path: root/drivers/scsi
2013-05-10Merge branch 'postmerge' into for-linusJames Bottomley
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10Merge branch 'misc' into for-linusJames Bottomley
2013-05-10[SCSI] qla2xxx: Update firmware link in Kconfig file.Chad Dupuis
Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com> Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10[SCSI] iscsi class, qla4xxx: fix sess/conn refcounting when find fns are usedMike Christie
This fixes a bug where the iscsi class/driver did not do a put_device when a sess/conn device was found. This also simplifies the interface by not having to pass in some arguments that were duplicated and did not need to be exported. Reported-by: Zhao Hongjiang <zhaohongjiang@huawei.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Acked-by: Vikas Chaudhary <vikas.chaudhary@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10[SCSI] sas: unify the pointlessly separated enums sas_dev_type and ↵James Bottomley
sas_device_type These enums have been separate since the dawn of SAS, mainly because the latter is a procotol only enum and the former includes additional state for libsas. The dichotomy causes endless confusion about which one you should use where and leads to pointless warnings like this: drivers/scsi/mvsas/mv_sas.c: In function 'mvs_update_phyinfo': drivers/scsi/mvsas/mv_sas.c:1162:34: warning: comparison between 'enum sas_device_type' and 'enum sas_dev_type' [-Wenum-compare] Fix by eliminating one of them. The one kept is effectively the sas.h one, but call it sas_device_type and make sure the enums are all properly namespaced with the SAS_ prefix. Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10[SCSI] pm80xx: thermal, sas controller config and error handling updateSakthivel K
Modified thermal configuration to happen after interrupt registration Added SAS controller configuration during initialization Added error handling logic to handle I_T_Nexus errors and variants [jejb: fix up tabs and spaces issues] Signed-off-by: Anand Kumar S <AnandKumar.Santhanam@pmcs.com> Acked-by: Jack Wang <jack_wang@usish.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10[SCSI] pm80xx: NCQ error handling changesSakthivel K
Handled NCQ errors in the low level driver as the FW is not providing the faulty tag for NCQ errors for libsas to recover. [jejb: fix checkpatch issues] Signed-off-by: Anand Kumar S <AnandKumar.Santhanam@pmcs.com> Acked-by: Jack Wang <jack_wang@usish.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10[SCSI] pm80xx: WWN Modification for PM8081/88/89 controllersSakthivel K
Individual WWN read operations based on controller. PM8081 - Read WWN from Flash VPD. PM8088/89 - Read WWN from EEPROM. PM8001 - Read WWN from NVM. Signed-off-by: Sakthivel K <Sakthivel.SaravananKamalRaju@pmcs.com> Signed-off-by: Anand Kumar S <AnandKumar.Santhanam@pmcs.com> Acked-by: Jack Wang <jack_wang@usish.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10[SCSI] pm80xx: Changed module name and debug messages updateSakthivel K
Changed name in driver to pm80xx. Updated debug messages. Signed-off-by: Sakthivel K <Sakthivel.SaravananKamalRaju@pmcs.com> Signed-off-by: Anand Kumar S <AnandKumar.Santhanam@pmcs.com> Acked-by: Jack Wang <jack_wang@usish.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10[SCSI] pm80xx: Firmware flash memory free fix, with addition of new memory ↵Sakthivel K
region for it Performing pci_free_consistent in tasklet had result in a core dump. So allocated a new memory region for it. Fix for passing proper address and operation in firmware flash update. Signed-off-by: Sakthivel K <Sakthivel.SaravananKamalRaju@pmcs.com> Signed-off-by: Anand Kumar S <AnandKumar.Santhanam@pmcs.com> Acked-by: Jack Wang <jack_wang@usish.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10[SCSI] pm80xx: SPC new firmware changes for device id 0x8081 aloneSakthivel K
Additional bar shift for new SPC firmware, applicable to device id 0x8081 only. Signed-off-by: Sakthivel K <Sakthivel.SaravananKamalRaju@pmcs.com> Signed-off-by: Anand Kumar S <AnandKumar.Santhanam@pmcs.com> Acked-by: Jack Wang <jack_wang@usish.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10[SCSI] pm80xx: Added SPCv/ve specific hardware functionalities and relevant ↵Sakthivel K
changes in common files Implementation of SPCv/ve specific hardware functionality and macros. Changing common functionalities wrt SPCv/ve operations. Conditional checks for SPC specific operations. Signed-off-by: Sakthivel K <Sakthivel.SaravananKamalRaju@pmcs.com> Signed-off-by: Anand Kumar S <AnandKumar.Santhanam@pmcs.com> Acked-by: Jack Wang <jack_wang@usish.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10[SCSI] pm80xx: MSI-X implementation for using 64 interruptsSakthivel K
Implementation of interrupt handlers and tasklets to support upto 64 interrupt for the device. Signed-off-by: Sakthivel K <Sakthivel.SaravananKamalRaju@pmcs.com> Signed-off-by: Anand Kumar S <AnandKumar.Santhanam@pmcs.com> Acked-by: Jack Wang <jack_wang@usish.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10[SCSI] pm80xx: Updated common functions common for SPC and SPCv/veSakthivel K
Update of function prototype for common function to SPC and SPCv/ve. Multiple queues implementation for IO. Signed-off-by: Sakthivel K <Sakthivel.SaravananKamalRaju@pmcs.com> Signed-off-by: Anand Kumar S <AnandKumar.Santhanam@pmcs.com> Acked-by: Jack Wang <jack_wang@usish.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10[SCSI] pm80xx: Multiple inbound/outbound queue configurationSakthivel K
Memory allocation and configuration of multiple inbound and outbound queues. Signed-off-by: Sakthivel K <Sakthivel.SaravananKamalRaju@pmcs.com> Signed-off-by: Anand Kumar S <AnandKumar.Santhanam@pmcs.com> Acked-by: Jack Wang <jack_wang@usish.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10[SCSI] pm80xx: Added SPCv/ve specific ids, variables and modify for SPCSakthivel K
Updated pci id table with device, vendor, subdevice and subvendor ids for 8081, 8088, 8089 SAS/SATA controllers. Added SPCv/ve related macros. Updated macros, hba info structure and other structures for SPCv/ve. Update of structure and variable names for SPC hardware functionalities. Signed-off-by: Sakthivel K <Sakthivel.SaravananKamalRaju@pmcs.com> Signed-off-by: Anand Kumar S <AnandKumar.Santhanam@pmcs.com> Acked-by: Jack Wang <jack_wang@usish.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10[SCSI] lpfc: fix up Kconfig dependenciesJames Bottomley
lpfc uses the generic checksum as well as the T10DIF one from the lib/ directory, so make sure they're selected. Reported-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10[SCSI] Handle MLQUEUE busy response in scsi_send_eh_cmndHannes Reinecke
scsi_send_eh_cmnd() is calling queuecommand() directly, so it needs to check the return value here. The only valid return codes for queuecommand() are 'busy' states, so we need to wait for a bit to allow the LLDD to recover. Based on an earlier patch from Wen Xiong. [jejb: fix confusion between msec and jiffies values and other issues] [bvanassche: correct stall_for interval] Cc: Wen Xiong <wenxiong@linux.vnet.ibm.com> Cc: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-08Merge branch 'for-3.10/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block core updates from Jens Axboe: - Major bit is Kents prep work for immutable bio vecs. - Stable candidate fix for a scheduling-while-atomic in the queue bypass operation. - Fix for the hang on exceeded rq->datalen 32-bit unsigned when merging discard bios. - Tejuns changes to convert the writeback thread pool to the generic workqueue mechanism. - Runtime PM framework, SCSI patches exists on top of these in James' tree. - A few random fixes. * 'for-3.10/core' of git://git.kernel.dk/linux-block: (40 commits) relay: move remove_buf_file inside relay_close_buf partitions/efi.c: replace useless kzalloc's by kmalloc's fs/block_dev.c: fix iov_shorten() criteria in blkdev_aio_read() block: fix max discard sectors limit blkcg: fix "scheduling while atomic" in blk_queue_bypass_start Documentation: cfq-iosched: update documentation help for cfq tunables writeback: expose the bdi_wq workqueue writeback: replace custom worker pool implementation with unbound workqueue writeback: remove unused bdi_pending_list aoe: Fix unitialized var usage bio-integrity: Add explicit field for owner of bip_buf block: Add an explicit bio flag for bios that own their bvec block: Add bio_alloc_pages() block: Convert some code to bio_for_each_segment_all() block: Add bio_for_each_segment_all() bounce: Refactor __blk_queue_bounce to not use bi_io_vec raid1: use bio_copy_data() pktcdvd: Use bio_reset() in disabled code to kill bi_idx usage pktcdvd: use bio_copy_data() block: Add bio_copy_data() ...
2013-05-07Merge branch 'akpm' (incoming from Andrew)Linus Torvalds
Merge more incoming from Andrew Morton: - Various fixes which were stalled or which I picked up recently - A large rotorooting of the AIO code. Allegedly to improve performance but I don't really have good performance numbers (I might have lost the email) and I can't raise Kent today. I held this out of 3.9 and we could give it another cycle if it's all too late/scary. I ended up taking only the first two thirds of the AIO rotorooting. I left the percpu parts and the batch completion for later. - Linus * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (33 commits) aio: don't include aio.h in sched.h aio: kill ki_retry aio: kill ki_key aio: give shared kioctx fields their own cachelines aio: kill struct aio_ring_info aio: kill batch allocation aio: change reqs_active to include unreaped completions aio: use cancellation list lazily aio: use flush_dcache_page() aio: make aio_read_evt() more efficient, convert to hrtimers wait: add wait_event_hrtimeout() aio: refcounting cleanup aio: make aio_put_req() lockless aio: do fget() after aio_get_req() aio: dprintk() -> pr_debug() aio: move private stuff out of aio.h aio: add kiocb_cancel() aio: kill return value of aio_complete() char: add aio_{read,write} to /dev/{null,zero} aio: remove retry-based AIO ...
2013-05-07aio: don't include aio.h in sched.hKent Overstreet
Faster kernel compiles by way of fewer unnecessary includes. [akpm@linux-foundation.org: fix fallout] [akpm@linux-foundation.org: fix build] Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07block_device_operations->release() should return voidAl Viro
The value passed is 0 in all but "it can never happen" cases (and those only in a couple of drivers) *and* it would've been lost on the way out anyway, even if something tried to pass something meaningful. Just don't bother. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-06[SCSI] sd: change to auto suspend modeLin Ming
Uses block layer runtime pm helper functions in scsi_runtime_suspend/resume for devices that take advantage of it. Remove scsi_autopm_* from sd open/release path and check_events path. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Aaron Lu <aaron.lu@intel.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-06[SCSI] sd: use REQ_PM in sd's runtime suspend operationLin Ming
With the introduction of REQ_PM, modify sd's runtime suspend operation functions to use that flag so that the operations to put the device into runtime suspended state(i.e. sync cache and stop device) will not affect its runtime PM status. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Aaron Lu <aaron.lu@intel.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-05megaraid: single_open() leakAl Viro
Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-04sun3_scsi: add ->show_info()Geert Uytterhoeven
Based on Al's changes to atari_scsi. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-02[SCSI] qla4xxx: Fix iocb_cnt calculation in qla4xxx_send_mbox_iocb()Vikas Chaudhary
Increment 'ha->iocb_cnt' before adding mbox_iocb to iocb queue. Signed-off-by: Vikas Chaudhary <vikas.chaudhary@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-02[SCSI] ufs: Correct the expected data transfersizeVinayak Holikatti
This patch corrects the expected data transfer size of the command UPIU. The current implementation of cmd->transfersize is wrong as it probably equal to sector size. With this implementation the transfer size is updated correctly Reported-by: KOBAYASHI Yoshitake <yoshitake.kobayashi@toshiba.co.jp> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Namjae Jeon <linkinjeon@gmail.com> Reviewed-by: Subhash Jadavani <subhashj@codeaurora.org> Tested-by: Maya Erez <merez@codeaurora.org> Signed-off-by: Santosh Yaraganavi <santoshsy@gmail.com> Signed-off-by: Vinayak Holikatti <vinholikatti@gmail.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-02[SCSI] ufs: Add Platform glue driver for ufshcdVinayak Holikatti
This patch adds Platform glue driver for ufshcd. Reviewed-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Namjae Jeon <linkinjeon@gmail.com> Reviewed-by: Subhash Jadavani <subhashj@codeaurora.org> Reviewed-by: Sujit Reddy Thumma <sthumma@codeaurora.org> Tested-by: Maya Erez <merez@codeaurora.org> Signed-off-by: Vinayak Holikatti <vinholikatti@gmail.com> Signed-off-by: Santosh Yaraganavi <santoshsy@gmail.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-02[SCSI] sd: fix array cache flushing bug causing performance problemsJames Bottomley
Some arrays synchronize their full non volatile cache when the sd driver sends a SYNCHRONIZE CACHE command. Unfortunately, they can have Terrabytes of this and we send a SYNCHRONIZE CACHE for every barrier if an array reports it has a writeback cache. This leads to massive slowdowns on journalled filesystems. The fix is to allow userspace to turn off the writeback cache setting as a temporary measure (i.e. without doing the MODE SELECT to write it back to the device), so even though the device reported it has a writeback cache, the user, knowing that the cache is non volatile and all they care about is filesystem correctness, can turn that bit off in the kernel and avoid the performance ruinous (and safety irrelevant) SYNCHRONIZE CACHE commands. The way you do this is add a 'temporary' prefix when performing the usual cache setting operations, so echo temporary write through > /sys/class/scsi_disk/<disk>/cache_type Reported-by: Ric Wheeler <rwheeler@redhat.com> Cc: <stable@vger.kernel.org> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-02[SCSI] qla2xxx: qla2x00_sp_compl can be static.Fengguang Wu
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-02[SCSI] qla2xxx: fix sparse warning "large integer implicitly truncated to ↵Armen Baloyan
unsigned type" Found by 0 day test project Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Armen Baloyan <armen.baloyan@qlogic.com> Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-02[SCSI] scsi_debug: fix logical block provisioning supportAkinobu Mita
provisioning map (map_storep) is a bitmap accessed by bitops. So the allocation size should be a multiple of sizeof(unsigned long) and also the bitmap should be cleared by using bitmap_clear() instead of memset(). Otherwise it will cause problem on big-endian architecture if the number of bits is not a multiple of BITS_PER_LONG. I tried testing the logical block provisioning support in scsi_debug, but it didn't work as I expected. For example, load scsi_debug module with UNMAP command supported and fill the storage with random data. # modprobe scsi_debug lbpu=1 # dd if=/dev/urandom of=/dev/sdb Then, try to unmap LBA 0, but Get LBA status reports: # sg_unmap --lba=0 --num=1 /dev/sdb # sg_get_lba_status --lba=0 /dev/sdb descriptor LBA: 0x0000000000000000 blocks: 16384 mapped This is unexpected result. Because UNMAP command to LBA 0 finished without any errors, but Get LBA status shows that LBA 0 is still mapped. This problem is due to the wrong translation between LBA and index of provisioning map. Fix it by using correct translation functions. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-02[SCSI] scsi_debug: clear correct memory region when LBPRZ is enabledAkinobu Mita
The function unmap_region() clears memory region specified as the logical block address and the number of logical blocks in ramdisk storage (fake_storep) if lbpu and lbprz module parameters are enabled. In the while loop of unmap_region(), it advances optimal unmap granularity in logical blocks. But it only clears one logical block at LBA 'block' per loop iteration. And furthermore, the 'block' is not pointing to a logical block address which should be cleared, it is a index of probisioning map (map_storep). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-02[SCSI] scsi_debug: prohibit scsi_debug_unmap_granularity == ↵Akinobu Mita
scsi_debug_unmap_alignment scsi_debug prohibits setting scsi_debug_unmap_alignment to be greater than scsi_debug_unmap_granularity. But setting them to be the same value is not prohibited. In this case, the only difference with scsi_debug_unmap_alignment == 0 is the logical blocks from 0 to scsi_debug_unmap_alignment - 1 cannot be unmapped. But the difference is not properly handled in the current code. So this prohibits such unusual setting. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-02[SCSI] scsi_debug: call map_region() and unmap_region() only when neededAkinobu Mita
If the logical block provisioning is not enabled, map_region() and unmap_region() have no effect and they don't need to be called. So this makes map_region() and unmap_region() to be called only when scsi_debug_lbp() returns true, i.e. logical block provisioning is enabled. While I'm at it, this also removes meaningless non-zero check for scsi_debug_unmap_granularity. Because scsi_debug_unmap_granularity cannot be zero with usual setting: scsi_debug_unmap_granularity is 1 by default, and it can be changed to zero with explicit module parameter setting only when the logical block provisioning is disabled. But it is only meaningful module parameter when the logical block provisioning is enabled. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-02[SCSI] sd_dif: problem with verify of type 1 protection information (PI)Jeremy Higdon
It appears to me that there is a problem with handling of type 1 protection information. It is considering a logical block reference tag of 0xffffffff to be an error, but it is actually valid any time ((lba & 0xffffffff) == 0xffffffff) [for example, 2TiB-1, 4TiB-1, 6TiB-1, etc.]. I'm going by what's written in 4.18.3 of SBC3, where there doesn't appear to be any invalid value for the reference tag. Signed-off-by: Jeremy Higdon <jeremy@sgi.com> Acked-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-02[SCSI] ipr: SATA DVD probing failed with 64bit adapterwenxiong@linux.vnet.ibm.com
Driver passed the wrong IOADL address to IOA adapter. The patch fixes the issue. Signed-off-by: Wen Xiong <wenxiong@linux.vnet.ibm.com> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-02[SCSI] scsi_transport_iscsi: fix error return code in iscsi_transport_init()Wei Yongjun
Fix to return -ENOMEM in the create workqueue error case instead of 0, as done elsewhere in this function. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-02Merge tag 'virtio-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull virtio & lguest updates from Rusty Russell: "Lots of virtio work which wasn't quite ready for last merge window. Plus I dived into lguest again, reworking the pagetable code so we can move the switcher page: our fixmaps sometimes take more than 2MB now..." Ugh. Annoying conflicts with the tcm_vhost -> vhost_scsi rename. Hopefully correctly resolved. * tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (57 commits) caif_virtio: Remove bouncing email addresses lguest: improve code readability in lg_cpu_start. virtio-net: fill only rx queues which are being used lguest: map Switcher below fixmap. lguest: cache last cpu we ran on. lguest: map Switcher text whenever we allocate a new pagetable. lguest: don't share Switcher PTE pages between guests. lguest: expost switcher_pages array (as lg_switcher_pages). lguest: extract shadow PTE walking / allocating. lguest: make check_gpte et. al return bool. lguest: assume Switcher text is a single page. lguest: rename switcher_page to switcher_pages. lguest: remove RESERVE_MEM constant. lguest: check vaddr not pgd for Switcher protection. lguest: prepare to make SWITCHER_ADDR a variable. virtio: console: replace EMFILE with EBUSY for already-open port virtio-scsi: reset virtqueue affinity when doing cpu hotplug virtio-scsi: introduce multiqueue support virtio-scsi: push vq lock/unlock into virtscsi_vq_done virtio-scsi: pass struct virtio_scsi to virtqueue completion function ...
2013-05-02[SCSI] lpfc 8.3.39: Update lpfc version for 8.3.39 driver releaseJames Smart
Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-02[SCSI] lpfc 8.3.39: Fixed driver handling of CLEAR_LA with NPIV enabled ↵James Smart
causing SID=0 frames out Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-02[SCSI] lpfc 8.3.39: Reduced tmo value set to FLOGI WQE for quick recovery ↵James Smart
from FLOGI sequence timeout Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-02[SCSI] lpfc 8.3.39: Add log message when completes with clean address bit ↵James Smart
set to zero Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-02[SCSI] lpfc 8.3.39: Fixed driver vector mapping to CPU affinityJames Smart
2013-05-02[SCSI] lpfc 8.3.39: Fixed iocb flags not being reset for scsi commandsJames Smart
2013-05-02[SCSI] lpfc 8.3.39: Fixed system panic during EEH recovery due to midlayer ↵James Smart
acting on outstanding I/O Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-02[SCSI] lpfc 8.3.39: Fixed not returning FAILED status when SCSI invoking ↵James Smart
host reset handler failed Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-02[SCSI] lpfc 8.3.39: Fixed bad book keeping in posting els sgls to portJames Smart
2013-05-02[SCSI] lpfc 8.3.39: Fixed deadlock between hbalock and nlp_lock useJames Smart
