3aec2f41a8bae introduced a merge error where we would end up check for
sdkp instead of sdkp->ATO. Fix this so we register app tag capability
correctly.
Cc: <stable@vger.kernel.org> # v3.17+
Reviewed-by: Sagi Grimberg <sagig@mellanox.com>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
A set of flags introduced in the block layer enable better control over
how protection information is handled. These flags are useful for both
error injection and data recovery purposes. Checking can be enabled and
disabled for controller and disk, and the guard tag format is now a
per-I/O property.
Update sd_protect_op to communicate the relevant information to the
low-level device driver via a set of flags in scsi_cmnd.
Acked-by: Christoph Hellwig <hch@lst.de>
Signed-off-by: Jens Axboe <axboe@fb.com>
The T10 Protection Information format is also used by some devices that
do not go through the SCSI layer (virtual block devices, NVMe). Relocate
the relevant functions to a block layer library that can be used without
involving SCSI.
Make the choice of checksum a per-I/O property by introducing a flag
that can be inspected by the SCSI layer. There are several reasons for
this:
1. It allows us to switch choice of checksum without unloading and
reloading the HBA driver.
2. During error recovery we need to be able to tell the HBA that
checksums read from disk should not be verified and converted to IP
checksums.
3. For error injection purposes we need to be able to write a bad guard
tag to storage. Since the storage device only supports T10 CRC we
need to be able to disable IP checksum conversion on the HBA.
Move flags affecting the integrity code out of the bio bi_flags and into
the block integrity payload.
So far we have relied on the app tag size to determine whether a disk
has been formatted with T10 protection information or not. However, not
all target devices provide application tag storage.
Add a flag to the block integrity profile that indicates whether the
disk has been formatted with protection information.
Reviewed-by: Sagi Grimberg <sagig@dev.mellanox.co.il>
Instead of the "operate" parameter we pass in a seed value and a pointer
to a function that can be used to process the integrity metadata. The
generation function is changed to have a return value to fit into this
scheme.
The protection interval is not necessarily tied to the logical block
size of a block device. Stop using the terms "sector" and "sectors".
Going forward we will use the term "seed" to describe the initial
reference tag value for a given I/O. "Interval" will be used to describe
the portion of the data buffer that a given piece of protection
information is associated with.
None of the filesystems appear interested in using the integrity tagging
feature. Potentially because very few storage devices actually permit
using the application tag space.
Remove the tagging functions.
For commands like REQ_COPY we need a way to pass extra information along
with each bio. Like integrity metadata this information must be
available at the bottom of the stack so bi_private does not suffice.
Rename the existing bi_integrity field to bi_special and make it a union
so we can have different bio extensions for each class of command.
We previously used bi_integrity != NULL as a way to identify whether a
bio had integrity metadata or not. Introduce a REQ_INTEGRITY to be the
indicator now that bi_special can contain different things.
In addition, bio_integrity(bio) will now return a pointer to the
integrity payload (when applicable).
The bio integrity is also stored in a bvec array, so if we use the bvec
iter code we just added, the integrity code won't need to implement its
own iteration stuff (bio_integrity_mark_head(), bio_integrity_mark_tail())
Signed-off-by: Kent Overstreet <kmo@daterainc.com>
Cc: "Martin K. Petersen" <martin.petersen@oracle.com>
Cc: "James E.J. Bottomley" <JBottomley@parallels.com>
It appears to me that there is a problem with handling of type 1 protection
information.
It is considering a logical block reference tag of 0xffffffff to be an error,
but it is actually valid any time ((lba & 0xffffffff) == 0xffffffff) [for
example, 2TiB-1, 4TiB-1, 6TiB-1, etc.].
I'm going by what's written in 4.18.3 of SBC3, where there doesn't appear
to be any invalid value for the reference tag.
Signed-off-by: Jeremy Higdon <jeremy@sgi.com>
Acked-by: Martin K. Petersen <martin.petersen@oracle.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
It does not make sense to translate ref tags with unexpected values.
Instead we simply ignore them and let the upper layers catch the
problem. Ref tags that contain the expected value are still remapped.
Signed-off-by: Cong Wang <amwang@redhat.com>
Fix setting bio flags in drivers (sd_dif/floppy).
Signed-off-by: Muthukumar R <muthur@gmail.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Previously we tracked whether the integrity metadata had been remapped
using a request flag. This was fine for low-level retries. However, if
an I/O was redriven by upper layers we would end up remapping again,
causing the retry to fail.
Deprecate the REQ_INTEGRITY flag and introduce BIO_MAPPED_INTEGRITY
which enables filesystems to notify lower layers that the bio in
question has already been remapped.
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
sd_dif.c was not updated to return -EILSEQ, leading to error handling
failures in applications which provide their own integrity metadata (as
opposed to being protected by the block layer functions).
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
So far we have only issued DIF commands if CONFIG_BLK_DEV_INTEGRITY is
enabled. However, communication between initiator and target should be
independent of protection information DMA. There are DIF-only host
adapters coming out that will be able to take advantage of this.
Move the relevant DIF bits to sd.c.
The checksum format is orthogonal to whether the protection information
is being passed on beyond the HBA or not. It is perfectly valid to use
a non-T10 CRC with WRITE_STRIP and READ_INSERT.
Consequently it no longer makes sense to explicitly refer to the
conversion in the protection operation. Update sd_dif and lpfc
accordingly.
Acked-by: Ihab Hamadi <Ihab.Hamadi@Emulex.Com>
With recent cleanups, there is no place where low level driver
directly manipulates request fields. This means that the 'hard'
request fields always equal the !hard fields. Convert all
rq->sectors, nr_sectors and current_nr_sectors references to
accessors.
While at it, drop superflous blk_rq_pos() < 0 test in swim.c.
[ Impact: use pos and nr_sectors accessors ]
Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Tested-by: Grant Likely <grant.likely@secretlab.ca>
Tested-by: Adrian McMenamin <adrian@mcmen.demon.co.uk>
Acked-by: Adrian McMenamin <adrian@mcmen.demon.co.uk>
Acked-by: Mike Miller <mike.miller@hp.com>
Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Cc: Borislav Petkov <petkovbb@googlemail.com>
Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com>
Cc: Eric Moore <Eric.Moore@lsi.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: Pete Zaitcev <zaitcev@redhat.com>
Cc: Paul Clements <paul.clements@steeleye.com>
Cc: Tim Waugh <tim@cyberelk.net>
Cc: Jeff Garzik <jgarzik@pobox.com>
Cc: Jeremy Fitzhardinge <jeremy@xensource.com>
Cc: Alex Dubov <oakad@yahoo.com>
Cc: Dario Ballabio <ballabio_dario@emc.com>
Cc: unsik Kim <donari75@gmail.com>
Cc: Laurent Vivier <Laurent@lvivier.info>
DIF does not work with 6-byte commands so we previously ignored those
commands when preparing a request. However, DIX does not need
RDPROTECT/WRPROTECT to be set and 6-byte commands are consequently
perfectly valid in host-only mode.
This patch fixes a problem where we would set the wrong DIX operation
when issuing commands to a legacy disk.
Reviewed-by: Matthew Wilcox <willy@linux.intel.com>
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Switch tag arrays to u8 to prevent problems on platforms with signed
char.
Reported-by: Tim LaBerge <tim.laberge@Quantum.Com>
Add application tag to the output displayed on error.
For some reason these messages ended up being printed with KERN_INFO
rendering them invisible to pretty much everyone. Switch to
KERN_NOTICE.
The old detection code couldn't handle all possible combinations of
DIX and DIF. This version does, giving priority to DIX if the
controller is capable.
Now that we no longer use protection_type as trigger for preparing
protected CDBs we can remove the places that set it to zero. This
allows userland to see which protection type the device is formatted
with regardless of whether the HBA supports DIF or not.
Support for controllers and disks that implement DIF protection
information:
- During command preparation the RDPROTECT/WRPROTECT must be set
correctly if the target has DIF enabled.
- READ(6) and WRITE(6) are not supported when DIF is on.
- The controller must be told how to handle the I/O via the
protection operation field in scsi_cmnd.
- Refactor the I/O completion code that extracts failed LBA from the
returned sense data and handle DIF failures correctly.
- sd_dif.c implements the functions required to prepare and complete
requests with protection information attached.
