path: root/drivers/scsi
2006-11-16Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: [SCSI] psi240i.c: fix an array overrun [SCSI] gdth: Fix && typos [SCSI] iscsi class: update version [SCSI] iscsi_tcp: fix xmittask oops [SCSI] iscsi: add newlines to debug messages [SCSI] iscsi: always release crypto [SCSI] sg: fix incorrect last scatg length [SCSI] 3ware 9000 add support for 9650SE [SCSI] aic94xx SCSI timeout fix: SMP retry fix. [SCSI] aic94xx SCSI timeout fix
2006-11-16[PATCH] scsi: clear garbage after CDBs on SG_IOTejun Heo
ATAPI devices transfer fixed number of bytes for CDBs (12 or 16). Some ATAPI devices choke when shorter CDB is used and the left bytes contain garbage. Block SG_IO cleared left bytes but SCSI SG_IO didn't. This patch makes SCSI SG_IO clear it and simplify CDB clearing in block SG_IO. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Mathieu Fluhr <mfluhr@nero.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Douglas Gilbert <dougg@torque.net> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: <stable@kernel.org> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-13[PATCH] SCSI core: always store >= 36 bytes of INQUIRY dataAlan Stern
This patch (as810c) copies a minimum of 36 bytes of INQUIRY data, even if the device claims that not all of them are valid. Often badly behaved devices put plausible data in the Vendor, Product, and Revision strings but set the Additional Length byte to a small value. Using potentially valid data is certainly better than allocating a short buffer and then reading beyond the end of it, which is what we do now. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-10[SCSI] psi240i.c: fix an array overrunAdrian Bunk
Fix an array overrun spotted by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-11-10[SCSI] gdth: Fix && typosJean Delvare
Fix uses of "&&" where "&" was obviously intended instead. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-11-10[SCSI] iscsi class: update versionMike Christie
Update version number Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-11-10[SCSI] iscsi_tcp: fix xmittask oopsMike Christie
XMSTATE_SOL_HDR could be set when the xmit thread tests it, but there may not be anything on the r2tqueue yet. Move the XMSTATE_SOL_HDR set before the addition to the queue to make sure that when we pull something off it it is valid. This does not add locks around the xmstate test or make that a atmoic_t because this is a fast path and if it is set when we test it we can handle it there without the overhead. Later on we check the xmitqueue for all requests with the session lock so we will not miss it. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-11-10[SCSI] iscsi: add newlines to debug messagesPete Wyckoff
Some messages from debug_scsi do not have trailing newlines, making console messages difficult to read. Fix that. Signed-off-by: Pete Wyckoff <pw@osc.edu> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-11-10[SCSI] iscsi: always release cryptoPete Wyckoff
Unconditionally free crypto state, as it is always allocated during TCP connection creation. Without this, crypto structures leak and crc32c module refcounts grow as connections are created and destroyed. Signed-off-by: Pete Wyckoff <pw@osc.edu> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-11-09[SCSI] sg: fix incorrect last scatg lengthDouglas Gilbert
For certain LLDs the sg driver can cause on oops when the transfer length is large and not a multiple of PAGE_SIZE. ChangeLog: - correct the length of the last scatter gather list element. - fix some printk()s that have the wrong function name. Signed-off-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-11-09[SCSI] 3ware 9000 add support for 9650SEadam radford
Updates the 3ware 9000 driver: - Free irq handler in __twa_shutdown(). - Serialize reset code. - Add support for 9650SE controllers. Signed-off-by: Adam Radford <linuxraid@amcc.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-11-09[SCSI] aic94xx SCSI timeout fix: SMP retry fix.malahal@us.ibm.com
Updating DDB0 inside aic94xx driver itself caused SMP command timeout. I hit this SMP timeout problem twice but I am not able to reproduce it since then. Here is a fix that retries an SMP command. Signed-off-by: Malahal Naineni <malahal@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-11-09[SCSI] aic94xx SCSI timeout fixmalahal@us.ibm.com
The patch updates DDB0 in the aic94xx driver itself. It doesn't supply or use lldd_port_formed field. DDB0 is updated prior to posting notification to libsas layer. Signed-off-by: Malahal Naineni <malahal@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-31[PATCH] SCSI: ISCSI build failureRandy Dunlap
SCSI_QLA_ISCSI needs to depend on NET to prevent build (link) failures that are caused by selecting SCSI_ISCSI_ATTRS. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-30[PATCH] lockdep: annotate DECLARE_WAIT_QUEUE_HEADPeter Zijlstra
kernel: INFO: trying to register non-static key. kernel: the code is fine but needs lockdep annotation. kernel: turning off the locking correctness validator. kernel: [<c04051ed>] show_trace_log_lvl+0x58/0x16a kernel: [<c04057fa>] show_trace+0xd/0x10 kernel: [<c0405913>] dump_stack+0x19/0x1b kernel: [<c043b1e2>] __lock_acquire+0xf0/0x90d kernel: [<c043bf70>] lock_acquire+0x4b/0x6b kernel: [<c061472f>] _spin_lock_irqsave+0x22/0x32 kernel: [<c04363d3>] prepare_to_wait+0x17/0x4b kernel: [<f89a24b6>] lpfc_do_work+0xdd/0xcc2 [lpfc] kernel: [<c04361b9>] kthread+0xc3/0xf2 kernel: [<c0402005>] kernel_thread_helper+0x5/0xb Another case of non-static lockdep keys; duplicate the paradigm set by DECLARE_COMPLETION_ONSTACK and introduce DECLARE_WAIT_QUEUE_HEAD_ONSTACK. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Greg KH <gregkh@suse.de> Cc: Markus Lidel <markus.lidel@shadowconnect.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Arjan van de Ven <arjan@infradead.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-25Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: (40 commits) [SCSI] aic79xx: Print out signalling [SCSI] aic7xxx: Remove slave_destroy [SCSI] aic79xx: set precompensation [SCSI] aic79xx: Fixup external device reset [SCSI] replace u8 and u32 with __u8 and __u32 in scsi.h for user space [SCSI] lpfc: fix printk format warning [SCSI] aic79xx: make ahd_set_tags() static [SCSI] aic7xxx: cleanups [SCSI] drivers/scsi: Handcrafted MIN/MAX macro removal [SCSI] scsi_debug: support REPORT TARGET PORT GROUPS [SCSI] qla1280 bus reset typo [SCSI] libiscsi: fix logout pdu processing [SCSI] libiscsi: fix aen support [SCSI] libiscsi: fix missed iscsi_task_put in xmit error path [SCSI] libiscsi: fix oops in connection create failure path [SCSI] iscsi class: fix slab corruption during restart [SCSI] Switch fdomain to the pci_get API [SCSI] add can_queue to host parameters [SCSI] megaraid_{mm,mbox}: 64-bit DMA capability fix [SCSI] aic94xx: Supermicro motherboards support ...
2006-10-25[SCSI] aic79xx: Print out signallingHannes Reinecke
This is a cross-port of a similar patch for aic7xxx; only it's a bit simpler here as we don't support HVD and all controller actually implement this register. I hope. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] aic7xxx: Remove slave_destroyHannes Reinecke
This is a cross-port from aic79xx; we still hit the occasional BUG_ON in slave_destroy. And again we don't really need the slave_destroy callback nor the ahc_linux_target structure at all. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] aic79xx: set precompensationHannes Reinecke
aic79xx has a special 'iocell' chip which handles the precompensation. If it's set via DV we should make sure to set the chip correctly, too. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] aic79xx: Fixup external device resetHannes Reinecke
Whenever an external device is resetted we really have to take care to keep the channel in sync. Just notifying SCSI-ML and retry is not enough as we have to make sure the SCSI bus is not getting confused, either. So whenever we detect an external reset we rewrite the command to TUR, disable packetized command and notify the internal engine that an abort has happened. This way we trigger a proper bus reset sequence and all devices will be renegotiated properly. Kudos to Justin Gibbs and Luben Tuikov for this idea. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] lpfc: fix printk format warningRandy Dunlap
Fix printk format warning: drivers/scsi/lpfc/lpfc_attr.c:597: warning: long long unsigned int format, uint64_t arg (arg 4) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: James Smart <James.Smart@Emulex.Com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] aic79xx: make ahd_set_tags() staticAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Acked-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] aic7xxx: cleanupsAdrian Bunk
- make needlessly global code static - #if 0 the following unused global functions: - aic79xx_core.c: ahd_print_scb - aic79xx_core.c: ahd_suspend - aic79xx_core.c: ahd_resume - aic79xx_core.c: ahd_dump_scbs - aic79xx_osm.c: ahd_softc_comp Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Acked-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] drivers/scsi: Handcrafted MIN/MAX macro removalAmol Lad
Cleanups done to use min/max macros from kernel.h. Handcrafted MIN/MAX macros are changed to use macros in kernel.h [akpm@osdl.org: fix warning] Signed-off-by: Amol Lad <amol@verismonetworks.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] scsi_debug: support REPORT TARGET PORT GROUPSHannes Reinecke
This patch adds support for REPORT TARGET PORT GROUPS. This is used eg for the multipathing priority callout to determine the path priority. With this patch multipath-tools can use the existing mpath_prio_alua callout to exercise the path priority grouping. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Douglas Gilbert <dougg@torque.net> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] qla1280 bus reset typoJes Sorensen
Fix typo in check of return value of qla1280_bus_reset() which would result in an adapter reset in addition to the bus reset. Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] libiscsi: fix logout pdu processingMike Christie
According to the iscsi RFC, we cannot send other requests if we have sent a logout pdu. This patch enforces this requirement by blocking the session and suspending the send thread. Userspace decides if we restart the connection or if we just free everything. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] libiscsi: fix aen supportMike Christie
We have been dropping the pdu. We should just send it to userspace and let it handle it. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] libiscsi: fix missed iscsi_task_put in xmit error pathMike Christie
from bhalevy@gmail.com: It looks like change 652 to libiscsi.c added some dead code around line 670 if (rc) { spin_unlock_bh(&conn->session->lock); goto again; } since 5 lines above we goto again if (rc). It looks like the previous if (rc) should go away if we want to put the ctask before breaking out of the while loop with "goto again" (see following patch). Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] libiscsi: fix oops in connection create failure pathMike Christie
If connection creation fails we end up calling list_del on a invalid struct. This then causes an oops. We are not acutally using the lists (old MCS code we thought might be useful elsewhere) so this patch just removes that code. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] iscsi class: fix slab corruption during restartMike Christie
The transport class recv mempools are causing slab corruption. We could hack around netlink's lack of mempool support like dm, but it is just too ulgy (dm's hack is ugly enough :) when you need to support broadcast. This patch removes the recv pools. We have not used them even when we were allocting 20 MB per session and the system only had 64 MBs. And we have no pools on the send side and have been ok there. When Peter's work gets merged we can use that since the network guys are in favor of that approach and are not going to add mempools everywhere. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] Switch fdomain to the pci_get APIAlan Cox
Doesn't make the hardware hot pluggable but does ensure the driver won't crash when another device is hot-unplugged at the wrong moment. Soon I propose to deprecate pci_find_device() and some of its friends. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] add can_queue to host parametersJames Bottomley
Debugging TCQ issues has shown me this is a very useful parameter to be able to view. Add it to he host class parameters. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] megaraid_{mm,mbox}: 64-bit DMA capability fixAndrey Mirkin
It is known that 2 LSI Logic MegaRAID SATA RAID Controllers (150-4 and 150-6) don't support 64-bit DMA. Unfortunately currently this check is wrong and driver sets 64-bit DMA mode for these devices. Signed-off-by: Andrey Mirkin <amirkin@sw.ru> Acked-by: "Ju, Seokmann" <Seokmann.Ju@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] aic94xx: Supermicro motherboards supportSergey Kononenko
Add PCI id. Plus correct for possibly missing resistor that can cause FLASHEX to have the wrong value. Signed-off-by: Sergey Kononenko <sergk@sergk.org.ua> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] ibmvscsi: correctly reenable CRQSantiago Leon
The "ibmvscsi: treat busy and error conditions separately" patch submitted by Dave Boutcher back in June incorrectly reenables the CRQ. The broken logic causes the adapter to get disabled if the CRQ connection happens to close temporarily. This patch "fixes that obviously wrong logic check" (Dave's words). Signed-off-by: Santiago Leon <santil@us.ibm.com> Signed-off-by: David Boutcher <sleddog@us.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] qla2xxx: Update version number to 8.01.07-k3.Andrew Vasquez
Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] qla2xxx: Correct QUEUE_FULL handling.Andrew Vasquez
- Drop queue-depths across all luns for a given fcport during TASK_SET_FULL statuses. - Ramp-up I/Os after throttling. - Consolidate completion-status handling of CS_QUEUE_FULL with CS_COMPLETE as ISP24xx firmware no longer reports CS_QUEUE_FULL. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] qla2xxx: Workaround D3 power-management issues.Andrew Vasquez
Early ISP2432 parts have a known hardware issue when coming out of a D3 hot state. This issue can result in a hung PCIe link. Recent firmwares contain a workaround whereby the stop-firmware mailbox command prevents the ISP from entering the D3 hot state. In order to ensure that the workaround succeeded the driver must verify that the stop-firmware mailbox command completes successfully. In the event of a failure, the driver attempts a shutdown-retry after resetting the ISP and re-executing firmware. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] qla2xxx: Check return value of sysfs_create_bin_file() usage.Andrew Vasquez
2006-10-25[SCSI] convert ninja driver to struct scsi_cmndHenrik Kretzschmar
Changes the obsolete typedefd Scsi_Cmnd to struct scsi_cmnd in the ninja scsi pcmcia driver. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] Scsi_Cmnd conversion in psi240i driverHenrik Kretzschmar
Changes the obsolete Scsi_Cmnd to struct scsi_cmnd in psi240i-driver. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] lpfc: check before dereference in lpfc_ct.cEric Sesterhenn
If we fail to allocate mp->virt during the first while loop iteration, mlist is still uninitialized, therefore we should check if before dereferencing. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Acked-by: James Smart <James.Smart@Emulex.Com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] scsi_lib.c: use BUILD_BUG_ONAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] fix typo in previous Scsi_Cmnd convertion in aic7xxx_old.cHenne
Fixes a typo in the aic7xxx_old.c. Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] Maintain module-parameter name consistency with qla2xxx/qla4xxx.Andrew Vasquez
2006-10-25[SCSI] aic7xxx: Adjust .max_sectorsHannes Reinecke
According to the adaptec sources aic7xxx / aic79xx really can do 4MB transfers. So we should adjust .max_sectors. Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] qla4xxx: fix double printk on loadDoug Maxey
There is a dup printk at the tail of qla4xxx_module_init(). Remove the first instance as it's before the complete success of the function. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] tmscsim: set max_sectorsGuennadi Liakhovetski
AM53C974A's Start Transfer Counter register has 24 bits, thus maximum transfer length is 16MiB. But the maximum I can test is 8MiB, so use that until somebody tests 16MiB. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-10-25[SCSI] st: Fixup -ENOMEDIUMKai Makisara
Based on the original patch from Hannes Reinecke <hare@suse.de> Fix st_open() to return -ENOMEDIUM instead of -EIO if no medium is found. Signed-off-by: Kai Makisara <kai.makisara@kolumbus.fi> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
