[ Upstream commit cabe92a55e3a12005a4ac4d3954c9a174b0efe2a ]
Increase cmd_per_lun to allow more I/Os in progress per device,
particularly for NVMe's. The Hyper-V host side can handle the higher
count with no issues.
Signed-off-by: Michael Kelley <mikelley@microsoft.com>
Reviewed-by: K. Y. Srinivasan <kys@microsoft.com>
Acked-by: K. Y. Srinivasan <kys@microsoft.com>
[ Upstream commit d1b8b2391c24751e44f618fcf86fb55d9a9247fd ]
When an I/O is returned with an srb_status of SRB_STATUS_INVALID_LUN
which has zero good_bytes it must be assigned an error. Otherwise the
I/O will be continuously requeued and will cause a deadlock in the case
where disks are being hot added and removed. sd_probe_async will wait
forever for its I/O to complete while holding scsi_sd_probe_domain.
Also returning the default error of DID_TARGET_FAILURE causes multipath
to not retry the I/O resulting in applications receiving I/O errors
before a failover can occur.
Signed-off-by: Cathy Avery <cavery@redhat.com>
Signed-off-by: Long Li <longli@microsoft.com>
Reviewed-by: Stephen Hemminger <stephen@networkplumber.org>
commit f1c635b439a5c01776fe3a25b1e2dc546ea82e6f upstream.
Hyper-V host emulation of SCSI for virtual DVD device reports SCSI
version 0 (UNKNOWN) but is still capable of supporting REPORTLUN.
Without this patch, a GEN2 Linux guest on Hyper-V will not boot 4.11
successfully with virtual DVD ROM device. What happens is that the SCSI
scan process falls back to doing sequential probing by INQUIRY. But the
storvsc driver has a previous workaround that masks/blocks all errors
reports from INQUIRY (or MODE_SENSE) commands. This workaround causes
the scan to then populate a full set of bogus LUN's on the target and
then sends kernel spinning off into a death spiral doing block reads on
the non-existent LUNs.
By setting the correct blacklist flags, the target with the DVD device
is scanned with REPORTLUN and that works correctly.
Patch needs to go in current 4.11, it is safe but not necessary in older
kernels.
Signed-off-by: Stephen Hemminger <sthemmin@microsoft.com>
commit 0208eeaa650c5c866a3242201678a19e6dc4a14e upstream.
When storvsc is sending I/O to Hyper-v, it may allocate a bigger buffer
descriptor for large data payload that can't fit into a pre-allocated
buffer descriptor. This bigger buffer is freed on return path.
If I/O request to Hyper-v fails due to ring buffer busy, the storvsc
allocated buffer descriptor should also be freed.
[mkp: applied by hand]
Fixes: be0cf6ca301c ("scsi: storvsc: Set the tablesize based on the information given by the host")
commit 40630f462824ee24bc00d692865c86c3828094e0 upstream.
On I/O errors, the Windows driver doesn't set data_transfer_length
on error conditions other than SRB_STATUS_DATA_OVERRUN.
In these cases we need to set data_transfer_length to 0,
indicating there is no data transferred. On SRB_STATUS_DATA_OVERRUN,
data_transfer_length is set by the Windows driver to the actual data transferred.
Reported-by: Shiva Krishna <Shiva.Krishna@nimblestorage.com>
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
commit bba5dc332ec2d3a685cb4dae668c793f6a3713a3 upstream.
When sense message is present on error, we should pass along to the upper
layer to decide how to deal with the error.
This patch fixes connectivity issues with Fiber Channel devices.
commit 3cd6d3d9b1abab8dcdf0800224ce26daac24eea2 upstream.
Properly set SRB flags when hosting device supports tagged queuing.
This patch improves the performance on Fiber Channel disks.
commit ff06c5ffbcb4ffa542fb80c897be977956fafecc upstream.
Commit 3209f9d780d1 ("scsi: storvsc: Fix a bug in the handling of SRB
status flags") filtered SRB_STATUS_AUTOSENSE_VALID out effectively making
the (SRB_STATUS_ABORTED | SRB_STATUS_AUTOSENSE_VALID) case a dead code. The
logic from this branch (e.g. storvsc_device_scan() call) is still required,
fix the check.
Fixes: 3209f9d780d1 ("scsi: storvsc: Fix a bug in the handling of SRB status flags")
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
SRB status can have additional information. Mask these out before processing
SRB status.
This patch was sent as part of a collection of patches more than a year ago.
While the rest of the patches in the set were comitted, this patch was not.
I woulod like to thank Olaf for noticing that this patch was not committed
upstream.
Reviewed-by: Long Li <longli@microsoft.com>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
Storvsc driver needs to ensure there are no 'holes' in the presented
sg list (all segments in the middle of the list need to be of PAGE_SIZE).
When a hole is detected storvsc driver creates a 'bounce sgl' without
holes and copies data over with copy_{to,from}_bounce_buffer() functions.
Setting virt_boundary_mask to PAGE_SIZE - 1 guarantees we'll never see
such holes so we can significantly simplify the driver. This is also
supposed to bring us some performance improvement for certain workloads
as we eliminate copying.
Reported-by: Radim Krčmář <rkrcmar@redhat.com>
Tested-by: Alex Ng <alexng@microsoft.com>
Don't set the SRB_FLAGS_QUEUE_ACTION_ENABLE flag since we are not specifying
tags. Without this, the qlogic driver doesn't work properly with storvsc.
Cc: stable@vger.kernel.org
In the function storvsc_channel_init(), error code was not getting
set correctly in some of the failure cases. Fix this issue.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Allow WRITE_SAME for Windows10 and above hosts.
Signed-off-by: Keith Mange <keith.mange@microsoft.com>
Use storage protocol version instead of vmbus protocol
version when determining storage capabilities.
Use correct defaults for values determined by protocol negotiation,
instead of resetting them with every scsi controller.
negotiation.
Currently we are making decisions based on vmbus protocol versions
that have been negotiated; use storage potocol versions instead.
[jejb: fold ARRAY_SIZE conversion suggested by Johannes Thumshirn
<jthumshirn@suse.de>
make vmstor_protocol static]
Use a single value to track protocol versions to simplify
comparisons and to be consistent with vmbus version tracking.
decisions based on ranges.
Rather than look for sets of specific protocol versions,
make decisions based on ranges. This will be safer and require fewer changes
going forward as we add more storage protocol versions.
Comment in struct Scsi_Host says that drivers are not supposed to access
__devices directly. storvsc_host_scan() doesn't happen in irq context
so we can just use shost_for_each_device().
Under the 'default' case in scmnd->sc_data_direction we have 3 options:
- DMA_NONE which we handle correctly.
- DMA_BIDIRECTIONAL which is never supposed to be set by SCSI stack.
- Garbage value.
Do WARN() and return -EINVAL in the last two cases. virtio_scsi does
BUG_ON() here but it looks like an overkill.
Set the SRB flags correctly when there is no data transfer. Without this
change some IHV drivers will fail valid commands such as TEST_UNIT_READY.
Cc: <stable@vger.kernel.org>
Set the tablesize based on the information given by the host.
Tested-by: Long Li <longli@microsoft.com>
The current code assumes that the scatterlists presented are not chained.
Fix the code to not make this assumption.
We may exit this function without properly freeing up the maapings
we may have acquired. Fix the bug.
The storage protocol informs the guest of the I/O capabilities of the storage
stack. Retrieve this information and use it in the guest.
The current code always sent packets without data on the primary channel.
Properly distribute sending of packets with no data amongst all available
channels. I would like to thank Long Li for noticing this problem.
Size the queue depth based on the ringbuffer size. Also accommodate for the
fact that we could have multiple channels (ringbuffers) per adaptor.
Increase the default ring buffer size as this can significantly
improve performance especially on high latency storage back-ends.
On win8 and win8 r2 hosts force SPC-3 compliance for MSFT virtual disks.
Ubuntu has been carrying a similar patch outside the tree for a while now.
Starting with win10, the host will support SPC-3 compliance. Based on all
the testing that has been done on win8 and win8 r2 hosts, we are comfortable
claiming SPC-3 compliance on these hosts as well. This will enable TRIM
support on these hosts.
Suggested by: James Bottomley <James.Bottomley@HansenPartnership.com>
Commit 4cd83ecdac20d30725b4f96e5d7814a1e290bc7e changed the limits to
reflect the values on the host. It turns out that WS2008R2 cannot
correctly handle these new limits. Fix this bug by setting the limits
based on the host.
The host asks the guest to scan when a LUN is removed or added.
The only way a guest can identify the removed LUN is when an I/O is
attempted on a removed LUN - the SRB status code indicates that the LUN
is invalid. We currently handle this SRB status and remove the device.
Rather than waiting for an I/O to remove the device, force the discovery of
LUNs that may have been removed prior to discovering LUNs that may have
been added.
The virtual HBA that storvsc implements can support multiple channels and
targets. So, scan the host when the host notifies that a scan is needed.
STORVSC uses its own momory pool to manage device request data. However,
the SCSI layer already has a mechanisim for allocating additional memory
for each command issued to device driver. This patch removes the memory
pool in STORVSC and makes it use SCSI layer to allocate memory for device
request data.
When ring buffer returns an error indicating retry, storvsc may not
return a proper error code to SCSI when bounce buffer is not used.
This has introduced I/O freeze on RAID running atop storvsc devices.
This patch fixes it by always returning a proper error code.
cc: stable@vger.kernel.org
Drop the now unused reason argument from the ->change_queue_depth method.
Also add a return value to scsi_adjust_queue_depth, and rename it to
scsi_change_queue_depth now that it can be used as the default
->change_queue_depth implementation.
Reviewed-by: Mike Christie <michaelc@cs.wisc.edu>
Reviewed-by: Hannes Reinecke <hare@suse.de>
Remove the tagged argument from scsi_adjust_queue_depth, and just let it
handle the queue depth. For most drivers those two are fairly separate,
given that most modern drivers don't care about the SCSI "tagged" status
of a command at all, and many old drivers allow queuing of multiple
untagged commands in the driver.
Instead we start out with the ->simple_tags flag set before calling
->slave_configure, which is how all drivers actually looking at
->simple_tags except for one worke anyway. The one other case looks
broken, but I've kept the behavior as-is for now.
Except for that we only change ->simple_tags from the ->change_queue_type,
and when rejecting a tag message in a single driver, so keeping this
churn out of scsi_adjust_queue_depth is a clear win.
Now that the usage of scsi_adjust_queue_depth is more obvious we can
also remove all the trivial instances in ->slave_alloc or ->slave_configure
that just set it to the cmd_per_lun default.
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
We should be using the standard dev_printk() variants for
sense code printing.
[hch: remove __scsi_print_sense call in xen-scsiback, Acked by Juergen]
[hch: folded bracing fix from Dan Carpenter]
Signed-off-by: Hannes Reinecke <hare@suse.de>
Reviewed-by: Robert Elliott <elliott@hp.com>
Get rid of the warning messages since they will clutter up various system logs
and are of questionable value to the end user. For debugging purposes, this
information can be gotten by setting the scsi log level appropriately.
Reviewed-by: Olaf Hering <olaf@aepfle.de>
Add blist flags to permit the reading of the VPD pages even when
the target may claim SPC-2 compliance. MSFT targets currently
claim SPC-2 compliance while they implement post SPC-2 features.
With this patch we can correctly handle WRITE_SAME_16 issues.
On some Windows hosts on FC SANs, TEST_UNIT_READY can return SRB_STATUS_ERROR.
Correctly handle this. Note that there is sufficient sense information to
support scsi error handling even in this case.
Correctly set SRB flags for all valid I/O directions. Some IHV drivers on the
Windows host require this. The host validates the command and SRB flags
prior to passing the command down to native driver stack.
On Azure, we have seen instances of unbounded I/O latencies. To deal with
this issue, implement handler that can reset the timeout. Note that the
host gaurantees that it will respond to each command that has been issued.
[hch: added a better comment explaining the issue]
Based on the negotiated VMBUS protocol version, we adjust the size of the storage
protocol messages. The two sizes we currently handle are pre-win8 and post-win8.
In WS2012 R2, we are negotiating higher VMBUS protocol version than the win8
version. Make adjustments to correctly handle this.
Going forward it is possible that some of the commands that are not currently
implemented will be implemented on future Windows hosts. Even if they are not
implemented, we are told the host will corrrectly handle unsupported
commands (by returning appropriate return code and sense information).
Make command filtering depend on the host version.
Set cmd_per_lun to reflect value supported by the Host.
Hyper-V hosts can support multiple targets and multiple channels and larger number of
LUNs per target. Update the code to reflect this. With this patch we can correctly
enumerate all the paths in a multi-path storage environment.
If the initialization of storvsc fails, the storvsc_device_destroy()
causes NULL pointer dereference.
storvsc_bus_scan()
scsi_scan_target()
__scsi_scan_target()
scsi_probe_and_add_lun(hostdata=NULL)
scsi_alloc_sdev(hostdata=NULL)
sdev->hostdata = hostdata
now the host allocation fails
__scsi_remove_device(sdev)
calls sdev->host->hostt->slave_destroy() ==
storvsc_device_destroy(sdev)
access of sdev->hostdata->request_mempool
Signed-off-by: Ales Novak <alnovak@suse.cz>
Signed-off-by: Thomas Abraham <tabraham@suse.com>
Reviewed-by: Jiri Kosina <jkosina@suse.cz>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
Some host adapters do not pass commands through to the target disk
directly. Instead they provide an emulated target which may or may not
accurately report its capabilities. In some cases the physical device
characteristics are reported even when the host adapter is processing
commands on the device's behalf. This can lead to adapter firmware hangs
or excessive I/O errors.
This patch disables WRITE SAME for devices connected to host adapters
that provide an emulated target. Driver writers can disable WRITE SAME
by setting the no_write_same flag in the host adapter template.
[jejb: fix up rejections due to eh_deadline patch]
Cc: stable@kernel.org
Remove HV_DRV_VERSION, it has no meaning for upstream drivers.
Initially it was supposed to show the "Linux Integration Services"
version, now it is not in sync anymore with the out-of-tree drivers
available from the MSFT website.
The only place where a version string is still required is the KVP
command "IntegrationServicesVersion" which is handled by
tools/hv/hv_kvp_daemon.c. To satisfy such KVP request from the host pass
the current string to the daemon during KVP userland registration.
Signed-off-by: Olaf Hering <olaf@aepfle.de>
Increase the value of STORVSC_MAX_IO_REQUESTS to 200 requests. The current
ringbuffer size can support this higher value.
Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com>
