commit 5e420fe635813e5746b296cfc8fff4853ae205a2 upstream.
Add missing break statement and fix identation issue.
This bug was found thanks to the ongoing efforts to enable
-Wimplicit-fallthrough.
Fixes: 9cb62fa24e0d ("aacraid: Log firmware AIF messages")
Cc: stable@vger.kernel.org
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
[ Upstream commit d8f6382a7d026989029e2e50c515df954488459b ]
This reverts commit bbc0f8bd88abefb0f27998f40a073634a3a2db89.
It added a warning whose intent was to check whether the rport was still
linked into the peer list. It doesn't work as intended and gives false
positive warnings for two reasons:
1) If the rport is never linked into the peer list it will not be
considered empty since the list_head is never initialized.
2) If the rport is deleted from the peer list using list_del_rcu(), then
the list_head is in an undefined state and it is not considered empty.
Signed-off-by: Ross Lagerwall <ross.lagerwall@citrix.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
[ Upstream commit 8437fcf14deed67e5ad90b5e8abf62fb20f30881 ]
The "hostdata->dev" pointer is NULL here. We set "hostdata->dev = dev;"
later in the function and we also use "hostdata->dev" when we call
dma_free_attrs() in NCR_700_release().
This bug predates git version control.
[ Upstream commit b2d3492fc591b1fb46b81d79ca1fc44cac6ae0ae ]
There are two issues here. First if cmgr->hba is not set early enough then
it leads to a NULL dereference. Second if we don't completely initialize
cmgr->io_bdt_pool[] then we end up dereferencing uninitialized pointers.
Fixes: 853e2bd2103a ("[SCSI] bnx2fc: Broadcom FCoE offload driver")
[ Upstream commit 40d07b523cf434f252b134c86b1f8f2d907ffb0b ]
The WRITE SAME(10) and (16) implementations didn't take account of the
buffer wrap required when the virtual_gb parameter is greater than 0.
Fix that and rename the fake_store() function to lba2fake_store() to lessen
confusion with the global fake_storep pointer. Bump version date.
Signed-off-by: Douglas Gilbert <dgilbert@interlog.com>
Reported-by: Bart Van Assche <bvanassche@acm.org>
Tested by: Bart Van Assche <bvanassche@acm.org>
[ Upstream commit 5d8fc4a9f0eec20b6c07895022a6bea3fb6dfb38 ]
The issue to be fixed in this commit is when libfc found it received a
invalid FLOGI response from FC switch, it would return without freeing the
fc frame, which is just the skb data. This would cause memory leak if FC
switch keeps sending invalid FLOGI responses.
This fix is just to make it execute `fc_frame_free(fp)` before returning
from function `fc_lport_flogi_resp`.
Signed-off-by: Ming Lu <ming.lu@citrix.com>
commit 4a067cf823d9d8e50d41cfb618011c0d4a969c72 upstream.
Up to 4.12, __scsi_error_from_host_byte() would reset the host byte to
DID_OK for various cases including DID_NEXUS_FAILURE. Commit
2a842acab109 ("block: introduce new block status code type") replaced this
function with scsi_result_to_blk_status() and removed the host-byte
resetting code for the DID_NEXUS_FAILURE case. As the line
set_host_byte(cmd, DID_OK) was preserved for the other cases, I suppose
this was an editing mistake.
The fact that the host byte remains set after 4.13 is causing problems with
the sg_persist tool, which now returns success rather then exit status 24
when a RESERVATION CONFLICT error is encountered.
Fixes: 2a842acab109 "block: introduce new block status code type"
Signed-off-by: Martin Wilck <mwilck@suse.com>
commit c326de562f1fc149da4855a1b9d0433300c2a85d upstream.
The change to use dma_set_mask_and_coherent() incorrectly made a second
call with the 32 bit DMA mask value when the call with the 64 bit DMA mask
value succeeded.
[mkp: fixed subject]
Fixes: 3a21986f1a59 ("scsi: aic94xx: fully convert to the generic DMA API")
Cc: <stable@vger.kernel.org>
Signed-off-by: Hannes Reinecke <hare@suse.com>
Reviewed-by: Ewan D. Milne <emilne@redhat.com>
commit 33d6667416c73eb0b37f0f10f56d825b15389dab upstream.
value succeeded.
Fixes: b000bced5739 ("scsi: 3w-9xxx: fully convert to the generic DMA API")
commit 732f3238dcf27acb92959a99b7923dc49395980e upstream.
value succeeded.
Fixes: c22b332d811b ("scsi: csiostor: switch to generic DMA API")
commit 1feb3b02294994ee3a067c9b6cda6c244fd0ee18 upstream.
value succeeded.
Fixes: b1fa122930c4 ("scsi: 3w-sas: fully convert to the generic DMA API")
[ Upstream commit fe35a40e675473eb65f2f5462b82770f324b5689 ]
Assign fc_vport to ln->fc_vport before calling csio_fcoe_alloc_vnp() to
avoid a NULL pointer dereference in csio_vport_set_state().
ln->fc_vport is dereferenced in csio_vport_set_state().
Signed-off-by: Varun Prakash <varun@chelsio.com>
[ Upstream commit c41f59884be5cca293ed61f3d64637dbba3a6381 ]
We cannot wait on a completion object in the lpfc_nvme_targetport structure
in the _destroy_targetport() code path because the NVMe/fc transport will
free that structure immediately after the .targetport_delete() callback.
This results in a use-after-free, and a hang if slub_debug=FZPU is enabled.
Fix this by putting the completion on the stack.
Signed-off-by: Ewan D. Milne <emilne@redhat.com>
Acked-by: James Smart <james.smart@broadcom.com>
[ Upstream commit 7961cba6f7d8215fa632df3d220e5154bb825249 ]
We cannot wait on a completion object in the lpfc_nvme_lport structure in
the _destroy_localport() code path because the NVMe/fc transport will free
that structure immediately after the .localport_delete() callback. This
commit ffeafdd2bf0b280d67ec1a47ea6287910d271f3f upstream.
The sysfs phy_identifier attribute for a sas_end_device comes from the rphy
phy_identifier value.
Currently this is not being set for rphys with an end device attached, so
we see incorrect symlinks from systemd disk/by-path:
root@localhost:~# ls -l /dev/disk/by-path/
total 0
lrwxrwxrwx 1 root root 9 Feb 13 12:26 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy0-lun-0 -> ../../sdb
lrwxrwxrwx 1 root root 10 Feb 13 12:26 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy0-lun-0-part1 -> ../../sdb1
lrwxrwxrwx 1 root root 10 Feb 13 12:26 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy0-lun-0-part2 -> ../../sdb2
lrwxrwxrwx 1 root root 10 Feb 13 12:26 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy0-lun-0-part3 -> ../../sdc3
Indeed, each sas_end_device phy_identifier value is 0:
root@localhost:/# more sys/class/sas_device/end_device-0\:0\:2/phy_identifier
0
root@localhost:/# more sys/class/sas_device/end_device-0\:0\:10/phy_identifier
0
This patch fixes the discovery code to set the phy_identifier. With this,
we now get proper symlinks:
total 0
lrwxrwxrwx 1 root root 9 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy10-lun-0 -> ../../sdg
lrwxrwxrwx 1 root root 9 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy11-lun-0 -> ../../sdh
lrwxrwxrwx 1 root root 9 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy2-lun-0 -> ../../sda
lrwxrwxrwx 1 root root 10 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy2-lun-0-part1 -> ../../sda1
lrwxrwxrwx 1 root root 9 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy3-lun-0 -> ../../sdb
lrwxrwxrwx 1 root root 10 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy3-lun-0-part1 -> ../../sdb1
lrwxrwxrwx 1 root root 10 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy3-lun-0-part2 -> ../../sdb2
lrwxrwxrwx 1 root root 9 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy4-lun-0 -> ../../sdc
lrwxrwxrwx 1 root root 10 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy4-lun-0-part1 -> ../../sdc1
lrwxrwxrwx 1 root root 10 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy4-lun-0-part2 -> ../../sdc2
lrwxrwxrwx 1 root root 10 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy4-lun-0-part3 -> ../../sdc3
lrwxrwxrwx 1 root root 9 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy5-lun-0 -> ../../sdd
lrwxrwxrwx 1 root root 9 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy7-lun-0 -> ../../sde
lrwxrwxrwx 1 root root 10 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy7-lun-0-part1 -> ../../sde1
lrwxrwxrwx 1 root root 10 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy7-lun-0-part2 -> ../../sde2
lrwxrwxrwx 1 root root 10 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy7-lun-0-part3 -> ../../sde3
lrwxrwxrwx 1 root root 9 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy8-lun-0 -> ../../sdf
lrwxrwxrwx 1 root root 10 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy8-lun-0-part1 -> ../../sdf1
lrwxrwxrwx 1 root root 10 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy8-lun-0-part2 -> ../../sdf2
lrwxrwxrwx 1 root root 10 Feb 13 11:53 platform-HISI0162:01-sas-exp0x500e004aaaaaaa1f-phy8-lun-0-part3 -> ../../sdf3
Fixes: 2908d778ab3e ("[SCSI] aic94xx: new driver")
Reported-by: dann frazier <dann.frazier@canonical.com>
Signed-off-by: John Garry <john.garry@huawei.com>
Reviewed-by: Jason Yan <yanaijie@huawei.com>
Tested-by: dann frazier <dann.frazier@canonical.com>
commit 515ce60613128be7a176a8b82b20c7624f3b440d upstream.
The function sd_zbc_do_report_zones() issues a REPORT ZONES command with a
buffer size calculated based on the number of zones requested by the
caller. This value should however not exceed the capabilities of the
hardware maximum command size, that is, should not exceed the
max_hw_sectors limit of the device. This problem leads to failures of
report zones commands when re-validating disks with some SAS HBAs.
Fix this by limiting a report zone command buffer size to the minimum of
the device max_hw_sectors and calculated value based on the requested
number of zones. This does not change the semantic of the report_zones file
operation as report zones can always return less zone reports than
requested. Short reports are handled using a loop execution of the
report_zones file operation in the function blk_report_zones().
[Damien]
Before patch 'e76239a3748c ("block: add a report_zones method")', report
zones buffer allocation was limited to max_sectors when allocated in
blk_report_zones(). This however does not consider the actual format of the
device reply which is interface dependent. Limiting the allocation based
on the size of the expected reply format rather than the size of the array
of generic sturct blkzone passed by blk_report_zones() makes more sense.
Fixes: e76239a3748c ("block: add a report_zones method")
Signed-off-by: Masato Suzuki <masato.suzuki@wdc.com>
Signed-off-by: Damien Le Moal <damien.lemoal@wdc.com>
[ Upstream commit 9e8f1c79831424d30c0e3df068be7f4a244157c9 ]
In case of ->set_param() and ->bind_conn() cxgb4i driver does not wait for
cmd completion, this can create race conditions, to avoid this add
wait_for_completion().
[ Upstream commit 4a01ab60f55041b1ccc760e43258a5b3aeeca1bc ]
After Commit 54aed4dd3526 ("MIPS: IP27: use dma_direct_ops") qla1280 driver
failed on SGI IP27 machines with
qla1280: QLA1040 found on PCI bus 0, dev 0
qla1280 0000:00:00.0: enabling device (0006 -> 0007)
qla1280: Failed to get request memory
qla1280: probe of 0000:00:00.0 failed with error -12
Reason is that SGI IP27 always generates 64bit DMA addresses and has no
fallback mode for 32bit DMA addresses implemented. QLA1280 supports 64bit
addressing for all DMA accesses so setting coherent mask to 64bit fixes the
issue.
Signed-off-by: Thomas Bogendoerfer <tbogendoerfer@suse.de>
[ Upstream commit 9be9db9f78f52ef03ee90063730cb9d730e7032b ]
Albeit we no longer rely on those hard-coded descriptor sizes, we still use
them as our defaults, so better get it right. While adding its sysfs
entries, we forgot to update the geometry descriptor size. It is 0x48
according to UFS2.1, and wasn't changed in UFS3.0.
[mkp: typo]
Fixes: c720c091222e (scsi: ufs: sysfs: geometry descriptor)
Signed-off-by: Avri Altman <avri.altman@wdc.com>
[ Upstream commit 34a2ce887668db9dda4b56e6f155c49ac13f3e54 ]
When the driver finds invalid destination MAC for the first un-reachable
target, and before completes the PATH_REQ operation, set new ep_state to
OFFLDCONN_NONE so that as part of driver ep_poll mechanism, the upper
open-iscsi layer is notified to complete the login process on the first
un-reachable target and thus proceed login to other reachable targets.
Signed-off-by: Manish Rangankar <mrangankar@marvell.com>
[ Upstream commit ce9e7bce43526626f7cffe2e657953997870197e ]
hba->is_sys_suspended is set after successful system suspend but
not clear after successful system resume.
According to current behavior, hba->is_sys_suspended will not be set if
host is runtime-suspended but not system-suspended. Thus we shall aligh the
same policy: clear this flag even if host remains runtime-suspended after
ufshcd_system_resume is successfully returned.
Simply fix this flag to correct host status logs.
Signed-off-by: Stanley Chu <stanley.chu@mediatek.com>
Reviewed-by: Avri Altman <avri.altman@wdc.com>
[ Upstream commit cc29a1b0a3f2597ce887d339222fa85b9307706d ]
scsi_mq_setup_tags(), which is called by scsi_add_host(), calculates the
command size to allocate based on the prot_capabilities. In the isci
driver, scsi_host_set_prot() is called after scsi_add_host() so the command
size gets calculated to be smaller than it needs to be. Eventually,
scsi_mq_init_request() locates the 'prot_sdb' after the command assuming it
was sized correctly and a buffer overrun may occur.
However, seeing blk_mq_alloc_rqs() rounds up to the nearest cache line
size, the mistake can go unnoticed.
The bug was noticed after the struct request size was reduced by commit
9d037ad707ed ("block: remove req->timeout_list")
Which likely reduced the allocated space for the request by an entire cache
line, enough that the overflow could be hit and it caused a panic, on boot,
at:
RIP: 0010:t10_pi_complete+0x77/0x1c0
Call Trace:
<IRQ>
sd_done+0xf5/0x340
scsi_finish_command+0xc3/0x120
blk_done_softirq+0x83/0xb0
__do_softirq+0xa1/0x2e6
irq_exit+0xbc/0xd0
call_function_single_interrupt+0xf/0x20
</IRQ>
sd_done() would call scsi_prot_sg_count() which reads the number of
entities in 'prot_sdb', but seeing 'prot_sdb' is located after the end of
the allocated space it reads a garbage number and erroneously calls
t10_pi_complete().
To prevent this, the calls to scsi_host_set_prot() are moved into
isci_host_alloc() before the call to scsi_add_host(). Out of caution, also
move the similar call to scsi_host_set_guard().
Fixes: 3d2d75254915 ("[SCSI] isci: T10 DIF support")
Link: http://lkml.kernel.org/r/da851333-eadd-163a-8c78-e1f4ec5ec857@deltatee.com
Signed-off-by: Logan Gunthorpe <logang@deltatee.com>
Cc: Intel SCU Linux support <intel-linux-scu@intel.com>
Cc: Artur Paszkiewicz <artur.paszkiewicz@intel.com>
Cc: "James E.J. Bottomley" <jejb@linux.ibm.com>
Cc: "Martin K. Petersen" <martin.petersen@oracle.com>
Cc: Jeff Moyer <jmoyer@redhat.com>
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
Reviewed-by: Jens Axboe <axboe@kernel.dk>
[ Upstream commit 72b4a0465f995175a2e22cf4a636bf781f1f28a7 ]
The return code should be check while qla4xxx_copy_from_fwddb_param fails.
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Acked-by: Manish Rangankar <mrangankar@marvell.com>
commit e4a056987c86f402f1286e050b1dee3f4ce7c7eb upstream.
The problem is that the default for MQ is not to gather entropy, whereas
the default for the legacy queue was always to gather it. The original
attempt to fix entropy gathering for rotational disks under MQ added an
else branch in sd_read_block_characteristics(). Unfortunately, the entire
check isn't reached if the device has no characteristics VPD page. Since
this page was only introduced in SBC-3 and its optional anyway, most less
expensive rotational disks don't have one, meaning they all stopped
gathering entropy when we made MQ the default. In a wholly unrelated
change, openssl and openssh won't function until the random number
generator is initialised, meaning lots of people have been seeing large
delays before they could log into systems with default MQ kernels due to
this lack of entropy, because it now can take tens of minutes to initialise
the kernel random number generator.
The fix is to set the non-rotational and add-randomness flags
unconditionally early on in the disk initialization path, so they can be
reset only if the device actually reports being non-rotational via the VPD
page.
Reported-by: Mikael Pettersson <mikpelinux@gmail.com>
Fixes: 83e32a591077 ("scsi: sd: Contribute to randomness when running rotational device")
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Reviewed-by: Xuewei Zhang <xueweiz@google.com>
commit 42caa0edabd6a0a392ec36a5f0943924e4954311 upstream.
The aic94xx driver is currently failing to load with errors like
sysfs: cannot create duplicate filename '/devices/pci0000:00/0000:00:03.0/0000:02:00.3/0000:07:02.0/revision'
Because the PCI code had recently added a file named 'revision' to every
PCI device. Fix this by renaming the aic94xx revision file to
aic_revision. This is safe to do for us because as far as I can tell,
there's nothing in userspace relying on the current aic94xx revision file
so it can be renamed without breaking anything.
Fixes: 702ed3be1b1b (PCI: Create revision file in sysfs)
commit bb61b843ffd46978d7ca5095453e572714934eeb upstream.
Presently when an error is encountered during probe of the cxlflash
adapter, a deadlock is seen with cpu thread stuck inside
cxlflash_remove(). Below is the trace of the deadlock as logged by
khungtaskd:
cxlflash 0006:00:00.0: cxlflash_probe: init_afu failed rc=-16
INFO: task kworker/80:1:890 blocked for more than 120 seconds.
Not tainted 5.0.0-rc4-capi2-kexec+ #2
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
kworker/80:1 D 0 890 2 0x00000808
Workqueue: events work_for_cpu_fn
Call Trace:
0x4d72136320 (unreliable)
__switch_to+0x2cc/0x460
__schedule+0x2bc/0xac0
schedule+0x40/0xb0
cxlflash_remove+0xec/0x640 [cxlflash]
cxlflash_probe+0x370/0x8f0 [cxlflash]
local_pci_probe+0x6c/0x140
work_for_cpu_fn+0x38/0x60
process_one_work+0x260/0x530
worker_thread+0x280/0x5d0
kthread+0x1a8/0x1b0
ret_from_kernel_thread+0x5c/0x80
INFO: task systemd-udevd:5160 blocked for more than 120 seconds.
The deadlock occurs as cxlflash_remove() is called from cxlflash_probe()
without setting 'cxlflash_cfg->state' to STATE_PROBED and the probe thread
starts to wait on 'cxlflash_cfg->reset_waitq'. Since the device was never
successfully probed the 'cxlflash_cfg->state' never changes from
STATE_PROBING hence the deadlock occurs.
We fix this deadlock by setting the variable 'cxlflash_cfg->state' to
STATE_PROBED in case an error occurs during cxlflash_probe() and just
before calling cxlflash_remove().
Fixes: c21e0bbfc485("cxlflash: Base support for IBM CXL Flash Adapter")
Signed-off-by: Vaibhav Jain <vaibhav@linux.ibm.com>
commit 88fc41c407158a7d2eaa4b2f7cfa289749d456c6 upstream.
Commit bf5054569653 ("block: Introduce blk_revalidate_disk_zones()")
inadvertently broke the message output of sd_zbc_print_zones() because the
zone information initialization of the scsi disk structure was moved to the
second scan run while sd_zbc_print_zones() is called on the first
scan. This leads to the following incorrect message to be printed for any
ZBC or ZAC zoned disks.
"...[sdX] 4294967295 zones of 0 logical blocks + 1 runt zone"
Fix this by initializing sdkp zone size and number of zones early on the
first scan. This does not impact the execution of
blk_revalidate_zones(). This functions is still called only once the block
device capacity is set on the second revalidate run on boot, or if the disk
zone configuration changed (i.e. the disk changed).
Fixes: bf5054569653 ("block: Introduce blk_revalidate_disk_zones()")
[ Upstream commit 65111785acccb836ec75263b03b0e33f21e74f47 ]
Problem:
- during the driver initialization, driver will poll fw
for KERNEL_UP in a 30 seconds timeout.
- if the firmware is not ready after 30 seconds,
driver will not be loaded.
Fix:
- change timeout from 30 seconds to 3 minutes.
Reported-by: Feng Li <lifeng1519@gmail.com>
Reviewed-by: Ajish Koshy <ajish.koshy@microsemi.com>
Reviewed-by: Murthy Bhat <Murthy.Bhat@microsemi.com>
Reviewed-by: Dave Carroll <david.carroll@microsemi.com>
Reviewed-by: Kevin Barnett <kevin.barnett@microsemi.com>
Signed-off-by: Mahesh Rajashekhara <mahesh.rajashekhara@microsemi.com>
Signed-off-by: Don Brace <don.brace@microsemi.com>
[ Upstream commit 7ff44499bafbd376115f0bb6b578d980f56ee13b ]
- fix race condition when a unit is deleted after an RLL,
and before we have gotten the LV_STATUS page of the unit.
- In this case we will get a standard inquiry, rather than
the desired page. This will result in a unit presented
which no longer exists.
- If we ask for LV_STATUS, insure we get LV_STATUS
Reviewed-by: Murthy Bhat <murthy.bhat@microsemi.com>
Reviewed-by: Mahesh Rajashekhara <mahesh.rajashekhara@microsemi.com>
Reviewed-by: Scott Teel <scott.teel@microsemi.com>
Signed-off-by: Dave Carroll <david.carroll@microsemi.com>
[ Upstream commit b2346b5030cf9458f30a84028d9fe904b8c942a7 ]
Reviewed-by: Scott Benesh <scott.benesh@microsemi.com>
[ Upstream commit 8d0bb86e2cf6c96d88c3de56a2a29329872c454d ]
I fixed a bug by adding a dependency in the network driver, but that fix
caused a related bug in the SCSI driver:
WARNING: unmet direct dependencies detected for CHELSIO_T4
Depends on [m]: NETDEVICES [=y] && ETHERNET [=y] && NET_VENDOR_CHELSIO [=y] && PCI [=y] && (IPV6 [=y] || IPV6 [=y]=n) && (THERMAL [=m] || !THERMAL [=m])
Selected by [y]:
- SCSI_CXGB4_ISCSI [=y] && SCSI_LOWLEVEL [=y] && SCSI [=y] && PCI [=y] && INET [=y] && (IPV6 [=y] || IPV6 [=y]=n)
drivers/net/ethernet/chelsio/cxgb4/cxgb4_thermal.o: In function `cxgb4_thermal_init':
cxgb4_thermal.c:(.text+0x158): undefined reference to `thermal_zone_device_register'
drivers/net/ethernet/chelsio/cxgb4/cxgb4_thermal.o: In function `cxgb4_thermal_remove':
cxgb4_thermal.c:(.text+0x1d8): undefined reference to `thermal_zone_device_unregister'
/git/arm-soc/Makefile:1042: recipe for target 'vmlinux' failed
The same dependency needs to be propagated here to make it work correctly
with CONFIG_THERMAL=m and SCSI_CXGB4_ISCSI=y. That change by itself causes
another problem with a circular dependency, as we use 'select NETDEVICES'.
This is something we really should not do anyway, as a driver symbol should
never select another major subsystem, so let's turn that into a 'depends
on'. I don't see any downsides of that, as NETDEVICES is only disabled in
rather obscure cases that are not relevant to the users of cxgb4i.
Fixes: e70a57fa59bb ("cxgb4: fix thermal configuration dependencies")
[ Upstream commit 15bc43f31a074076f114e0b87931e3b220b7bff1 ]
Currently the time of SAS SSP connection is 1ms, which means the link
connection will fail if no IO response after this period.
For some disks handling large IO (such as 512k), 1ms is not enough, so
change it to 5ms.
Signed-off-by: Xiang Chen <chenxiang66@hisilicon.com>
[ Upstream commit 30e196cacefdd9a38c857caed23cefc9621bc5c1 ]
After a LOGO in response to an ABTS timeout, a PLOGI wasn't issued to
re-establish the login. An nlp_type check in the LOGO completion
handler failed to restart discovery for NVME targets. Revised the
nlp_type check for NVME as well as SCSI.
While reviewing the LOGO handling a few other issues were seen and
were addressed:
- Better lock synchronization around ndlp data types
- When the ABTS times out, unregister the RPI before sending the LOGO
so that all local exchange contexts are cleared and nothing received
while awaiting LOGO/PLOGI handling will be accepted.
- LOGO handling optimized to:
Wait only R_A_TOV for a response.
It doesn't need to be retried on timeout. If there wasn't a
response, a PLOGI will be sent, thus an implicit logout
applies as well when the other port sees it.
If there is a response, any kind of response is considered "good"
and the XRI quarantined for a exchange qualifier window.
- PLOGI is issued as soon a LOGO state is resolved.
Signed-off-by: Dick Kennedy <dick.kennedy@broadcom.com>
Signed-off-by: James Smart <jsmart2021@gmail.com>
[ Upstream commit dc730212e8a378763cb182b889f90c8101331332 ]
Call sas_remove_host() before removing the target devices in the driver's
.remove() callback function(i.e. during driver unload time). So that
driver can provide a way to allow SYNC CACHE, START STOP unit commands
etc. (which are issued from SML) to the target drives during driver unload
time.
Once sas_remove_host() is called before removing the target drives then
driver can just clean up the resources allocated for target devices and no
need to call sas_port_delete_phy(), sas_port_delete() API's as these API's
internally called from sas_remove_host().
Signed-off-by: Suganath Prabu <suganath-prabu.subramani@broadcom.com>
Reviewed-by: Bjorn Helgaas <bhelgaas@google.com>
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
[ Upstream commit b114d9009d386276bfc3352289fc235781ae3353 ]
When LCB's are rejected, if beaconing was already in progress, the
Reason Code Explanation was not being set. Should have been set to
command in progress.
commit d67247566450cf89a693307c9bc9f05a32d96cea upstream.
memcpy_fromio() doesn't provide any control over access size. For example,
on arm64, it is implemented using readb and readq. This may trigger a
synchronous external abort:
[ 3.729943] Internal error: synchronous external abort: 96000210 [#1] PREEMPT SMP
[ 3.737000] Modules linked in:
[ 3.744371] CPU: 2 PID: 1 Comm: swapper/0 Tainted: G S 4.20.0-rc4 #16
[ 3.747413] Hardware name: Qualcomm Technologies, Inc. MSM8998 v1 MTP (DT)
[ 3.755295] pstate: 00000005 (nzcv daif -PAN -UAO)
[ 3.761978] pc : __memcpy_fromio+0x68/0x80
[ 3.766718] lr : ufshcd_dump_regs+0x50/0xb0
[ 3.770767] sp : ffff00000807ba00
[ 3.774830] x29: ffff00000807ba00 x28: 00000000fffffffb
[ 3.778344] x27: ffff0000089db068 x26: ffff8000f6e58000
[ 3.783728] x25: 000000000000000e x24: 0000000000000800
[ 3.789023] x23: ffff8000f6e587c8 x22: 0000000000000800
[ 3.794319] x21: ffff000008908368 x20: ffff8000f6e1ab80
[ 3.799615] x19: 000000000000006c x18: ffffffffffffffff
[ 3.804910] x17: 0000000000000000 x16: 0000000000000000
[ 3.810206] x15: ffff000009199648 x14: ffff000089244187
[ 3.815502] x13: ffff000009244195 x12: ffff0000091ab000
[ 3.820797] x11: 0000000005f5e0ff x10: ffff0000091998a0
[ 3.826093] x9 : 0000000000000000 x8 : ffff8000f6e1ac00
[ 3.831389] x7 : 0000000000000000 x6 : 0000000000000068
[ 3.836676] x5 : ffff8000f6e1abe8 x4 : 0000000000000000
[ 3.841971] x3 : ffff00000928c868 x2 : ffff8000f6e1abec
[ 3.847267] x1 : ffff00000928c868 x0 : ffff8000f6e1abe8
[ 3.852567] Process swapper/0 (pid: 1, stack limit = 0x(____ptrval____))
[ 3.857900] Call trace:
[ 3.864473] __memcpy_fromio+0x68/0x80
[ 3.866683] ufs_qcom_dump_dbg_regs+0x1c0/0x370
[ 3.870522] ufshcd_print_host_regs+0x168/0x190
[ 3.874946] ufshcd_init+0xd4c/0xde0
[ 3.879459] ufshcd_pltfrm_init+0x3c8/0x550
[ 3.883264] ufs_qcom_probe+0x24/0x60
[ 3.887188] platform_drv_probe+0x50/0xa0
Assuming aligned 32-bit registers, let's use readl, after making sure
that 'offset' and 'len' are indeed multiples of 4.
Fixes: ba80917d9932d ("scsi: ufs: ufshcd_dump_regs to use memcpy_fromio")
Signed-off-by: Marc Gonzalez <marc.w.gonzalez@free.fr>
Acked-by: Tomas Winkler <tomas.winkler@intel.com>
Reviewed-by: Jeffrey Hugo <jhugo@codeaurora.org>
Reviewed-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Tested-by: Evan Green <evgreen@chromium.org>
[ Upstream commit c7a082e4242fd8cd21a441071e622f87c16bdacc ]
UBSAN reported those with MegaRAID SAS-3 3108,
[ 77.467308] UBSAN: Undefined behaviour in drivers/scsi/megaraid/megaraid_sas_fp.c:117:32
[ 77.475402] index 255 is out of range for type 'MR_LD_SPAN_MAP [1]'
[ 77.481677] CPU: 16 PID: 333 Comm: kworker/16:1 Not tainted 4.20.0-rc5+ #1
[ 77.488556] Hardware name: Huawei TaiShan 2280 /BC11SPCD, BIOS 1.50 06/01/2018
[ 77.495791] Workqueue: events work_for_cpu_fn
[ 77.500154] Call trace:
[ 77.502610] dump_backtrace+0x0/0x2c8
[ 77.506279] show_stack+0x24/0x30
[ 77.509604] dump_stack+0x118/0x19c
[ 77.513098] ubsan_epilogue+0x14/0x60
[ 77.516765] __ubsan_handle_out_of_bounds+0xfc/0x13c
[ 77.521767] mr_update_load_balance_params+0x150/0x158 [megaraid_sas]
[ 77.528230] MR_ValidateMapInfo+0x2cc/0x10d0 [megaraid_sas]
[ 77.533825] megasas_get_map_info+0x244/0x2f0 [megaraid_sas]
[ 77.539505] megasas_init_adapter_fusion+0x9b0/0xf48 [megaraid_sas]
[ 77.545794] megasas_init_fw+0x1ab4/0x3518 [megaraid_sas]
[ 77.551212] megasas_probe_one+0x2c4/0xbe0 [megaraid_sas]
[ 77.556614] local_pci_probe+0x7c/0xf0
[ 77.560365] work_for_cpu_fn+0x34/0x50
[ 77.564118] process_one_work+0x61c/0xf08
[ 77.568129] worker_thread+0x534/0xa70
[ 77.571882] kthread+0x1c8/0x1d0
[ 77.575114] ret_from_fork+0x10/0x1c
[ 89.240332] UBSAN: Undefined behaviour in drivers/scsi/megaraid/megaraid_sas_fp.c:117:32
[ 89.248426] index 255 is out of range for type 'MR_LD_SPAN_MAP [1]'
[ 89.254700] CPU: 16 PID: 95 Comm: kworker/u130:0 Not tainted 4.20.0-rc5+ #1
[ 89.261665] Hardware name: Huawei TaiShan 2280 /BC11SPCD, BIOS 1.50 06/01/2018
[ 89.268903] Workqueue: events_unbound async_run_entry_fn
[ 89.274222] Call trace:
[ 89.276680] dump_backtrace+0x0/0x2c8
[ 89.280348] show_stack+0x24/0x30
[ 89.283671] dump_stack+0x118/0x19c
[ 89.287167] ubsan_epilogue+0x14/0x60
[ 89.290835] __ubsan_handle_out_of_bounds+0xfc/0x13c
[ 89.295828] MR_LdRaidGet+0x50/0x58 [megaraid_sas]
[ 89.300638] megasas_build_io_fusion+0xbb8/0xd90 [megaraid_sas]
[ 89.306576] megasas_build_and_issue_cmd_fusion+0x138/0x460 [megaraid_sas]
[ 89.313468] megasas_queue_command+0x398/0x3d0 [megaraid_sas]
[ 89.319222] scsi_dispatch_cmd+0x1dc/0x8a8
[ 89.323321] scsi_request_fn+0x8e8/0xdd0
[ 89.327249] __blk_run_queue+0xc4/0x158
[ 89.331090] blk_execute_rq_nowait+0xf4/0x158
[ 89.335449] blk_execute_rq+0xdc/0x158
[ 89.339202] __scsi_execute+0x130/0x258
[ 89.343041] scsi_probe_and_add_lun+0x2fc/0x1488
[ 89.347661] __scsi_scan_target+0x1cc/0x8c8
[ 89.351848] scsi_scan_channel.part.3+0x8c/0xc0
[ 89.356382] scsi_scan_host_selected+0x130/0x1f0
[ 89.361002] do_scsi_scan_host+0xd8/0xf0
[ 89.364927] do_scan_async+0x9c/0x320
[ 89.368594] async_run_entry_fn+0x138/0x420
[ 89.372780] process_one_work+0x61c/0xf08
[ 89.376793] worker_thread+0x13c/0xa70
[ 89.380546] kthread+0x1c8/0x1d0
[ 89.383778] ret_from_fork+0x10/0x1c
This is because when populating Driver Map using firmware raid map, all
non-existing VDs set their ldTgtIdToLd to 0xff, so it can be skipped later.
From drivers/scsi/megaraid/megaraid_sas_base.c ,
memset(instance->ld_ids, 0xff, MEGASAS_MAX_LD_IDS);
From drivers/scsi/megaraid/megaraid_sas_fp.c ,
/* For non existing VDs, iterate to next VD*/
if (ld >= (MAX_LOGICAL_DRIVES_EXT - 1))
continue;
However, there are a few places that failed to skip those non-existing VDs
due to off-by-one errors. Then, those 0xff leaked into MR_LdRaidGet(0xff,
map) and triggered the out-of-bound accesses.
Fixes: 51087a8617fe ("megaraid_sas : Extended VD support")
Signed-off-by: Qian Cai <cai@lca.pw>
Acked-by: Sumit Saxena <sumit.saxena@broadcom.com>
[ Upstream commit e57b2945aa654e48f85a41e8917793c64ecb9de8 ]
We must free all irqs during shutdown, else kexec's 2nd kernel would hang
in pqi_wait_for_completion_io() as below:
Call trace:
pqi_submit_raid_request_synchronous.constprop.78+0x23c/0x310 [smartpqi]
pqi_configure_events+0xec/0x1f8 [smartpqi]
pqi_ctrl_init+0x814/0xca0 [smartpqi]
pqi_pci_probe+0x400/0x46c [smartpqi]
local_pci_probe+0x48/0xb0
pci_device_probe+0x14c/0x1b0
really_probe+0x218/0x3fc
driver_probe_device+0x70/0x140
__driver_attach+0x11c/0x134
bus_for_each_dev+0x70/0xc8
driver_attach+0x30/0x38
bus_add_driver+0x1f0/0x294
driver_register+0x74/0x12c
__pci_register_driver+0x64/0x70
pqi_init+0xd0/0x10000 [smartpqi]
do_one_initcall+0x60/0x1d8
do_init_module+0x64/0x1f8
load_module+0x10ec/0x1350
__se_sys_finit_module+0xd4/0x100
__arm64_sys_finit_module+0x28/0x34
el0_svc_handler+0x104/0x160
el0_svc+0x8/0xc
This happens only in the following combinations:
1. smartpqi is built as module, not built-in;
2. We have a disk connected to smartpqi card;
3. Both kexec's 1st and 2nd kernels use this disk as Rootfs' mount point.
Signed-off-by: Yanjiang Jin <yanjiang.jin@hxt-semitech.com>
Acked-by: Don Brace <don.brace@microsemi.com>
[ Upstream commit 2ba55c9851d74eb015a554ef69ddf2ef061d5780 ]
Problem:
The Linux kernel takes a logical volume offline after a LUN reset. This is
generally accompanied by this message in the dmesg output:
Device offlined - not ready after error recovery
Root Cause:
The root cause is a "quirk" in the timeout handling in the Linux SCSI
layer. The Linux kernel places a 30-second timeout on most media access
commands (reads and writes) that it send to device drivers. When a media
access command times out, the Linux kernel goes into error recovery mode
for the LUN that was the target of the command that timed out. Every
command that timed out is kept on a list inside of the Linux kernel to be
retried later. The kernel attempts to recover the command(s) that timed out
by issuing a LUN reset followed by a TEST UNIT READY. If the LUN reset and
TEST UNIT READY commands are successful, the kernel retries the command(s)
that timed out.
Each SCSI command issued by the kernel has a result field associated with
it. This field indicates the final result of the command (success or
error). When a command times out, the kernel places a value in this result
field indicating that the command timed out.
The "quirk" is that after the LUN reset and TEST UNIT READY commands are
completed, the kernel checks each command on the timed-out command list
before retrying it. If the result field is still "timed out", the kernel
treats that command as not having been successfully recovered for a
retry. If the number of commands that are in this state are greater than
two, the kernel takes the LUN offline.
Fix:
When our RAIDStack receives a LUN reset, it simply waits until all
outstanding commands complete. Generally, all of these outstanding commands
complete successfully. Therefore, the fix in the smartpqi driver is to
always set the command result field to indicate success when a request
completes successfully. This normally isn’t necessary because the result
field is always initialized to success when the command is submitted to the
driver. So when the command completes successfully, the result field is
left untouched. But in this case, the kernel changes the result field
behind the driver’s back and then expects the field to be changed by the
driver as the commands that timed-out complete.
Signed-off-by: Kevin Barnett <kevin.barnett@microsemi.com>
[ Upstream commit 23c3828aa2f84edec7020c7397a22931e7a879e1 ]
With commit 09c2f95ad404 ("scsi: mpt3sas: Swap I/O memory read value back
to cpu endianness"), 64bit writes in _base_writeq() were rewritten to use
__raw_writeq() instad of writeq().
This introduced a bug apparent on powerpc64 systems such as the Raptor
Talos II that causes the HBA to drop from the PCIe bus under heavy load and
being reinitialized after a couple of seconds.
It can easily be triggered on affacted systems by using something like
fio --name=random-write --iodepth=4 --rw=randwrite --bs=4k --direct=0 \
--size=128M --numjobs=64 --end_fsync=1
fio --name=random-write --iodepth=4 --rw=randwrite --bs=64k --direct=0 \
a couple of times. In my case I tested it on both a ZFS raidz2 and a btrfs
raid6 using LSI 9300-8i and 9400-8i controllers.
The fix consists in resembling the write ordering of writeq() by adding a
mandatory write memory barrier before device access and a compiler barrier
afterwards. The additional MMIO barrier is superfluous.
Signed-off-by: Stephan Günther <moepi@moepi.net>
Reported-by: Matt Corallo <linux@bluematt.me>
Acked-by: Sreekanth Reddy <Sreekanth.Reddy@broadcom.com>
[ Upstream commit d5632b11f0a17efa6356311e535ae135d178438d ]
The kernel panic was observed after switch side perturbation,
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff8132b5a0>] strcmp+0x20/0x40
PGD 0 Oops: 0000 [#1] SMP
CPU: 8 PID: 647 Comm: kworker/8:1 Tainted: G W OE ------------ 3.10.0-693.el7.x86_64 #1
Hardware name: HPE ProLiant DL380 Gen10/ProLiant DL380 Gen10, BIOS U30 06/20/2018
Workqueue: slowpath-13:00. qed_slowpath_task [qed]
task: ffff880429eb8fd0 ti: ffff880429190000 task.ti: ffff880429190000
RIP: 0010:[<ffffffff8132b5a0>] [<ffffffff8132b5a0>] strcmp+0x20/0x40
RSP: 0018:ffff880429193c68 EFLAGS: 00010202
RAX: 000000000000000a RBX: 0000000000000002 RCX: 0000000000000000
RDX: 0000000000000001 RSI: 0000000000000001 RDI: ffff88042bda7a41
RBP: ffff880429193c68 R08: 000000000000ffff R09: 000000000000ffff
R10: 0000000000000007 R11: ffff88042b3af338 R12: ffff880420b007a0
R13: ffff88081aa56af8 R14: 0000000000000001 R15: ffff88081aa50410
FS: 0000000000000000(0000) GS:ffff88042fe00000(0000) knlGS:0000000000000000
CR2: 0000000000000000 CR3: 00000000019f2000 CR4: 00000000003407e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Stack:
ffff880429193d20 ffffffffc02a0c90 ffffc90004b32000 ffff8803fd3ec600
ffff88042bda7800 ffff88042bda7a00 ffff88042bda7840 ffff88042bda7a40
0000000129193d10 2e3836312e323931 ff000a342e363232 ffffffffc01ad99d
Call Trace:
[<ffffffffc02a0c90>] qedi_get_protocol_tlv_data+0x270/0x470 [qedi]
[<ffffffffc01ad99d>] ? qed_mfw_process_tlv_req+0x24d/0xbf0 [qed]
[<ffffffffc01653ae>] qed_mfw_fill_tlv_data+0x5e/0xd0 [qed]
[<ffffffffc01ad9b9>] qed_mfw_process_tlv_req+0x269/0xbf0 [qed]
Fix kernel NULL pointer deref by checking for session is online before
getting iSCSI TLV data.
Signed-off-by: Manish Rangankar <manish.rangankar@cavium.com>
Reviewed-by: Lee Duncan <lduncan@suse.com>
commit 44759979a49bfd2d20d789add7fa81a21eb1a4ab upstream.
Changing of caching mode via /sys/devices/.../scsi_disk/.../cache_type may
fail if device responds to MODE SENSE command with DPOFUA flag set, and
then checks this flag to be not set on MODE SELECT command.
In this scenario, when trying to change cache_type, write always fails:
# echo "none" >cache_type
bash: echo: write error: Invalid argument
And following appears in dmesg:
[13007.865745] sd 1:0:1:0: [sda] Sense Key : Illegal Request [current]
[13007.865753] sd 1:0:1:0: [sda] Add. Sense: Invalid field in parameter list
From SBC-4 r15, 6.5.1 "Mode pages overview", description of DEVICE-SPECIFIC
PARAMETER field in the mode parameter header:
The write protect (WP) bit for mode data sent with a MODE SELECT
command shall be ignored by the device server.
The DPOFUA bit is reserved for mode data sent with a MODE SELECT
command.
The remaining bits in the DEVICE-SPECIFIC PARAMETER byte are also reserved
and shall be set to zero.
[mkp: shuffled commentary to commit description]
Signed-off-by: Ivan Mironov <mironov.ivan@gmail.com>
commit 3f7e62bba0003f9c68f599f5997c4647ef5b4f4e upstream.
The commit 356fd2663cff ("scsi: Set request queue runtime PM status back to
active on resume") fixed up the inconsistent RPM status between request
queue and device. However changing request queue RPM status shall be done
only on successful resume, otherwise status may be still inconsistent as
below,
Request queue: RPM_ACTIVE
Device: RPM_SUSPENDED
This ends up soft lockup because requests can be submitted to underlying
devices but those devices and their required resource are not resumed.
For example,
After above inconsistent status happens, IO request can be submitted to UFS
device driver but required resource (like clock) is not resumed yet thus
lead to warning as below call stack,
WARN_ON(hba->clk_gating.state != CLKS_ON);
ufshcd_queuecommand
scsi_dispatch_cmd
scsi_request_fn
__blk_run_queue
cfq_insert_request
__elv_add_request
blk_flush_plug_list
blk_finish_plug
jbd2_journal_commit_transaction
kjournald2
We may see all behind IO requests hang because of no response from storage
host or device and then soft lockup happens in system. In the end, system
may crash in many ways.
Fixes: 356fd2663cff (scsi: Set request queue runtime PM status back to active on resume)
Reviewed-by: Bart Van Assche <bvanassche@acm.org>
invalid
commit 4e87eb2f46ea547d12a276b2e696ab934d16cfb6 upstream.
Certain older adapters such as the OneConnect OCe10100 may not have a valid
wqpcnt value. In this case, do not set queue->page_count to 0 in
lpfc_sli4_queue_alloc() as this will prevent the driver from initializing.
Fixes: 895427bd01 ("scsi: lpfc: NVME Initiator: Base modifications")
Cc: stable@vger.kernel.org # 4.11+
Reviewed-by: Laurence Oberman <loberman@redhat.com>
Tested-by: Laurence Oberman <loberman@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi
Pull SCSI fixes from James Bottomley:
"This is two simple target fixes and one discard related I/O starvation
problem in sd.
The discard problem occurs because the discard page doesn't have a
mempool backing so if the allocation fails due to memory pressure, we
then lose the forward progress we require if the writeout is on the
same device. The fix is to back it with a mempool"
* tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi:
scsi: sd: use mempool for discard special page
scsi: target: iscsi: cxgbit: add missing spin_lock_init()
scsi: target: iscsi: cxgbit: fix csk leak
"Three fixes: The t10-pi one is a regression from the 4.19 release, the
qla2xxx one is a 4.20 merge window regression and the bnx2fc is a very
old bug"
scsi: t10-pi: Return correct ref tag when queue has no integrity profile
scsi: bnx2fc: Fix NULL dereference in error handling
Revert "scsi: qla2xxx: Fix NVMe Target discovery"
When boxes are run near (or to) OOM, we have a problem with the discard
page allocation in sd. If we fail allocating the special page, we return
busy, and it'll get retried. But since ordering is honored for dispatch
requests, we can keep retrying this same IO and failing. Behind that IO
could be requests that want to free memory, but they never get the
chance. This means you get repeated spews of traces like this:
[1201401.625972] Call Trace:
[1201401.631748] dump_stack+0x4d/0x65
[1201401.639445] warn_alloc+0xec/0x190
[1201401.647335] __alloc_pages_slowpath+0xe84/0xf30
[1201401.657722] ? get_page_from_freelist+0x11b/0xb10
[1201401.668475] ? __alloc_pages_slowpath+0x2e/0xf30
[1201401.679054] __alloc_pages_nodemask+0x1f9/0x210
[1201401.689424] alloc_pages_current+0x8c/0x110
[1201401.699025] sd_setup_write_same16_cmnd+0x51/0x150
[1201401.709987] sd_init_command+0x49c/0xb70
[1201401.719029] scsi_setup_cmnd+0x9c/0x160
[1201401.727877] scsi_queue_rq+0x4d9/0x610
[1201401.736535] blk_mq_dispatch_rq_list+0x19a/0x360
[1201401.747113] blk_mq_sched_dispatch_requests+0xff/0x190
[1201401.758844] __blk_mq_run_hw_queue+0x95/0xa0
[1201401.768653] blk_mq_run_work_fn+0x2c/0x30
[1201401.777886] process_one_work+0x14b/0x400
[1201401.787119] worker_thread+0x4b/0x470
[1201401.795586] kthread+0x110/0x150
[1201401.803089] ? rescuer_thread+0x320/0x320
[1201401.812322] ? kthread_park+0x90/0x90
[1201401.820787] ? do_syscall_64+0x53/0x150
[1201401.829635] ret_from_fork+0x29/0x40
Ensure that the discard page allocation has a mempool backing, so we
know we can make progress.
If "interface" is NULL then we can't release it and trying to will only
lead to an Oops.
Fixes: aea71a024914 ("[SCSI] bnx2fc: Introduce interface structure for each vlan interface")
This reverts commit db186382af21e926e90df19499475f2552192b77.
This commit introduced regression with FCP discovery so revert it to fix
discovery for FCP luns.
Signed-off-by: Himanshu Madhani <hmadhani@marvell.com>
"Four obvious bug fixes. The vmw_pscsi is so old that it's amazing
no-one noticed before now"
scsi: storvsc: Fix a race in sub-channel creation that can cause panic
scsi: vmw_pscsi: Rearrange code to avoid multiple calls to free_irq during unload
scsi: libiscsi: Fix NULL pointer dereference in iscsi_eh_session_reset
scsi: lpfc: fix block guard enablement on SLI3 adapters
