path: root/drivers/scsi/wd719x.c
2016-09-01drivers/scsi/wd719x.c: remove last declaration using DEFINE_PCI_DEVICE_TABLEJoe Perches
Convert it to the preferred const struct pci_device_id instead. Link: http://lkml.kernel.org/r/95c5e4100c3cd4eda643624f5b70e8d7abceb86c.1472660229.git.joe@perches.com Signed-off-by: Joe Perches <joe@perches.com> Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> Cc: "James E.J. Bottomley" <jejb@linux.vnet.ibm.com> Cc: "Martin K. Petersen" <martin.petersen@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-08-07[SCSI] Fix printk typos in drivers/scsiMasanari Iida
This patch fix spme spelling typos in printk within drivers/scsi. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.com>
2015-05-31scsi: Do not set cmd_per_lun to 1 in the host templateHannes Reinecke
'0' is now used as the default cmd_per_lun value, so there's no need to explicitly set it to '1' in the host template. Signed-off-by: Hannes Reinecke <hare@suse.de> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <JBottomley@Odin.com>
2015-02-15wd719x: add missing .module to wd719x_templateOndrej Zary
wd719x_template is missing the .module field, causing module refcount not to work, allowing to rmmod the driver while in use (mounted filesystem), causing an oops. Set .module to THIS_MODULE to fix the problem. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Cc: <stable@vger.kernel.org> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2014-11-27wd719x: remove dma_cache_sync callOndrej Zary
Remove dma_cache_sync call to fix build on other architectures. Driver still works fine on x86 without that. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-11-25wd719x: Introduce Western Digital WD7193/7197/7296 PCI SCSI card driverOndrej Zary
Introduce wd719x, a driver for Western Digital WD7193, WD7197 and WD7296 PCI SCSI controllers based on WD33C296A chip. Tested with WD7193 card. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Christoph Hellwig <hch@lst.de>
