path: root/drivers/scsi/sr.c
2011-07-21[SCSI] sr: check_events() ignore GET_EVENT when TUR says otherwiseKay Sievers
Some broken devices indicates that media has changed on every GET_EVENT_STATUS_NOTIFICATION. This translates into MEDIA_CHANGE uevent on every open() which lets udev run into a loop. Verify GET_EVENT result against TUR and if it generates spurious events for several times in a row, ignore the GET_EVENT events, and trust only the TUR status. This is the log of a USB stick with a (broken) fake CDROM drive: scsi 5:0:0:0: Direct-Access SanDisk U3 Cruzer Micro 8.02 PQ: 0 ANSI: 0 CCS sd 5:0:0:0: Attached scsi generic sg3 type 0 scsi 5:0:0:1: CD-ROM SanDisk U3 Cruzer Micro 8.02 PQ: 0 ANSI: 0 sd 5:0:0:0: [sdb] Attached SCSI removable disk sr2: scsi3-mmc drive: 48x/48x tray sr 5:0:0:1: Attached scsi CD-ROM sr2 sr 5:0:0:1: Attached scsi generic sg4 type 5 sr2: GET_EVENT and TUR disagree continuously, suppress GET_EVENT events sd 5:0:0:0: [sdb] 31777279 512-byte logical blocks: (16.2 GB/15.1 GiB) sd 5:0:0:0: [sdb] No Caching mode page present sd 5:0:0:0: [sdb] Assuming drive cache: write through sd 5:0:0:0: [sdb] No Caching mode page present sd 5:0:0:0: [sdb] Assuming drive cache: write through sdb: sdb1 -tj: Updated to consider only spurious GET_EVENT events among different types of disagreement and allow using TUR for kernel event polling after GET_EVENT is ignored. Reported-By: Markus Rathgeb maggu2810@googlemail.com Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@kernel.org # >= v2.6.38, fixes udev busy looping w/ certain devices Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-04-21block: don't block events on excl write for non-optical devicesTejun Heo
Disk event code automatically blocks events on excl write. This is primarily to avoid issuing polling commands while burning is in progress. This behavior doesn't fit other types of devices with removeable media where polling commands don't have adverse side effects and door locking usually doesn't exist. This patch introduces new genhd flag which controls the auto-blocking behavior and uses it to enable auto-blocking only on optical devices. Note for stable: 2.6.38 and later only Cc: stable@kernel.org Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-14[SCSI] sd,sr: kill compat SDEV_MEDIA_CHANGE eventTejun Heo
SDEV_MEDIA_CHANGE event was first added by commit a341cd0f (SCSI: add asynchronous event notification API) for SATA AN support and then extended to cover generic media change events by commit 285e9670 ([SCSI] sr,sd: send media state change modification events). This event was mapped to block device in userland with all properties stripped to simulate CHANGE event on the block device, which, in turn, was used to trigger further userspace action on media change. The recent addition of disk event framework kept this event for backward compatibility but it turns out to be unnecessary and causes erratic and inefficient behavior. The new disk event generates proper events on the block devices and the compat events are mapped to block device with all properties stripped, so the block device ends up generating multiple duplicate events for single actual event. This patch removes the compat event generation from both sr and sd as suggested by Kay Sievers. Both existing and newer versions of udev and the associated tools will behave better with the removal of these events as they from the beginning were expecting events on the block devices. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-12-16sr: implement sr_check_events()Tejun Heo
Replace sr_media_change() with sr_check_events(). It normally only uses GET_EVENT_STATUS_NOTIFICATION to check both media change and eject request. If @clearing includes DISK_EVENT_MEDIA_CHANGE, it issues TUR and compares whether media presence has changed. The SCSI specific media change uevent is kept for compatibility. sr_media_change() was doing both media change check and revalidation. The revalidation part is split into sr_block_revalidate_disk(). Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-12-16scsi: replace sr_test_unit_ready() with scsi_test_unit_ready()Tejun Heo
The usage of TUR has been confusing involving several different commits updating different parts over time. Currently, the only differences between scsi_test_unit_ready() and sr_test_unit_ready() are, * scsi_test_unit_ready() also sets sdev->changed on NOT_READY. * scsi_test_unit_ready() returns 0 if TUR ended with UNIT_ATTENTION or NOT_READY. Due to the above two differences, sr is using its own sr_test_unit_ready(), but sd - the sole user of the above extra handling - doesn't even need them. Where scsi_test_unit_ready() is used in sd_media_changed(), the code is looking for device ready w/ media present state which is true iff TUR succeeds w/o sense data or UA, and when the device is not ready for whatever reason sd_media_changed() explicitly marks media as missing so there's no reason to set sdev->changed automatically from scsi_test_unit_ready() on NOT_READY. Drop both special handlings from scsi_test_unit_ready(), which makes it equivalant to sr_test_unit_ready(), and replace sr_test_unit_ready() with scsi_test_unit_ready(). Also, drop the unnecessary explicit NOT_READY check from sd_media_changed(). Checking return value is enough for testing device readiness. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-12-16scsi: fix TUR error handling in sr_media_change()Tejun Heo
sr_test_unit_ready() returns 0 iff TUR succeeded - IOW, when media is present and the device is actually ready, so the return value wouldn't be zero when TUR ends with sense data. sr_media_change() incorrectly tests (retval || (scsi_sense_valid(sshdr)...)) when it tries to test whether TUR failed without sense data or with sense data indicating media-not-present. Fix the test using scsi_status_is_good() and update comments. - Fixed a comment typo spotted by Eike. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Rolf Eike Beer <eike-kernel@sf-tec.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (141 commits) USB: mct_u232: fix broken close USB: gadget: amd5536udc.c: fix error path USB: imx21-hcd - fix off by one resource size calculation usb: gadget: fix Kconfig warning usb: r8a66597-udc: Add processing when USB was removed. mxc_udc: add workaround for ENGcm09152 for i.MX35 USB: ftdi_sio: add device ids for ScienceScope USB: musb: AM35x: Workaround for fifo read issue USB: musb: add musb support for AM35x USB: AM35x: Add musb support usb: Fix linker errors with CONFIG_PM=n USB: ohci-sh - use resource_size instead of defining its own resource_len macro USB: isp1362-hcd - use resource_size instead of defining its own resource_len macro USB: isp116x-hcd - use resource_size instead of defining its own resource_len macro USB: xhci: Fix compile error when CONFIG_PM=n USB: accept some invalid ep0-maxpacket values USB: xHCI: PCI power management implementation USB: xHCI: bus power management implementation USB: xHCI: port remote wakeup implementation USB: xHCI: port power management implementation ... Manually fix up (non-data) conflict: the SCSI merge gad renamed the 'hw_sector_size' member to 'physical_block_size', and the USB tree brought a new use of it.
2010-10-22scsi/sr: add no_read_disc_info scsi_device flagHans de Goede
Some USB devices emulate a usb-mass-storage attached (scsi) cdrom device, usually this fake cdrom contains the windows software for the device. While working on supporting Appotech ax3003 based photoframes, which do this I discovered that they will go of into lala land when ever they see a READ_DISC_INFO scsi command. Thus this patch adds a scsi_device flag (which can then be set by the usb-storage driver through an unsual-devs entry), to indicate this, and makes the sr driver honor this flag. I know this sucks, but as discussed on linux-scsi list there is no other way to make this device work properly. Looking at usb traces made under windows, windows never sends a READ_DISC_INFO during normal interactions with a usb cdrom device. So as this cdrom emulation thingie becomes more common we might see more of this problem. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Matthew Dharm <mdharm-usb@one-eyed-alien.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-05block: autoconvert trivial BKL users to private mutexArnd Bergmann
The block device drivers have all gained new lock_kernel calls from a recent pushdown, and some of the drivers were already using the BKL before. This turns the BKL into a set of per-driver mutexes. Still need to check whether this is safe to do. file=$1 name=$2 if grep -q lock_kernel ${file} ; then if grep -q 'include.*linux.mutex.h' ${file} ; then sed -i '/include.*<linux\/smp_lock.h>/d' ${file} else sed -i 's/include.*<linux\/smp_lock.h>.*$/include <linux\/mutex.h>/g' ${file} fi sed -i ${file} \ -e "/^#include.*linux.mutex.h/,$ { 1,/^\(static\|int\|long\)/ { /^\(static\|int\|long\)/istatic DEFINE_MUTEX(${name}_mutex); } }" \ -e "s/\(un\)*lock_kernel\>[ ]*()/mutex_\1lock(\&${name}_mutex)/g" \ -e '/[ ]*cycle_kernel_lock();/d' else sed -i -e '/include.*\<smp_lock.h\>/d' ${file} \ -e '/cycle_kernel_lock()/d' fi Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-08-07block: push down BKL into .open and .releaseArnd Bergmann
The open and release block_device_operations are currently called with the BKL held. In order to change that, we must first make sure that all drivers that currently rely on this have no regressions. This blindly pushes the BKL into all .open and .release operations for all block drivers to prepare for the next step. The drivers can subsequently replace the BKL with their own locks or remove it completely when it can be shown that it is not needed. The functions blkdev_get and blkdev_put are the only remaining users of the big kernel lock in the block layer, besides a few uses in the ioctl code, none of which need to serialize with blkdev_{get,put}. Most of these two functions is also under the protection of bdev->bd_mutex, including the actual calls to ->open and ->release, and the common code does not access any global data structures that need the BKL. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: push down BKL into .locked_ioctlArnd Bergmann
As a preparation for the removal of the big kernel lock in the block layer, this removes the BKL from the common ioctl handling code, moving it into every single driver still using it. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-10-02[SCSI] sr: consider the last written sector when determining media sizeTejun Heo
On certain cases, UDF disc doesn't report capacity correctly via READ_CAPACITY but TOC or trackinfo contains valid information which can be obtained using cdrom_get_last_written(). ide-cd considers both values and uses the larger one. Do the same in sr. This fixes bko#9668. http://bugzilla.kernel.org/show_bug.cgi?id=9668 Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Milan Kocian <milan.kocian@wq.cz> Cc: Jan Kara <jack@suse.cz> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-09-22const: make block_device_operations constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-21sd, sr: fix Driver 'sd' needs updating messageHannes Reinecke
If a SCSI ULD driver sets blk_queue_prep_rq(), it should clean it up itself on remove(), and not from the bus callbacks. This removes the need to hook into bus->remove(), which should not be used at the same time as driver->remove(). [jejb: fix sdkp initialisation problem due to mismerge] Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-05-22block: Do away with the notion of hardsect_sizeMartin K. Petersen
Until now we have had a 1:1 mapping between storage device physical block size and the logical block sized used when addressing the device. With SATA 4KB drives coming out that will no longer be the case. The sector size will be 4KB but the logical block size will remain 512-bytes. Hence we need to distinguish between the physical block size and the logical ditto. This patch renames hardsect_size to logical_block_size. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: convert to pos and nr_sectors accessorsTejun Heo
With recent cleanups, there is no place where low level driver directly manipulates request fields. This means that the 'hard' request fields always equal the !hard fields. Convert all rq->sectors, nr_sectors and current_nr_sectors references to accessors. While at it, drop superflous blk_rq_pos() < 0 test in swim.c. [ Impact: use pos and nr_sectors accessors ] Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Tested-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Grant Likely <grant.likely@secretlab.ca> Tested-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Acked-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Acked-by: Mike Miller <mike.miller@hp.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Tim Waugh <tim@cyberelk.net> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Dario Ballabio <ballabio_dario@emc.com> Cc: David S. Miller <davem@davemloft.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: unsik Kim <donari75@gmail.com> Cc: Laurent Vivier <Laurent@lvivier.info> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-03[SCSI] fix recovered error handlingJames Bottomley
We have a problem with recovered error handling in that any command which goes down as BLOCK_PC but which returns a sense code of RECOVERED ERROR gets completed with -EIO. For actual SG_IO commands, this doesn't matter at all, since the error return code gets dropped in favour of req->errors which contain the SCSI completion code. However, if this command is part of the block system, then it will pay attention to the returned error code. In particularly if a SYNCHRONIZE CACHE from a barrier command completes with RECOVERED ERROR, the resulting -EIO on the barrier causes block to error the request and return it to the filesystem. Fix this by converting the -EIO for recovered error to zero, plus remove the printing of this from sd and sr so the message isn't double printed. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29[SCSI] add residual argument to scsi_execute and scsi_execute_reqFUJITA Tomonori
scsi_execute() and scsi_execute_req() discard the residual length information. Some callers need it. This adds residual argument (optional) to scsi_execute and scsi_execute_req. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-04[PATCH 1/2] kill FMODE_NDELAY_NOWChristoph Hellwig
Update FMODE_NDELAY before each ioctl call so that we can kill the magic FMODE_NDELAY_NOW. It would be even better to do this directly in setfl(), but for that we'd need to have FMODE_NDELAY for all files, not just block special files. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-21[PATCH] switch srAl Viro
2008-10-21[PATCH] beginning of methods conversionAl Viro
To keep the size of changesets sane we split the switch by drivers; to keep the damn thing bisectable we do the following: 1) rename the affected methods, add ones with correct prototypes, make (few) callers handle both. That's this changeset. 2) for each driver convert to new methods. *ALL* drivers are converted in this series. 3) kill the old (renamed) methods. Note that it _is_ a flagday; all in-tree drivers are converted and by the end of this series no trace of old methods remain. The only reason why we do that this way is to keep the damn thing bisectable and allow per-driver debugging if anything goes wrong. New methods: open(bdev, mode) release(disk, mode) ioctl(bdev, mode, cmd, arg) /* Called without BKL */ compat_ioctl(bdev, mode, cmd, arg) locked_ioctl(bdev, mode, cmd, arg) /* Called with BKL, legacy */ Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-21[PATCH] don't mess with file in scsi_nonblockable_ioctl()Al Viro
2008-10-21[PATCH] switch cdrom_{open,release,ioctl} to sane APIsAl Viro
... convert to it in callers Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-09block: unify request timeout handlingJens Axboe
Right now SCSI and others do their own command timeout handling. Move those bits to the block layer. Instead of having a timer per command, we try to be a bit more clever and simply have one per-queue. This avoids the overhead of having to tear down and setup a timer for each command, so it will result in a lot less timer fiddling. Signed-off-by: Mike Anderson <andmike@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: don't depend on consecutive minor spaceTejun Heo
* Implement disk_devt() and part_devt() and use them to directly access devt instead of computing it from ->major and ->first_minor. Note that all references to ->major and ->first_minor outside of block layer is used to determine devt of the disk (the part0) and as ->major and ->first_minor will continue to represent devt for the disk, converting these users aren't strictly necessary. However, convert them for consistency. * Implement disk_max_parts() to avoid directly deferencing genhd->minors. * Update bdget_disk() such that it doesn't assume consecutive minor space. * Move devt computation from register_disk() to add_disk() and make it the only one (all other usages use the initially determined value). These changes clean up the code and will help disk->part dereference fix and extended block device numbers. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-09-11block: disable sysfs parts of the disk command filterJens Axboe
We still have life time issues with the sysfs command filter kobject, so disable it for 2.6.27 release. We can revisit this and make it work properly for 2.6.28, for 2.6.27 release it's too risky. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-08-29remove blk_register_filter and blk_unregister_filter in gendiskFUJITA Tomonori
This patch remove blk_register_filter and blk_unregister_filter in gendisk, and adds them to sd.c, sr.c. and ide-cd.c The commit abf5439370491dd6fbb4fe1a7939680d2a9bc9d4 moved cmdfilter from gendisk to request_queue. It turned out that in some subsystems multiple gendisks share a single request_queue. So we get: Using physmap partition information Creating 3 MTD partitions on "physmap-flash": 0x00000000-0x01c00000 : "User FS" 0x01c00000-0x01c40000 : "booter" kobject (8511c410): tried to init an initialized object, something is seriously wrong. Call Trace: [<8036644c>] dump_stack+0x8/0x34 [<8021f050>] kobject_init+0x50/0xcc [<8021fa18>] kobject_init_and_add+0x24/0x58 [<8021d20c>] blk_register_filter+0x4c/0x64 [<8021c194>] add_disk+0x78/0xe0 [<8027d14c>] add_mtd_blktrans_dev+0x254/0x278 [<8027c8f0>] blktrans_notify_add+0x40/0x78 [<80279c00>] add_mtd_device+0xd0/0x150 [<8027b090>] add_mtd_partitions+0x568/0x5d8 [<80285458>] physmap_flash_probe+0x2ac/0x334 [<802644f8>] driver_probe_device+0x12c/0x244 [<8026465c>] __driver_attach+0x4c/0x84 [<80263c64>] bus_for_each_dev+0x58/0xac [<802633ec>] bus_add_driver+0xc4/0x24c [<802648e0>] driver_register+0xcc/0x184 [<80100460>] _stext+0x60/0x1bc In the long term, we need to fix such subsystems but we need a quick fix now. This patch add the command filter support to only sd and sr though it might be useful for other SG_IO users (such as cciss). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Reported-by: Manuel Lauss <mano@roarinelk.homelinux.net> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-04scsi: sr avoids useless buffer allocationFUJITA Tomonori
blk_rq_map_kern can handle the stack buffers correctly (avoid DMA from/to the stack buffers by using the bounce buffer) so we don't need to complicate the code by allocating just 8 bytes. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-06-10[SCSI] sr: fix corrupt CD data after media change and delayJames Bottomley
Reported-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> If you delay 30s or more before mounting a CD after inserting it then the kernel has the wrong value for the CD size. http://marc.info/?t=121276133000001 The problem is in sr_test_unit_ready(): the function eats unit attentions without adjusting the sdev->changed status. This means that when the CD signals changed media via unit attention, we can ignore it. Fix by making sr_test_unit_ready() adjust the changed status. Tested-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-03-19[SCSI] sd, sr: do not emit change event at device addKay Sievers
Initialize the "state changed" flag, so we do not send a change event immediately after registering a new device. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-07[SCSI] sr: fix test unit ready responsesJames Bottomley
Commit 210ba1d1724f5c4ed87a2ab1a21ca861a915f734 updated sr.c to use the scsi_test_unit_ready() function. Unfortunately, this has the wrong characteristic of eating NOT_READY returns which sr.c relies on for tray status. Fix by rolling an internal sr_test_unit_ready() that doesn't do this. Tested-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-30[SCSI] implement scsi_data_bufferBoaz Harrosh
In preparation for bidi we abstract all IO members of scsi_cmnd, that will need to duplicate, into a substructure. - Group all IO members of scsi_cmnd into a scsi_data_buffer structure. - Adjust accessors to new members. - scsi_{alloc,free}_sgtable receive a scsi_data_buffer instead of scsi_cmnd. And work on it. - Adjust scsi_init_io() and scsi_release_buffers() for above change. - Fix other parts of scsi_lib/scsi.c to members migration. Use accessors where appropriate. - fix Documentation about scsi_cmnd in scsi_host.h - scsi_error.c * Changed needed members of struct scsi_eh_save. * Careful considerations in scsi_eh_prep/restore_cmnd. - sd.c and sr.c * sd and sr would adjust IO size to align on device's block size so code needs to change once we move to scsi_data_buff implementation. * Convert code to use scsi_for_each_sg * Use data accessors where appropriate. - tgt: convert libsrp to use scsi_data_buffer - isd200: This driver still bangs on scsi_cmnd IO members, so need changing [jejb: rebased on top of sg_table patches fixed up conflicts and used the synergy to eliminate use_sg and sg_count] Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] sr: update to follow tray status correctlyJames Bottomley
Based on an original patch from: David Martin <tasio@tasio.net> When trying to get the drive status via ioctl CDROM_DRIVE_STATUS, with no disk it gives CDS_TRAY_OPEN even if the tray is closed. ioctl works as expected with ide-cd driver. Gentoo bug report: http://bugs.gentoo.org/show_bug.cgi?id=196879 Cc: Maarten Bressers <mbres@gentoo.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] sd,sr: add early detection of medium not presentJames Bottomley
The current scsi_test_unit_ready() is updated to return sense code information (in struct scsi_sense_hdr). The sd and sr drivers are changed to interpret the sense code return asc 0x3a as no media and adjust the device status accordingly. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] sr,sd: send media state change modification eventsKay Sievers
This will send for a card reader slot (remove/add media): UEVENT[1187091572.155884] change /devices/pci0000:00/0000:00:1d.7/usb5/5-2/5-2:1.0/host7/target7:0:0/7:0:0:0 (scsi) UEVENT[1187091572.162314] remove /block/sdb/sdb1 (block) UEVENT[1187091572.172464] add /block/sdb/sdb1 (block) UEVENT[1187091572.175408] change /devices/pci0000:00/0000:00:1d.7/usb5/5-2/5-2:1.0/host7/target7:0:0/7:0:0:0 (scsi) and for a DVD drive (add/eject media): UEVENT[1187091590.189159] change /devices/pci0000:00/0000:00:1f.1/host4/target4:0:0/4:0:0:0 (scsi) UEVENT[1187091590.957124] add /module/isofs (module) UEVENT[1187091604.468207] change /devices/pci0000:00/0000:00:1f.1/host4/target4:0:0/4:0:0:0 (scsi) Userspace gets events, even for unpartitioned media. This unifies the event handling for asynchronoous events (AN) and events caused by perodical polling the device from userspace. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> [jejb: modified for new event API] Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-06Revert "scsi: revert "[SCSI] Get rid of scsi_cmnd->done""Linus Torvalds
This reverts commit ac40532ef0b8649e6f7f83859ea0de1c4ed08a19, which gets us back the original cleanup of 6f5391c283d7fdcf24bf40786ea79061919d1e1d. It turns out that the bug that was triggered by that commit was apparently not actually triggered by that commit at all, and just the testing conditions had changed enough to make it appear to be due to it. The real problem seems to have been found by Peter Osterlund: "pktcdvd sets it [block device size] when opening the /dev/pktcdvd device, but when the drive is later opened as /dev/scd0, there is nothing that sets it back. (Btw, 40944 is possible if the disk is a CDRW that was formatted with "cdrwtool -m 10236".) The problem is that pktcdvd opens the cd device in non-blocking mode when pktsetup is run, and doesn't close it again until pktsetup -d is run. The effect is that if you meanwhile open the cd device, blkdev.c:do_open() doesn't call bd_set_size() because bdev->bd_openers is non-zero." In particular, to repeat the bug (regardless of whether commit 6f5391c283d7fdcf24bf40786ea79061919d1e1d is applied or not): " 1. Start with an empty drive. 2. pktsetup 0 /dev/scd0 3. Insert a CD containing an isofs filesystem. 4. mount /dev/pktcdvd/0 /mnt/tmp 5. umount /mnt/tmp 6. Press the eject button. 7. Insert a DVD containing a non-writable filesystem. 8. mount /dev/scd0 /mnt/tmp 9. find /mnt/tmp -type f -print0 | xargs -0 sha1sum >/dev/null 10. If the DVD contains data beyond the physical size of a CD, you get I/O errors in the terminal, and dmesg reports lots of "attempt to access beyond end of device" errors." which in turn is because the nested open after the media change won't cause the size to be set properly (because the original open still holds the block device, and we only do the bd_set_size() when we don't have other people holding the device open). The proper fix for that is probably to just do something like bdev->bd_inode->i_size = (loff_t)get_capacity(disk)<<9; in fs/block_dev.c:do_open() even for the cases where we're not the original opener (but *not* call bd_set_size(), since that will also change the block size of the device). Cc: Peter Osterlund <petero2@telia.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Ingo Molnar <mingo@elte.hu> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-02scsi: revert "[SCSI] Get rid of scsi_cmnd->done"Ingo Molnar
This reverts commit 6f5391c283d7fdcf24bf40786ea79061919d1e1d ("[SCSI] Get rid of scsi_cmnd->done") that was supposed to be a cleanup commit, but apparently it causes regressions: Bug 9370 - v2.6.24-rc2-409-g9418d5d: attempt to access beyond end of device http://bugzilla.kernel.org/show_bug.cgi?id=9370 this patch should be reintroduced in a more split-up form to make testing of it easier. Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Matthew Wilcox <matthew@wil.cx> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12[SCSI] Get rid of scsi_cmnd->doneMatthew Wilcox
The ULD ->done callback moves into the scsi_driver. By moving the call to scsi_io_completion() from scsi_blk_pc_done() to scsi_finish_command(), we can eliminate the latter entirely. By returning 'good_bytes' from the ->done callback (rather than invoking scsi_io_completion()), we can stop exporting scsi_io_completion(). Also move the prototypes from sd.h to sd.c as they're all internal anyway. Rename sd_rw_intr to sd_done and rw_intr to sr_done. Inspired-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] move ULD attachment into the prep functionJames Bottomley
One of the intents of the block prep function was to allow ULDs to use it for preprocessing. The original SCSI model was to have a single prep function and add a pointer indirect filter to build the necessary commands. This patch reverses that, does away with the init_command field of the scsi_driver structure and makes ULDs attach directly to the prep function instead. The value is really that it allows us to begin to separate the ULDs from the SCSI mid layer (as long as they don't use any core functions---which is hard at the moment---a ULD doesn't even need SCSI to bind). Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-24[BLOCK] Get rid of request_queue_t typedefJens Axboe
Some of the code has been gradually transitioned to using the proper struct request_queue, but there's lots left. So do a full sweet of the kernel and get rid of this typedef and replace its uses with the proper type. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-18[SCSI] small cleanupsAdrian Bunk
This patch contains the following cleanups: - make needlessly global functions static - every file should #include the headers containing the prototypes for it's global functions Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-14[SCSI] sr: fix error handling in module_initAkinobu Mita
Sweep registered blkdev when scsi_register_driver has failed. Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-04-17[SCSI] modalias for scsi devicesMichael Tokarev
The following patch adds support for sysfs/uevent modalias attribute for scsi devices (like disks, tapes, cdroms etc), based on whatever current sd.c, sr.c, st.c and osst.c drivers supports. The modalias format is like this: scsi:type-0x04 (for TYPE_WORM, handled by sr.c now). Several comments. o This hexadecimal type value is because all TYPE_XXX constants in include/scsi/scsi.h are given in hex, but __stringify() will not convert them to decimal (so it will NOT be scsi:type-4). Since it does not really matter in which format it is, while both modalias in module and modalias attribute match each other, I descided to go for that 0x%02x format (and added a comment in include/scsi/scsi.h to keep them that way), instead of changing them all to decimal. o There was no .uevent routine for SCSI bus. It might be a good idea to add some more ueven environment variables in there. o osst.c driver handles tapes too, like st.c, but only SOME tapes. With this setup, hotplug scripts (or whatever is used by the user) will try to load both st and osst modules for all SCSI tapes found, because both modules have scsi:type-0x01 alias). It is not harmful, but one extra module is no good either. It is possible to solve this, by exporting more info in modalias attribute, including vendor and device identification strings, so that modalias becomes something like scsi:type-0x12:vendor-Adaptec LTD:device-OnStream Tape Drive and having that, match for all 3 attributes, not only device type. But oh well, vendor and device strings may be large, and they do contain spaces and whatnot. So I left them for now, awaiting for comments first. Signed-off-by: Michael Tokarev <mjt@tls.msk.ru> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-01-06[SCSI] sr: fix error code check in sr_block_ioctl()Tejun Heo
sr_block_ioctl() should proceed to SCSI ioctls if cdrom_ioctl() returns -ENOSYS. However it tested for ENOSYS instead of -ENOSYS rendering all SCSI ioctls other than GET_IDLUN and GET_BUS_NUMBER inaccessible. Fix it. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-09[SCSI] hide EH backup data outside the scsi_cmndChristoph Hellwig
Currently struct scsi_cmnd has various fields that are used to backup original data after the corresponding fields have been overridden for EH commands. This means drivers can easily get at it and misuse it. Due to the old_ naming this doesn't happen for most of them, but two that have different names have been used wrong a lot (see previous patch). Another downside is that they unessecarily bloat the scsi_cmnd size. This patch moves them onstack in scsi_send_eh_cmnd to fix those two issues aswell as allowing future EH fixes like moving the EH command submissions to use SG lists like everything else. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-26[SCSI] sd/scsi_lib simplify sd_rw_intr and scsi_io_completionLuben Tuikov
This patch simplifies "good_bytes" computation in sd_rw_intr(). sd: "good_bytes" computation is always done in terms of the resolution of the device's medium, since after that it is the number of good bytes we pass around and other layers/contexts (as opposed ot sd) can translate that to their own resolution (block layer:512). It also makes scsi_io_completion() processing more straightforward, eliminating the 3rd argument to the function. It also fixes a couple of bugs like not checking return value, using "break" instead of "return;", etc. I've been running with this patch for some time now on a test (do-it-all) system. Signed-off-by: Luben Tuikov <ltuikov@yahoo.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-06[SCSI] fix up request buffer reference in various scsi driversChristoph Hellwig
Various scsi drivers use scsi_cmnd.buffer and scsi_cmnd.bufflen in their queuecommand functions. Those fields are internal storage for the midlayer only and are used to restore the original payload after request_buffer and request_bufflen have been overwritten for EH. Using the buffer and bufflen fields means they do very broken things in error handling. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
