path: root/drivers/serial/serial_cs.c
2011-01-13tty: move drivers/serial/ to drivers/tty/serial/Greg Kroah-Hartman
The serial drivers are really just tty drivers, so move them to drivers/tty/ to make things a bit neater overall. This is part of the tty/serial driver movement proceedure as proposed by Arnd Bergmann and approved by everyone involved a number of months ago. Cc: Arnd Bergmann <arnd@arndb.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Rogier Wolff <R.E.Wolff@bitwizard.nl> Cc: Michael H. Warfield <mhw@wittsend.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-16serial_cs: drop spurious flush_scheduled_work() callTejun Heo
serial_cs doesn't use the system workqueue. Drop spurious flush_scheduled_work() call. This is to prepare for the deprecation and removal of flush_scheduled_work(). Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: remove obsolete and wrong commentsDominik Brodowski
What's worse than no comment? A wrong comment. Several PCMCIA device drivers contained the same comments, which were based on how the PCMCIA subsystem worked in the old days of 2.4., and which were originally part of a "dummy_cs" driver. These comments no longer matched at all what is happening now, and therefore should be removed. Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: move driver name to struct pcmcia_driverDominik Brodowski
2010-09-29pcmcia: use autoconfiguration feature for ioports and iomemDominik Brodowski
When CONF_AUTO_SET_IO or CONF_AUTO_SET_IOMEM are set, the corresponding fields in struct pcmcia_device *p_dev->resource[0,1,2] are set accordinly. Drivers wishing to override certain settings may do so in the callback function, but they no longer need to parse the CIS entries stored in cistpl_cftable_entry_t themselves. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: linux-bluetooth@vger.kernel.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: introduce autoconfiguration featureDominik Brodowski
Introduce an autoconfiguration feature to set certain values in pcmcia_loop_config(), instead of copying the same code over and over in each PCMCIA driver. At first, introduce the following options: CONF_AUTO_CHECK_VCC check or matching Vcc entry CONF_AUTO_SET_VPP set Vpp CONF_AUTO_AUDIO enable the speaker line CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: convert pcmcia_request_configuration to pcmcia_enable_deviceDominik Brodowski
pcmcia_enable_device() now replaces pcmcia_request_configuration(). Instead of config_req_t, all necessary flags are either passed as a parameter to pcmcia_enable_device(), or (in rare circumstances) set in struct pcmcia_device -> flags. With the last remaining user of include/pcmcia/cs.h gone, remove all references. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: move config_{base,index,regs} to struct pcmcia_deviceDominik Brodowski
Several drivers prefer to explicitly set config_{base,index,regs}, formerly known as ConfigBase, ConfigIndex and Present. Instead of passing these values inside config_req_t, store it in struct pcmcia_device. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: simplify IntTypeDominik Brodowski
IntType was only set to INT_MEMORY (driver pcmciamtd) or INT_MEMORY_AND_IO (all other drivers). As this flags seems to relate to ioport access, make it conditional to the driver having requested IO port access. There are two drivers which do not request IO ports, but did set INT_MEMORY_AND_IO: ray_cs and b43. For those, we consistently only set INT_MEMORY in future. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Jiri Kosina <jkosina@suse.cz> CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: simplify Status, ExtStatus register accessDominik Brodowski
The Status (CISREG_CCSR) and ExtStatus (CISREG_ESR) registers were only accessed to enable audio output for some drivers and IRQ for serial_cs.c. The former also required setting config_req_t.Attributes to CONF_ENABLE_SPKR; the latter can be simplified to setting this field to CONF_ENABLE_ESR. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-serial@vger.kernel.org CC: linux-scsi@vger.kernel.org Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-29pcmcia: move Vpp setup to struct pcmcia_deviceDominik Brodowski
Some drivers prefer to explicitly set Vpp. Instead of passing the voltage inside config_req_t, store it in struct pcmcia_device. CC: linux-ide@vger.kernel.org CC: netdev@vger.kernel.org CC: linux-mtd@lists.infradead.org CC: linux-wireless@vger.kernel.org CC: linux-serial@vger.kernel.org CC: linux-usb@vger.kernel.org CC: linux-scsi@vger.kernel.org Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth) Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-15pcmcia serial_cs.c: fix multifunction card handlingDominik Brodowski
We shouldn't overwrite pre-set values, and we should also set the port address to the beginning, and not the end of the 8-port range. CC: linux-serial@vger.kernel.org Reported-by: Komuro <komurojun-mbn@nifty.com> Hardware-supplied-by: Jochen Frieling <j.frieling@pengutronix.de> Tested-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-08-03pcmcia: do not use io_req_t when calling pcmcia_request_io()Dominik Brodowski
Instead of io_req_t, drivers are now requested to fill out struct pcmcia_device *p_dev->resource[0,1] for up to two ioport ranges. After a call to pcmcia_request_io(), the ports found there are reserved, after calling pcmcia_request_configuration(), they may be used. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org CC: Michael Buesch <mb@bu3sch.de> Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/) Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-08-03pcmcia: do not use io_req_t after call to pcmcia_request_io()Dominik Brodowski
After pcmcia_request_io(), do not make use of the values stored in io_req_t, but instead use those found in struct pcmcia_device->resource[]. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/) Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-08-03pcmcia: use pcmica_{read,write}_config_byteDominik Brodowski
Use pcmcia_read_config_byte and pcmcia_write_config_byte instead of pcmcia_access_configuration_register. CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-serial@vger.kernel.org CC: Michael Buesch <mb@bu3sch.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-07-30pcmcia: remove cs_types.hDominik Brodowski
Remove cs_types.h which is no longer needed: Most definitions aren't used at all, a few can be made away with, and two remaining definitions (typedefs, unfortunatley) may be moved to more specific places. CC: linux-ide@vger.kernel.org CC: linux-usb@vger.kernel.org CC: laforge@gnumonks.org CC: linux-mtd@lists.infradead.org CC: alsa-devel@alsa-project.org CC: linux-serial@vger.kernel.org Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/) Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-06-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (52 commits) phylib: Add autoload support for the LXT973 phy. ISDN: hysdn, fix potential NULL dereference vxge: fix memory leak in vxge_alloc_msix() error path isdn/gigaset: correct CAPI connection state storage isdn/gigaset: encode HLC and BC together isdn/gigaset: correct CAPI DATA_B3 Delivery Confirmation isdn/gigaset: correct CAPI voice connection encoding isdn/gigaset: honor CAPI application's buffer size request cpmac: do not leak struct net_device on phy_connect errors smc91c92_cs: fix the problem that lan & modem does not work simultaneously ipv6: fix NULL reference in proxy neighbor discovery Bluetooth: Bring back var 'i' increment xfrm: check bundle policy existance before dereferencing it sky2: enable rx/tx in sky2_phy_reinit() cnic: Disable statistics initialization for eth clients that do not support statistics net: add dependency on fw class module to qlcnic and netxen_nic snmp: fix SNMP_ADD_STATS() hso: remove setting of low_latency flag udp: Fix bogus UFO packet generation lasi82596: fix netdev_mc_count conversion ...
2010-06-16pcnet_cs: add new id (TOSHIBA Modem/LAN Card)Ken Kawasaki
pcnet_cs: serial_cs: add new id (TOSHIBA Modem/LAN Card) Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-04serial_cs: add and sort IDs for serial and modem cardsAlexander Kurz
Signed-off-by: Alexander Kurz <linux@kbdbabel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-10pcmcia: dev_node removal (write-only drivers)Dominik Brodowski
dev_node_t was only used to transport some minor/major numbers from the PCMCIA device drivers to deprecated userspace helpers. However, only a few drivers made use of it, and the userspace helpers are deprecated anyways. Therefore, get rid of dev_node_t . As a first step, remove any usage of dev_node_t from drivers which only wrote to this typedef/struct, but did not make use of it. CC: linux-bluetooth@vger.kernel.org CC: Harald Welte <laforge@gnumonks.org> CC: linux-mtd@lists.infradead.org CC: linux-wireless@vger.kernel.org CC: netdev@vger.kernel.org CC: linux-serial@vger.kernel.org CC: alsa-devel@alsa-project.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-05-10pcmcia: re-work pcmcia_request_irq()Dominik Brodowski
Instead of the old pcmcia_request_irq() interface, drivers may now choose between: - calling request_irq/free_irq directly. Use the IRQ from *p_dev->irq. - use pcmcia_request_irq(p_dev, handler_t); the PCMCIA core will clean up automatically on calls to pcmcia_disable_device() or device ejection. - drivers still not capable of IRQF_SHARED (or not telling us so) may use the deprecated pcmcia_request_exclusive_irq() for the time being; they might receive a shared IRQ nonetheless. CC: linux-bluetooth@vger.kernel.org CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-serial@vger.kernel.org CC: alsa-devel@alsa-project.org CC: linux-usb@vger.kernel.org CC: linux-ide@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-04-17serial_cs: MD55x support (PCMCIA GPRS/EDGE modem) (kernel 2.6.33)Timur Maximov
Many PCMCIA GPRS modems like: Onda Edge N100E, Novaway PC98 (OEM SPC98Z), Rovermate Edgus Adaptmate-039 and others have same construction and identification: lspcmcia -vvv Product Name: Generic Modem: MD55x 1.00 Serial number: xxxxx-xxx Identification: manf_id: 0x015d card_id: 0x4c45 function: 2 (serial) prod_id(1): "Generic" (0xc49e4731) prod_id(2): "Modem: MD55x" (0x8913b110) prod_id(3): "1.00" (0x83dbf271) prod_id(4): "Serial number: xxxxx-xxx" (0x73ee9514) Serial connection to GSM module based on Elan VPU16551 PCMCIA UART with datasheet recommeded 14.7456MHz crystal oscillator. By default serial_cs set UART clock == 1843200 Hz For correct work need set clock 14745600 Hz. This quirk already present in driver, only need add device in quirk list. Signed-off-by: Timur Maximov <xcom.org@gmail.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-03-27pcnet_cs: add new idKen Kawasaki
pcnet_cs: *add new id (Allied Telesis LM33-PCM-T Lan&Modem multifunction card) *use PROD_ID for LA-PCM.(because LA-PCM and LM33-PCM-T use the same MANF_ID). Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: (49 commits) pcmcia: validate late-added resources pcmcia: allow for extension of resource interval pcmcia: remove useless msleep in ds.c pcmcia: use read_cis_mem return value pcmcia: handle error in serial_cs config calls pcmcia: add locking to pcmcia_{read,write}_cis_mem pcmcia: avoid prod_id memleak pcmcia: avoid sysfs-related lockup for cardbus pcmcia: use state machine for extended requery pcmcia: delay re-scanning and re-querying of PCMCIA bus pcmcia: use pccardd to handle eject, insert, suspend and resume requests pcmcia: use ops_mutex for rsrc_{mgr,nonstatic} locking pcmcia: use mutex for dynid lock pcmcia: assert locking to struct pcmcia_device pcmcia: add locking documentation pcmcia: simplify locking pcmcia: add locking to struct pcmcia_socket->pcmcia_state() pcmcia: protect s->device_count pcmcia: properly lock skt->irq, skt->irq_mask pcmcia: lock ops->set_socket ...
2010-02-17pcmcia: handle error in serial_cs config callsDominik Brodowski
Do not ignore the error returned by simple_config() / multi_config(). CC: linux-serial@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-01-23fmvj18x_cs: add new id (Panasonic lan & modem card)Ken Kawasaki
fmvj18x_cs, serial_cs: add new id Panasonic lan & modem card (model name:AL-VML101) Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-20serial: serial_cs: oxsemi quirk breaks resumePavel Machek
Quirk is applied on all cards with given manfid (is it that correct?). Unfortunately, that quirk breaks resume on zaurus with billionton bluetooth card inserted: c950ctrl is 0 and outb() faults. I believe it is simply not a multiport card. (info->multi == 1). ... ... confirmed by printks. Signed-off-by: Pavel Machek <pavel@ucw.cz> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-06pcnet_cs: add cis of KTI PE520 pcmcia network cardKen Kawasaki
pcnet_cs,serial_cs: add cis of KTI PE520 pcmcia network card, and serial card(Sierra Wireless AC860). Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: (50 commits) pcmcia: rework the irq_req_t typedef pcmcia: remove deprecated handle_to_dev() macro pcmcia: pcmcia_request_window() doesn't need a pointer to a pointer pcmcia: remove unused "window_t" typedef pcmcia: move some window-related code to pcmcia_ioctl.c pcmcia: Change window_handle_t logic to unsigned long pcmcia: Pass struct pcmcia_socket to pcmcia_get_mem_page() pcmcia: Pass struct pcmcia_device to pcmcia_map_mem_page() pcmcia: Pass struct pcmcia_device to pcmcia_release_window() drivers/pcmcia: remove unnecessary kzalloc pcmcia: correct handling for Zoomed Video registers in topic.h pcmcia: fix printk formats pcmcia: autoload module pcmcia pcmcia/staging: update comedi drivers PCMCIA: stop duplicating pci_irq in soc_pcmcia_socket PCMCIA: ss: allow PCI IRQs > 255 PCMCIA: soc_common: remove 'dev' member from soc_pcmcia_socket PCMCIA: soc_common: constify soc_pcmcia_socket ops member PCMCIA: sa1111: remove duplicated initializers PCMCIA: sa1111: wrap soc_pcmcia_socket to contain sa1111 specific data ...
2009-11-28pcmcia: rework the irq_req_t typedefDominik Brodowski
Most of the irq_req_t typedef'd struct can be re-worked quite easily: (1) IRQInfo2 was unused in any case, so drop it. (2) IRQInfo1 was used write-only, so drop it. (3) Instance (private data to be passed to the IRQ handler): Most PCMCIA drivers using pcmcia_request_irq() to actually register an IRQ handler set the "dev_id" to the same pointer as the "priv" pointer in struct pcmcia_device. Modify the two exceptions (ipwireless, ibmtr_cs) to also work this waym and set the IRQ handler's "dev_id" to p_dev->priv unconditionally. (4) Handler is to be of type irq_handler_t. (5) Handler != NULL already tells whether an IRQ handler is present. Therefore, we do not need the IRQ_HANDLER_PRESENT flag in irq_req_t.Attributes. CC: netdev@vger.kernel.org CC: linux-bluetooth@vger.kernel.org CC: linux-ide@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-scsi@vger.kernel.org CC: alsa-devel@alsa-project.org CC: Jaroslav Kysela <perex@perex.cz> CC: Jiri Kosina <jkosina@suse.cz> CC: Karsten Keil <isdn@linux-pingi.de> for the Bluetooth parts: Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-11-28pcmcia: remove deprecated handle_to_dev() macroDominik Brodowski
Update remaining users and remove deprecated handle_to_dev() macro CC: Harald Welte <laforge@gnumonks.org> CC: netdev@vger.kernel.org CC: linux-wireless@vger.kernel.org CC: linux-serial@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-11-09pcmcia: use dynamic debug infrastructure, deprecate CS_CHECK (serial_cs)Dominik Brodowski
Convert PCMCIA drivers to use the dynamic debug infrastructure, instead of requiring manual settings of PCMCIA_DEBUG. Also, remove all usages of the CS_CHECK macro and replace them with proper Linux style calling and return value checking. The extra error reporting may be dropped, as the PCMCIA core already complains about any (non-driver-author) errors. CC: linux-serial@vger.kernel.org CC: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-10-29pcnet_cs: add cis of PreMax PE-200 ethernet pcmcia cardKen Kawasaki
pcnet_cs,serial_cs: add cis of PreMax ethernet pcmcia card, and some Sierra Wireless serial card(AC555, AC7xx, AC8xx). use PROD_ID for AC7xx, because MANF_ID of AC7xx and AC8xx are the same. Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-24serial_cs: use pcmcia_loop_config() and pre-determined valuesDominik Brodowski
As the PCMCIA core already determines the multifunction count, the ConfigBase address and the Present value, we can use them directly instead of parsing the CIS again. By making use of pcmcia_loop_config(), we can further remove the remaining call to pcmcia_get_first_tuple() and friends. CC: linux-serial@vger.kernel.org CC: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-10-05pcnet_cs: add cis of National Semicondoctor's multifunction pcmcia cardKen Kawasaki
pcnet_cs,serial_cs: add cis of National Semicondoctor's lan&modem mulitifunction pcmcia card, NE2K, tamarack ethernet card, and some serial card(COMpad2, COMpad4). Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-19tty: serial/pcmcia: add ID for Advantech cardWolfram Sang
Add ID as reported in: http://lists.infradead.org/pipermail/linux-pcmcia/2009-May/006127.html Reported-by: Kenneth Moorman <KMoorman@transy.edu> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-15pcnet_cs: add cis of Linksys multifunction pcmcia cardKen Kawasaki
pcnet_cs,serial_cs: add cis of Linksys lan&modem mulitifunction pcmcia card and some modem card(MT5634ZLX, RS-COM-2P). Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-013c589_cs: add cis(firmware) of 3Com multifunction pcmcia cardKen Kawasaki
3c589_cs,3c574_cs,serial_cs: (1)add cis(firmware) of 3Com lan&modem mulitifunction pcmcia card. (2)load correct configuration register for 3Com card Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-31pcmcia: remove unused argument to pcmcia_parse_tuple()Dominik Brodowski
Since we're just parsing the tuple being passed to this function, we don't need any device-specific information. Also, remove the call to pcmcia_validate_cis() from pcmciamtd.c, since it is already called by the PCMCIA core. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-23pcmcia: deprecate CS_NO_MORE_ITEMSDominik Brodowski
CS_NO_MORE_ITEMS is returned by the CIS tuple reading and parsing code if the end of a tuple chain is reached. As at least one PCMCIA driver relies on matching this return value, replace it with -ENOSPC which is now uniquely used for this purpose within the in-kernel pcmcia subsystem. CC: Russell King <rmk+kernel@arm.linux.org.uk> CC: linux-serial@vger.kernel.org CC: Michael Buesch <mb@bu3sch.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-23pcmcia: deprecate CS_SUCCESSDominik Brodowski
Instead of using own error or success codes, the PCMCIA code should rely on the generic return values. Therefore, replace all occurrences of CS_SUCCESS with 0. CC: netdev@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-23pcmcia: remove remaining in-kernel pcmcia_get_configuration_info() usersDominik Brodowski
Remove the three remaining pcmcia_get_configuration_info() users: - pcmciamtd is marked broken anyway. - serial_cs.c can access the relevant structs directly - ipwireless didn't use the output CC: linux-serial@vger.kernel.org CC: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: David Sterba <dsterba@suse.cz> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-23pcmcia: pcmcia_config_loop() improvement by passing vccDominik Brodowski
By passing the current Vcc setting to the pcmcia_config_loop callback function, we can remove pcmcia_get_configuration_info() calls from many drivers. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-23pcmcia: pcmcia_config_loop() default CIS entry handlingDominik Brodowski
Many drivers use the default CIS entry within their pcmcia_config_loop() callback function. Therefore, factor the default CIS entry handling out. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-23pcmcia: pcmcia_config_loop() ConfigIndex unificationDominik Brodowski
Almost all drivers set p_dev->conf.ConfigIndex to cfg->index in the pcmcia_config_loop() callback function. Therefore, factor it out. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-23pcmcia: use pcmcia_loop_config in misc pcmcia driversDominik Brodowski
Use the config loop helper in misc pcmcia drivers. CC: Harald Welte <laforge@gnumonks.org> CC: <linux-parport@lists.infradead.org> CC: Russell King <rmk+kernel@arm.linux.org.uk> CC: Ed Okerson <eokerson@quicknet.net> CC: linux-serial@vger.kernel.org CC: boti@rocketmail.com CC: linux-usb@vger.kernel.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-02-05pcmcia: replace kio_addr_t with unsigned int everywhereOlof Johansson
Remove kio_addr_t, and replace it with unsigned int. No known architecture needs more than 32 bits for IO addresses and ports and having a separate type for it is just messy. Signed-off-by: Olof Johansson <olof@lixom.net> Cc: Christoph Hellwig <hch@lst.de> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-29netdrvr/pcmcia: use IRQ_TYPE_DYNAMIC_SHARING flag for irq.Attributes.Komuro
The drivers below support IRQ-sharing. 3c574_cs, 3c589_cs, pcnet_cs, axnet_cs, smc91c92_cs, fmvj18x_cs. xirc2ps_cs, serial_cs. Signed-off-by: Komuro <komurojun-mbn@nifty.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-16Add support for PCMCIA card Sierra WIreless AC850Eric Leblond
Add support for Sierra Wireless AC850 which has the same Ids as the AC710/750 but has a different firmware. Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-07Add manufacturer and card id of teltonica pcmcia modemsAttila Kinali
Add the manufacturer and card id of teltonica pcmcia modems to serial_cs.c Signed-off-by: Attila Kinali <attila@kinali.ch> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
