path: root/drivers/spi/amba-pl022.c
2011-06-13spi-pl022: Add missing return value updateVirupax Sadashivpetimath
Return error on out of range cpsdvsr value. Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-20spi/amba-pl022: work in polling or interrupt mode if pl022_dma_probe failsViresh Kumar
If pl022_dma_probe fails, we can try to transfer data in polling or interrupt mode. Also, set platform_info->enable_dma to 0, so that no other code tries to use dma. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-20spi/pl022: use cpu_relax in the busy loopLinus Walleij
This relaxes the cpu in the polling busy-wait loop. Reported-by: Vitaly Wool <vitalywool@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-20spi/pl022: timeout on polled transfer v2Magnus Templing
This adds the missing handling of polling timeouts and deletes our last todo. Signed-off-by: Magnus Templing <magnus.templing@stericsson.com> Reviewed-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> [Fixups from review by Wolfram Sang] Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-04-11Merge branch 'spi/merge' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'spi/merge' of git://git.secretlab.ca/git/linux-2.6: dt/fsldma: fix build warning caused by of_platform_device changes spi: Fix race condition in stop_queue() gpio/pch_gpio: Fix output value of pch_gpio_direction_output() gpio/ml_ioh_gpio: Fix output value of ioh_gpio_direction_output() gpio/pca953x: fix error handling path in probe() call
2011-04-07spi: Fix race condition in stop_queue()Vasily Khoruzhick
There's a race condition in stop_queue() in some drivers - if drv_data->queue is empty, but drv_data->busy is still set (or opposite situation) stop_queue will return -EBUSY. So fix loop condition to check that both drv_data->queue is empty and drv_data->busy is not set. This patch affects following drivers: pxa2xx_spi spi_bfin5xx amba-pl022 dw_spi Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-23spi/pl022: Add loopback support for the SPI on 5500Philippe Langlais
Extend the vendor data with a loopback field, and add new amba-pl022 vendor data for the DB5500 pl023, as the pl023 on db8500 and db5500 vary. Signed-off-by: Prajadevi H <prajadevi.h@stericsson.com> Signed-off-by: Philippe Langlais <philippe.langlais@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-18Merge branch 'spi/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'spi/next' of git://git.secretlab.ca/git/linux-2.6: (34 commits) spi/dw_spi: move dw_spi.h into drivers/spi spi/dw_spi: Fix missing header gpio/langwell: Clear edge bit before handling gpio/langwell: Simplify demux loop gpio/langwell: Convert irq name space gpio/langwell: Fix broken irq_eoi change. gpio; Make Intel chipset gpio drivers depend on x86 gpio/cs5535-gpio: Fix section mismatch spi/rtc-{ds1390,ds3234,m41t94}: Use spi_get_drvdata() for SPI devices spi/davinci: Support DMA transfers larger than 65535 words spi/davinci: Use correct length parameter to dma_map_single calls gpio: Use __devexit at necessary places gpio: add MODULE_DEVICE_TABLE to pch_gpio and ml_ioh_gpio gpio/mcp23s08: support mcp23s17 variant of_mmc_spi: add card detect irq support spi/omap_mcspi: catch xfers of non-multiple SPI word size spi/omap_mcspi: Off-by-one error in finding the right divisor gpio/pca953x: Fix wrong pointer type spi/pl022: rid dangling labels spi: add support for SuperH SPI ...
2011-02-23ARM: amba: make probe() functions take const id tablesRussell King
Make Primecell driver probe functions take a const pointer to their ID tables. Drivers should never modify their ID tables in their probe handler. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-22spi/pl022: rid dangling labelsLinus Walleij
Remove a compilation error regarding unused labels that came about when simplifying the DMA code. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-02-15spi/pl022: minor kerneldoc updatesLinus Walleij
2011-02-15spi/pl022: remove dangling status checkVirupax Sadashivpetimath
Signed-off-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-02-15spi/pl022: disable core voltage when idleLinus Walleij
This utilizes the new core voltage switch to power off the PL022 core voltage when it's not in use transmitting packets, if and only if a core voltage switch is available. Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-02-15spi/pl022: use dmaengine helper macrosLinus Walleij
This simplifies the DMA code a bit by using the dmaengine helpers. The cookie from descriptor submission can be ignored in this case as has been established in review of the MMCI/PL180 driver. Cc: Dan Williams <dan.j.williams@intel.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-01-14spi/amba-pl022: fixing compilation warning.Viresh Kumar
clk_freq is used uninitialized in pl022_setup routine. This patch fix compilation warning for using uninitialized variable Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-12-23spi/pl022: convert running variableLinus Walleij
This variable is a bool but defined an int and defined completely backwards. This makes the code more readable. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-12-23spi/pl022: convert busy flag to a boolLinus Walleij
2010-12-23spi/pl022: pass the returned sglen to the DMA engineLinus Walleij
The sglen return by the dma_map_sg() should be passed to the DMA engine, not the one passed in. If we one day have a DMA mapper that can coalesce entries, this will bug due to a too large number of entries being passed in. Reported-by: Russell King <linux@arm.linux.org.uk> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-12-23spi/pl022: map the buffers on the DMA engineLinus Walleij
The struct device for the DMA engine is the apropriate one to use when mapping/unmapping buffers. This is because the memory which is addressable by DMA is determined by the DMA engine rather than the device. Reported-by: Russell King <linux@arm.linux.org.uk> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-11-14drivers/spi: Remove unnecessary semicolonsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-10-12spi/pl022: fix dubious allocation staticize platform dataLinus Walleij
This removes some dubious allocation of a local chipinfo struct in favor of a constant preset, tagging that one const revealed further problems with platform data being modified so fixed up these too. Reported-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-10-12spi/pl022: get rid of chipinfo dev pointerLinus Walleij
What is the dev pointer doing inside the platform data anyway. We have another pointer to the actual device at hand, use that. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-10-12spi/pl022: Add spi->mode support to AMBA SPI driverKevin Wells
This patch adds spi->mode support for the AMBA pl022 driver and allows spidev to correctly alter SPI modes. Unused fields used in the pl022 header file for the pl022_config_chip have been removed. The ab8500 client driver selects the data transfer size instead of the platform data. For platforms that use the amba pl022 driver, the unused fields in the controller data structure have been removed and the .mode field in the SPI board info structure is used instead. Signed-off-by: Kevin Wells <wellsk40@gmail.com> Tested-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-10-12spi/pl022: add PrimeCell generic DMA supportLinus Walleij
This extends the PL022 SSP/SPI driver with generic DMA engine support using the PrimeCell DMA engine interface. Also fix up the test code for the U300 platform. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-09-29spi/amba-pl022: Fix error case return statement.Julia Lawall
The return -EINVAL appears to only make sense if the if branch that it is aligned with is taken, and the indentation indicates that this is the authors intent, so move it into that branch. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r disable braces4@ position p1,p2; statement S1,S2; @@ ( if (...) { ... } | if (...) S1@p1 S2@p2 ) @script:python@ p1 << r.p1; p2 << r.p2; @@ if (p1[0].column == p2[0].column): cocci.print_main("branch",p1) cocci.print_secs("after",p2) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-09-08spi/pl022: move probe call to subsys_initcall()Linus Walleij
The PL022 SPI bus is sometimes used for early stuff like regulators that need to be present at module_init() time, so we move this to a subsys_initcall(). Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-09-08spi/pl022: fix APB pclk power regression on U300Linus Walleij
With the introduction of an AMBA PrimeCell per-cell block clock, the pclk was left on after probe() unless explicitly disabled. This clock is wired to the same clock on PL022 causing it to stay always on since. Fix this up properly by clocking the pclk whenever we want to write into any PL022 registers and clocking the external clock whenever we want to transmit messages on the bus. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Tested-by : Kevin Wells <wellsk40@gmail.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-08-01spi/amba_pl022: Fix probe and remove hook section annotations.Kevin Wells
Probe and remove hooks belong in the __devinit and __devexit sections respectively. This patch fixes incorrect annotations on the pl022 spi driver. Signed-off-by: Kevin Wells <wellsk40@gmail.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-25spi/pl022: fix stop queue procedureGrzegorz Sygieda
This fix prevents queue being marked as "stopped", if data exists in the queue list. Signed-off-by: Grzegorz Sygieda <grzegorz.sygieda@tieto.com> Signed-off-by: Lukasz Baj <lukasz.baj@tieto.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-25spi/pl022: add support for the PL023 derivateLinus Walleij
This adds support for a further ST variant of the PL022 called PL023. Some differences in the control registers due to being stripped down to SPI mode only, and a new clock feedback sample delay config setting is available. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-25spi/pl022: fix up differences between ARM and ST versionsLinus Walleij
The PL022 SPI driver did not cleanly separate between the original unmodified ARM version and the ST Microelectronics versions. Split this more cleanly and fix some whitespace moaning from checkpatch at the same time. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-27ARM: 5893/1: SPI AMBA PL022: Limit TX FIFO fillsLinus Walleij
Added logic to cap TX FIFO fill size based on current free RX FIFO entries instead of TX status flags. This is to prevent an issue with RX FIFO overflows. Signed-off-by: Kevin Wells <kevin.wells@nxp.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-10-05ARM: 5741/1: pl022: fix peripheral id for ST vendorSrinidhi Kasagar
This fixes the wrong peripheral id being used in pl022 driver for ST derivative. Signed-off-by: srinidhi kasagar <srinidhi.kasagar@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-09-21Merge branch 'u300' into develRussell King
2009-09-18ARM: 5678/1: SSP/SPI PL022 polarity terminology fixLinus Walleij
The definition of the SPI clock phase for the Motorola mode of the PL022 driver was incorrect: the spec had been interpreted as data being recieved on rising or falling edge of the clocks while the correct interpretation is that data can be recieved on the first or second edge transition, falling or rising depending on the polarity setting. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-07-11[ARM] remove duplicated #includeHuang Weiyi
Remove duplicated #include('s) in drivers/spi/amba-pl022.c Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-06-10[ARM] 5546/1: ARM PL022 SSP/SPI driver v3Linus Walleij
This adds a driver for the ARM PL022 PrimeCell SSP/SPI driver found in the U300 platforms as well as in some ARM reference hardware, and in a modified version on the Nomadik board. Reviewed-by: Alessandro Rubini <rubini-list@gnudd.com> Reviewed-by: Russell King <linux@arm.linux.org.uk> Reviewed-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
