Platform driver support
Signed-off-by: Fred.fan <r01011@freescale.com>
Signed-off-by: Alejandro Gonzalez <alex.gonzalez@digi.com>
Add D-UART driver support for MX28
Signed-off-by: Fred Fan <r01011@freescale.com>
Signed-off-by: Robby Cai <R63905@freescale.com>
This is i.MX BSP 5.0.0 release ported to 2.6.31
Signed-off-by: Rob Herring <r.herring@freescale.com>
Signed-off-by: Alan Tull <r80115@freescale.com>
Signed-off-by: Xinyu Chen <xinyu.chen@freescale.com>
The typo causes drivers/serial/s3c6400.c not being built for s3c6400 platform.
Signed-off-by: Ramax Lo <ramaxlo@gmail.com>
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Signed-off-by: Brian Swetland <swetland@google.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
.ko is normally not included in Kconfig help, make it consistent.
Signed-off-by: Pavel Machek <pavel@ucw.cz>
for calculation of numerator and denominator
used in baud rate setting, use generic library function
for optimum settings.
Signed-off-by: Oskar Schirmer <os@emlix.com>
Driver for the UART found in the Timberdale FPGA
Signed-off-by: Richard Röjfors <richard.rojfors.ext@mocean-labs.com>
* 'for-linus' of git://git.monstr.eu/linux-2.6-microblaze: (60 commits)
microblaze_v8: Add MAINTAINERS fragment
microblaze_v8: Uartlite for Microblaze
microblaze_v8: Makefiles for Microblaze cpu
microblaze_v8: Kconfig patches
microblaze_v8: Interrupt handling and timer support
microblaze_v8: syscalls.h
microblaze_v8: pci headers
microblaze_v8: Kbuild file
microblaze_v8: string.h thread_info.h
microblaze_v8: unistd.h
microblaze_v8: fcntl.h sockios.h ucontext.h
microblaze_v8: pool.h socket.h
microblaze_v8: device.h param.h topology.h
microblaze_v8: headers files entry.h current.h mman.h registers.h sembuf.h
microblaze_v8: namei.h
microblaze_v8: gpio.h, serial.h
microblaze_v8: headers simple files - empty or redirect to asm-generic
microblaze_v8: sigcontext.h siginfo.h
microblaze_v8: termbits.h termios.h
microblaze_v8: stats headers
Signed-off-by: Mike Frysinger <vapier.adi@gmail.com>
Signed-off-by: Bryan Wu <cooloney@kernel.org>
Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Depend on KGDB_SERIAL_CONSOLE being set to N rather than !Y, since it can
be built as a module.
Both software emulated and hardware based CTS and RTS are enabled in
serial driver.
The CTS RTS PIN connection on BF548 UART port is defined as a modem
device not as a host device. In order to test it under Linux, please
nake a cross UART cable to exchange CTS and RTS signal.
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
(akpm: queued pending confirmation of the new major number)
[randy.dunlap@oracle.com: select SERIAL_CORE]
Signed-off-by: Christian Pellegrin <chripell@fsfe.org>
Enable third UART on BF538/9
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com>
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Acked-by: Peter Korsgaard <jacmet@sunsite.dk>
Acked-by: John Linn <john.linn@xilinx.com>
Acked-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com>
Acked-by: John Williams <john.williams@petalogix.com>
Signed-off-by: Eric Miao <eric.miao@marvell.com>
Enabled serial UART driver for PNX833X devices.
Signed-off-by: Ihar Hrachyshka <ihar.hrachyshka@gmail.com>
Signed-off-by: Alan Cox <number6@the-village.bc.nu>
* master.kernel.org:/home/rmk/linux-2.6-arm: (23 commits)
[ARM] fix pxa930_trkball build errors
[ARM] fix netx
[ARM] fix pnx4008
[ARM] fix pxa
[ARM] remove missed CLPS7500 defconfig
[ARM] clps711x: fix warning in edb7211-mm.c
[ARM] clps711x: fix warning in fortunet
[ARM] fix AT91, davinci, h720x, ks8695, msm, mx2, mx3, netx, omap1, omap2, pxa, s3c
[ARM] Fix realview build
[ARM] 5357/1: Kirkwood: add missing ge01 tclk initialization
[ARM] 5358/1: AT2440EVB: Use new include path of mci.h
[ARM] 5361/1: mv78xx0: fix compilation error
[ARM] 5360/1: Orion: fix compilation error
[ARM] 5359/1: Kirkwood: fix compilation error
[ARM] S3C64XX: Fix EINT group macro definition
[ARM] Ensure CONFIG_SERIAL_SAMSUNG_UARTS is always set.
[ARM] S3C24XX: Add gpio_to_irq implementation
[ARM] S3C24XX: Add gpio_to_irq() facility
[ARM] footbridge: dc21285.c warning fixes
[ARM] footbridge: add isa_init_irq() to common header
Always set CONFIG_SERIAL_SAMSUNG_UARTS when building any
of the S3C platforms as even if the driver is not selected
there it is still the facility for the machine files to
register configuration data for the possibility of the
driver being built.
Add support for the nwp serial device which is connected to a DCR bus. It
uses the of_serial device driver to determine necessary properties from
the device tree. The supported device is added as serial port number 85.
NWP stands for network processor and it is part of the QPACE - Quantum
Chromodynamics Parallel Computing on the Cell Broadband Engine project.
The implementation is a lightweight uart implementation with the focus
to consume as little resources as possible and it is connected to a
DCR bus.
Signed-off-by: Benjamin Krill <ben@codiert.org>
Update the serial driver to handle the 4 ports of the
S3C2443 and S364XX series.
Add support to the Samsung serial driver for the S3C6400
and S3C6410 serial ports.
Add serial support for S3C24A0, based on current S3C2410
UART driver. It adds necessary new defines in regs-serial.h
for S3C24A0 and the code to support this device in
drivers/serial/s3c24a0.c
Signed-off-by: Sandeep Patil <sandeep.patil@azingo.com>
Make the netX serial driver tristate (as the help text implied). Make the
serial driver build correctly if the netX serial console is disabled. Do not
allow the netX serial console if the netX serial driver is build as a module.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
The SERIAL_SAMSUNG_DEBUG used printascii() to avoid debugging
through itself when selected as a console. Disable this option
when DEBUG_LL is not set (printascii is unavailable).
Manual fixup of conflicts on:
arch/powerpc/include/asm/dcr-regs.h
drivers/net/ibm_newemac/core.h
This requires three changes:
1) Remove !SPARC restriction in Kconfig.
2) Move Sparc specific serial drivers before 8250, so that serial
console devices don't change names on us, even if 8250 finds
devices.
3) Since the Sparc specific serial drivers try to use the
same major/minor device namespace as 8250, some coordination
is necessary. Use the sunserial_*() layer routines to allocate
minor number space within TTY_MAJOR when CONFIG_SPARC.
This has no effect on other platforms.
Thanks to Josip Rodin for bringing up this issue and testing
plus debugging various revisions of this patch.
Signed-off-by: Alan Cox <alan@redhat.com>
This patch contains the scheduled removal of the obsolete
SERIAL_COLDFIRE driver.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
With the change to device tree based setup we no longer need the explicit
Kconfig options for each SCC{1,4} or SMC{1,2} port.
into for-rmk
Trying to compile the v850 port brings many compile errors, one of them exists
since at least kernel 2.6.19.
There also seems to be noone willing to bring this port back into a usable
state.
This patch therefore removes the v850 port.
If anyone ever decides to revive the v850 port the code will still be
available from older kernels, and it wouldn't be impossible for the port to
reenter the kernel if it would become actively maintained again.
Acked-by: Greg Ungerer <gerg@uclinux.org>
This patch removes CVS keywords that weren't updated for a long time in
comments, printk's and MODULE_DESCRIPTION's (no printk's or
MODULE_DESCRIPTION's are completely removed).
While doing this I also found and fixed a missing \n in a printk
in m32r_sio.c
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into for-rmk
The SERIAL_SAMSUNG needs SERIAL_CORE but doesn't select it, leading to a
build failure. Adding a 'select SERIAL_CORE' cure the trouble.
Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org>
arch/arm/mm/Kconfig
This patch adds MX3 support for the i.MX internal uart driver.
The S3C2410 serial driver in drivers/serial/s3c2410.c has been
growing bigger with the addition of more variants of this hardware
with the growing Samsung SoCs range. As such, it would be
easier to split this code up into a core and per-cpu drivers to
make driver addition easier, and the core smaller.
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Schedule a removal for this driver. Alternative driver is available for
a while now.
Signed-off-by: Sebastian Siewior <bigeasy@linutronix.de>
Acked-by: Alan Cox <alan@redhat.com>
Signed-off-by: Bryan Wu <bryan.wu@analog.com>
Cc: Alan Cox <alan@redhat.com>
Move the code registering the Alchemy UART platform devices from
drivers/serial/ to its proper place, into the Alchemy platform code. Fix
the related Kconfig entry, while at it...
polled console handling support, to access a console in an irq-less
way while in debug or irq context.
absolutely zero impact as long as CONFIG_CONSOLE_POLL is disabled.
(which is the default)
[ jan.kiszka@siemens.com: lots of cleanups ]
[ mingo@elte.hu: redesign, splitups, cleanups. ]
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
Signed-off-by: Jan Kiszka <jan.kiszka@web.de>
This patch is based on the DMA-patch by Chip Coldwell for the AT91/AT32 serial
USARTS, with some tweaks to make it apply neatly on top of the other patches
in this series.
The RX and TX code has been moved to a tasklet and reworked a bit. Instead of
depending on the ENDRX and TIMEOUT bits in CSR, we simply grab as much data as
we can from the DMA buffers. I think this closes a race where the ENDRX bit
is set after we read CSR but before we read RPR, although I haven't confirmed
this.
Similarly, the two TX handlers (ENDTX and TXBUFE) have been combined into one.
Since the current code only uses a single TX buffer, there's no point in
handling those interrupts separately.
This also fixes a DMA sync bug in the original patch.
[linux@bohmer.net: rebased onto irq-splitup patch]
[hskinnemoen@atmel.com: moved to tasklet, fixed dma bug, misc cleanups]
[hskinnemoen@atmel.com: atmel_serial dma: Misc fixes and cleanups]
Signed-off-by: Remy Bohmer <linux@bohmer.net>
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Cc: Andrew Victor <linux@maxim.org.za>
Tested-by: Marc Pignat <marc.pignat@hevs.ch>
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'for-2.6.25' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (69 commits)
[POWERPC] Add SPE registers to core dumps
[POWERPC] Use regset code for compat PTRACE_*REGS* calls
[POWERPC] Use generic compat_sys_ptrace
[POWERPC] Use generic compat_ptrace_request
[POWERPC] Use generic ptrace peekdata/pokedata
[POWERPC] Use regset code for PTRACE_*REGS* requests
[POWERPC] Switch to generic compat_binfmt_elf code
[POWERPC] Switch to using user_regset-based core dumps
[POWERPC] Add user_regset compat support
[POWERPC] Add user_regset_view definitions
[POWERPC] Use user_regset accessors for GPRs
[POWERPC] ptrace accessors for special regs MSR and TRAP
[POWERPC] Use user_regset accessors for SPE regs
[POWERPC] Use user_regset accessors for altivec regs
[POWERPC] Use user_regset accessors for FP regs
[POWERPC] mpc52xx: fix compile error introduce when rebasing patch
[POWERPC] 4xx: PCIe indirect DCR spinlock fix.
[POWERPC] Add missing native dcr dcr_ind_lock spinlock
[POWERPC] 4xx: Fix offset value on Warp board
[POWERPC] 4xx: Add 440EPx Sequoia ehci dts entry
Reformat the Kconfig entries and update descriptions for accuracy. Select the
driver by default for configurations of interest. For the curious: 32BIT
means only 32-bit DECstations support the device, not that the driver is not
64-bit clean; I have not checked that either though.
Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org>
Cc: Jiri Slaby <jirislaby@gmail.com>
into for-2.6.25
