path: root/drivers/scsi/zorro7xx.c
2010-05-17m68k: amiga - Zorro bus modalias supportGeert Uytterhoeven
Add Amiga Zorro bus modalias and uevent support Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2007-11-29m68k: zorro7xx needs <asm/amigahw.h>Geert Uytterhoeven
m68k: zorro7xx needs <asm/amigahw.h> if !CONFIG_AMIGA_PCMCIA Reported by Ingo Juergensmann <ij@2007.bluespice.org> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12[SCSI] kmalloc + memset conversion to kzallocMariusz Kozlowski
In NCR_D700, a4000t, aic7xxx_old, bvme6000, dpt_i2o, gdth, lpfc, megaraid, mvme16x osst, pluto, qla2xxx, zorro7xx Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-18[SCSI] a4000t, zorro7xx, mvme16x, bvme6000,sim710: xxx_device_remove seems buggyMatthew Wilcox
Fix drivers misusing dev_to_shost Some drivers were using dev_to_shost to go from a struct device to the corresponding shost. Unfortunately, dev_to_shost only looks up the tree to find an shost (it's designed to go from a scsi_device or a scsi_target to the parent scsi_host), and these drivers were calling it with the parent of the scsi_host. I've fixed this by saving a pointer to the Scsi_Host in the drvdata, which matches what most scsi drivers do. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-19[SCSI] 53c700: Fixup m68k drivers:Geert Uytterhoeven
- a4000t.c: Add missing include, needed in some configurations - bvme6000_scsi.c: Kill bogus opening brace - zorro7xx.c: Remove MODULE_DEVICE_TABLE, it should be part of another patch Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-17[SCSI] 53c700: Amiga Zorro NCR53c710 SCSIKars de Jong
New driver for Amiga Zorro bus NCR53c710 SCSI controllers, using the 53c700 SCSI core. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
