path: root/drivers/serial/crisv10.c
2011-01-13tty: move drivers/serial/ to drivers/tty/serial/Greg Kroah-Hartman
The serial drivers are really just tty drivers, so move them to drivers/tty/ to make things a bit neater overall. This is part of the tty/serial driver movement proceedure as proposed by Arnd Bergmann and approved by everyone involved a number of months ago. Cc: Arnd Bergmann <arnd@arndb.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Rogier Wolff <R.E.Wolff@bitwizard.nl> Cc: Michael H. Warfield <mhw@wittsend.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-28CRIS: Fix RS485 delay handling.Jesper Nilsson
Very recently, the RS485 interface has been fixed by adding two further fields (see commit 1b6331848b69d1ed165a6bdc75c4046d68767563). Check the value of the flag SER_RS485_RTS_BEFORE_SEND before delaying. Signed-off-by: Claudio Scordino <claudio@evidence.eu.com> Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
2010-10-28Add missing "struct" to in sizeof.Jesper Nilsson
Lead to a compile error when the struct was no longer typedef'd. Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
2010-08-10serial: crisv10: formatting of pointers in printk()Kulikov Vasiliy
Use %p instead of %08x in printk(). Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10tty: release BTM while sleeping in block_til_readyArnd Bergmann
Most tty drivers may block while opening a device. Since this possibly depends on another thread closing it first and both threads may need the BTM, we need to release it here. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10tty: untangle locking of wait_until_sentArnd Bergmann
Some wait_until_sent versions require the big tty mutex, others don't and some callers of wait_until_sent already hold it while other don't. That leads to recursive use of the BTM in these functions, which we're trying to get rid of. This turns all cleans up the locking there so that the driver's wait_until_sent function never takes the BTM itself if it is already called with that lock held. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10tty: introduce wait_event_interruptible_ttyArnd Bergmann
Calling wait_event_interruptible implicitly releases the BKL when it sleeps, but we need to do this explcitly when we have converted it to a mutex. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10tty: replace BKL with a new tty_lockArnd Bergmann
As a preparation for replacing the big kernel lock in the TTY layer, wrap all the callers in new macros tty_lock, tty_lock_nested and tty_unlock. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-09CRIS: ioctl for getting RS485 informationClaudio Scordino
Add ioctl to CRIS serial driver to get RS485 data from user-space. Signed-off-by: Claudio Scordino <claudio@evidence.eu.com> Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
2009-08-31CRIS: fix defconfig build failureIngo Molnar
The CRIS defconfig fails to build with: drivers/serial/crisv10.c: In function 'rs_wait_until_sent': drivers/serial/crisv10.c:3926: error: implicit declaration of function 'lock_kernel' drivers/serial/crisv10.c:3943: error: implicit declaration of function 'unlock_kernel' Include smp_lock.h. LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
2009-05-02CRISv10: fix serial driver proc-usageJesper Nilsson
drivers/serial/crisv10.c:4428: error: unknown field 'read_proc' specified in initializer Commit 0f043a81ebe84be3576667f04fdda481609e3816 ("proc tty: remove struct tty_operations::read_proc") removes the read_proc entry from struct tty_operations. Rework the proc handling in the CRISv10 serial driver to use proc_fops instead. Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Mikael Starvik <starvik@axis.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07tty: Use the generic RS485 ioctl on CRISClaudio Scordino
Use the new general RS485 Linux data structure (introduced by Alan with commit number c26c56c0f40e200e61d1390629c806f6adaffbcc) in the Cris architecture too (currently, Cris still uses the old private data structure instead of the new one). Signed-off-by: Claudio Scordino <claudio@evidence.eu.com> Tested-by: Hinko Kocevar <hinko.kocevar@cetrtapot.si> Tested-by: Janez Cufer <janez.cufer@cetrtapot.si> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06trivial: fix then -> than typos in comments and documentationFrederik Schwarzer
- (better, more, bigger ...) then -> (...) than Signed-off-by: Frederik Schwarzer <schwarzerf@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-10-29[CRIS] Move header files from include to arch/cris/include.Jesper Nilsson
Change all users of header files to correct path. Remove some unneeded headers for arch-v32. Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
2008-10-13tty: simplify ktermios allocationAlan Cox
Copy the simplification from the pty unix98 special case to the generic one. This allows us to kill off driver->termios_locked entirely which is nice. We have to whack bits of the cris driver as it meddles in places it shouldn't providing its own arrays that were never used anyway. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13drivers/serial/crisv10.c: add missing put_tty_driverJulia Lawall
alloc_tty_driver is called at the beginning of the function containing the lines of code shown in the patch. Thus, put_tty_driver is needed before returning in the error handling code. The semantic match that finds this problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @nr exists@ local idexpression x; expression E,f; position p1,p2,p3; identifier l; statement S; @@ x = alloc_tty_driver@p1(...) ... if (x == NULL) S ... when != E = x when != put_tty_driver(x) when != goto l; ( return \(0\|x\); | return@p3 ...; ) @script:python@ p1 << nr.p1; p3 << nr.p3; @@ print "%s: call on line %s not freed or saved before return on line %s" % (p1[0].file,p1[0].line,p3[0].line) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-04cris: Fixup compile problemsAlan Cox
It now compiles with the tty changes but isn't tested (which has to be better than not compiling.. Closes bug #11218 Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20Fix compile errors in SGI console drivers (linux-next tree)Takashi Iwai
The below is the patch to replace blindly all possible places, including Jack's fixes. Signed-off-by: Takashi Iwai <tiwai@suse.de> (Reviewed and checked rather than blindly added) Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-12cris: Fix compile failure due to typo in serial driverAlan Cox
2008-04-30serial: replace remaining __FUNCTION__ occurrencesHarvey Harrison
2008-04-30tty/serial: lay the foundations for the next set of reworksAlan Cox
- Stop drivers calling their own flush method indirectly, it obfuscates code and it will change soon anyway - A few more lock_kernel paths temporarily needed in some driver internal waiting code - Remove private put_char method that does a write call for one char - we have that anyway - Most but not yet all of the termios copy under lock fixing (some has other dependencies to follow) - Note a few locking bugs in drivers found in the process - Kill remaining [ab]users of TIOCG/SSOFTCAR in the driver, these must go to fix the termios locking Signed-off-by: Alan Cox <alan@redhat.com> Cc: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28crisv10: prepare for BKL push downAlan Cox
Just the modem bits this time Signed-off-by: Alan Cox <alan@redhat.com> Cc: Mikael Starvik <mikael.starvik@axis.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Char: char/serial, remove SERIAL_TYPE_NORMAL redefinesJiri Slaby
Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-14CRISv10 serial driver rewriteJesper Nilsson
New and improved serial driver for CRISv10, take three, with improvements suggested by Jiri Slaby. - Call wait_event_interruptible with a _correct_ and sensible condition. - Removed superfluous test of info->flags & ASYNC_CLOSING, since that is done by wait_event_interruptible. - Moved common code for deregistering DMA and IRQ to deinit_port function. - Use setup_timer when initializing flush_timer. - Convert bit-field for uses_dma_in and uses_dma_out to regular bytes. - Removed CVS tags. - Removed defines and comments for CRIS_BUF_SIZE and TTY_THRESHOLD_THROTTLE (no longer used). - Cleaned up code to pass checkpatch. - Add crisv10.h header file. - Merge of CRISv10 from Axis internal CVS. Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com> Reviewed-by: Jiri Slaby <jirislaby@gmail.com> Cc: Mikael Starvik <starvik@axis.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19remove asm/bitops.h includesJiri Slaby
remove asm/bitops.h includes including asm/bitops directly may cause compile errors. don't include it and include linux/bitops instead. next patch will deny including asm header directly. Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16tty: bring the old cris driver back somewhere into the realm of new tty ↵Alan Cox
buffering Signed-off-by: Alan Cox <alan@redhat.com> Cc: Mikael Starvik <starvik@axis.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Char: tty_wakeup cleanupJiri Slaby
tty_wakeup cleanup - remove wake_up_interruptible(&tty->write_wait) surrounding tty_wakup(tty); - substitute tty->ldisc.write_wakeup(tty) + wake_up() by tty_wakeup(tty); Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] tty: switch to ktermiosAlan Cox
This is the grungy swap all the occurrences in the right places patch that goes with the updates. At this point we have the same functionality as before (except that sgttyb() returns speeds not zero) and are ready to begin turning new stuff on providing nobody reports lots of bugs If you are a tty driver author converting an out of tree driver the only impact should be termios->ktermios name changes for the speed/property setting functions from your upper layers. If you are implementing your own TCGETS function before then your driver was broken already and its about to get a whole lot more painful for you so please fix it 8) Also fill in c_ispeed/ospeed on init for most devices, although the current code will do this for you anyway but I'd like eventually to lose that extra paranoia [akpm@osdl.org: bluetooth fix] [mp3@de.ibm.com: sclp fix] [mp3@de.ibm.com: warning fix for tty3270] [hugh@veritas.com: fix tty_ioctl powerpc build] [jdike@addtoit.com: uml: fix ->set_termios declaration] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Martin Peschke <mp3@de.ibm.com> Acked-by: Peter Oberparleiter <oberpar@de.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-02[PATCH] const struct tty_operationsJeff Dike
As part of an SMP cleanliness pass over UML, I consted a bunch of structures in order to not have to document their locking. One of these structures was a struct tty_operations. In order to const it in UML without introducing compiler complaints, the declaration of tty_set_operations needs to be changed, and then all of its callers need to be fixed. This patch declares all struct tty_operations in the tree as const. In all cases, they are static and used only as input to tty_set_operations. As an extra check, I ran an i386 allyesconfig build which produced no extra warnings. 53 drivers are affected. I checked the history of a bunch of them, and in most cases, there have been only a handful of maintenance changes in the last six months. serial_core.c was the busiest one that I looked at. Signed-off-by: Jeff Dike <jdike@addtoit.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: serial: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/devfs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/devfs-2.6: (22 commits) [PATCH] devfs: Remove it from the feature_removal.txt file [PATCH] devfs: Last little devfs cleanups throughout the kernel tree. [PATCH] devfs: Rename TTY_DRIVER_NO_DEVFS to TTY_DRIVER_DYNAMIC_DEV [PATCH] devfs: Remove the tty_driver devfs_name field as it's no longer needed [PATCH] devfs: Remove the line_driver devfs_name field as it's no longer needed [PATCH] devfs: Remove the videodevice devfs_name field as it's no longer needed [PATCH] devfs: Remove the gendisk devfs_name field as it's no longer needed [PATCH] devfs: Remove the miscdevice devfs_name field as it's no longer needed [PATCH] devfs: Remove the devfs_fs_kernel.h file from the tree [PATCH] devfs: Remove devfs_remove() function from the kernel tree [PATCH] devfs: Remove devfs_mk_cdev() function from the kernel tree [PATCH] devfs: Remove devfs_mk_bdev() function from the kernel tree [PATCH] devfs: Remove devfs_mk_symlink() function from the kernel tree [PATCH] devfs: Remove devfs_mk_dir() function from the kernel tree [PATCH] devfs: Remove devfs_*_tape() functions from the kernel tree [PATCH] devfs: Remove devfs support from the sound subsystem [PATCH] devfs: Remove devfs support from the ide subsystem. [PATCH] devfs: Remove devfs support from the serial subsystem [PATCH] devfs: Remove devfs from the init code [PATCH] devfs: Remove devfs from the partition code ...
2006-06-28[PATCH] remove TTY_DONT_FLIPPaul Fulghum
Remove TTY_DONT_FLIP tty flag. This flag was introduced in 2.1.X kernels to prevent the N_TTY line discipline functions read_chan() and n_tty_receive_buf() from running at the same time. 2.2.15 introduced tty->read_lock to protect access to the N_TTY read buffer, which is the only state requiring protection between these two functions. The current TTY_DONT_FLIP implementation is broken for SMP, and is not universally honored by drivers that send data directly to the line discipline receive_buf function. Because TTY_DONT_FLIP is not necessary, is broken in implementation, and is not universally honored, it is removed. Signed-off-by: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] devfs: Rename TTY_DRIVER_NO_DEVFS to TTY_DRIVER_DYNAMIC_DEVGreg Kroah-Hartman
I've always found this flag confusing. Now that devfs is no longer around, it has been renamed, and the documentation for when this flag should be used has been updated. Also fixes all drivers that use this flag. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-23[PATCH] kill _INLINE_Adrian Bunk
This patch removes all occurances of _INLINE_ in the kernel. With the exception of tty_flip.h, I've simply removed the inline's since gcc should know best which functions to be inlined. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[SERIAL] turn serial semaphores into mutexesArjan van de Ven
Turn several drivers/serial/ semaphores-used-as-mutex into mutexes Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-07[PATCH] serial: fix-up schedule_timeout() usageNishanth Aravamudan
Use schedule_timeout_uninterruptible() instead of set_current_state()/schedule_timeout() to reduce kernel size. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Remove non-arch consumers of asm/segment.hKumar Gala
asm/segment.h varies greatly on different architectures but is clearly deprecated. Removing all non-architecture consumers will make it easier for us to get ride of asm/segment.h all together. Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-02[SERIAL] crisv10: Remove {,un}register_serial dummiesAdrian Bunk
It seems we can simply kill these dummies with this patch. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-16[PATCH] Serial: Remove linux/version.hOlaf Hering
changing CONFIG_LOCALVERSION rebuilds too much, for no appearent reason. Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
