path: root/drivers/scsi/scsi_tgt_priv.h
2007-10-12[SCSI] tgt: add I_T nexus supportFUJITA Tomonori
tgt uses scsi_host as I_T nexus. This works for ibmvstgt because it creates one scsi_host for one initiator. However, other target drivers don't work like that. This adds I_T nexus support, which enable one scsi_host to handle multiple initiators. New scsi_tgt_it_nexus_create/destroy functions are expected be called transport classes. For example, ibmvstgt creates an initiator remote port, then the srp transport calls tgt_it_nexus_create. tgt doesn't manages I_T nexus, instead it tells tgtd, user-space daemon, to create a new I_T nexus. On the receiving the response from tgtd, tgt calls shost->transportt->it_nexus_response. transports should notify a lld. The srp transport uses it_nexus_response callback in srp_function_template to do that. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-03-11[SCSI] tgt: fix sesnse buffer problemsFUJITA Tomonori
This patch simplify the way to notify LLDs of the command completion and addresses the following sense buffer problems: - can't handle both data and sense. - forces user-space to use aligned sense buffer tgt copies sense_data from userspace to cmnd->sense_buffer (if necessary), maps user-space pages (if necessary) and then calls host->transfer_response (host->transfer_data is removed). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-11-25[SCSI] scsi tgt: scsi target lib functionalityFUJITA Tomonori
The core scsi target lib functions. TODO: - mv md/dm-bio-list.h to linux/bio-list.h so md and us do not have to do that weird include. - convert scsi_tgt_cmd's work struct to James's execute code. And try to kill our scsi_tgt_cmd. - add host state checking. We do refcouting so hotplug is partially supported, but we need to add state checking to make it easier on the LLD. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
