path: root/drivers/scsi
2008-05-08drivers/scsi/dpt_i2o.c: fix build on alphaAndrew Morton
alpha: drivers/scsi/dpt_i2o.c:1997: error: implicit declaration of function 'adpt_alpha_info' drivers/scsi/dpt_i2o.c: At top level: drivers/scsi/dpt_i2o.c:2032: warning: conflicting types for 'adpt_alpha_info' drivers/scsi/dpt_i2o.c:2032: error: static declaration of 'adpt_alpha_info' follows non-static declaration drivers/scsi/dpt_i2o.c:1997: error: previous implicit declaration of 'adpt_alpha_info' was here Due to a copy-n-paste error in drivers/scsi/dpti.h. Fix that up and remove some of the many daft static-declarations-in-a-header which this driver enjoys. Cc: Miquel van Smoorenburg <miquels@cistron.nl> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-05CONFIG_SCSI_MAC_ESP needs CONFIG_SCSI_SPI_ATTRSGeert Uytterhoeven
The new mac_esp scsi driver needs CONFIG_SCSI_SPI_ATTRS, just like all other drivers using the new esp_scsi core. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: [SCSI] aic94xx: fix section mismatch [SCSI] u14-34f: Fix 32bit only problem [SCSI] dpt_i2o: sysfs code [SCSI] dpt_i2o: 64 bit support [SCSI] dpt_i2o: move from virt_to_bus/bus_to_virt to dma_alloc_coherent [SCSI] dpt_i2o: use standard __init / __exit code [SCSI] megaraid_sas: fix suspend/resume sections [SCSI] aacraid: Add Power Management support [SCSI] aacraid: Fix jbod operations scan issues [SCSI] aacraid: Fix warning about macro side-effects [SCSI] add support for variable length extended commands [SCSI] Let scsi_cmnd->cmnd use request->cmd buffer [SCSI] bsg: add large command support [SCSI] aacraid: Fix down_interruptible() to check the return value correctly [SCSI] megaraid_sas; Update the Version and Changelog [SCSI] ibmvscsi: Handle non SCSI error status [SCSI] bug fix for free list handling [SCSI] ipr: Rename ipr's state scsi host attribute to prevent collisions [SCSI] megaraid_mbox: fix Dell CERC firmware problem
2008-05-02[SCSI] aic94xx: fix section mismatchSam Ravnborg
Fix following warnings: WARNING: vmlinux.o(.data+0x17aa88): Section mismatch in reference from the variable asd_pcidev_data to the function .devinit.text:asd_aic9410_setup() WARNING: vmlinux.o(.data+0x17aa98): Section mismatch in reference from the variable asd_pcidev_data to the function .devinit.text:asd_aic9410_setup() WARNING: vmlinux.o(.data+0x17aaa8): Section mismatch in reference from the variable asd_pcidev_data to the function .devinit.text:asd_aic9405_setup() asd_pcidev_data is only used by __devinit asd_pci_probe. So mark is const and annotate it __devinitconst to fix the warnings. [akpm@linux-foundation.org: fix warning] Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-02[SCSI] u14-34f: Fix 32bit only problemAlan Cox
Another user of 32bit time Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-02[SCSI] dpt_i2o: sysfs codeMiquel van Smoorenburg
Create a /sys/class/dpt_i2o directory and populate it with dptiN directories. Each dptiN directory contains a "dev" file that makes udev create /dev/dptiN Signed-off-by: Miquel van Smoorenburg <miquels@cistron.nl> Acked-by: Mark Salyzyn <Mark_Salyzyn@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-02[SCSI] dpt_i2o: 64 bit supportMiquel van Smoorenburg
This is the code to actually support 64 bit platforms. 64 bit DMA is enabled on both x86_32 PAE and 64 bit platforms. This code is based in part on the unofficial adaptec 64-bit dpt_i2o driver update that I got from Mark Salyzyn at Adaptec. Signed-off-by: Miquel van Smoorenburg <miquels@cistron.nl> Acked-by: Mark Salyzyn <Mark_Salyzyn@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-02[SCSI] dpt_i2o: move from virt_to_bus/bus_to_virt to dma_alloc_coherentMiquel van Smoorenburg
Remove virt_to_bus/bus_to_virt code from dpt_i2o, and use dma_alloc_coherent() / dma_free_coherent(). This is in preparation of 64-bit support, dma_alloc_coherent() can allocate memory in the lower 32 bits of physical memory which is needed because the HBA only supports message blocks under 4GB This code is based in part on the unofficial adaptec 64-bit dpt_i2o driver update that I got from Mark Salyzyn at Adaptec. Signed-off-by: Miquel van Smoorenburg <miquels@cistron.nl> Acked-by: Mark Salyzyn <Mark_Salyzyn@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-02[SCSI] dpt_i2o: use standard __init / __exit codeMiquel van Smoorenburg
Update dpt_i2o.c to use the standard __init / __exit code instead of the legacy '#include "scsi_module.c"' code. This is needed in preparation of 64-bit support. scsi_module.c calls scsi_add_host() with the device pointer set to NULL, and that crashes code like arch/x64/kernel/pci-gart_64.c::need_iommu(). The reboot_notifier code is deleted because it wasn't compiled in ever anyway, and it would be useless to duplicate it in the new code. Signed-off-by: Miquel van Smoorenburg <miquels@cistron.nl> Acked-by: Mark Salyzyn <Mark_Salyzyn@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-02[SCSI] megaraid_sas: fix suspend/resume sectionsJiri Slaby
megaraid_sas suspend and resume are inappropriatelly placed in __devinit section. Remove those placements and make the stuff dependent on CONFIG_PM. While at it, mark remove function as __devexit. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Acked-by: "Yang, Bo" <Bo.Yang@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-02[SCSI] aacraid: Add Power Management supportMark Salyzyn
For firmware that supports the feature(s), add the ability to start or stop an array using the associated SCSI commands, to automatically manage the spin-up of an array on new I/O reporting back the appropriate check conditions and actions in cooperation with the normal timeout mechanisms and enable the blackout period management in the Firmware associated with the background spin-down of the arrays when the Firmware times out and deems the arrays as idle. Signed-off-by: Mark Salyzyn <aacraid@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-02[SCSI] aacraid: Fix jbod operations scan issuesMark Salyzyn
As JBOD devices (really just Simple Single Drive Volumes exported to the SCSI channel) are managed, they fail to update correctly when the driver triggers a SCSI scan. In addition, the ability to change multiple arrays or JBODs at the same time was resulting in dropped scans, set up a mechanism to issue a list of single target scans on a single configuration change notification from the Firmware. Performed some additional sundry cosmetic code style cleanups. Signed-off-by: Mark Salyzyn <aacraid@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-02[SCSI] aacraid: Fix warning about macro side-effectsMark Salyzyn
On some compile environments, warnings are produced regarding the usage of aac_logical_to_phys macro. Signed-off-by: Mark Salyzyn <aacraid@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-02[SCSI] add support for variable length extended commandsBoaz Harrosh
Add support for variable-length, extended, and vendor specific CDBs to scsi-ml. It is now possible for initiators and ULD's to issue these types of commands. LLDs need not change much. All they need is to raise the .max_cmd_len to the longest command they support (see iscsi patch). - clean-up some code paths that did not expect commands to be larger than 16, and change cmd_len members' type to short as char is not enough. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-02[SCSI] Let scsi_cmnd->cmnd use request->cmd bufferBoaz Harrosh
- struct scsi_cmnd had a 16 bytes command buffer of its own. This is an unnecessary duplication and copy of request's cmd. It is probably left overs from the time that scsi_cmnd could function without a request attached. So clean that up. - Once above is done, few places, apart from scsi-ml, needed adjustments due to changing the data type of scsi_cmnd->cmnd. - Lots of drivers still use MAX_COMMAND_SIZE. So I have left that #define but equate it to BLK_MAX_CDB. The way I see it and is reflected in the patch below is. MAX_COMMAND_SIZE - means: The longest fixed-length (*) SCSI CDB as per the SCSI standard and is not related to the implementation. BLK_MAX_CDB. - The allocated space at the request level - I have audit all ISA drivers and made sure none use ->cmnd in a DMA Operation. Same audit was done by Andi Kleen. (*)fixed-length here means commands that their size can be determined by their opcode and the CDB does not carry a length specifier, (unlike the VARIABLE_LENGTH_CMD(0x7f) command). This is actually not exactly true and the SCSI standard also defines extended commands and vendor specific commands that can be bigger than 16 bytes. The kernel will support these using the same infrastructure used for VARLEN CDB's. So in effect MAX_COMMAND_SIZE means the maximum size command scsi-ml supports without specifying a cmd_len by ULD's Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-02[SCSI] aacraid: Fix down_interruptible() to check the return value correctlyMark Salyzyn
On Apr 21, 2008, at 8:42 PM, Yinghai Lu wrote: > bisected to: > > commit e6990c6448ca9359b6d4ad027c0a6efbf4379e64 > Author: Mark Salyzyn <Mark_Salyzyn@adaptec.com> > Date: Mon Apr 14 14:20:16 2008 -0400 > > [SCSI] aacraid: Fix down_interruptible() to check the return value The return value for down_interruptible was incorrectly checked! updated patch enclosed. Signed-off-by: Mark Salyzyn <aacraid@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-01drivers/scsi/mvsas.c: fix printk warningsAndrew Morton
drivers/scsi/mvsas.c: In function `mvs_update_phyinfo': drivers/scsi/mvsas.c:2822: warning: long long unsigned int format, u64 arg (arg 5) drivers/scsi/mvsas.c:2822: warning: long long unsigned int format, u64 arg (arg 6) We do not know what type the arch uses to implement u64. Cc: Ke Wei <kewei@marvell.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01drivers/scsi/ncr53c8xx.c: fix warningAndrew Morton
drivers/scsi/ncr53c8xx.c: In function 'process_waiting_list': drivers/scsi/ncr53c8xx.c:8225: warning: suggest parentheses around assignment used as truth value recently added by commit 172c122df5186e7cbd413d61757ff90267331002 Author: Harvey Harrison <harvey.harrison@gmail.com> Date: Mon Apr 28 16:50:03 2008 -0700 scsi: fix integer as NULL pointer warnings Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29[SCSI] megaraid_sas; Update the Version and Changelogbo yang
Update the Version and Changelog for megaraid_sas Driver Signed-off-by: Bo Yang<bo.yang@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-29[SCSI] ibmvscsi: Handle non SCSI error statusBrian King
Adds support to the ibmvscsi driver to handle non SCSI error status. This is needed to support some new VIOS enhancements. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Santiago Leon <santil@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-29[SCSI] bug fix for free list handlingAlan D. Brunelle
commit: commit 542bd1377a963070bc4a03ff7d2690ddf3920596 Author: James Bottomley <James.Bottomley@HansenPartnership.com> Date: Mon Apr 21 10:57:20 2008 -0500 [SCSI] fix SLUB WARN_ON Fixed another problem in free list handling by moving list allocation from scsi_host_alloc() to scsi_add_host(). Unfortunately it introduced a new failure mode in that hosts can pass straight from alloc to put without going through add, leaving the free list uninitialised. Fix by checking shost->cmd_pool on the release path to see if it got initialised. Signed-off-by: Alan D. Brunelle <alan.brunelle@hp.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-29[SCSI] ipr: Rename ipr's state scsi host attribute to prevent collisionsBrian King
Due to recent device model changes it now no longer tolerates name collisions. This causes a problem for ipr whose "state" attribute collides with an identically named one in the SCSI mid-layer. Rename the ipr driver attribute to be more specific. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-29[SCSI] megaraid_mbox: fix Dell CERC firmware problemHannes Reinecke
Newer Dell CERC firmware (>= 6.62) implement a random deletion handling compatible with the legacy megaraid driver. The legacy handling shifted the target ID by 0x80 only for I/O commands (READ/WRITE/etc), whereas megaraid_mbox shifts the target ID always if random deletion is supported. The resulted in megaraid_mbox sending an INQUIRY to the wrong channel, and not finding any devices, obviously. So we disable the random deletion support if the offending firmware is found. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=6695 Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: "Yang, Bo" <Bo.Yang@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-29Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: block: Skip I/O merges when disabled block: add large command support block: replace sizeof(rq->cmd) with BLK_MAX_CDB ide: use blk_rq_init() to initialize the request block: use blk_rq_init() to initialize the request block: rename and export rq_init() block: no need to initialize rq->cmd with blk_get_request block: no need to initialize rq->cmd in prepare_flush_fn hook block/blk-barrier.c:blk_ordered_cur_seq() mustn't be inline block/elevator.c:elv_rq_merge_ok() mustn't be inline block: make queue flags non-atomic block: add dma alignment and padding support to blk_rq_map_kern unexport blk_max_pfn ps3disk: Remove superfluous cast block: make rq_init() do a full memset() relay: fix splice problem
2008-04-29Remove duplicated unlikely() in IS_ERR()Hirofumi Nakagawa
Some drivers have duplicated unlikely() macros. IS_ERR() already has unlikely() in itself. This patch cleans up such pointless code. Signed-off-by: Hirofumi Nakagawa <hnakagawa@miraclelinux.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Jeff Garzik <jeff@garzik.org> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Patrick McHardy <kaber@trash.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29scsi: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create() to make sure that ->proc_fops be setup before gluing PDE to main tree. Add correct ->owner to proc_fops to fix reading/module unloading race. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: switch /proc/scsi/device_info to seq_file interfaceAlexey Dobriyan
Note 1: 0644 should be used, but root bypasses permissions, so writing to /proc/scsi/device_info still works. Note 2: looks like scsi_dev_info_list is unprotected Note 3: probably make proc whine about "unwriteable but with ->write hook" entries. Probably. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: James Bottomley <James.Bottomley@SteelEye.com> Cc: Mike Christie <michaelc@cs.wisc.edu> Cc: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: remove proc_root from driversAlexey Dobriyan
Remove proc_root export. Creation and removal works well if parent PDE is supplied as NULL -- it worked always that way. So, one useless export removed and consistency added, some drivers created PDEs with &proc_root as parent but removed them as NULL and so on. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29block: use blk_rq_init() to initialize the requestFUJITA Tomonori
Any path needs to call it to initialize the request. This is a preparation for large command support, which needs to initialize the request in a proper way (that is, just doing a memset() will not work). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-29block: no need to initialize rq->cmd in prepare_flush_fn hookFUJITA Tomonori
The block layer initializes rq->cmd (queue_flush calls rq_init) so prepare_flush_fn hooks don't need to do that. The purpose of this patch is to remove sizeof(rq->cmd), as a preparation for large command support, which changes rq->cmd from the static array to a pointer. sizeof(rq->cmd) will not make sense. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-29block: make queue flags non-atomicNick Piggin
We can save some atomic ops in the IO path, if we clearly define the rules of how to modify the queue flags. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-28scsi: fix integer as NULL pointer warningsHarvey Harrison
drivers/scsi/aic7xxx/aic7770_osm.c:53:58: warning: Using plain integer as NULL pointer drivers/scsi/aic7xxx/aic7xxx_osm_pci.c:355:47: warning: Using plain integer as NULL pointer drivers/scsi/aic7xxx/aic7xxx_osm_pci.c:372:55: warning: Using plain integer as NULL pointer drivers/scsi/aha152x.c:997:28: warning: Using plain integer as NULL pointer drivers/scsi/aha152x.c:1003:28: warning: Using plain integer as NULL pointer drivers/scsi/aha152x.c:1165:46: warning: Using plain integer as NULL pointer drivers/scsi/fdomain.c:1446:40: warning: Using plain integer as NULL pointer drivers/scsi/sym53c8xx_2/sym_hipd.c:1650:51: warning: Using plain integer as NULL pointer drivers/scsi/sym53c8xx_2/sym_hipd.c:3171:42: warning: Using plain integer as NULL pointer drivers/scsi/sym53c8xx_2/sym_hipd.c:5732:52: warning: Using plain integer as NULL pointer drivers/scsi/ncr53c8xx.c:8189:31: warning: Using plain integer as NULL pointer drivers/scsi/ncr53c8xx.c:8225:34: warning: Using plain integer as NULL pointer drivers/scsi/dpt_i2o.c:156:32: warning: Using plain integer as NULL pointer drivers/scsi/ultrastor.c:954:42: warning: Using plain integer as NULL pointer drivers/scsi/ultrastor.c:1104:18: warning: Using plain integer as NULL pointer Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28ide: add ide_pad_transfer() helperBartlomiej Zolnierkiewicz
* Add ide_pad_transfer() helper (which uses ->{in,out}put_data methods internally so the transfer is also padded to drive+host requirements) and use it instead of ide_atapi_{write_zeros,discard_data}(). * Remove no longer needed ide_atapi_{write_zeros,discard_data}(). Cc: Borislav Petkov <petkovbb@gmail.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-28ide: add ide_execute_pkt_cmd() helperBartlomiej Zolnierkiewicz
Add ide_execute_pkt_cmd() helper for executing PACKET command, then convert ATAPI device drivers to use it. As a nice side-effect this fixes ide-{floppy,tape,scsi} w.r.t. ide_lock taking (ide-cd was OK). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-28ide-{floppy,tape,scsi}: 400ns delay is required after executing the commandBartlomiej Zolnierkiewicz
2008-04-28ide: always use ->OUTBSYNC method for executing commandsBartlomiej Zolnierkiewicz
Always use ->OUTBSYNC method for executing commands so the posting is done if needed (this affects only pmac and scc_pata host drivers at the moment). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-28ide: merge ->atapi_*put_bytes and ->ata_*put_data methodsBartlomiej Zolnierkiewicz
* Merge ->atapi_{in,out}put_bytes and ->ata_{in,out}put_data methods into new ->{in,out}put_data methods which take number of bytes to transfer as an argument and always do padding. While at it: * Use 'hwif' or 'drive->hwif' instead of 'HWIF(drive)'. There should be no functional changes caused by this patch (all users of ->ata_{in,out}put_data methods were using multiply-of-4 word counts). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (40 commits) [SCSI] jazz_esp, sgiwd93, sni_53c710, sun3x_esp: fix platform driver hotplug/coldplug [SCSI] aic7xxx: add const [SCSI] aic7xxx: add static [SCSI] aic7xxx: Update _shipped files [SCSI] aic7xxx: teach aicasm to not emit unused debug code/data [SCSI] qla2xxx: Update version number to 8.02.01-k2. [SCSI] qla2xxx: Correct regression in relogin code. [SCSI] qla2xxx: Correct misc. endian and byte-ordering issues. [SCSI] qla2xxx: make qla2x00_issue_iocb_timeout() static [SCSI] qla2xxx: qla_os.c, make 2 functions static [SCSI] qla2xxx: Re-register FDMI information after a LIP. [SCSI] qla2xxx: Correct SRB usage-after-completion/free issues. [SCSI] qla2xxx: Correct ISP84XX verify-chip response handling. [SCSI] qla2xxx: Wakeup DPC thread to process any deferred-work requests. [SCSI] qla2xxx: Collapse RISC-RAM retrieval code during a firmware-dump. [SCSI] m68k: new mac_esp scsi driver [SCSI] zfcp: Add some statistics provided by the FCP adapter to the sysfs [SCSI] zfcp: Print some messages only during ERP [SCSI] zfcp: Wait for free SBAL during exchange config [SCSI] scsi_transport_fc: fc_user_scan correction ...
2008-04-27[SCSI] jazz_esp, sgiwd93, sni_53c710, sun3x_esp: fix platform driver ↵Kay Sievers
hotplug/coldplug Since commit 43cc71eed1250755986da4c0f9898f9a635cb3bf Author: Kay Sievers <kay.sievers@vrfy.org> Date: Sat Aug 18 04:40:39 2007 +0200 platform: prefix MODALIAS with "platform:" the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable SCSI platform drivers, to re-enable auto loading. [dbrownell@users.sourceforge.net: more drivers, registration fixes] [akpm@linux-foundation.org: fix sgiwd93.c] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-27[SCSI] aic7xxx: add constDenys Vlasenko
This patch adds more const keywords where appropriate. Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Acked-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-27[SCSI] aic7xxx: add staticDenys Vlasenko
This patch adds static (and sometimes const) keywords where appropriate. Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Acked-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-27[SCSI] aic7xxx: Update _shipped filesHannes Reinecke
Update the precompiled sequencer code to match the latest aicasm changes. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-27[SCSI] aic7xxx: teach aicasm to not emit unused debug code/dataHannes Reinecke
Add a 'count' variable to each symbol which gets increased every time the symbol is referenced. And then modify the register definition to include counts for symbols which are referenced from the source code only and not from the sequencer code. This will give us an automatic usage count for the symbols with only minimal hand-crafting. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-27[SCSI] qla2xxx: Update version number to 8.02.01-k2.Andrew Vasquez
Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-27[SCSI] qla2xxx: Correct regression in relogin code.Andrew Vasquez
Commit 63a8651f2548c6bb5132c0b4e7dad4f57a9274db ([SCSI] qla2xxx: Correct infinite-login-retry issue.) introduced a small regression where a successful relogin would result in an fcport's loop_id to be incorrectly reset to FC_NO_LOOP_ID. Only clear-out loopid, if retries have been 'truly' exhausted. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-27[SCSI] qla2xxx: Correct misc. endian and byte-ordering issues.Seokmann Ju
There were several places in the driver which could cause byte ordering problem as provided by Al Viro <viro@ZenIV.linux.org.uk>. Signed-off-by: Seokmann Ju <seokmann.ju@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-27[SCSI] qla2xxx: make qla2x00_issue_iocb_timeout() staticAdrian Bunk
This patch makes the needlessly global qla2x00_issue_iocb_timeout() static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-27[SCSI] qla2xxx: qla_os.c, make 2 functions staticAdrian Bunk
This patch makes the following needlessly global functions static: - qla2x00_alloc_work() - qla2x00_post_work() Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-27[SCSI] qla2xxx: Re-register FDMI information after a LIP.Andrew Vasquez
Original code would (incorrectly) only re-register after a loop-down condition. Also, FDMI registration should be enabled by default. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-27[SCSI] qla2xxx: Correct SRB usage-after-completion/free issues.Andrew Vasquez
The driver is incorrectly assuming that the 'sp' reference held in qla2[x00|4xx]_abort_command() is valid after the mailbox command is issued to abort the exchange. It is *not*, as the command may be completed during interrupt context before control is returned to the mailbox caller. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
