path: root/drivers/scsi/scsi_tgt_lib.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-05-11block: cleanup rq->data_len usagesTejun Heo
With recent unification of fields, it's now guaranteed that rq->data_len always equals blk_rq_bytes(). Convert all non-IDE direct users to accessors. IDE will be converted in a separate patch. Boaz: spotted incorrect data_len/resid_len conversion in osd. [ Impact: convert direct rq->data_len usages to blk_rq_bytes() ] Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: Darrick J. Wong <djwong@us.ibm.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: Boaz Harrosh <bharrosh@panasas.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (37 commits) [SCSI] zfcp: fix double dbf id usage [SCSI] zfcp: wait on SCSI work to be finished before proceeding with init dev [SCSI] zfcp: fix erp list usage without using locks [SCSI] zfcp: prevent fc_remote_port_delete calls for unregistered rport [SCSI] zfcp: fix deadlock caused by shared work queue tasks [SCSI] zfcp: put threshold data in hba trace [SCSI] zfcp: Simplify zfcp data structures [SCSI] zfcp: Simplify get_adapter_by_busid [SCSI] zfcp: remove all typedefs and replace them with standards [SCSI] zfcp: attach and release SAN nameserver port on demand [SCSI] zfcp: remove unused references, declarations and flags [SCSI] zfcp: Update message with input from review [SCSI] zfcp: add queue_full sysfs attribute [SCSI] scsi_dh: suppress comparison warning [SCSI] scsi_dh: add Dell product information into rdac device handler [SCSI] qla2xxx: remove the unused SCSI_QLOGIC_FC_FIRMWARE option [SCSI] qla2xxx: fix printk format warnings [SCSI] qla2xxx: Update version number to 8.02.01-k8. [SCSI] qla2xxx: Ignore payload reserved-bits during RSCN processing. [SCSI] qla2xxx: Additional residual-count corrections during UNDERRUN handling. ...
2008-10-09block: introduce struct rq_map_data to use reserved pagesFUJITA Tomonori
This patch introduces struct rq_map_data to enable bio_copy_use_iov() use reserved pages. Currently, bio_copy_user_iov allocates bounce pages but drivers/scsi/sg.c wants to allocate pages by itself and use them. struct rq_map_data can be used to pass allocated pages to bio_copy_user_iov. The current users of bio_copy_user_iov simply passes NULL (they don't want to use pre-allocated pages). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Douglas Gilbert <dougg@torque.net> Cc: Mike Christie <michaelc@cs.wisc.edu> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: add gfp_mask argument to blk_rq_map_user and blk_rq_map_user_iovFUJITA Tomonori
Currently, blk_rq_map_user and blk_rq_map_user_iov always do GFP_KERNEL allocation. This adds gfp_mask argument to blk_rq_map_user and blk_rq_map_user_iov so sg can use it (sg always does GFP_ATOMIC allocation). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Douglas Gilbert <dougg@torque.net> Cc: Mike Christie <michaelc@cs.wisc.edu> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-03[SCSI] scsi_host_lookup: error returns and NULL pointersJames Smart
This patch cleans up the behavior of scsi_host_lookup(). The original implementation attempted to use the dual role of either returning a pointer value, or a negative error code. User's needed to use IS_ERR() to check the result. Additionally, the IS_ERR() macro never checks for when a NULL pointer was returned, so a NULL pointer actually passes with a success case. Note: scsi_host_get(), used by scsi_host_lookup(), can return a NULL pointer. Talk about a mudhole for the unitiated to step into.... This patch converts scsi_host_lookup() to return either NULL or a valid pointer. The consumers were updated for the change. Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-02[SCSI] Let scsi_cmnd->cmnd use request->cmd bufferBoaz Harrosh
- struct scsi_cmnd had a 16 bytes command buffer of its own. This is an unnecessary duplication and copy of request's cmd. It is probably left overs from the time that scsi_cmnd could function without a request attached. So clean that up. - Once above is done, few places, apart from scsi-ml, needed adjustments due to changing the data type of scsi_cmnd->cmnd. - Lots of drivers still use MAX_COMMAND_SIZE. So I have left that #define but equate it to BLK_MAX_CDB. The way I see it and is reflected in the patch below is. MAX_COMMAND_SIZE - means: The longest fixed-length (*) SCSI CDB as per the SCSI standard and is not related to the implementation. BLK_MAX_CDB. - The allocated space at the request level - I have audit all ISA drivers and made sure none use ->cmnd in a DMA Operation. Same audit was done by Andi Kleen. (*)fixed-length here means commands that their size can be determined by their opcode and the CDB does not carry a length specifier, (unlike the VARIABLE_LENGTH_CMD(0x7f) command). This is actually not exactly true and the SCSI standard also defines extended commands and vendor specific commands that can be bigger than 16 bytes. The kernel will support these using the same infrastructure used for VARLEN CDB's. So in effect MAX_COMMAND_SIZE means the maximum size command scsi-ml supports without specifying a cmd_len by ULD's Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-16[SCSI] tgt: use KMEM_CACHE macroFUJITA Tomonori
This uses new KMEM_CACHE() macro instead of kmem_cache_create directly to simplify slab cache creation. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-03-03[SCSI] tgt: set the data length properlyFUJITA Tomonori
scsi_tgt uses REQ_TYPE_BLOCK_PC so scsi_init_io doesn't set the length for us. scsi_tgt needs to do it by itself. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-03-03[SCSI] tgt: stop zero'ing scsi_cmndFUJITA Tomonori
The scsi midlayer allocates scsi_cmnd->sense_buffer dynamically so we can't initialize scsi_cmnd (the midlyaer does for us). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-03drivers/scsi/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Acked-by: James Smart <james.smart@emulex.com> Acked-by: Darrick J. Wong <djwong@us.ibm.com> Acked-by: David Somayajulu <david.somayajulu@qlogic.com> Acked-by: Mark Salyzyn <mark_salyzyn@adaptec.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-01-30[SCSI] tgt: use scsi_init_io instead of scsi_alloc_sgtableBoaz Harrosh
If we export scsi_init_io()/scsi_release_buffers() instead of scsi_{alloc,free}_sgtable() from scsi_lib than tgt code is much more insulated from scsi_lib changes. As a bonus it will also gain bidi capability when it comes. [jejb: rebase on to sg_table and fix up rejections] Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-28SG: Convert SCSI to use scatterlist helpers for sg chainingJens Axboe
Also change scsi_alloc_sgtable() to just return 0/failure, since it maps to the command passed in. ->request_buffer is now no longer needed, once drivers are adapted to use scsi_sglist() it can be killed. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-11[SCSI] BUG_ON() impossible condition in sg list countingRusty Russell
If blk_rq_map_sg wrote more than was allocated in the scatterlist, BUG_ON() is probably the right thing to do. [jejb: rejections fixed up] Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] tgt: fix build when dprintk is definedRandy Dunlap
Fix scsi_tgt_lib build when dprintk is defined: Also fix accessors problem when dprintk is defined drivers/scsi/scsi_tgt_lib.c: In function 'scsi_tgt_cmd_destroy': drivers/scsi/scsi_tgt_lib.c:183: warning: format '%lu' expects type 'long unsigned int', but argument 6 has type 'unsigned int' drivers/scsi/scsi_tgt_lib.c: In function 'scsi_tgt_cmd_done': drivers/scsi/scsi_tgt_lib.c:330: warning: format '%lu' expects type 'long unsigned int', but argument 5 has type 'unsigned int' drivers/scsi/scsi_tgt_lib.c: In function 'scsi_tgt_transfer_response': drivers/scsi/scsi_tgt_lib.c:345: warning: format '%lu' expects type 'long unsigned int', but argument 5 has type 'unsigned int' drivers/scsi/scsi_tgt_lib.c: In function 'scsi_tgt_init_cmd': drivers/scsi/scsi_tgt_lib.c:368: warning: format '%lu' expects type 'long unsigned int', but argument 6 has type 'unsigned int' drivers/scsi/scsi_tgt_lib.c: In function 'scsi_tgt_kspace_exec': drivers/scsi/scsi_tgt_lib.c:499: warning: format '%lu' expects type 'long unsigned int', but argument 9 has type 'unsigned int' drivers/scsi/scsi_tgt_lib.c: In function 'scsi_tgt_kspace_it_nexus_rsp': drivers/scsi/scsi_tgt_lib.c:620: error: 'mid' undeclared (first use in this function) drivers/scsi/scsi_tgt_lib.c:620: error: (Each undeclared identifier is reported only once drivers/scsi/scsi_tgt_lib.c:620: error: for each function it appears in.) make[2]: *** [drivers/scsi/scsi_tgt_lib.o] Error 1 [tomo: > - dprintk("%d %d %llx\n", host_no, result, (unsigned long long) mid); > + dprintk("%d %d\n", host_no, result); 'mid' is a typo. I wanted to do: dprintk("%d %d %llx\n", host_no, result, (unsigned long long)itn_id); The rest looks ok. Thanks, ] Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] tgt: convert to use the data buffer accessorsFUJITA Tomonori
- convert to use the new accessors for the sg lists and the parameters. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-16scsi: simplify scsi_free_sgtable()Jens Axboe
Just pass in the command, no point in passing in the scatterlist and scatterlist pool index seperately. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-12[SCSI] tgt: fix can_queue bugFUJITA Tomonori
should use host->can_queue instead of host->hostt->can_queue. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] tgt: move tsk_mgmt_response callback to transport classFUJITA Tomonori
This moves tsk_mgmt_response callback in struct scsi_host_template to struct scsi_transport_template since struct scsi_transport_template is more suitable for the task management stuff. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] tgt: add I_T nexus supportFUJITA Tomonori
tgt uses scsi_host as I_T nexus. This works for ibmvstgt because it creates one scsi_host for one initiator. However, other target drivers don't work like that. This adds I_T nexus support, which enable one scsi_host to handle multiple initiators. New scsi_tgt_it_nexus_create/destroy functions are expected be called transport classes. For example, ibmvstgt creates an initiator remote port, then the srp transport calls tgt_it_nexus_create. tgt doesn't manages I_T nexus, instead it tells tgtd, user-space daemon, to create a new I_T nexus. On the receiving the response from tgtd, tgt calls shost->transportt->it_nexus_response. transports should notify a lld. The srp transport uses it_nexus_response callback in srp_function_template to do that. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-03-20[SCSI] tgt: remove the code to build senseFUJITA Tomonori
tgt notifies a LLD of the failure with sense when it hits the user-space daemon bugs. However, tgt doesn't know anything about SCSI devices that initiators talks to. So it's impossible to send proper sense buffer (format and contents). This patch changes tgt not to notify a LLD of the failure with bogus sense. Instead, tgt just re-queues the failure command to the internal list so that it will be freed cleanly later on when the scsi_host is removed. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-03-11[SCSI] tgt: fix scsi command leakFUJITA Tomonori
The failure to map user-space pages leads to scsi command leak. It can happens mostly because of user-space daemon bugs (or OOM). This patch makes tgt just notify a LLD of the failure with sense when blk_rq_map_user() fails. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-03-11[SCSI] tgt: fix sesnse buffer problemsFUJITA Tomonori
This patch simplify the way to notify LLDs of the command completion and addresses the following sense buffer problems: - can't handle both data and sense. - forces user-space to use aligned sense buffer tgt copies sense_data from userspace to cmnd->sense_buffer (if necessary), maps user-space pages (if necessary) and then calls host->transfer_response (host->transfer_data is removed). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-03-11[SCSI] tgt: rm bio hacks in scsi tgtMike Christie
scsi tgt breaks up a command into multple scatterlists if we cannot fit all the data in one. This was because the block rq helpers did not support large requests and because we can get a command of any old size so it is hard to preallocate pages for scatterlist large enough (we cannot really preallocate pages with the bio map user path). In 2.6.20, we added large request support to the block layer helper, blk_rq_map_user. And at LSF, we talked about increasing SCSI_MAX_PHYS_SEGMENTS for scsi tgt if we want to support really really :) large (greater than 256 * PAGE_SIZE in the worst mapping case) requests. The only target currently implemented does not even support the multiple scatterlists stuff and only supports smaller requests, so this patch just coverts scsi tgt to use blk_rq_map_user. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-12-06Actually update the fixed up compile failures.David Howells
Signed-Off-By: David Howells <dhowells@redhat.com>
2006-11-25[SCSI] scsi tgt: scsi target lib functionalityFUJITA Tomonori
The core scsi target lib functions. TODO: - mv md/dm-bio-list.h to linux/bio-list.h so md and us do not have to do that weird include. - convert scsi_tgt_cmd's work struct to James's execute code. And try to kill our scsi_tgt_cmd. - add host state checking. We do refcouting so hotplug is partially supported, but we need to add state checking to make it easier on the LLD. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
