The fix for this is to implement a bus remove method that resets the prep_fn pointer correctly before calling the ULD specific driver remove method. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-11-03SCSI: add asynchronous event notification APIJeff Garzik
Originally based on a patch by Kristen Carlson Accardi @ Intel. Copious input from James Bottomley. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-17[SCSI] make supported_mode default to initiator.James Bottomley
if shost->supported mode is zero (i.e. MODE_UNKNOWN) show it as initiator (it's obviously an unconverted driver that won't do target). Acked-by: FUJITA Tomonori <tomof@acm.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-15Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (207 commits) [SCSI] gdth: fix CONFIG_ISA build failure [SCSI] esp_scsi: remove __dev{init,exit} [SCSI] gdth: !use_sg cleanup and use of scsi accessors [SCSI] gdth: Move members from SCp to gdth_cmndinfo, stage 2 [SCSI] gdth: Setup proper per-command private data [SCSI] gdth: Remove gdth_ctr_tab[] [SCSI] gdth: switch to modern scsi host registration [SCSI] gdth: gdth_interrupt() gdth_get_status() & gdth_wait() fixes [SCSI] gdth: clean up host private data [SCSI] gdth: Remove virt hosts [SCSI] gdth: Reorder scsi_host_template intitializers [SCSI] gdth: kill gdth_{read,write}[bwl] wrappers [SCSI] gdth: Remove 2.4.x support, in-kernel changelog [SCSI] gdth: split out pci probing [SCSI] gdth: split out eisa probing [SCSI] gdth: split out isa probing gdth: Make one abuse of scsi_cmnd less obvious [SCSI] NCR5380: Use scsi_eh API for REQUEST_SENSE invocation [SCSI] usb storage: use scsi_eh API in REQUEST_SENSE execution [SCSI] scsi_error: Refactoring scsi_error to facilitate in synchronous REQUEST_SENSE ...
