path: root/drivers/serial/8250.h
2008-05-318250 Serial Driver: revert extra IRQ flag definition patchBryan Wu
As Russell pointed out, original patch will break some serial configurations because of the dependency of the <asm/serial.h> header file. Revert it first and try to find out other solution later Cc: Javier Herrero <jherrero@hvsistemas.es> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Russell King <rmk+lkml@arm.linux.org.uk> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-05-178250 Serial Driver: Added support for 8250-class UARTs in HV Sistemas H8606 ↵Javier Herrero
board Added support for 8250-class UARTs in HV Sistemas H8606 board, modification in 8250.c driver for correct compilation with Blackfin Besides, I think that there is more people using 8250-class UARTs with a different hardware than the H8606 board. This code can be shared by them. Signed-off-by: Javier Herrero <jherrero@hvsistemas.es> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2006-01-04[SERIAL] Remove _INLINE_Russell King
2005-11-06[SERIAL] Support Au1x00 8250 UARTs using the generic 8250 driver.Pantelis Antoniou
The offsets of the registers are in a different place, and some parts cannot handle a full set of modem control signals. Signed-off-by: Pantelis Antoniou <pantelis@embeddedalley.ocm> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-01[SERIAL] Move serial8250_*_port prototypes to linux/serial_8250.hRussell King
2005-06-23[PATCH] Serial: Mobility's 16550A ports need a helping handRussell King
The Mobility 16550A serial ports don't behave the same as standard 16550A ports, and need a helping hand to get them going once the transmitter has drained and been disabled. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-23[PATCH] Serial: Convert 8250 revision-based bug fixes to bug bitmaskRussell King
For some 8250 port types, we used to check the type of the port, and then determine whether the chip revision means the device is buggy. Instead, introduce a bit array, and set the appropriate bit(s) when we discover a buggy device. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
