path: root/drivers/scsi/wd33c93.c
2010-05-02[SCSI] wd33c93: Kill empty wd33c93_release()Geert Uytterhoeven
wd33c93_release() has been empty since ages, and sgiwd93.c no longer calls it since its conversion to a proper platform driver 2 years ago. Also remove the callers in the m68k wd33c93 shims. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2008-04-07[SCSI] WD33C93: let platform stub override no_sync/fast/dma_modeThomas Bogendoerfer
SGI machines with WD33C93 allow usage of burst mode DMA, which increases performance noticable. To make this selectable by the sgiwd93 stub, setting the values for no_sync, fast and dma_mode has been moved to the individual platform stubs. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] wd33c93: convert to accessors and !use_sg cleanupBoaz Harrosh
- convert to accessors and !use_sg cleanup Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-22[SG] Update drivers to use sg helpersJens Axboe
2007-10-12[SCSI] Remove ->pid field from scsi_cmndMatthew Wilcox
The pid field is a duplicate of the serial_number field and has been scheduled for removal for a long time. A few drivers were still using it, so just change them to use serial_number instead. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-18[SCSI] wd33c93: cleanupsAdrian Bunk
- #include <asm/irq.h> for getting the prototypes of {dis,en}able_irq() - make the needlessly global wd33c93_setup() static Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-02-16[SCSI] wd33c93: Fast SCSI with WD33C93Bpeter fuerst
Attached are patches, which help to utilize more of the WD33C93B SCSI controller's capabilities. 1) Added/changed all the necessary code to enable Burst Mode DMA. Only Single Byte DMA was used before. 2) Added/changed all the necessary code to enable Fast-10 SCSI transfers. 3) The original driver inadvertently used a transfer period of 1000-800ns (the lowest possible transfer rate) for asynchronous data transfers, instead of the (configurable) default period intended for this purpose, if the target responded to a SDTR not with a Reject-message, but with a zero-SDTR. This issue was fixed. Moreover, in case of a Reject the driver used the default-period's initialization-value instead of its (maybe smaller) current value. The missing assignment was added. 4) The driver's commandline- and proc-file-interface was augmented to handle the new options properly. The WD33C93 manual, found at http://www.datasheet.in/datasheet-html/W/D/3/WD33C93B_WesternDigital.pdf.html, was very helpful. Signed-off-by: peter fuerst <post@pfrst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-14[SCSI] More buffer->request_buffer changesChristoph Hellwig
Seem like quite a few splipped through the cracks. Here's a patch to update all references I could find: Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-23[PATCH] m68k: wd33c93: extra delayRoman Zippel
The wd33c93 needs a small delay before a new command can be started. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-10[SCSI] drivers/scsi: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove duplicates of the macro. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-12[SCSI] wd33c93: Fix missing prototypes by including <linux/interrupt.h>.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-12[PATCH] m68k: NULL noise removalAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
