path: root/drivers/serial/8250.h
2006-01-04[SERIAL] Remove _INLINE_Russell King
2005-11-06[SERIAL] Support Au1x00 8250 UARTs using the generic 8250 driver.Pantelis Antoniou
The offsets of the registers are in a different place, and some parts cannot handle a full set of modem control signals. Signed-off-by: Pantelis Antoniou <pantelis@embeddedalley.ocm> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-01[SERIAL] Move serial8250_*_port prototypes to linux/serial_8250.hRussell King
2005-06-23[PATCH] Serial: Mobility's 16550A ports need a helping handRussell King
The Mobility 16550A serial ports don't behave the same as standard 16550A ports, and need a helping hand to get them going once the transmitter has drained and been disabled. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-23[PATCH] Serial: Convert 8250 revision-based bug fixes to bug bitmaskRussell King
For some 8250 port types, we used to check the type of the port, and then determine whether the chip revision means the device is buggy. Instead, introduce a bit array, and set the appropriate bit(s) when we discover a buggy device. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
