path: root/drivers/serial/pmac_zilog.h
2006-12-08[PATCH] tty: switch to ktermiosAlan Cox
This is the grungy swap all the occurrences in the right places patch that goes with the updates. At this point we have the same functionality as before (except that sgttyb() returns speeds not zero) and are ready to begin turning new stuff on providing nobody reports lots of bugs If you are a tty driver author converting an out of tree driver the only impact should be termios->ktermios name changes for the speed/property setting functions from your upper layers. If you are implementing your own TCGETS function before then your driver was broken already and its about to get a whole lot more painful for you so please fix it 8) Also fill in c_ispeed/ospeed on init for most devices, although the current code will do this for you anyway but I'd like eventually to lose that extra paranoia [akpm@osdl.org: bluetooth fix] [mp3@de.ibm.com: sclp fix] [mp3@de.ibm.com: warning fix for tty3270] [hugh@veritas.com: fix tty_ioctl powerpc build] [jdike@addtoit.com: uml: fix ->set_termios declaration] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Martin Peschke <mp3@de.ibm.com> Acked-by: Peter Oberparleiter <oberpar@de.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
