commit 940f5d47e2f2e1fa00443921a0abf4822335b54d upstream.
When we call scsi_unprep_request() the command associated with the request
gets destroyed and therefore drops its reference on the device. If this was
the only reference, the device may get released and we end up with a NULL
pointer deref when we call blk_requeue_request.
Reported-by: Mike Christie <michaelc@cs.wisc.edu>
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
Reviewed-by: Mike Christie <michaelc@cs.wisc.edu>
Reviewed-by: Tejun Heo <tj@kernel.org>
[jejb: enhance commend and add commit log for stable]
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit 3b661a92e869ebe2358de8f4b3230ad84f7fce51 upstream.
The following crash results from cases where the end_device has been
removed before scsi_sysfs_add_sdev has had a chance to run.
BUG: unable to handle kernel NULL pointer dereference at 0000000000000098
IP: [<ffffffff8115e100>] sysfs_create_dir+0x32/0xb6
Call Trace:
[<ffffffff8125e4a8>] kobject_add_internal+0x120/0x1e3
[<ffffffff81075149>] ? trace_hardirqs_on+0xd/0xf
[<ffffffff8125e641>] kobject_add_varg+0x41/0x50
[<ffffffff8125e70b>] kobject_add+0x64/0x66
[<ffffffff8131122b>] device_add+0x12d/0x63a
[<ffffffff814b65ea>] ? _raw_spin_unlock_irqrestore+0x47/0x56
[<ffffffff8107de15>] ? module_refcount+0x89/0xa0
[<ffffffff8132f348>] scsi_sysfs_add_sdev+0x4e/0x28a
[<ffffffff8132dcbb>] do_scan_async+0x9c/0x145
...teach scsi_sysfs_add_devices() to check for deleted devices() before
trying to add them, and teach scsi_remove_target() how to remove targets
that have not been added via device_add().
Reported-by: Dariusz Majchrzak <dariusz.majchrzak@intel.com>
commit 57fc2e335fd3c2f898ee73570dc81426c28dc7b4 upstream.
Rapid ata hotplug on a libsas controller results in cases where libsas
is waiting indefinitely on eh to perform an ata probe.
A race exists between scsi_schedule_eh() and scsi_restart_operations()
in the case when scsi_restart_operations() issues i/o to other devices
in the sas domain. When this happens the host state transitions from
SHOST_RECOVERY (set by scsi_schedule_eh) back to SHOST_RUNNING and
->host_busy is non-zero so we put the eh thread to sleep even though
->host_eh_scheduled is active.
Before putting the error handler to sleep we need to check if the
host_state needs to return to SHOST_RECOVERY for another trip through
eh. Since i/o that is released by scsi_restart_operations has been
blocked for at least one eh cycle, this implementation allows those
i/o's to run before another eh cycle starts to discourage hung task
timeouts.
Reported-by: Tom Jackson <thomas.p.jackson@intel.com>
Tested-by: Tom Jackson <thomas.p.jackson@intel.com>
commit b17caa174a7e1fd2e17b26e210d4ee91c4c28b37 upstream.
commit 198439e4 [SCSI] libsas: do not set res = 0 in sas_ex_discover_dev()
commit 19252de6 [SCSI] libsas: fix wide port hotplug issues
The above commits seem to have confused the return value of
sas_ex_discover_dev which is non-zero on failure and
sas_ex_join_wide_port which just indicates short circuiting discovery on
already established ports. The result is random discovery failures
depending on configuration.
Calls to sas_ex_join_wide_port are the source of the trouble as its
return value is errantly assigned to 'res'. Convert it to bool and stop
returning its result up the stack.
Tested-by: Dan Melnic <dan.melnic@amd.com>
Reported-by: Dan Melnic <dan.melnic@amd.com>
Reviewed-by: Jack Wang <jack_wang@usish.com>
commit 26f2f199ff150d8876b2641c41e60d1c92d2fb81 upstream.
Continue running revalidation until no more broadcast devices are
discovered. Fixes cases where re-discovery completes too early in a
domain with multiple expanders with pending re-discovery events.
Servicing BCNs can get backed up behind error recovery.
commit b7e94a1686c5daef4f649f7f4f839cc294f07710 upstream.
block congestion control doesn't have any concept of fairness across
multiple queues. This means that if SCSI reports the host as busy in
the queue congestion control it can result in an unfair starvation
situation in dm-mp if there are multiple multipath devices on the same
host. For example:
http://www.redhat.com/archives/dm-devel/2012-May/msg00123.html
The fix for this is to report only the sdev busy state (and ignore the
host busy state) in the block congestion control call back.
The host is still congested, but the SCSI subsystem will sort out the
congestion in a fair way because it knows the relation between the
queues and the host.
[jejb: fixed up trailing whitespace]
Reported-by: Bernd Schubert <bernd.schubert@itwm.fraunhofer.de>
Tested-by: Bernd Schubert <bernd.schubert@itwm.fraunhofer.de>
Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
commit 1ff2f40305772b159a91c19590ee159d3a504afc upstream.
Commit c751085943362143f84346d274e0011419c84202
Author: Rafael J. Wysocki <rjw@sisk.pl>
Date: Sun Apr 12 20:06:56 2009 +0200
PM/Hibernate: Wait for SCSI devices scan to complete during resume
Broke the scsi_wait_scan module in 2.6.30. Apparently debian still uses it so
fix it and backport to stable before removing it in 3.6.
The breakage is caused because the function template in
include/scsi/scsi_scan.h is defined to be a nop unless SCSI is built in.
That means that in the modular case (which is every distro), the
scsi_wait_scan module does a simple async_synchronize_full() instead of
waiting for scans.
commit fc25f79af321c01a739150ba2c09435cf977a63d upstream.
OEM parameters [1] are parsed from the platform option-rom / efi
driver. By default the driver was validating the parameters for the
dual-controller case, but in single-controller case only the first set
of parameters may be valid.
Limit the validation to the number of actual controllers detected
otherwise the driver may fail to parse the valid parameters leading to
driver-load or runtime failures.
[1] the platform specific set of phy address, configuration,and analog
tuning values
Reported-by: Dave Jiang <dave.jiang@intel.com>
Tested-by: Dave Jiang <dave.jiang@intel.com>
[bwh: Backported to 3.2: adjust context]
commit 9bc3711cbb67ac620bf09b4a147cbab45b2c36c0 upstream.
Upgraded firmware on Smart Array P7xx (and some others) made them show up as
SCSI revision 5 devices and this caused the driver to fail to map MSA2xxx
logical drives to the correct bus/target/lun. A symptom of this would be that
the target ID of the logical drives as presented by the external storage array
is ignored, and all such logical drives are assigned to target zero,
differentiated only by LUN. Some multipath software reportedly does not deal
well with this behavior, failing to recognize different paths to the same
device as such.
Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com>
Signed-off-by: Scott Teel <scott.teel@hp.com>
Cc: Jonathan Nieder <jrnieder@gmail.com>
commit e42fafc25fa86c61824e8d4c5e7582316415d24f upstream.
The ioc->pfacts member in the IOC structure is getting set to zero
following a call to _base_get_ioc_facts due to the memset in that routine.
So if the ioc->pfacts was read after a host reset, there would be a NULL
pointer dereference. The routine _base_get_ioc_facts is called from context
of host reset. The problem in _base_get_ioc_facts is the size of
Mpi2IOCFactsReply is 64, whereas the sizeof "struct mpt2sas_facts" is 60,
so there is a four byte overflow resulting from the memset.
Also, there is memset in _base_get_port_facts using the incorrect structure,
it should be "struct mpt2sas_port_facts" instead of Mpi2PortFactsReply.
Signed-off-by: Nagalakshmi Nandigama <nagalakshmi.nandigama@lsi.com>
commit 45bcf018d1a4779d592764ef57517c92589d55d7 upstream.
IRQF_SHARED is required for older controllers that don't support MSI(X)
and which may end up sharing an interrupt. All the controllers hpsa
normally supports have MSI(X) capability, but older controllers may be
encountered via the hpsa_allow_any=1 module parameter.
Also remove deprecated IRQF_DISABLED.
commit 7d1d865181185bdf1316d236b1b4bd02c9020729 upstream.
Normalize phy->attached_sas_addr to return a zero-address in the case
when device-type == NO_DEVICE or the linkrate is invalid to handle
expanders that put non-zero sas addresses in the discovery response:
sas: ex 5001b4da000f903f phy02:U:0 attached: 0100000000000000 (no device)
sas: ex 5001b4da000f903f phy01:U:0 attached: 0100000000000000 (no device)
sas: ex 5001b4da000f903f phy03:U:0 attached: 0100000000000000 (no device)
sas: ex 5001b4da000f903f phy00:U:0 attached: 0100000000000000 (no device)
Reported-by: Andrzej Jakowski <andrzej.jakowski@intel.com>
commit 1699490db339e2c6b3037ea8e7dcd6b2755b688e upstream.
If an expander reports 'PHY VACANT' for a phy index prior to the one
that generated a BCN libsas fails rediscovery. Since a vacant phy is
defined as a valid phy index that will never have an attached device
just continue the search.
Signed-off-by: Thomas Jackson <thomas.p.jackson@intel.com>
commit 41f8ad76362e7aefe3a03949c43e23102dae6e0b upstream.
It used to be that minors where 8 bit. But now they
are actually 20 bit. So the fix is simplicity itself.
I've tested with 300 devices and all user-mode utils
work just fine. I have also mechanically added 10,000
to the ida (so devices are /dev/osd10000, /dev/osd10001 ...)
and was able to mkfs an exofs filesystem and access osds
from user-mode.
All the open-osd user-mode code uses the same library
to access devices through their symbolic names in
/dev/osdX so I'd say it's pretty safe. (Well tested)
This patch is very important because some of the systems
that will be deploying the 3.2 pnfs-objects code are larger
than 64 OSDs and will stop to work properly when reaching
that number.
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
commit fea6d607e154cf96ab22254ccb48addfd43d4cb5 upstream.
This patch (as1520) fixes a bug in the SCSI layer's power management
implementation.
LUN scanning can be carried out asynchronously in do_scan_async(), and
sd uses an asynchronous thread for the time-consuming parts of disk
probing in sd_probe_async(). Currently nothing coordinates these
async threads with system sleep transitions; they can and do attempt
to continue scanning/probing SCSI devices even after the host adapter
has been suspended. As one might expect, the outcome is not ideal.
This is what the "prepare" stage of system suspend was created for.
After the prepare callback has been called for a host, target, or
device, drivers are not allowed to register any children underneath
them. Currently the SCSI prepare callback is not implemented; this
patch rectifies that omission.
For SCSI hosts, the prepare routine calls scsi_complete_async_scans()
to wait until async scanning is finished. It might be slightly more
efficient to wait only until the host in question has been scanned,
but there's currently no way to do that. Besides, during a sleep
transition we will ultimately have to wait until all the host scanning
has finished anyway.
For SCSI devices, the prepare routine calls async_synchronize_full()
to wait until sd probing is finished. The routine does nothing for
SCSI targets, because asynchronous target scanning is done only as
part of host scanning.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
commit 267a6ad4aefaafbde607804c60945bcf97f91c1b upstream.
In do_scan_async(), calling scsi_autopm_put_host(shost) may reference
freed shost, and cause Posison overwitten warning.
Yes, this case can happen, for example, an USB is disconnected just
when do_scan_async() thread starts to run, then scsi_host_put() called
in scsi_finish_async_scan() will lead to shost be freed(because the
refcount of shost->shost_gendev decreases to 1 after USB disconnects),
at this point, if references shost again, system will show following
warning msg.
To make scsi_autopm_put_host(shost) always reference a valid shost,
put it just before scsi_host_put() in function
scsi_finish_async_scan().
[ 299.281565] =============================================================================
[ 299.281634] BUG kmalloc-4096 (Tainted: G I ): Poison overwritten
[ 299.281682] -----------------------------------------------------------------------------
[ 299.281684]
[ 299.281752] INFO: 0xffff880056c305d0-0xffff880056c305d0. First byte
0x6a instead of 0x6b
[ 299.281816] INFO: Allocated in scsi_host_alloc+0x4a/0x490 age=1688
cpu=1 pid=2004
[ 299.281870] __slab_alloc+0x617/0x6c1
[ 299.281901] __kmalloc+0x28c/0x2e0
[ 299.281931] scsi_host_alloc+0x4a/0x490
[ 299.281966] usb_stor_probe1+0x5b/0xc40 [usb_storage]
[ 299.282010] storage_probe+0xa4/0xe0 [usb_storage]
[ 299.282062] usb_probe_interface+0x172/0x330 [usbcore]
[ 299.282105] driver_probe_device+0x257/0x3b0
[ 299.282138] __driver_attach+0x103/0x110
[ 299.282171] bus_for_each_dev+0x8e/0xe0
[ 299.282201] driver_attach+0x26/0x30
[ 299.282230] bus_add_driver+0x1c4/0x430
[ 299.282260] driver_register+0xb6/0x230
[ 299.282298] usb_register_driver+0xe5/0x270 [usbcore]
[ 299.282337] 0xffffffffa04ab03d
[ 299.282364] do_one_initcall+0x47/0x230
[ 299.282396] sys_init_module+0xa0f/0x1fe0
[ 299.282429] INFO: Freed in scsi_host_dev_release+0x18a/0x1d0 age=85
cpu=0 pid=2008
[ 299.282482] __slab_free+0x3c/0x2a1
[ 299.282510] kfree+0x296/0x310
[ 299.282536] scsi_host_dev_release+0x18a/0x1d0
[ 299.282574] device_release+0x74/0x100
[ 299.282606] kobject_release+0xc7/0x2a0
[ 299.282637] kobject_put+0x54/0xa0
[ 299.282668] put_device+0x27/0x40
[ 299.282694] scsi_host_put+0x1d/0x30
[ 299.282723] do_scan_async+0x1fc/0x2b0
[ 299.282753] kthread+0xdf/0xf0
[ 299.282782] kernel_thread_helper+0x4/0x10
[ 299.282817] INFO: Slab 0xffffea00015b0c00 objects=7 used=7 fp=0x
(null) flags=0x100000000004080
[ 299.282882] INFO: Object 0xffff880056c30000 @offset=0 fp=0x (null)
[ 299.282884]
Signed-off-by: Huajun Li <huajun.li.lee@gmail.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
[ Upstream commit d3aaeb38c40e5a6c08dd31a1b64da65c4352be36, along
with dependent backports of commits:
69cce1d1404968f78b177a0314f5822d5afdbbfb
9de79c127cccecb11ae6a21ab1499e87aa222880
218fa90f072e4aeff9003d57e390857f4f35513e
580da35a31f91a594f3090b7a2c39b85cb051a12
f7e57044eeb1841847c24aa06766c8290c202583
e049f28883126c689cf95859480d9ee4ab23b7fa ]
Gergely Kalman reported crashes in check_peer_redir().
It appears commit f39925dbde778 (ipv4: Cache learned redirect
information in inetpeer.) added a race, leading to possible NULL ptr
dereference.
Since we can now change dst neighbour, we should make sure a reader can
safely use a neighbour.
Add RCU protection to dst neighbour, and make sure check_peer_redir()
can be called safely by different cpus in parallel.
As neighbours are already freed after one RCU grace period, this patch
should not add typical RCU penalty (cache cold effects)
Many thanks to Gergely for providing a pretty report pointing to the
bug.
Reported-by: Gergely Kalman <synapse@hippy.csoma.elte.hu>
commit cced5041ed5a2d1352186510944b0ddfbdbe4c0b upstream.
sym53c8xx_slave_destroy unconditionally assumes that sym53c8xx_slave_alloc has
succesesfully allocated a sym_lcb. This can lead to a NULL pointer dereference
(exposed by commit 4e6c82b).
Signed-off-by: Stratos Psomadakis <psomas@gentoo.org>
commit 0bfc96cb77224736dfa35c3c555d37b3646ef35e upstream.
[ Changes with respect to 3.3: return -ENOTTY from scsi_verify_blk_ioctl
and -ENOIOCTLCMD from sd_compat_ioctl. ]
Linux allows executing the SG_IO ioctl on a partition or LVM volume, and
will pass the command to the underlying block device. This is
well-known, but it is also a large security problem when (via Unix
permissions, ACLs, SELinux or a combination thereof) a program or user
needs to be granted access only to part of the disk.
This patch lets partitions forward a small set of harmless ioctls;
others are logged with printk so that we can see which ioctls are
actually sent. In my tests only CDROM_GET_CAPABILITY actually occurred.
Of course it was being sent to a (partition on a) hard disk, so it would
have failed with ENOTTY and the patch isn't changing anything in
practice. Still, I'm treating it specially to avoid spamming the logs.
In principle, this restriction should include programs running with
CAP_SYS_RAWIO. If for example I let a program access /dev/sda2 and
/dev/sdb, it still should not be able to read/write outside the
boundaries of /dev/sda2 independent of the capabilities. However, for
now programs with CAP_SYS_RAWIO will still be allowed to send the
ioctls. Their actions will still be logged.
This patch does not affect the non-libata IDE driver. That driver
however already tests for bd != bd->bd_contains before issuing some
ioctl; it could be restricted further to forbid these ioctls even for
programs running with CAP_SYS_ADMIN/CAP_SYS_RAWIO.
Cc: linux-scsi@vger.kernel.org
Cc: James Bottomley <JBottomley@parallels.com>
[ Make it also print the command name when warning - Linus ]
commit 577ebb374c78314ac4617242f509e2f5e7156649 upstream.
Introduce a wrapper around scsi_cmd_ioctl that takes a block device.
The function will then be enhanced to detect partition block devices
and, in that case, subject the ioctls to whitelisting.
commit aff132d95ffe14eca96cab90597cdd010b457af7 upstream.
The amount of memory required for tracking chain buffers is rather
large, and when the host credit count is big, memory allocation
failure occurs inside __get_free_pages.
The fix is to limit the number of chains to 100,000. In addition,
the number of host credits is limited to 30,000 IOs. However this
limitation can be overridden this using the command line option
max_queue_depth. The algorithm for calculating the
reply_post_queue_depth is changed so that it is equal to
(reply_free_queue_depth + 16), previously it was (reply_free_queue_depth * 2).
commit 30c43282f3d347f47f9e05199d2b14f56f3f2837 upstream.
Added code to release the spinlock that is used to protect the
raid device list before calling a function that can block. The
blocking was causing a reschedule, and subsequently it is tried
to acquire the same lock, resulting in a panic (NMI Watchdog
detecting a CPU lockup).
commit 9ae89b0296e275d5a556068b40b7c2557a556a85 upstream.
mpt2sas_base_detach() call was removed from _scsih_remove() while
doing some code shuffling. Mainly when we work on adding code for
scsih_shutdown(). I have added back mpt2sas_base_detach() which will
get callled from _scsih_remove().
Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com>
Upstrem commit: 911ae9434f83e7355d343f6c2be3ef5b00ea7aed
There's a bug in the MSIX backup and restore routines that cause a crash on
non-x86 (direct access to PCI space not via read/write). These routines are
unnecessary and were removed by the above commit, so also remove them from
stable to fix the crash.
commit 7e1e7ead88dff75b11b86ee0d5232c4591be1326 upstream.
The error exit path leaks preempt count. Add the missing put_cpu().
Reviewed-by: Yi Zou <yi.zou@intel.com>
commit f6a290b419a2675c4b77a6b0731cd2a64332365e upstream.
_scsih_smart_predicted_fault is called in an interrupt and therefore
must allocate memory using GFP_ATOMIC.
commit 745718132c3c7cac98a622b610e239dcd5217f71 upstream.
When we tear down a device we try to flush all outstanding
commands in scsi_free_queue(). However the check in
scsi_request_fn() is imperfect as it only signals that
we _might start_ aborting commands, not that we've actually
aborted some.
So move the printk inside the scsi_kill_request function,
this will also give us a hint about which commands are aborted.
Signed-off-by: Hannes Reinecke <hare@suse.de>
Cc: Christoph Biedl <linux-kernel.bfrz@manchmal.in-ulm.de>
commit cf16123c9c8e346ed1dd171295a678d77648d7f8 upstream.
Aacraid controller can hang on some nodes if kernel uses non-default
(powersave) ASPM policy. Controller hangs shortly after successful load and
hardware detection. Scsi error handler detects this hang and tries to restart
hardware but it does not help.
Initially it was noticed on RHEL6-based openVZ kernel after backporting
aacraid driver from mainline (RHEL6 kernel with original driver works well)
http://bugzilla.openvz.org/show_bug.cgi?id=2043
This issue happens because default ASPM policy was changed in Red Hat
kernels. Therefore guys from Red Hat have noticed this problem long time ago:
on Fedora 12
https://bugzilla.redhat.com/show_bug.cgi?id=540478
on Fedora 14
https://bugzilla.redhat.com/show_bug.cgi?id=679385
In RHEL6 kernel this issue was fixed, ASPM was disabled in aacraid driver. In
kernel changelog I've found that seems it was done by Matthew Garrett: -
[scsi] aacraid: Disable ASPM by default (Matthew Garrett) [599735]
However seems this patch was not submitted to mainline. I've reproduced this
issue on vanilla 3.1.0 kernel booted with "pcie_aspm.policy=powersave" option,
So I believe it makes sense to do it now.
Signed-off-by: Vasily Averin <vvs@sw.ru>
[mjg: Checking the Windows drivers indicates that they disable ASPM under all
circumstances, so:]
Acked-by: Matthew Garrett <mjg@redhat.com>
Acked-by: Achim Leubner <Achim_Leubner@pmc-sierra.com>
commit e5a44df85e8d78e5c2d3d2e4f59b460905691e2f upstream.
The Windows driver .inf disables ASPM on hpsa devices. Do the same because the
selection of a non default ASPM policy can cause the device to hang.
Acked-by: Mike Miller <mike.miller@hp.com>
commit 4e6c82b3614a18740ef63109d58743a359266daf upstream.
On Mon, 2011-11-07 at 17:24 +1100, Stephen Rothwell wrote:
> Hi all,
> Starting some time last week I am getting the following during boot on
> our PPC970 blade:
> calling .ipr_init+0x0/0x68 @ 1
> ipr: IBM Power RAID SCSI Device Driver version: 2.5.2 (April 27, 2011)
> ipr 0000:01:01.0: Found IOA with IRQ: 26
> ipr 0000:01:01.0: Starting IOA initialization sequence.
> ipr 0000:01:01.0: Adapter firmware version: 06160039
> ipr 0000:01:01.0: IOA initialized.
> scsi0 : IBM 572E Storage Adapter
> ------------[ cut here ]------------
> WARNING: at drivers/scsi/scsi_lib.c:1704
> Modules linked in:
> NIP: c00000000053b3d4 LR: c00000000053e5b0 CTR: c000000000541d70
> REGS: c0000000783c2f60 TRAP: 0700 Not tainted (3.1.0-autokern1)
> MSR: 8000000000029032 <EE,ME,CE,IR,DR> CR: 24002024 XER: 20000002
> TASK = c0000000783b8000[1] 'swapper' THREAD: c0000000783c0000 CPU: 0
> GPR00: 0000000000000001 c0000000783c31e0 c000000000cf38b0 c00000000239a9d0
> GPR04: c000000000cbe8f8 0000000000000000 c0000000783c3040 0000000000000000
> GPR08: c000000075daf488 c000000078a3b7ff c000000000bcacc8 0000000000000000
> GPR12: 0000000044002028 c000000007ffb000 0000000002e40000 000000000099b800
> GPR16: 0000000000000000 c000000000bba5fc c000000000a61db8 0000000000000000
> GPR20: 0000000001b77200 0000000000000000 c000000078990000 0000000000000001
> GPR24: c000000002396828 0000000000000000 0000000000000000 c000000078a3b938
> GPR28: fffffffffffffffa c0000000008ad2c0 c000000000c7faa8 c00000000239a9d0
> NIP [c00000000053b3d4] .scsi_free_queue+0x24/0x90
> LR [c00000000053e5b0] .scsi_alloc_sdev+0x280/0x2e0
> Call Trace:
> [c0000000783c31e0] [c000000000c7faa8] wireless_seq_fops+0x278d0/0x2eb88 (unreliable)
> [c0000000783c3270] [c00000000053e5b0] .scsi_alloc_sdev+0x280/0x2e0
> [c0000000783c3330] [c00000000053eba0] .scsi_probe_and_add_lun+0x390/0xb40
> [c0000000783c34a0] [c00000000053f7ec] .__scsi_scan_target+0x16c/0x650
> [c0000000783c35f0] [c00000000053fd90] .scsi_scan_channel+0xc0/0x100
> [c0000000783c36a0] [c00000000053fefc] .scsi_scan_host_selected+0x12c/0x1c0
> [c0000000783c3750] [c00000000083dcb4] .ipr_probe+0x2c0/0x390
> [c0000000783c3830] [c0000000003f50b4] .local_pci_probe+0x34/0x50
> [c0000000783c38a0] [c0000000003f5f78] .pci_device_probe+0x148/0x150
> [c0000000783c3950] [c0000000004e1e8c] .driver_probe_device+0xdc/0x210
> [c0000000783c39f0] [c0000000004e20cc] .__driver_attach+0x10c/0x110
> [c0000000783c3a80] [c0000000004e1228] .bus_for_each_dev+0x98/0xf0
> [c0000000783c3b30] [c0000000004e1bf8] .driver_attach+0x28/0x40
> [c0000000783c3bb0] [c0000000004e07d8] .bus_add_driver+0x218/0x340
> [c0000000783c3c60] [c0000000004e2a2c] .driver_register+0x9c/0x1b0
> [c0000000783c3d00] [c0000000003f62d4] .__pci_register_driver+0x64/0x140
> [c0000000783c3da0] [c000000000b99f88] .ipr_init+0x4c/0x68
> [c0000000783c3e20] [c00000000000ad24] .do_one_initcall+0x1a4/0x1e0
> [c0000000783c3ee0] [c000000000b512d0] .kernel_init+0x14c/0x1fc
> [c0000000783c3f90] [c000000000022468] .kernel_thread+0x54/0x70
> Instruction dump:
> ebe1fff8 7c0803a6 4e800020 7c0802a6 fba1ffe8 fbe1fff8 7c7f1b78 f8010010
> f821ff71 e8030398 3120ffff 7c090110 <0b000000> e86303b0 482de065 60000000
> ---[ end trace 759bed76a85e8dec ]---
> scsi 0:0:1:0: Direct-Access IBM-ESXS MAY2036RC T106 PQ: 0 ANSI: 5
> I get lots more of these. The obvious commit to point the finger at
> is 3308511c93e6 ("[SCSI] Make scsi_free_queue() kill pending SCSI
> commands") but the root cause may be something different.
Caused by
commit f7c9c6bb14f3104608a3a83cadea10a6943d2804
Author: Anton Blanchard <anton@samba.org>
Date: Thu Nov 3 08:56:22 2011 +1100
[SCSI] Fix block queue and elevator memory leak in scsi_alloc_sdev
Doesn't completely do the teardown. The true fix is to do a proper
teardown instead of hand rolling it
Tested-by: Stephen Rothwell <sfr@canb.auug.org.au>
commit c4853efec665134b2e6fc9c13447323240980351 upstream.
The P600 requires a small delay when changing states. Otherwise we may think
the board did not reset and we bail. This for kdump only and is particular
to the P600.
Signed-off-by: Mike Miller <mike.miller@hp.com>
commit 0167ac67ff6f35bf2364f7672c8012b0cd40277f upstream.
Fix for issue : While discovery is in progress, hot unplug and hot plug of
enclosure connected to the controller card is causing system to hang.
When a device is in the process of being detected at driver load time then
if it is removed, the device that is no longer present will not be added
to the list. So the code in _scsih_probe_sas() is rearranged as such so
the devices that failed to be detected are not added to the list.
commit f7c9c6bb14f3104608a3a83cadea10a6943d2804 upstream.
When looking at memory consumption issues I noticed quite a
lot of memory in the kmalloc-2048 bucket:
OBJS ACTIVE USE OBJ SIZE SLABS OBJ/SLAB CACHE SIZE NAME
6561 6471 98% 2.30K 243 27 15552K kmalloc-2048
Over 15MB. slub debug shows that cfq is responsible for almost
all of it:
# sort -nr /sys/kernel/slab/kmalloc-2048/alloc_calls
6402 .cfq_init_queue+0xec/0x460 age=43423/43564/43655 pid=1 cpus=4,11,13
In scsi_alloc_sdev we do scsi_alloc_queue but if slave_alloc
fails we don't free it with scsi_free_queue.
The patch below fixes the issue:
135 72 53% 2.30K 5 27 320K kmalloc-2048
# cat /sys/kernel/slab/kmalloc-2048/alloc_calls
3 .cfq_init_queue+0xec/0x460 age=3811/3876/3925 pid=1 cpus=4,11,13
commit 3308511c93e6ad0d3c58984ecd6e5e57f96b12c8 upstream.
Make sure that SCSI device removal via scsi_remove_host() does finish
all pending SCSI commands. Currently that's not the case and hence
removal of a SCSI host during I/O can cause a deadlock. See also
"blkdev_issue_discard() hangs forever if underlying storage device is
removed" (http://bugzilla.kernel.org/show_bug.cgi?id=40472). See also
http://lkml.org/lkml/2011/8/27/6.
commit a18a920c70d48a8e4a2b750d8a183b3c1a4be514 upstream.
This patch validates sdev pointer in scsi_dh_activate before proceeding further.
Without this check we might see the panic as below. I have seen this
panic multiple times..
Call trace:
#0 [ffff88007d647b50] machine_kexec at ffffffff81020902
#1 [ffff88007d647ba0] crash_kexec at ffffffff810875b0
#2 [ffff88007d647c70] oops_end at ffffffff8139c650
#3 [ffff88007d647c90] __bad_area_nosemaphore at ffffffff8102dd15
#4 [ffff88007d647d50] page_fault at ffffffff8139b8cf
[exception RIP: scsi_dh_activate+0x82]
RIP: ffffffffa0041922 RSP: ffff88007d647e00 RFLAGS: 00010046
RAX: 0000000000000000 RBX: 0000000000000000 RCX: 00000000000093c5
RDX: 00000000000093c5 RSI: ffffffffa02e6640 RDI: ffff88007cc88988
RBP: 000000000000000f R8: ffff88007d646000 R9: 0000000000000000
R10: ffff880082293790 R11: 00000000ffffffff R12: ffff88007cc88988
R13: 0000000000000000 R14: 0000000000000286 R15: ffff880037b845e0
ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0000
#5 [ffff88007d647e38] run_workqueue at ffffffff81060268
#6 [ffff88007d647e78] worker_thread at ffffffff81060386
#7 [ffff88007d647ee8] kthread at ffffffff81064436
#8 [ffff88007d647f48] kernel_thread at ffffffff81003fba
Signed-off-by: Babu Moger <babu.moger@netapp.com>
commit c68bf8eeaa57c852e74adcf597237be149eef830 upstream.
The call to complete() in st_scsi_execute_end() wakes up sleeping thread
in write_behind_check(), which frees the st_request, thus invalidating
the pointer to the associated bio structure, which is then passed to the
blk_rq_unmap_user(). Fix by storing pointer to bio structure into
temporary local variable.
This bug is present since at least linux-2.6.32.
Signed-off-by: Petr Uzel <petr.uzel@suse.cz>
Reported-by: Juergen Groß <juergen.gross@ts.fujitsu.com>
Acked-by: Kai Mäkisara <kai.makisara@kolumbus.fi>
commit 983d3fdd332742167d0482c06fd29cf4b8a687c0 upstream.
Needed to jump to scic_lock unlock.
Also spotted by coccicheck.
Signed-off-by: Jeff Skirvin <jeffrey.d.skirvin@intel.com>
commit 54b5e3a4bfa3452bc10cd4da672099ccc46b8c09 upstream.
Kill the local smp response buffer.
Besides being unnecessary, it is too small (currently truncates
responses to 60 bytes). The mid-layer will have already allocated a
sufficiently sized buffer, just kmap and copy into it directly.
Reported-by: Derick Marks <derick.w.marks@intel.com>
Tested-by: Derick Marks <derick.w.marks@intel.com>
commit bb041a0e9c31229071b6e56e1d0d8374af0d2038 upstream.
Libsas forget to set the sas_address and device type of rphy lead to file
under /sys/class/sas_x show wrong value, fix that.
Signed-off-by: Jack Wang <jack_wang@usish.com>
Tested-by: Crystal Yu <crystal_yu@usish.com>
commit 5d7c20b7fa5c6ca19e871b4050e321c99d32bd43 upstream.
During kdump testing I noticed timeouts when initialising each IPR
adapter. While the driver has logic to detect an adapter in an
indeterminate state, it wasn't triggering and each adapter went
through a 5 minute timeout before finally going operational.
Some analysis showed the needs_hard_reset flag wasn't getting set.
We can check the reset_devices kernel parameter which is set by
kdump and force a full reset. This fixes the problem.
Acked-by: Brian King <brking@linux.vnet.ibm.com>
commit f575c5d3ebdca3b0482847d8fcba971767754a9e upstream.
The following patch for megaraid_sas will fix a potential bad pointer access
in megasas_reset_timer(), when a MegaRAID 9265/9285 or 9360/9380 gets a
timeout. megasas_build_io_fusion() sets SCp.ptr to be a struct
megasas_cmd_fusion *, but then megasas_reset_timer() was casting SCp.ptr to be
a struct megasas_cmd *, then trying to access cmd->instance, which is invalid.
Just loading instance from scmd->device->host->hostdata in
megasas_reset_timer() fixes the issue.
Signed-off-by: Adam Radford <aradford@gmail.com>
commit a73914c35b05d80f8ce78288e10056c91090b666 upstream.
When a wide port is being utilized to a target, if one disables only one
of the
phys, we get an OS crash:
0000000000000238
IP: [<ffffffff814ca9b1>] mutex_lock+0x21/0x50
PGD 4103f5067 PUD 41dba9067 PMD 0
Oops: 0002 [#1] SMP
last sysfs file: /sys/bus/pci/slots/5/address
CPU 0
Modules linked in: pm8001(U) ses enclosure fuse nfsd exportfs autofs4
ipmi_devintf ipmi_si ipmi_msghandler nfs lockd fscache nfs_acl
auth_rpcgss 8021q fcoe libfcoe garp libfc scsi_transport_fc stp scsi_tgt
llc sunrpc cpufreq_ondemand acpi_cpufreq freq_table ipv6 sr_mod cdrom
dm_mirror dm_region_hash dm_log uinput sg i2c_i801 i2c_core iTCO_wdt
iTCO_vendor_support e1000e mlx4_ib ib_mad ib_core mlx4_en mlx4_core ext3
jbd mbcache sd_mod crc_t10dif usb_storage ata_generic pata_acpi ata_piix
libsas(U) scsi_transport_sas dm_mod [last unloaded: pm8001]
Pid: 5146, comm: scsi_wq_5 Not tainted
2.6.32-71.29.1.el6.lustre.7.x86_64 #1 Storage Server
RIP: 0010:[<ffffffff814ca9b1>] [<ffffffff814ca9b1>]
RSP: 0018:ffff8803e4e33d30 EFLAGS: 00010246
RAX: 0000000000000000 RBX: 0000000000000238 RCX: 0000000000000000
RDX: 0000000000000000 RSI: ffff8803e664c800 RDI: 0000000000000238
RBP: ffff8803e4e33d40 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000001 R12: 0000000000000000
R13: 0000000000000238 R14: ffff88041acb7200 R15: ffff88041c51ada0
FS: 0000000000000000(0000) GS:ffff880028200000(0000)
knlGS:0000000000000000
CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b
CR2: 0000000000000238 CR3: 0000000410143000 CR4: 00000000000006f0
Process scsi_wq_5 (pid: 5146, threadinfo ffff8803e4e32000, task
ffff8803e4e294a0)
Stack:
ffff8803e664c800 0000000000000000 ffff8803e4e33d70 ffffffffa001f06e
<0> ffff8803e4e33d60 ffff88041c51ada0 ffff88041acb7200 ffff88041bc0aa00
<0> ffff8803e4e33d90 ffffffffa0032b6c 0000000000000014 ffff88041acb7200
Call Trace:
[<ffffffffa001f06e>] sas_port_delete_phy+0x2e/0xa0 [scsi_transport_sas]
[<ffffffffa0032b6c>] sas_unregister_devs_sas_addr+0xac/0xe0 [libsas]
[<ffffffffa0034914>] sas_ex_revalidate_domain+0x204/0x330 [libsas]
[<ffffffffa00307f0>] ? sas_revalidate_domain+0x0/0x90 [libsas]
[<ffffffffa0030855>] sas_revalidate_domain+0x65/0x90 [libsas]
[<ffffffff8108c7d0>] worker_thread+0x170/0x2a0
[<ffffffff81091ea0>] ? autoremove_wake_function+0x0/0x40
[<ffffffff8108c660>] ? worker_thread+0x0/0x2a0
[<ffffffff81091b36>] kthread+0x96/0xa0
[<ffffffff810141ca>] child_rip+0xa/0x20
[<ffffffff81091aa0>] ? kthread+0x0/0xa0
[<ffffffff810141c0>] ? child_rip+0x0/0x20
Code: ff ff 85 c0 75 ed eb d6 66 90 55 48 89 e5 48 83 ec 10 48 89 1c 24
4c 89 64 24 08 0f 1f 44 00 00 48 89 fb e8 92 f4 ff ff 48 89 df <f0> ff
0f 79 05 e8 25 00 00 00 65 48 8b 04 25 08 cc 00 00 48 2d
RIP [<ffffffff814ca9b1>] mutex_lock+0x21/0x50
RSP <ffff8803e4e33d30>
The following patch is admittedly a band-aid, and does not solve the
root cause, but it still is a good candidate for hardening as a pointer
check before reference.
Signed-off-by: Mark Salyzyn <mark_salyzyn@us.xyratex.com>
Tested-by: Jack Wang <jack_wang@usish.com>
commit 9bfacd01dc9b7519e1e6da12b01963550b9d09a2 upstream.
I hit a crash in qla2x00_abort_all_cmds() if the qla2xxx module is
unloaded right after it is loaded. I debugged this down to the abort
handling improperly treating a command of type SRB_ADISC_CMD as if it
had a bsg_job to complete when that command actually uses the iocb_cmd
part of the union. (I guess to hit this one has to unload the module
while the async FC initialization is still in progress)
It seems we should only look for a bsg_job if type is SRB_ELS_CMD_RPT,
SRB_ELS_CMD_HST or SRB_CT_CMD, so switch the test to make that explicit.
Signed-off-by: Roland Dreier <roland@purestorage.com>
Acked-by: Chad Dupuis <chad.dupuis@qlogic.com>
commit 3538a001ea7db13fa1be2966b71f69d808acff01 upstream.
qla4xxx driver needs to be linked with libiscsi.o to fix
build errors. This happens when no other drivers that use
libiscsi.o are enabled.
ERROR: "iscsi_conn_stop" [drivers/scsi/qla4xxx/qla4xxx.ko] undefined!
ERROR: "iscsi_conn_get_addr_param" [drivers/scsi/qla4xxx/qla4xxx.ko] undefined!
ERROR: "iscsi_session_teardown" [drivers/scsi/qla4xxx/qla4xxx.ko] undefined!
ERROR: "iscsi_host_alloc" [drivers/scsi/qla4xxx/qla4xxx.ko] undefined!
ERROR: "iscsi_conn_start" [drivers/scsi/qla4xxx/qla4xxx.ko] undefined!
ERROR: "iscsi_conn_send_pdu" [drivers/scsi/qla4xxx/qla4xxx.ko] undefined!
ERROR: "iscsi_session_get_param" [drivers/scsi/qla4xxx/qla4xxx.ko] undefined!
ERROR: "iscsi_conn_get_param" [drivers/scsi/qla4xxx/qla4xxx.ko] undefined!
ERROR: "iscsi_set_param" [drivers/scsi/qla4xxx/qla4xxx.ko] undefined!
ERROR: "iscsi_session_failure" [drivers/scsi/qla4xxx/qla4xxx.ko] undefined!
ERROR: "iscsi_complete_pdu" [drivers/scsi/qla4xxx/qla4xxx.ko] undefined!
ERROR: "iscsi_session_setup" [drivers/scsi/qla4xxx/qla4xxx.ko] undefined!
ERROR: "iscsi_conn_bind" [drivers/scsi/qla4xxx/qla4xxx.ko] undefined!
ERROR: "iscsi_conn_setup" [drivers/scsi/qla4xxx/qla4xxx.ko] undefined!
ERROR: "iscsi_itt_to_task" [drivers/scsi/qla4xxx/qla4xxx.ko] undefined!
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
child.
commit 24926dadc41cc566e974022b0e66231b82c6375f upstream.
In an enclosure model where there are chaining expanders to a large body
of storage, it was discovered that libsas, responding to a broadcast
event change, would only revalidate the domain of first child expander
in the list.
The issue is that the pointer value to the discovered source device was
used to break out of the loop, rather than the content of the pointer.
This still remains non-compliant as the revalidate domain code is
supposed to loop through all child expanders, and not stop at the first
one it finds that reports a change count. However, the design of this
routine does not allow multiple device discoveries and that would be a
more complicated set of patches reserved for another day. We are fixing
the glaring bug rather than refactoring the code.
Signed-off-by: Mark Salyzyn <msalyzyn@us.xyratex.com>
commit d0efab26f89506387a1bde898556660e06d7eb15 upstream.
scsi reset on hardware with enabled MSI interrupts generates WARNING message
[11027.798722] aacraid: Host adapter abort request (0,0,0,0)
[11027.798814] aacraid: Host adapter reset request. SCSI hang ?
[11087.762237] aacraid: SCSI bus appears hung
[11135.082543] ------------[ cut here ]------------
[11135.082646] WARNING: at drivers/pci/msi.c:658 pci_enable_msi_block+0x251/0x290()
Acked-by: Mark Salyzyn <mark_salyzyn@us.xyratex.com>
commit 96067723e46b0dd24ae7b934085ab4eff4d26a1b upstream.
Following reports on the list, it looks like the 3e-9xxx driver will leak dma
mappings every time we get a transient queueing error back from the card.
This is because it maps the sg list in the routine that sends the command, but
doesn't unmap again in the transient failure path (even though the command is
sent back to the block layer). Fix by unmapping before returning the status.
Reported-by: Chris Boot <bootc@bootc.net>
Tested-by: Chris Boot <bootc@bootc.net>
Acked-by: Adam Radford <aradford@gmail.com>
commit e48f129c2f200dde8899f6ea5c6e7173674fc482 upstream.
This oops was reported recently:
d:mon> e
cpu 0xd: Vector: 300 (Data Access) at [c0000000fd4c7120]
pc: d00000000076f194: .t3_l2t_get+0x44/0x524 [cxgb3]
lr: d000000000b02108: .init_act_open+0x150/0x3d4 [cxgb3i]
sp: c0000000fd4c73a0
msr: 8000000000009032
dar: 0
dsisr: 40000000
current = 0xc0000000fd640d40
paca = 0xc00000000054ff80
pid = 5085, comm = iscsid
d:mon> t
[c0000000fd4c7450] d000000000b02108 .init_act_open+0x150/0x3d4 [cxgb3i]
[c0000000fd4c7500] d000000000e45378 .cxgbi_ep_connect+0x784/0x8e8 [libcxgbi]
[c0000000fd4c7650] d000000000db33f0 .iscsi_if_rx+0x71c/0xb18
[scsi_transport_iscsi2]
[c0000000fd4c7740] c000000000370c9c .netlink_data_ready+0x40/0xa4
[c0000000fd4c77c0] c00000000036f010 .netlink_sendskb+0x4c/0x9c
[c0000000fd4c7850] c000000000370c18 .netlink_sendmsg+0x358/0x39c
[c0000000fd4c7950] c00000000033be24 .sock_sendmsg+0x114/0x1b8
[c0000000fd4c7b50] c00000000033d208 .sys_sendmsg+0x218/0x2ac
[c0000000fd4c7d70] c00000000033f55c .sys_socketcall+0x228/0x27c
[c0000000fd4c7e30] c0000000000086a4 syscall_exit+0x0/0x40
commit b5a95fe7ef464a67fab6ff870aa740739e788f90 upstream.
Do not set io_req->sc_cmd to NULL until bnx2fc_unmap_sg_list() is called to
enable it to unmap the DMA mappings.
Signed-off-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com>
commit d36b3279e157641c345b12eddb3db78fb42da80f upstream.
Deleting NPIV port causes a kernel panic when the NPIV port is in the same zone
as the physical port and shares the same LUN. This happens due to the fact that
vport destroy and unsolicited ELS are scheduled to run on the same workqueue,
and vport destroy destroys the lport and the unsolicited ELS tries to access
the invalid lport. This patch fixes this issue by maintaining a list of valid
lports and verifying if the lport is valid or not before accessing it.
