path: root/drivers/scsi/sun3_NCR5380.c
2011-06-29[SCSI] sun3: Remove commented out merge_contiguous_buffersGeert Uytterhoeven
This fixes: drivers/scsi/sun3_NCR5380.c:475: warning: ‘merge_contiguous_buffers’ defined but not used Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Sam Creasey <sammy@sammy.net> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-06-29[SCSI] sun3: Check for NCR_TIMEOUT being defined instead of having a valueGeert Uytterhoeven
This fixes: drivers/scsi/sun3_NCR5380.c:1448:5: warning: "NCR_TIMEOUT" is not defined Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-06-29[SCSI] sun3: Provide a dummy NCR5380_exit()Geert Uytterhoeven
and call it from sun3scsi_release(), cfr. the other NCR5380 drivers. This fixes: drivers/scsi/NCR5380.h:303: warning: ‘NCR5380_exit’ declared ‘static’ but never defined Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-06-29[SCSI] sun3: sun3scsi_detect() and NCR5380_init() should be __initGeert Uytterhoeven
WARNING: vmlinux.o(.text+0x18545c): Section mismatch in reference from the function sun3scsi_detect() to the function .init.text:NCR5380_print_options() WARNING: vmlinux.o(.text+0x18556c): Section mismatch in reference from the function sun3scsi_detect() to the function .init.text:NCR5380_print_options() WARNING: vmlinux.o(.text+0x187692): Section mismatch in reference from the function sun3scsi_detect() to the function .init.text:NCR5380_print_options() WARNING: vmlinux.o(.text+0x187770): Section mismatch in reference from the function sun3scsi_detect() to the function .init.text:NCR5380_print_options() Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2011-06-29[SCSI] sun3_NCR5380: Split NEXT() for lvalues/rvaluesGeert Uytterhoeven
Using the current NEXT() macro for both lvalues and rvalues gives: In file included from drivers/scsi/sun3_scsi.c:623: drivers/scsi/sun3_NCR5380.c: In function ‘NCR5380_queue_command_lck’: drivers/scsi/sun3_NCR5380.c:993: warning: assignment discards qualifiers from pointer target type drivers/scsi/sun3_NCR5380.c: In function ‘NCR5380_main’: drivers/scsi/sun3_NCR5380.c:1147: warning: assignment discards qualifiers from pointer target type drivers/scsi/sun3_NCR5380.c: In function ‘NCR5380_information_transfer’: drivers/scsi/sun3_NCR5380.c:2277: warning: assignment discards qualifiers from pointer target type drivers/scsi/sun3_NCR5380.c:2333: warning: assignment discards qualifiers from pointer target type Change NEXT() to operate on rvalues only(), and introduce SET_NEXT() to operate on lvalues, as is done in drivers/scsi/atari_NCR5380.c. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2010-11-16SCSI host lock push-downJeff Garzik
Move the mid-layer's ->queuecommand() invocation from being locked with the host lock to being unlocked to facilitate speeding up the critical path for drivers who don't need this lock taken anyway. The patch below presents a simple SCSI host lock push-down as an equivalent transformation. No locking or other behavior should change with this patch. All existing bugs and locking orders are preserved. Additionally, add one parameter to queuecommand, struct Scsi_Host * and remove one parameter from queuecommand, void (*done)(struct scsi_cmnd *) Scsi_Host* is a convenient pointer that most host drivers need anyway, and 'done' is redundant to struct scsi_cmnd->scsi_done. Minimal code disturbance was attempted with this change. Most drivers needed only two one-line modifications for their host lock push-down. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Acked-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-07block: remove wrappers for request type/flagsChristoph Hellwig
Remove all the trivial wrappers for the cmd_type and cmd_flags fields in struct requests. This allows much easier grepping for different request types instead of unwinding through macros. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-07-08Remove multiple KERN_ prefixes from printk formatsJoe Perches
Commit 5fd29d6ccbc98884569d6f3105aeca70858b3e0f ("printk: clean up handling of log-levels and newlines") changed printk semantics. printk lines with multiple KERN_<level> prefixes are no longer emitted as before the patch. <level> is now included in the output on each additional use. Remove all uses of multiple KERN_<level>s in formats. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-11[SCSI] atari_NCR5380, sun3_NCR5380: operator precedence fixRoel Kluin
SR_REQ is defined 0x20, but bitanding has no effect because '!' has a higher priority than '&' Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] NCR5380 family: convert to accessors & !use_sg cleanupBoaz Harrosh
- This patch depends on: NCR5380: Use scsi_eh API for REQUEST_SENSE invocation - convert to accessors and !use_sg cleanup - FIXME: Not sg-chain ready look for ++cmd->SCp.buffer Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James <James.Bottomley@HansenPartnership.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-22[SG] Update drivers to use sg helpersJens Axboe
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-12[SCSI] NCR5380: Use scsi_eh API for REQUEST_SENSE invocationBoaz Harrosh
- Use new scsi_eh_prep/restor_cmnd() for synchronous REQUEST_SENSE invocation. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] Fix mistaken uses of ->doneMatthew Wilcox
All these drivers meant to call ->scsi_done() but got confused. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-12-17[PATCH] m68k trivial build fixesAl Viro
amikbd: missing declaration sun3_NCR5380: more work_struct mess sun3_NCR5380: cast is not an lvalue Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-12-09[PATCH] Sun3 SCSI: Make sun3 scsi drivers compile/work againSam Creasey
Make sun3 scsi drivers compile/work again (though with way too many warnings...) Tested on 3/50, 3/60. Signed-off-by: Sam Creasey <sammy@sammy.net> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-25[SCSI] Scsi_Cmnd convertion in sun3-driverHenne
Change the obsolete Scsi_Cmnd to struct scsi_cmnd in the sun3-driver. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-30[PATCH] Split struct request ->flags into two partsJens Axboe
Right now ->flags is a bit of a mess: some are request types, and others are just modifiers. Clean this up by splitting it into ->cmd_type and ->cmd_flags. This allows introduction of generic Linux block message types, useful for sending generic Linux commands to block devices. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-07-14[SCSI] More buffer->request_buffer changesChristoph Hellwig
Seem like quite a few splipped through the cracks. Here's a patch to update all references I could find: Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-15[SCSI] Rename scsi_print_msg to spi_print_msgMatthew Wilcox
Rename scsi_print_msg to spi_print_msg and move its prototype from scsi_dbg.h to scsi_transport_spi.h Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-09[SCSI] remove Scsi_Host_Template typedefChristoph Hellwig
2005-04-18[PATCH] remove outdated print_* functions
We have the scsi_print_* functions in the proper namespace for a long time now and there weren't a lot users left. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
