Convert the SuperH clocks framework and shared interrupt handling
code to using struct syscore_ops instead of a sysdev classes and
sysdevs for power managment.
This reduces the code size significantly and simplifies it. The
optimizations causing things not to be restored after creating a
hibernation image are removed, but they might lead to undesirable
effects during resume from hibernation (e.g. the clocks would be left
as the boot kernel set them, which might be not the same way as the
hibernated kernel had seen them before the hibernation).
This also is necessary for removing sysdevs from the kernel entirely
in the future.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Clear the valid flag is in the INTC code.
Without this fix bit 7 of the sense register
is mistakenly set.
Signed-off-by: Magnus Damm <damm@opensource.se>
Presently the root node is initialized by way of kzalloc on the parent
data structure, which by chance happens to do the bulk of what an
explicit initialization does with GFP_NOWAIT semantics. This however is
more by luck than by design, and as we ideally want to permit radix node
allocations access to the emergency pools anyways, add in the proper
initializer with the desired mask.
The radix tree retry logic got a bit of an overhaul and subsequently
broke the virtual IRQ subgroup build. Simply switch over to
radix_tree_deref_retry() as per the filemap changes, which the virq
lookup logic was modelled after in the first place.
There's no need to iterative over every single irq_desc when we can
already work out which IRQs have a backing descriptor via the shiny new
for_each_active_irq(). Switch to that instead.
Now that the genirq code provides an IRQ bitmap of its own and the
necessary API to manipulate it, there's no need to keep our own version
around anymore.
In the process we kill off some unused IRQ reservation code, with future
users now having to tie in to the genirq API as normal.
Switch over to the new allocator functions.
The balancing stubs obviously need to be static inline..
The Kconfig and Makefile were overlooked, add those in now to improve
odds of building.
This splits up the sh intc core in to something more vaguely resembling
a subsystem. Most of the functionality was alread fairly well
compartmentalized, and there were only a handful of interdependencies
that needed to be resolved in the process.
This also serves as future-proofing for the genirq and sparseirq rework,
which will make some of the split out functionality wholly generic,
allowing things to be killed off in place with minimal migration pain.
