path: root/drivers/scsi/sd.c
2011-05-24[SCSI] Retrieve the Caching mode page (version 2)Luben Tuikov
Some kernel transport drivers unconditionally disable retrieval of the Caching mode page. One such for example is the BBB/CBI transport over USB. Such a restraint is too harsh as some devices do support the Caching mode page. Unconditionally enabling the retrieval of this mode page over those transports at their transport code level may result in some devices failing and becoming unusable. This patch implements a method of retrieving the Caching mode page without unconditionally enabling it in the transports which unconditionally disable it. The idea is to ask for all supported pages, page code 0x3F, and then search for the Caching mode page in the mode parameter data returned. The sd driver already asks for all the mode pages supported by the attached device by setting the page code to 0x3F in order to find out if the media is write protected by reading the WP bit in the Device Specific Parameter field. It then attempts to retrieve only the Caching mode page by setting the page code to 8 and actually attempting to retrieve it if and only if the transport allows it. The method implemented here is that if the transport doesn't allow retrieval of the Caching mode page and the device is not RBC, then we ask for all pages supported by setting the page code to 0x3F (similarly to how the WP bit is retrieved above), and then we search for the Caching mode page in the mode parameter data returned. With this patch, devices over SATA, report this (no change): Oct 22 18:45:58 localhost kernel: sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB) Oct 22 18:45:58 localhost kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0 Oct 22 18:45:58 localhost kernel: sd 0:0:0:0: [sda] Write Protect is off Oct 22 18:45:58 localhost kernel: sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 Oct 22 18:45:58 localhost kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Smart devices report their Caching mode page. This is a change where we'd previously see the kernel making assumption about the device's cache being write-through: Oct 22 18:45:58 localhost kernel: sd 6:0:0:0: Attached scsi generic sg2 type 0 Oct 22 18:45:58 localhost kernel: sd 6:0:0:0: [sdb] 610472646 4096-byte logical blocks: (2.50 TB/2.27 TiB) Oct 22 18:45:58 localhost kernel: sd 6:0:0:0: [sdb] Write Protect is off Oct 22 18:45:58 localhost kernel: sd 6:0:0:0: [sdb] Mode Sense: 47 00 10 08 Oct 22 18:45:58 localhost kernel: sd 6:0:0:0: [sdb] Write cache: enabled, read cache: enabled, supports DPO and FUA And "dumb" devices over BBB, are correctly shown not to support reporting the Caching mode page: Oct 22 18:49:06 localhost kernel: sd 7:0:0:0: [sdc] 15663104 512-byte logical blocks: (8.01 GB/7.46 GiB) Oct 22 18:49:06 localhost kernel: sd 7:0:0:0: [sdc] Write Protect is off Oct 22 18:49:06 localhost kernel: sd 7:0:0:0: [sdc] Mode Sense: 23 00 00 00 Oct 22 18:49:06 localhost kernel: sd 7:0:0:0: [sdc] No Caching mode page present Oct 22 18:49:06 localhost kernel: sd 7:0:0:0: [sdc] Assuming drive cache: write through Version 2 adds this: Some devices don't support page code 0x3F, and others require a fixed transfer length of 192 bytes. This single commit includes a patch by Alan Stern which fixes this. Reported-and-tested-by: Richard Senior <richard@r-senior.demon.co.uk> Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Luben Tuikov <ltuikov@yahoo.com> Signed-off-by: James Bottomley <jbottomley@parallels.com>
2011-05-24[SCSI] sd: Unmap discard alignment needs to be converted to bytesMartin K. Petersen
The block layer discard alignment is reported in bytes, not in units of the logical block size. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <jbottomley@parallels.com>
2011-03-23[SCSI] Revert "[SCSI] Retrieve the Caching mode page"James Bottomley
This reverts commit 24d720b726c1a85f1962831ac30ad4d2ef8276b1. Previously we thought there was little possibility that devices would crash with this, but some have been found. Reported-by: Alan Stern <stern@rowland.harvard.edu> Cc: Luben Tuikov <ltuikov@yahoo.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-03-22sd: Fail discard requests when logical block provisioning has been disabledMartin K. Petersen
Ensure that we kill discard requests after logical block provisioning has been disabled in sysfs. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-14[SCSI] sd: Logical Block Provisioning updateMartin K. Petersen
SBC3r26 contains many changes to the Logical Block Provisioning interfaces (formerly known as Thin Provisioning ditto). This patch implements support for both the old and new schemes using the same heuristic as before (whether the LBP VPD page is present). The new code also allows the provisioning mode (i.e. choice of command) to be overridden on a per-device basis via sysfs. Two additional modes are supported in this version: - WRITE SAME(10) with the UNMAP bit set - WRITE SAME(10) without the UNMAP bit set. This allows us to support devices that predate the TP/LBP enhancements in SBC3 and which work by way zero-detection Switching between modes has been consolidated in a helper function that also updates the block layer topology according to the limitations of the chosen command. I experimented with trying WRITE SAME(16) if UNMAP fails, WRITE SAME(10) if WRITE SAME(16) fails, etc. but found several devices that got cranky. So for now we'll disable discard if one of the commands fail. The user still has the option of selecting a different mode in sysfs. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-01-14[SCSI] sd,sr: kill compat SDEV_MEDIA_CHANGE eventTejun Heo
SDEV_MEDIA_CHANGE event was first added by commit a341cd0f (SCSI: add asynchronous event notification API) for SATA AN support and then extended to cover generic media change events by commit 285e9670 ([SCSI] sr,sd: send media state change modification events). This event was mapped to block device in userland with all properties stripped to simulate CHANGE event on the block device, which, in turn, was used to trigger further userspace action on media change. The recent addition of disk event framework kept this event for backward compatibility but it turns out to be unnecessary and causes erratic and inefficient behavior. The new disk event generates proper events on the block devices and the compat events are mapped to block device with all properties stripped, so the block device ends up generating multiple duplicate events for single actual event. This patch removes the compat event generation from both sr and sd as suggested by Kay Sievers. Both existing and newer versions of udev and the associated tools will behave better with the removal of these events as they from the beginning were expecting events on the block devices. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-01-14[SCSI] sd: implement sd_check_events()Tejun Heo
Replace sd_media_change() with sd_check_events(). * Move media removed logic into set_media_not_present() and media_not_present() and set sdev->changed iff an existing media is removed or the device indicates UNIT_ATTENTION. * Make sd_check_events() sets sdev->changed if previously missing media becomes present. * Event is reported only if sdev->changed is set. This makes media presence event reported if scsi_disk->media_present actually changed or the device indicated UNIT_ATTENTION. For backward compatibility, SDEV_EVT_MEDIA_CHANGE is generated each time sd_check_events() detects media change event. [jejb: fix boot failure] Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Jens Axboe <jaxboe@fusionio.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-01-13Merge branch 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-block: (43 commits) block: ensure that completion error gets properly traced blktrace: add missing probe argument to block_bio_complete block cfq: don't use atomic_t for cfq_group block cfq: don't use atomic_t for cfq_queue block: trace event block fix unassigned field block: add internal hd part table references block: fix accounting bug on cross partition merges kref: add kref_test_and_get bio-integrity: mark kintegrityd_wq highpri and CPU intensive block: make kblockd_workqueue smarter Revert "sd: implement sd_check_events()" block: Clean up exit_io_context() source code. Fix compile warnings due to missing removal of a 'ret' variable fs/block: type signature of major_to_index(int) to major_to_index(unsigned) block: convert !IS_ERR(p) && p to !IS_ERR_NOR_NULL(p) cfq-iosched: don't check cfqg in choose_service_tree() fs/splice: Pull buf->ops->confirm() from splice_from_pipe actors cdrom: export cdrom_check_events() sd: implement sd_check_events() sr: implement sr_check_events() ...
2010-12-22[SCSI] fix medium error problems with some arrays which can cause data ↵James Bottomley
corruption Our current handling of medium error assumes that data is returned up to the bad sector. This assumption holds good for all disk devices, all DIF arrays and most ordinary arrays. However, an LSI array engine was recently discovered which reports a medium error without returning any data. This means that when we report good data up to the medium error, we've reported junk originally in the buffer as good. Worse, if the read consists of requested data plus a readahead, and the error occurs in readahead, we'll just strip off the readahead and report junk up to userspace as good data with no error. The fix for this is to have the error position computation take into account the amount of data returned by the driver using the scsi residual data. Unfortunately, not every driver fills in this data, but for those who don't, it's set to zero, which means we'll think a full set of data was transferred and the behaviour will be identical to the prior behaviour of the code (believe the buffer up to the error sector). All modern drivers seem to set the residual, so that should fix up the LSI failure/corruption case. Reported-by: Douglas Gilbert <dgilbert@interlog.com> Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-12-22Revert "sd: implement sd_check_events()"Jens Axboe
This reverts commit c8d2e937355d02db3055c2fc203e5f017297ee1f. We run into merging problems with the SCSI tree, revert this one so it can be handled by a postmerge tree there. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-12-21[SCSI] Retrieve the Caching mode pageLuben Tuikov
Some kernel transport drivers unconditionally disable retrieval of the Caching mode page. One such for example is the BBB/CBI transport over USB.  Such a restraint is too harsh as some devices do support the Caching mode page. Unconditionally enabling the retrieval of this mode page over those transports at their transport code level may result in some devices failing and becoming unusable. This patch implements a method of retrieving the Caching mode page without unconditionally enabling it in the transports which unconditionally disable it. The idea is to ask for all supported pages, page code 0x3F, and then search for the Caching mode page in the mode parameter data returned. The sd driver already asks for all the mode pages supported by the attached device by setting the page code to 0x3F in order to find out if the media is write protected by reading the WP bit in the Device Specific Parameter field. It then attempts to retrieve only the Caching mode page by setting the page code to 8 and actually attempting to retrieve it if and only if the transport allows it. The method implemented here is that if the transport doesn't allow retrieval of the Caching mode page and the device is not RBC, then we ask for all pages supported by setting the page code to 0x3F (similarly to how the WP bit is retrieved above), and then we search for the Caching mode page in the mode parameter data returned. With this patch, devices over SATA, report this (no change): Oct 22 18:45:58 localhost kernel: sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB) Oct 22 18:45:58 localhost kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0 Oct 22 18:45:58 localhost kernel: sd 0:0:0:0: [sda] Write Protect is off Oct 22 18:45:58 localhost kernel: sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 Oct 22 18:45:58 localhost kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Smart devices report their Caching mode page. This is a change where we'd previously see the kernel making assumption about the device's cache being write-through: Oct 22 18:45:58 localhost kernel: sd 6:0:0:0: Attached scsi generic sg2 type 0 Oct 22 18:45:58 localhost kernel: sd 6:0:0:0: [sdb] 610472646 4096-byte logical blocks: (2.50 TB/2.27 TiB) Oct 22 18:45:58 localhost kernel: sd 6:0:0:0: [sdb] Write Protect is off Oct 22 18:45:58 localhost kernel: sd 6:0:0:0: [sdb] Mode Sense: 47 00 10 08 Oct 22 18:45:58 localhost kernel: sd 6:0:0:0: [sdb] Write cache: enabled, read cache: enabled, supports DPO and FUA And "dumb" devices over BBB, are correctly shown not to support reporting the Caching mode page: Oct 22 18:49:06 localhost kernel: sd 7:0:0:0: [sdc] 15663104 512-byte logical blocks: (8.01 GB/7.46 GiB) Oct 22 18:49:06 localhost kernel: sd 7:0:0:0: [sdc] Write Protect is off Oct 22 18:49:06 localhost kernel: sd 7:0:0:0: [sdc] Mode Sense: 23 00 00 00 Oct 22 18:49:06 localhost kernel: sd 7:0:0:0: [sdc] No Caching mode page present Oct 22 18:49:06 localhost kernel: sd 7:0:0:0: [sdc] Assuming drive cache: write through Signed-off-by: Luben Tuikov <ltuikov@yahoo.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-12-21[SCSI] sd: improve logic and efficiecy of media-change detectionAlan Stern
This patch (as1415) improves the formerly incomprehensible logic in sd_media_changed() (the current code refers to "changed" as a state, whereas in fact it is a relation between two states). It also adds a big comment so that everyone can understand what is really going on. The patch also improves efficiency by not reporting a media change when no medium was ever present. If no medium was present the last time we checked and there's still no medium, it's not necessary to tell the caller that a change occurred. Doing so merely causes the caller to attempt to revalidate a non-existent disk, which is a waste of time. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-12-16sd: implement sd_check_events()Tejun Heo
Replace sd_media_change() with sd_check_events(). sd used to set the changed state whenever the device is not ready, which can cause event loop while the device is not ready. Media presence handling code is changed such that the changed state is set iff the media presence actually changes. UA still always sets the changed state and NOT_READY always (at least where it used to set ->changed) clears media presence, so no event is lost. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-12-16scsi: replace sr_test_unit_ready() with scsi_test_unit_ready()Tejun Heo
The usage of TUR has been confusing involving several different commits updating different parts over time. Currently, the only differences between scsi_test_unit_ready() and sr_test_unit_ready() are, * scsi_test_unit_ready() also sets sdev->changed on NOT_READY. * scsi_test_unit_ready() returns 0 if TUR ended with UNIT_ATTENTION or NOT_READY. Due to the above two differences, sr is using its own sr_test_unit_ready(), but sd - the sole user of the above extra handling - doesn't even need them. Where scsi_test_unit_ready() is used in sd_media_changed(), the code is looking for device ready w/ media present state which is true iff TUR succeeds w/o sense data or UA, and when the device is not ready for whatever reason sd_media_changed() explicitly marks media as missing so there's no reason to set sdev->changed automatically from scsi_test_unit_ready() on NOT_READY. Drop both special handlings from scsi_test_unit_ready(), which makes it equivalant to sr_test_unit_ready(), and replace sr_test_unit_ready() with scsi_test_unit_ready(). Also, drop the unnecessary explicit NOT_READY check from sd_media_changed(). Checking return value is enough for testing device readiness. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-25[SCSI] sd: Export effective protection mode in sysfsMartin K. Petersen
Create a sysfs entry that reports the negotiated DIX/DIF protection mode for a SCSI disk. This depends on the protection type the disk is formatted with as well as the protection capabilities advertised by the controller. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-10-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (141 commits) USB: mct_u232: fix broken close USB: gadget: amd5536udc.c: fix error path USB: imx21-hcd - fix off by one resource size calculation usb: gadget: fix Kconfig warning usb: r8a66597-udc: Add processing when USB was removed. mxc_udc: add workaround for ENGcm09152 for i.MX35 USB: ftdi_sio: add device ids for ScienceScope USB: musb: AM35x: Workaround for fifo read issue USB: musb: add musb support for AM35x USB: AM35x: Add musb support usb: Fix linker errors with CONFIG_PM=n USB: ohci-sh - use resource_size instead of defining its own resource_len macro USB: isp1362-hcd - use resource_size instead of defining its own resource_len macro USB: isp116x-hcd - use resource_size instead of defining its own resource_len macro USB: xhci: Fix compile error when CONFIG_PM=n USB: accept some invalid ep0-maxpacket values USB: xHCI: PCI power management implementation USB: xHCI: bus power management implementation USB: xHCI: port remote wakeup implementation USB: xHCI: port power management implementation ... Manually fix up (non-data) conflict: the SCSI merge gad renamed the 'hw_sector_size' member to 'physical_block_size', and the USB tree brought a new use of it.
2010-10-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (84 commits) [SCSI] be2iscsi: SGE Len == 64K [SCSI] be2iscsi: Remove premature free of cid [SCSI] be2iscsi: More time for FW [SCSI] libsas: fix bug for vacant phy [SCSI] sd: Fix overflow with big physical blocks [SCSI] st: add MTWEOFI to write filemarks without flushing drive buffer [SCSI] libsas: Don't issue commands to devices that have been hot-removed [SCSI] megaraid_sas: Add Online Controller Reset to MegaRAID SAS drive [SCSI] lpfc 8.3.17: Update lpfc driver version to 8.3.17 [SCSI] lpfc 8.3.17: Replace function reset methodology [SCSI] lpfc 8.3.17: SCSI fixes [SCSI] lpfc 8.3.17: BSG fixes [SCSI] lpfc 8.3.17: SLI Additions and Fixes [SCSI] lpfc 8.3.17: Code Cleanup and Locking fixes [SCSI] zfcp: Remove scsi_cmnd->serial_number from debug traces [SCSI] ipr: fix array error logging [SCSI] aha152x: enable PCMCIA on 64bit [SCSI] scsi_dh_alua: Handle all states correctly [SCSI] cxgb4i: connection and ddp setting update [SCSI] cxgb3i: fixed connection over vlan ...
2010-10-22scsi/sd: add a no_read_capacity_16 scsi_device flagHans de Goede
I seem to have a knack for digging up buggy usb devices which don't work with Linux, and I'm crazy enough to try to make them work. So this time a friend of mine asked me to get an mp4 player (an mp3 player which can play videos on a small screen) to work with Linux. It is based on the well known rockbox chipset for which we already have an unusual devs entries to work around some of its bugs. But this model comes with an additional twist. This model chokes on read_capacity_16 calls. Now normally we don't make those calls, but this model comes with an sdcard slot and when there is no card in there (and shipped from the factory there is none), it reports a size of 0. However this time the programmers actually got the read_capacity_10 response right! So they substract one from the size as stored internally in the mp3 player before reporting it back, resulting in an answer of ... 0xffffffff sectors, causing sd.c to try a read_capacity_16, on which the device crashes. This patch adds a flag to scsi_device to indicate that a a device cannot handle read_capacity_16, and when this flag is set if a device reports an lba of 0xffffffff as answer to a read_capacity_10, assumes it tries to report a size of 0. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Matthew Dharm <mdharm-usb@one-eyed-alien.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-19Merge branch 'v2.6.36-rc8' into for-2.6.37/barrierJens Axboe
Conflicts: block/blk-core.c drivers/block/loop.c mm/swapfile.c Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-11[SCSI] sd: Fix overflow with big physical blocksMartin K. Petersen
The hw_sector_size variable could overflow if a device reported huge physical blocks. Switch to the more accurate physical_block_size terminology and make sure we use an unsigned int to match the range permitted by READ CAPACITY(16). Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-10-07[SCSI] sd name space exhaustion causes system hangMichael Reed
Following a site power outage which re-enabled all the ports on my FC switches, my system subsequently booted with far too many luns! I had let it run hoping it would make multi-user. It didn't. :( It hung solid after exhausting the last sd device, sdzzz, and attempting to create sdaaaa and beyond. I was unable to get a dump. Discovered using a 2.6.32.13 based system. correct this by detecting when the last index is utilized and failing the sd probe of the device. Patch applies to scsi-misc-2.6. Signed-off-by: Michael Reed <mdr@sgi.com> Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-09-17[SCSI] sd: Update thin provisioning supportMartin K. Petersen
Add support for the Thin Provisioning VPD page and use the TPU and TPWS bits to switch between UNMAP and WRITE SAME(16) for discards. If no TP VPD page is present we fall back to old scheme where the max descriptor count combined with the max lba count are used trigger UNMAP. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-09-10block: deprecate barrier and replace blk_queue_ordered() with blk_queue_flush()Tejun Heo
Barrier is deemed too heavy and will soon be replaced by FLUSH/FUA requests. Deprecate barrier. All REQ_HARDBARRIERs are failed with -EOPNOTSUPP and blk_queue_ordered() is replaced with simpler blk_queue_flush(). blk_queue_flush() takes combinations of REQ_FLUSH and FUA. If a device has write cache and can flush it, it should set REQ_FLUSH. If the device can handle FUA writes, it should also set REQ_FUA. All blk_queue_ordered() users are converted. * ORDERED_DRAIN is mapped to 0 which is the default value. * ORDERED_DRAIN_FLUSH is mapped to REQ_FLUSH. * ORDERED_DRAIN_FLUSH_FUA is mapped to REQ_FLUSH | REQ_FUA. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Boaz Harrosh <bharrosh@panasas.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Michael S. Tsirkin <mst@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Chris Wright <chrisw@sous-sol.org> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: David S. Miller <davem@davemloft.net> Cc: Alasdair G Kergon <agk@redhat.com> Cc: Pierre Ossman <drzeus@drzeus.cx> Cc: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block: kill QUEUE_ORDERED_BY_TAGTejun Heo
Nobody is making meaningful use of ORDERED_BY_TAG now and queue draining for barrier requests will be removed soon which will render the advantage of tag ordering moot. Kill ORDERED_BY_TAG. The following users are affected. * brd: converted to ORDERED_DRAIN. * virtio_blk: ORDERED_TAG path was already marked deprecated. Removed. * xen-blkfront: ORDERED_TAG case dropped. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Christoph Hellwig <hch@infradead.org> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Michael S. Tsirkin <mst@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-07[SCSI] sd: fix medium-removal bugAlan Stern
Commit 409f3499a2cfcd1e9c2857c53af7fcce069f027f (scsi/sd: remove big kernel lock) introduced a bug in the sd_release routine. Medium removal should be allowed when the number of open file references drops to 0, not when it becomes non-zero. This patch (as1414) adjusts the test to fix the bug. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-09-05[SCSI] scsi/block: increase flush/sync timeoutMike Christie
We have been seeing the flush request timeout with a wide range of hardware from tgt+iser to FC targets from a major vendor. After discussions about if the value should be configurable and what the best value should be, this patch just increases the flush/sync cache timeout to 1 minute. 2 minutes was determined to be too long, and making it configurable was troublesome for users. This patch was made over Linus's tree. It is not made over scsi-misc or scsi-rc-fixes, because Linus's had block layer changes that my patch was built over. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Acked-by: Jens Axboe <jaxboe@fusionio.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-09-02[SCSI] sd, sym53c8xx: Remove warnings after vsprintf %pV introducation.David Miller
GCC warns about empty printf format strings, and after the addition of %pV these existing such cases in the scsi driver layer were exposed enough for the compiler to start seeing them. Based almost entirely upon a patch by Joe Perches. [jejb: fix up sym53c8xx msg] Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-08-11scsi/sd.c: quiet all sparse noiseH Hartley Sweeten
In sd_store_cache_type the symbol 'len' is declared twice. Remove the second declaration to quiet the following sparse warning. warning: symbol 'len' shadows an earlier one In sd_probe the variable 'index' is declared as a u32. This variable is used in a call to ida_get_new which is expecting an int *. Make the variable an int to quiet the following sparse warning. warning: incorrect type in argument 2 (different signedness) There are 4 symbols in the file that are not exported and produce the following sparse warnings. warning: symbol 'sd_cdb_cache' was not declared. Should it be static? warning: symbol 'sd_cdb_pool' was not declared. Should it be static? warning: symbol 'sd_read_protection_type' was not declared. Should it be static? warning: symbol 'sd_read_app_tag_own' was not declared. Should it be static? Make them static to quiet the warnings. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: James E.J. Bottomley <James.Bottomley@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-10Merge branch 'for-2.6.36' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.36' of git://git.kernel.dk/linux-2.6-block: (149 commits) block: make sure that REQ_* types are seen even with CONFIG_BLOCK=n xen-blkfront: fix missing out label blkdev: fix blkdev_issue_zeroout return value block: update request stacking methods to support discards block: fix missing export of blk_types.h writeback: fix bad _bh spinlock nesting drbd: revert "delay probes", feature is being re-implemented differently drbd: Initialize all members of sync_conf to their defaults [Bugz 315] drbd: Disable delay probes for the upcomming release writeback: cleanup bdi_register writeback: add new tracepoints writeback: remove unnecessary init_timer call writeback: optimize periodic bdi thread wakeups writeback: prevent unnecessary bdi threads wakeups writeback: move bdi threads exiting logic to the forker thread writeback: restructure bdi forker loop a little writeback: move last_active to bdi writeback: do not remove bdi from bdi_list writeback: simplify bdi code a little writeback: do not lose wake-ups in bdi threads ... Fixed up pretty trivial conflicts in drivers/block/virtio_blk.c and drivers/scsi/scsi_error.c as per Jens.
2010-08-07scsi: use REQ_TYPE_FS for flush requestFUJITA Tomonori
scsi-ml uses REQ_TYPE_BLOCK_PC for flush requests from file systems. The definition of REQ_TYPE_BLOCK_PC is that we don't retry requests even when we can (e.g. UNIT ATTENTION) and we send the response to the callers (then the callers can decide what they want). We need a workaround such as the commit 77a4229719e511a0d38d9c355317ae1469adeb54 to retry BLOCK_PC flush requests. We will need the similar workaround for discard requests too since SCSI-ml handle them as BLOCK_PC internally. This uses REQ_TYPE_FS for flush requests from file systems instead of REQ_TYPE_BLOCK_PC. scsi-ml retries only REQ_TYPE_FS requests that have data to transfer when we can retry them (e.g. UNIT_ATTENTION). However, we also need to retry REQ_TYPE_FS requests without data because the callers don't. This also changes scsi_check_sense() to retry all the REQ_TYPE_FS requests when appropriate. Thanks to scsi_noretry_cmd(), REQ_TYPE_BLOCK_PC requests don't be retried as before. Note that basically, this reverts the commit 77a4229719e511a0d38d9c355317ae1469adeb54 since now we use REQ_TYPE_FS for flush requests. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07scsi: convert discard to REQ_TYPE_FS from REQ_TYPE_BLOCK_PCFUJITA Tomonori
Jens, any reason why this isn't included in your for-2.6.36 yet? = From: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Subject: [PATCH resend] scsi: convert discard to REQ_TYPE_FS from REQ_TYPE_BLOCK_PC The block layer (file systems) sends discard requests as REQ_TYPE_FS (the role of REQ_TYPE_FS is that setting up commands and interpreting the results). But SCSI-ml treats discard requests as REQ_TYPE_BLOCK_PC. scsi-ml can handle discard requests as REQ_TYPE_FS easily. scsi_setup_discard_cmnd() sets up struct request and the bio nicely. Only remaining issue is that discard requests can't be completed partially so we need to modify sd_done. This conversion also fixes the problem that discard requests aren't retried when possible (e.g. UNIT ATTENTION). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07scsi/sd: remove big kernel lockArnd Bergmann
Every user of the BKL in the sd driver is the result of the pushdown from the block layer into the open/close/ioctl functions. The only place that used to rely on the BKL is the sdkp->openers variable, which gets converted into an atomic_t. Nothing else seems to rely on the BKL, since the functions do not touch global data without holding another lock, and the open/close functions are still protected from concurrent execution using the bdev->bd_mutex. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: linux-scsi@vger.kernel.org Cc: "James E.J. Bottomley" <James.Bottomley@suse.de> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: push down BKL into .open and .releaseArnd Bergmann
The open and release block_device_operations are currently called with the BKL held. In order to change that, we must first make sure that all drivers that currently rely on this have no regressions. This blindly pushes the BKL into all .open and .release operations for all block drivers to prepare for the next step. The drivers can subsequently replace the BKL with their own locks or remove it completely when it can be shown that it is not needed. The functions blkdev_get and blkdev_put are the only remaining users of the big kernel lock in the block layer, besides a few uses in the ioctl code, none of which need to serialize with blkdev_{get,put}. Most of these two functions is also under the protection of bdev->bd_mutex, including the actual calls to ->open and ->release, and the common code does not access any global data structures that need the BKL. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: push down BKL into .locked_ioctlArnd Bergmann
As a preparation for the removal of the big kernel lock in the block layer, this removes the BKL from the common ioctl handling code, moving it into every single driver still using it. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07scsi: fix discard page leakFUJITA Tomonori
We leak a page allocated for discard on some error conditions (e.g. scsi_prep_state_check returns BLKPREP_DEFER in scsi_setup_blk_pc_cmnd). We unprep on requests that weren't prepped in the error path of scsi_init_io. It makes the error path to clean up scsi commands messy. Let's strictly apply the rule that we can't unprep on a request that wasn't prepped. Calling just scsi_put_command() in the error path of scsi_init_io() is enough. We don't set REQ_DONTPREP yet. scsi_setup_discard_cmnd can safely free a page on the error case with the above rule. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07scsi: need to reset unprep_rq_fn in sd_removeFUJITA Tomonori
This is for block's for-2.6.36. We need to reset q->unprep_rq_fn in sd_remove. Otherwise we hit kernel oops if we access to a scsi disk device via sg after removing scsi disk module. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: remove q->prepare_flush_fn completelyFUJITA Tomonori
This removes q->prepare_flush_fn completely (changes the blk_queue_ordered API). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07scsi: stop using q->prepare_flush_fnFUJITA Tomonori
scsi-ml builds flush requests via q->prepare_flush_fn(), however, builds discard requests via q->prep_rq_fn. Using two different mechnisms for the similar requests (building commands in SCSI ULD) doesn't make sense. Handing both via q->prep_rq_fn makes the code design simpler. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: James Bottomley <James.Bottomley@suse.de> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07scsi: remove unused free discard page in sd_doneFUJITA Tomonori
- sd_done isn't called for pc request so we never call the code. - we use sd_unprep to free discard page now. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07scsi: add sd_unprep_fn to free discard pageFUJITA Tomonori
This fixes discard page leak by using q->unprep_rq_fn facility. q->unprep_rq_fn is called when all the data buffer (req->bio and scsi_data_buffer) in the request is freed. sd_unprep() uses rq->buffer to free discard page allocated in sd_prepare_discard(). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: don't allocate a payload for discard requestChristoph Hellwig
Allocating a fixed payload for discard requests always was a horrible hack, and it's not coming to byte us when adding support for discard in DM/MD. So change the code to leave the allocation of a payload to the lowlevel driver. Unfortunately that means we'll need another hack, which allows us to update the various block layer length fields indicating that we have a payload. Instead of hiding this in sd.c, which we already partially do for UNMAP support add a documented helper in the core block layer for it. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: remove wrappers for request type/flagsChristoph Hellwig
Remove all the trivial wrappers for the cmd_type and cmd_flags fields in struct requests. This allows much easier grepping for different request types instead of unwinding through macros. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-07-28[SCSI] sd: add support for runtime PMAlan Stern
This patch (as1399) adds runtime-PM support to the sd driver. The support is unsophisticated: If a SCSI disk device is mounted, or if its device file is held open, then the device will not be runtime-suspended; otherwise it will (provided userspace gives permission by writing "auto" to the sysfs power/control attribute). In order to make this work, a dev_set_drvdata() call had to be moved from sd_probe_async() to sd_probe(). Also, a few lines of code were changed to use a local variable instead of recalculating the address of an embedded struct device. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-06-02SCSI: implement sd_unlock_native_capacity()Tejun Heo
Implement sd_unlock_native_capacity() method which calls into hostt->unlock_native_capacity() if implemented. This will be invoked by block layer if partitions extend beyond the end of the device and can be used to implement, for example, on-demand ATA host protected area unlocking. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-05-18[SCSI] Merge scsi-misc-2.6 into scsi-rc-fixes-2.6James Bottomley
2010-05-05[SCSI] Enable retries for SYNCRONIZE_CACHE commands to fix I/O errorHannes Reinecke
Some arrays are giving I/O errors with ext3 filesystems when SYNCHRONIZE_CACHE gets a UNIT_ATTENTION. What is happening is that these commands have no retries, so the UNIT_ATTENTION causes the barrier to fail. We should be enable retries here to clear any transient error and allow the barrier to succeed. Signed-off-by: Hannes Reinecke <hare@suse.de> Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-04-11[SCSI] sd: retry read_capacity on UNIT_ATTENTIONJames Bottomley
Hazard testing uncovered yet another bug in sd. Under heavy reset activity the retry counter might be exhausted and the command will be returned with sense UNIT_ATTENTION/0x29/00 (POWER ON, RESET, OR BUS DEVICE RESET OCCURRED). In those cases we should just increase the retry counter again, retrying one more to clear up this Unit Attention state. [jejb: update to work with RC16 devices and not to loop endlessly] Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-04-11[SCSI] sd: quiet spurious error messages in READ_CAPACITY(16)Hannes Reinecke
sd always tries to submit a READ_CAPACITY(16) CDB, regardless whether the host actually supports it. queuecommand() will then return DID_ABORT, which is not qualified enough to detect the true cause here. So better check in sd_try_rc16 first if the cdblen is supported. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
