path: root/drivers/serial/serial_core.c
2008-05-08serial: access after NULL check in uart_flush_buffer()Tetsuo Handa
I noticed that static void uart_flush_buffer(struct tty_struct *tty) { struct uart_state *state = tty->driver_data; struct uart_port *port = state->port; unsigned long flags; /* * This means you called this function _after_ the port was * closed. No cookie for you. */ if (!state || !state->info) { WARN_ON(1); return; } is too late for checking state != NULL. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30tty: The big operations reworkAlan Cox
- Operations are now a shared const function block as with most other Linux objects - Introduce wrappers for some optional functions to get consistent behaviour - Wrap put_char which used to be patched by the tty layer - Document which functions are needed/optional - Make put_char report success/fail - Cache the driver->ops pointer in the tty as tty->ops - Remove various surplus lock calls we no longer need - Remove proc_write method as noted by Alexey Dobriyan - Introduce some missing sanity checks where certain driver/ldisc combinations would oops as they didn't check needed methods were present [akpm@linux-foundation.org: fix fs/compat_ioctl.c build] [akpm@linux-foundation.org: fix isicom] [akpm@linux-foundation.org: fix arch/ia64/hp/sim/simserial.c build] [akpm@linux-foundation.org: fix kgdb] Signed-off-by: Alan Cox <alan@redhat.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30serial: switch the serial core to int put_char methodsAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30serial_core: Prepare for BKL push downAlan Cox
Instead of checking for the BKL in these methods, take it ourselves. That avoids propogating it into the serial drivers and we can then fix them later on. Signed-off-by: Alan Cox <alan@redhat.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28uart_get_baud_rate: stop mangling termiosAlan Cox
Russell King noticed this one: We have to avoid replacing B0 when we pick a baud rate for a "hung up" port. Ugly but the proper fix is in the tty layer and means changing the tty<->serial interfaces so we will defer that for now. [akpm@linux-foundation.org: fix uninitialised var] Signed-off-by: Alan Cox <alan@redhat.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-19PM: Fix misuse of wakeup flag accessors in serial coreAlan Stern
This patch (as1059) fixes a mistake in the way the serial core initializes a device's wakeup settings. It should use the accessor routine instead of relying on a macro producing an lvalue. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-17kgdb: Kconfig fixAndrew Morton
ERROR: "uart_parse_options" [drivers/serial/serial_core.ko] undefined! Cc: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17consoles: polling support, kgdbocJason Wessel
polled console handling support, to access a console in an irq-less way while in debug or irq context. absolutely zero impact as long as CONFIG_CONSOLE_POLL is disabled. (which is the default) [ jan.kiszka@siemens.com: lots of cleanups ] [ mingo@elte.hu: redesign, splitups, cleanups. ] Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Reviewed-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-08fs/char_dev.c: chrdev_open marked static and removed from fs.hDenis Cheng
There is an outdated comment in serial_core.c also fixed. Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08serial_core: bring mostly into line with coding styleAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05serial: speed setup failure reportingAlan Cox
Invalid speeds are forced to 9600. Update the code for this to encode new style baud rates properly. Signed-off-by: Alan Cox <alan@redhat.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05serial: avoid stalling suspend if serial port won't drainRussell King
Some ports seem to be unable to drain their transmitters on shut down. Such a problem can occur if the port is programmed for hardware imposed flow control, characters are in the FIFO but the CTS signal is inactive. Normally, this isn't a problem because most places where we wait for the transmitter to drain have a time-out. However, there is no timeout in the suspend path. Give a port 30ms to drain; this is an arbitary value chosen to avoid long delays if there are many such ports in the system, while giving a reasonable chance for a single port to drain. Should a port not drain within this timeout, issue a warning. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05serial: avoid waking up closed serial ports on resumeRussell King
When we boot, serial ports remain in low power mode until they're used either by userspace or for the kernel console. However, if you suspend the system, and then resume, all serial ports will be taken out of low power mode. This is bad news for embedded devices where this can mean higher power consumption. Only bring a serial port out of low power mode if the port is being used as the kernel console, or is in use by userspace. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05serial: keep the DTR setting for serial console.Yinghai Lu
with reverting "x86, serial: convert legacy COM ports to platform devices", we will have the serial console before the port is probled again. uart_add_one_port==>uart_configure_port==>set_mcttrl(port, 0) will clear the DTR setting by uart_set_options(). then I will lose my output from serial console again. So try to keep DTR in uart_configure_port() Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Andi Kleen <ak@suse.de> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-25serial: stop passing NULL to functions that expect dataAlan Cox
Earlier patches have removed the checking for old v new differences from the USB drivers so we can now pass in a valid blank old termios so that we don't to fill the drivers with magic hacks for console support Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-18serial: turn serial console suspend a boot rather than compile time optionAndres Salomon
Currently, there's a CONFIG_DISABLE_CONSOLE_SUSPEND that allows one to stop the serial console from being suspended when the rest of the machine goes to sleep. This is incredibly useful for debugging power management-related things; however, having it as a compile-time option has proved to be incredibly inconvenient for us (OLPC). There are plenty of times that we want serial console to not suspend, but for the most part we'd like serial console to be suspended. This drops CONFIG_DISABLE_CONSOLE_SUSPEND, and replaces it with a kernel boot parameter (no_console_suspend). By default, the serial console will be suspended along with the rest of the system; by passing 'no_console_suspend' to the kernel during boot, serial console will remain alive during suspend. For now, this is pretty serial console specific; further fixes could be applied to make this work for things like netconsole. Signed-off-by: Andres Salomon <dilinger@debian.org> Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@suspend2.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16wake up from a serial portGuennadi Liakhovetski
Enable wakeup from serial ports, make it run-time configurable over sysfs, e.g., echo enabled > /sys/devices/platform/serial8250.0/tty/ttyS0/power/wakeup Requires # CONFIG_SYSFS_DEPRECATED is not set Following suggestions from Alan and Russell moved the may_wake_up checks to serial_core.c. This time actually tested - it does even work. Could someone, please, verify, that put_device after device_find_child is correct? Also would be nice to test with a Natsemi UART, that can wake up the system, if such systems exist. For this you just have to apply the patch below, issue the above "echo" command to one of your Natsemi port, suspend and resume your system, and verify that your Natsemi port still works. If you are actually capable of waking up the system from that port, would be nice to test that as well. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-15[SERIAL] Fix console initialisation orderingRussell King
Ensure pm callback is called upon initialisation to place port in correct power saving state. Ensure console is initialised prior to deciding whether to power down the port. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-08-22serial: don't optimise away baud rate changes when BOTHER is usedDavid Woodhouse
The uart_set_termios() function will bail out early without bothering to touch the hardware, if it decides that nothing "relevant" has changed. Unfortunately, its idea of "relevant" doesn't include c_[io]speed. So if the baud rate bits are BOTHER and you just change the speed, the change gets optimised away. This patch makes it ignore the old Bfoo bits in c_cflag and just check whether c_ispeed and c_ospeed have changed. Those integers are always set appropriately for us by set_termios(). Signed-off-by: David Woodhouse <dwmw2@infradead.org> Acked-by: Alan Cox <alan@redhat.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-24Use resource_size_t for serial port IO addressesJosh Boyer
At present, various parts of the serial code use unsigned long to define resource addresses. This is a problem, because some 32-bit platforms have physical addresses larger than 32-bits, and have mmio serial uarts located above the 4GB point. This patch changes the type of mapbase in both struct uart_port and struct plat_serial8250_port to resource_size_t, which can be configured to be 64 bits on such platforms. The mapbase in serial_struct can't safely be changed, because that structure is user visible. Signed-off-by: David Gibson <dwg@au1.ibm.com> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mackerras <paulus@samba.org> Cc: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16serial: assert DTR for serial console devicesYinghai Lu
Some RS-232 devices require DTR to be asserted before they can be used. DTR is normally asserted in uart_startup() when the port is opened. But we don't actually open serial console ports, so assert DTR when the port is added. BTW: earlyprintk and early_uart are hard coded to set DTR/RTS. rmk says The only issue I can think of is the possibility for an attached modem to auto-answer or maybe even auto-dial before the system is ready for it to do so. Might have an undesirable cost implication for some running with such a setup. Apart from that, I can't think of any other side effect of this specific patch. Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Andi Kleen <ak@suse.de> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Gerd Hoffmann <kraxel@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07Serial: serial_core, use pr_debugJiri Slaby
serial_core, use pr_debug Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07serial: define FIXED_PORT flag for serial_coreDavid Gibson
At present, the serial core always allows setserial in userspace to change the port address, irq and base clock of any serial port. That makes sense for legacy ISA ports, but not for (say) embedded ns16550 compatible serial ports at peculiar addresses. In these cases, the kernel code configuring the ports must know exactly where they are, and their clocking arrangements (which can be unusual on embedded boards). It doesn't make sense for userspace to change these settings. Therefore, this patch defines a UPF_FIXED_PORT flag for the uart_port structure. If this flag is set when the serial port is configured, any attempts to alter the port's type, io address, irq or base clock with setserial are ignored. In addition this patch uses the new flag for on-chip serial ports probed in arch/powerpc/kernel/legacy_serial.c, and for other hard-wired serial ports probed by drivers/serial/of_serial.c. Signed-off-by: David Gibson <dwg@au1.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07serial driver PMC MSP71xxMarc St-Jean
Serial driver patch for the PMC-Sierra MSP71xx devices. There are three different fixes: 1 Fix for DesignWare APB THRE errata: In brief, this is a non-standard 16550 in that the THRE interrupt will not re-assert itself simply by disabling and re-enabling the THRI bit in the IER, it is only re-enabled if a character is actually sent out. It appears that the "8250-uart-backup-timer.patch" in the "mm" tree also fixes it so we have dropped our initial workaround. This patch now needs to be applied on top of that "mm" patch. 2 Fix for Busy Detect on LCR write: The DesignWare APB UART has a feature which causes a new Busy Detect interrupt to be generated if it's busy when the LCR is written. This fix saves the value of the LCR and rewrites it after clearing the interrupt. 3 Workaround for interrupt/data concurrency issue: The SoC needs to ensure that writes that can cause interrupts to be cleared reach the UART before returning from the ISR. This fix reads a non-destructive register on the UART so the read transaction completion ensures the previously queued write transaction has also completed. Signed-off-by: Marc St-Jean <Marc_St-Jean@pmc-sierra.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] serial: replace kmalloc+memset with kzallocBurman Yan
2007-02-14[PATCH] serial: make sure UART is powered up when dumping MCTRL statusGeorge G. Davis
Since serial devices are powered down when not in use and some of those devices cannot be accessed when powered down, we need to enable power around calls to get_mcrtl() when dumping port state via uart_line_info(). This resolves hangs observed on some machines while reading serial device registers when a port is powered off. Signed-off-by: George G. Davis <gdavis@mvista.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] tty: switch to ktermiosAlan Cox
This is the grungy swap all the occurrences in the right places patch that goes with the updates. At this point we have the same functionality as before (except that sgttyb() returns speeds not zero) and are ready to begin turning new stuff on providing nobody reports lots of bugs If you are a tty driver author converting an out of tree driver the only impact should be termios->ktermios name changes for the speed/property setting functions from your upper layers. If you are implementing your own TCGETS function before then your driver was broken already and its about to get a whole lot more painful for you so please fix it 8) Also fill in c_ispeed/ospeed on init for most devices, although the current code will do this for you anyway but I'd like eventually to lose that extra paranoia [akpm@osdl.org: bluetooth fix] [mp3@de.ibm.com: sclp fix] [mp3@de.ibm.com: warning fix for tty3270] [hugh@veritas.com: fix tty_ioctl powerpc build] [jdike@addtoit.com: uml: fix ->set_termios declaration] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Martin Peschke <mp3@de.ibm.com> Acked-by: Peter Oberparleiter <oberpar@de.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-serialLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-serial: (21 commits) [SERIAL] add PNP IDs for FPI based touchscreens [SERIAL] Magic SysRq SAK does nothing on serial consoles [SERIAL] tickle NMI watchdog on serial output. [SERIAL] Fix oops when removing suspended serial port [SERIAL] Fix resume handling bug [SERIAL] Remove wrong asm/serial.h inclusions [SERIAL] CONFIG_PM=n slim: drivers/serial/8250_pci.c [SERIAL] OMAP1510 serial fix for 115200 baud [SERIAL] returning proper error from serial core driver [SERIAL] Make uart_line_info() correctly tell MMIO from I/O port [SERIAL] suspend/resume handlers don't have level arg anymore [SERIAL] 8250 resourse management fixes [SERIAL] serial_cs: Add quirk for brainboxes 2-port RS232 card [SERIAL] serial_cs: handle Nokia multi->single port bodge via config quirk [SERIAL] serial_cs: add configuration quirk [SERIAL] serial_cs: Convert Oxford 950 / Possio GCC wakeup quirk [SERIAL] serial_cs: convert IBM post-init handling to a quirk [SERIAL] serial_cs: allow wildcarded quirks [SERIAL] serial_cs: convert multi-port table to quirk table [SERIAL] serial_cs: Use clean up multiport card detection ...
2006-10-02[PATCH] const struct tty_operationsJeff Dike
As part of an SMP cleanliness pass over UML, I consted a bunch of structures in order to not have to document their locking. One of these structures was a struct tty_operations. In order to const it in UML without introducing compiler complaints, the declaration of tty_set_operations needs to be changed, and then all of its callers need to be fixed. This patch declares all struct tty_operations in the tree as const. In all cases, they are static and used only as input to tty_set_operations. As an extra check, I ran an i386 allyesconfig build which produced no extra warnings. 53 drivers are affected. I checked the history of a bunch of them, and in most cases, there have been only a handful of maintenance changes in the last six months. serial_core.c was the busiest one that I looked at. Signed-off-by: Jeff Dike <jdike@addtoit.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[SERIAL] Fix oops when removing suspended serial portRussell King
A serial card might have been removed when the system is resumed. This results in a suspended port being shut down, which results in the ports shutdown method being called twice in a row. This causes BUGs. Avoid this by tracking the suspended state separately from the initialised state. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-01[SERIAL] returning proper error from serial core driverRam Gupta
Fix the issue of returning 0 even in case of error from uart_set_info function. Now it returns the error EBUSY when it can not set new port. Signed-off-by: Ram Gupta <r.gupta@astronautics.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-01[SERIAL] Make uart_line_info() correctly tell MMIO from I/O portSergei Shtylyov
/proc/tty/driver/serial incorrectly claims that UARTs having iotype of UPIO_MEM32, UPIO_AU, or UPIO_TSI are I/O mapped. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-26[PATCH] suspend: make it possible to disable serial console suspendRafael J. Wysocki
Hack uart_suspend_port() and uart_resume_port() so that serial console ports are not suspended if CONFIG_DISABLE_CONSOLE_SUSPEND is set. This makes it possible to debug the suspend and resume routines of all device drivers as well as the lowest-level swsusp code with the help of the serial console. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-30[SERIAL] Make uart_match_port() work with all memory mapped UARTsSergei Shtylyov
uart_match_port() always fails with UPIO_MEM32, UPIO_AU, and UPIO_TSI cases. Since they match to the memory mapped UARTs, they should be handled just like UPIO_MEM case. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-09[SERIAL] 8250: add tsi108 serial supportZang Roy-r61911
The following patch gets rid of CONFIG_TSI108_BRIDGE. I add UPIO_TSI to handle IIR and IER register in serial_in and serial_out. (1) the reason to rewrite serial_in: TSI108 rev Z1 version ERRATA. Reading the UART's Interrupt Identification Register (IIR) clears the Transmit Holding Register Empty (THRE) and Transmit buffer Empty (TEMP) interrupts even if they are not enabled in the Interrupt Enable Register (IER). This leads to loss of the interrupts. Interrupts are not cleared when reading UART registers as 32-bit word. (2) the reason to rewrite serial_out: Check for UART_IER_UUE bit in the autoconfig routine. This section of autoconfig is excluded for Tsi108/109 because bits 7 and 6 are reserved for internal use. They are R/W bits. In addition to incorrect identification, changing these bits (from 00) will make Tsi108/109 UART non-functional. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-03Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-serialLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-serial: [SERIAL] Ensure 8250_pci quirks are not marked __devinit [SERIAL] Convert fifosize to an unsigned int
2006-07-03[PATCH] lockdep: annotate serialIngo Molnar
Teach special (dual-initialized) locking code to the lock validator. Has no effect on non-lockdep kernels. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[SERIAL] Convert fifosize to an unsigned intRussell King
Some UARTs have more than 255 bytes of FIFO, which can't be represented by an unsigned char. Change the kernel's internal structure to be an unsigned int, but still export an unsigned char via the TIOCGSERIAL ioctl. If the TIOCSSERIAL ioctl provides a fifo size of 0, assume this means "don't change" otherwise we'll corrupt the larger fifo sizes. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-26[PATCH] devfs: Rename TTY_DRIVER_NO_DEVFS to TTY_DRIVER_DYNAMIC_DEVGreg Kroah-Hartman
I've always found this flag confusing. Now that devfs is no longer around, it has been renamed, and the documentation for when this flag should be used has been updated. Also fixes all drivers that use this flag. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove devfs support from the serial subsystemGreg Kroah-Hartman
Also fixes all serial drivers. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-05-16[ARM] 3523/1: Serial core pm_stateAndrew Victor
Patch from Andrew Victor The serial_core already manages the power state of the UARTs, and therefore it shouldn't suspend a UART which was previously suspended. This patch modifies serial_core only call the UART-specific power-management function if the PM state is actually changing. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-04-30[SERIAL] Clean up serial locking when obtaining a reference to a portRussell King
The locking for the uart_port is over complicated, and can be simplified if we introduce a flag to indicate that a port is "dead" and will be removed. This also helps the validator because it removes a case of non-nested unlock ordering. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org>
2006-03-20[SERIAL] kernel console should send CRLF not LFCRRussell King
Glen Turner reported that writing LFCR rather than the more traditional CRLF causes issues with some terminals. Since this aflicts many serial drivers, extract the common code to a library function (uart_console_write) and arrange for each driver to supply a "putchar" function. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-08[PATCH] serial core: work around sub-driver bugsPavel Machek
We're presently getting oopses because Bluetooth (and possibly other) drivers are calling core functions after things have been shut down. So rather than oopsing, let's drop a warning then take avoiding action, so the machine survives. Once all the sub-drivers are fixed up we can remove the take-avoiding-action part. Signed-off-by: Pavel Machek <pavel@suse.cz> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-02[SERIAL] initialize spinlock for port failed to setup consoleAtsushi Nemoto
It seems serial_core intend to initialize port->lock just once for each ports. This is done in uart_set_options() for console, and in uart_add_one_port() for other ports. But there is a case the port->lock is not initialized by serial_core. If the setup function for the console was failed, it will not call uart_set_options() but the port is marked as console (uart_console(port) returns 1). It can happen if console was PCI port which can not detected at the time of register_console. This patch is to initialize port->lock for such console port. With this change, most of spin_lock_init() (some of them are labeled "Temporary fix.") in low-level serial drivers can be omitted. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-21[SERIAL] Make uart_port flags a bitwise typeRussell King
Same reasoning as commit 747c8a55946ed037bf7d62454c3c599c02af2262 but this time we're making uart_port flags a bitwise type - not all of these flags correspond with the old ASYNC_ flags, so there is the possibility for bugs if the wrong ASYNC_* constants are used. Always use UPF_* constants for uart_port->flags. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-21[SERIAL] Make port->ops constantRussell King
No one should write to the port->ops structure, so make it constant. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-13[SERIAL] convert uart_state.sem to uart_state.mutexIngo Molnar
semaphore to mutex conversion. the conversion was generated via scripts, and the result was validated automatically via a script as well. build and boot tested. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-12[SERIAL] turn serial semaphores into mutexesArjan van de Ven
Turn several drivers/serial/ semaphores-used-as-mutex into mutexes Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
