path: root/drivers/spi/mpc52xx_psc_spi.c
2009-06-18mpc52xx_psc_spi: convert to cs_control callbackAnton Vorontsov
mpc52xx_psc_spi driver is the last user of the legacy activate_cs and deactivate_cs callbacks, so convert the driver to the cs_control hook and remove the legacy callbacks from fsl_spi_platform_data struct. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18spi: move more spi_setup() functionality into coreDavid Brownell
Move some common spi_setup() error checks into the SPI framework from the spi_master controller drivers: - Add a new "mode_bits" field to spi_master - Use that in spi_setup to validate the spi->mode value being requested. Setting this new field is now mandatory for any controller supporting more than vanilla SPI_MODE_0. - Update all spi_master drivers to: * Initialize that field * Remove current spi_setup() checks using that value. This is a net minor code shrink. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-24spi: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Cc: dbrownell@users.sourceforge.net Cc: spi-devel-general@lists.sourceforge.net Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
2008-12-01spi: mpc52xx_psc_spi chipselect bugfixStefano Babic
According to the manual the "tdfOnExit" flag must be set on the last byte we want to send. The PSC controller holds SS low until the flag is set. However, the flag was set always on the last byte of the FIFO, independently if it is the last byte of the transfer. This generates spurious toggling of the SS signals that breaks the protocol of some peripherals. Fix. Signed-off-by: Stefano Babic <sbabic@denx.de> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16mpc52xx_psc_spi: remove code associated with !CONFIG_PPC_MERGEKumar Gala
Now that arch/ppc is gone we don't need CONFIG_PPC_MERGE anymore remove the dead code associated with !CONFIG_PPC_MERGE. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: David Brownell <david-b@pacbell.net> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-08powerpc/mpc5200: fix build warnings on mpc52xx_psc_spi driverGrant Likely
The register definitions have been changed for the mpc5200 PSC ports to cover some of the changes in the mpc5200b. One change is that the ccr register is now a u32 instead of a u16. However, for the purposes of this driver we want to continue to use 16 bit access to avoid changing the existing (working) behaviour. This patch allows the driver to continue to do 16 bit accesses without the compiler complaining about it. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2008-07-28mpc52xx_psc_spi: fix block transferLuotao Fu
The block transfer routine in the mpc52xx psc spi driver misinterpret the datasheet. According to the processor datasheet the chipselect is held as long as the EOF is not written. Theoretically blocks of any sizes can be transferred in this way. The old routine however writes an EOF after every word, which has the size of size_of_word. This makes the transfer slow. Also fixed some duplicate code. Signed-off-by: Luotao Fu <l.fu@pengutronix.de> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-12powerpc/mpc52xx_psc_spi: use linux/of_platform.h instead of asmStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2008-05-14mpc5200_psc_spi: typo fix in header blockGrant Likely
Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-11spi: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable SPI platform drivers, to allow module auto loading. [dbrownell@users.sourceforge.net: more drivers: registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04powerpc: mpc5200: fix build error on mpc52xx_psc_spi device driverGrant Likely
Commit id 94f389485e27641348c1951ab8d65157122a8939 (Separate MPC52xx PSC FIOF regsiters from the rest of PSC) split the PSC fifo registers away from the core PSC regs. Doing so broke the mpc52xx_psc_spi driver. This patch teaches the mpc52xx_psc_spi driver about the new PSC fifo register definitions. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: David Brownell <david-b@pacbell.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Kumar Gala <galak@gate.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-26[POWERPC] mpc52xx_psc_spi device driver must not touch port_config and cdmGrant Likely
It is dangerous for an mpc52xx device driver to modify the port_config register. If the driver is probed incorrectly, it will change the pin IO configuration in ways which may not be compatible with the board. port_config should be set up by the bootloader, or failing that, in the platform setup code in arch/powerpc/platforms/52xx. Also, modifying CDM registers directly can cause a race condition with other drivers. Instead call a common routine to modify CDM settings. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Dragos Carp <dragos.carp@toptica.com>
2008-01-26[POWERPC] mpc5200: normalize compatible property bindingsGrant Likely
Update MPC5200 drivers to also look for compatible properties in the form "fsl,mpc5200-*" to better conform to open firmware generic names recommended practice as published here: http://www.openfirmware.org/1275/practice/gnames/gnamv14a.html This patch should *not* break compatibility with older device trees which do not use the 'fsl,' prefix. The drivers will still bind against the older names also. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2008-01-18[POWERPC] mpc5200: eliminate mpc52xx_*_map_*() functions.Grant Likely
mpc5200 platform code defines a bunch of map functions which duplicate the functionality of of_iomap(). Remove them and use of_iomap() instead. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-10-19Fix misspellings of "system", "controller", "interrupt" and "necessary".Robert P. J. Day
Fix the various misspellings of "system", controller", "interrupt" and "[un]necessary". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-16spi doesn't need class_deviceTony Jones
Make the SPI framework and drivers stop using class_device. Update docs accordingly ... highlighting just which sysfs paths should be "safe"/stable. Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17SPI controller drivers: check for unsupported modesDavid Brownell
Minor SPI controller driver updates: make the setup() methods reject spi->mode bits they don't support, by masking aginst the inverse of bits they *do* support. This insures against misbehavior later when new mode bits get added. Most controllers can't support SPI_LSB_FIRST; more handle SPI_CS_HIGH. Support for all four SPI clock/transfer modes is routine. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23mpc52xx_psc_spi: fix it for CONFIG_PPC_MERGEDomen Puncer
Fix mpc5200 PSC SPI driver to actually work for CONFIG_PPC_MERGE - s/mpc52xx/mpc5200/, as this was changed in device tree some time ago - fix spi id detection The move from 'ppc' to 'powerpc' didn't quite match the latest kernel.org code. Signed-off-by: Domen Puncer <domen.puncer@telargo.com> Acked-by: Dragos Carp <dragos.carp@toptica.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11MPC52xx PSC SPI master driverDragos Carp
SPI master driver for MPC52xx using its Programmable Serial Controller. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Dragos Carp <dragos.carp@toptica.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
