path: root/drivers/spi/spi-au1550.c
2015-09-16spi: au1550: Simplify au1550_spi_setupxfer()Jarkko Nikula
SPI core validates both bits_per_word and speed_hz transfer parameters and defaults to spi->bits_per_word and spi->max_speed_hz in case these per transfer parameters are not set. This can simplify a little the au1550_spi_setupxfer() as there is need to check only for valid "struct spi_transfer" pointer. Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-12-22spi: Remove FSF mailing addressesJarkko Nikula
2014-10-20spi: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-08-19spi: spi-au1550: fix build failureManuel Lauss
Fix a build failure introduced with commit 30670539b86 (spi: au1550: Fix bug in deallocation of memory) Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-08-07Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "This is the main pull request for 3.17. It contains: - misc Cavium Octeon, BCM47xx, BCM63xx and Alchemy updates - MIPS ptrace updates and cleanups - various fixes that will also go to -stable - a number of cleanups and small non-critical fixes. - NUMA support for the Loongson 3. - more support for MSA - support for MAAR - various FP enhancements and fixes" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (139 commits) MIPS: jz4740: remove unnecessary null test before debugfs_remove MIPS: Octeon: remove unnecessary null test before debugfs_remove_recursive MIPS: ZBOOT: implement stack protector in compressed boot phase MIPS: mipsreg: remove duplicate MIPS_CONF4_FTLBSETS_SHIFT MIPS: Bonito64: remove a duplicate define MIPS: Malta: initialise MAARs MIPS: Initialise MAARs MIPS: detect presence of MAARs MIPS: define MAAR register accessors & bits MIPS: mark MSA experimental MIPS: Don't build MSA support unless it can be used MIPS: consistently clear MSA flags when starting & copying threads MIPS: 16 byte align MSA vector context MIPS: disable preemption whilst initialising MSA MIPS: ensure MSA gets disabled during boot MIPS: fix read_msa_* & write_msa_* functions on non-MSA toolchains MIPS: fix MSA context for tasks which don't use FP first MIPS: init upper 64b of vector registers when MSA is first used MIPS: save/disable MSA in lose_fpu MIPS: preserve scalar FP CSR when switching vector context ...
2014-07-30MIPS: Alchemy: remove au_read/write/syncManuel Lauss
replace au_read/write/sync with __raw_read/write and wmb. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Cc: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/7465/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-07-04spi: au1550: Fix bug in deallocation of memoryHimangi Saraogi
This patch fixes a bug on the deallocation of memory allocated using request_mem_region, by using release_mem_region instead of release_resource and kfree. Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-04-02Merge branch 'mips-for-linux-next' of ↵Linus Torvalds
git://git.linux-mips.org/pub/scm/ralf/upstream-sfr Pull MIPS updates from Ralf Baechle: - Support for Imgtec's Aptiv family of MIPS cores. - Improved detection of BCM47xx configurations. - Fix hiberation for certain configurations. - Add support for the Chinese Loongson 3 CPU, a MIPS64 R2 core and systems. - Detection and support for the MIPS P5600 core. - A few more random fixes that didn't make 3.14. - Support for the EVA Extended Virtual Addressing - Switch Alchemy to the platform PATA driver - Complete unification of Alchemy support - Allow availability of I/O cache coherency to be runtime detected - Improvments to multiprocessing support for Imgtec platforms - A few microoptimizations - Cleanups of FPU support - Paul Gortmaker's fixes for the init stuff - Support for seccomp * 'mips-for-linux-next' of git://git.linux-mips.org/pub/scm/ralf/upstream-sfr: (165 commits) MIPS: CPC: Use __raw_ memory access functions MIPS: CM: use __raw_ memory access functions MIPS: Fix warning when including smp-ops.h with CONFIG_SMP=n MIPS: Malta: GIC IPIs may be used without MT MIPS: smp-mt: Use common GIC IPI implementation MIPS: smp-cmp: Remove incorrect core number probe MIPS: Fix gigaton of warning building with microMIPS. MIPS: Fix core number detection for MT cores MIPS: MT: core_nvpes function to retrieve VPE count MIPS: Provide empty mips_mt_set_cpuoptions when CONFIG_MIPS_MT=n MIPS: Lasat: Replace del_timer by del_timer_sync MIPS: Malta: Setup PM I/O region on boot MIPS: Loongson: Add a Loongson-3 default config file MIPS: Loongson 3: Add CPU hotplug support MIPS: Loongson 3: Add Loongson-3 SMP support MIPS: Loongson: Add Loongson-3 Kconfig options MIPS: Loongson: Add swiotlb to support All-Memory DMA MIPS: Loongson 3: Add serial port support MIPS: Loongson 3: Add IRQ init and dispatch support MIPS: Loongson 3: Add HT-linked PCI support ...
2014-03-26MIPS: Alchemy: Unify Devboard support.Manuel Lauss
This patch merges support for all DB1xxx and PB1xxx boards into a single image, along with a new single defconfig for them. Run-tested on DB1300 and DB1500. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Cc: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/6577/ Patchwork: https://patchwork.linux-mips.org/patch/6659/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-02-14spi: au1550: Convert to let spi core handle checking transfer speedAxel Lin
By setting master->max_speed_hz and master->min_speed_hz, spi core will handle checking transfer speed. So we can remove the same checking in this driver. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-10-25Merge remote-tracking branch 'spi/topic/probe' into spi-nextMark Brown
2013-10-09spi: spi-au1550: replace platform_driver_probe to support deferred probingWolfram Sang
Subsystems like pinctrl and gpio rightfully make use of deferred probing at core level. Now, deferred drivers won't be retried if they don't have a .probe function specified in the driver struct. Fix this driver to have that, so the devices it supports won't get lost in a deferred probe. Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-17spi: bitbang: Let spi_bitbang_start() take a reference to masterAxel Lin
Many drivers that use bitbang library have a leak on probe error paths. This is because once a spi_master_get() call succeeds, we need an additional spi_master_put() call to free the memory. Fix this issue by moving the code taking a reference to master to spi_bitbang_start(), so spi_bitbang_start() will take a reference to master on success. With this change, the caller is responsible for calling spi_bitbang_stop() to decrement the reference and spi_master_put() as counterpart of spi_alloc_master() to prevent a memory leak. So now we have below patten for drivers using bitbang library: probe: spi_alloc_master -> Init reference count to 1 spi_bitbang_start -> Increment reference count remove: spi_bitbang_stop -> Decrement reference count spi_master_put -> Decrement reference count (reference count reaches 0) Fixup all users accordingly. Signed-off-by: Axel Lin <axel.lin@ingics.com> Suggested-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de> Acked-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-08-29spi: use dev_get_platdata()Jingoo Han
Use the wrapper function for retrieving the platform data instead of accessing dev->platform_data directly. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-06-26Merge remote-tracking branch 'spi/topic/core' into spi-nextMark Brown
2013-05-29spi: convert drivers to use bits_per_word_maskStephen Warren
Fill in the recently added spi_master.bits_per_word_mask field in as many drivers as possible. Make related cleanups, such as removing any redundant error-checking, or empty setup callbacks. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-05-13spi: remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure, since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d (device-core: Ensure drvdata = NULL when no driver is bound). Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Grant Likely <grant.likely@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-02-05spi: Remove erroneous __init, __exit and __exit_p() references in driversGrant Likely
Some of the spi driver module remove hooks were annotated with __exit and referenced with __exit_p(). Presumably these were supposed to be __devinit, __devexit and __devexit_p() since __init/__exit for a probe/remove hook has never been correct. They also got missed during the big __devinit/__devexit purge since they didn't match the pattern. Remove then now to be rid of it. v2: purge __init also Reported-by: Arnd Bergmann <arnd@arndb.de> [Arnd set a patch cleaning up one, and then I found more] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-09-01spi: fix comment/printk typos in spiMasanari Iida
Correct spelling typo in drivers/spi Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-10-31spi: Add module.h to implicit users in drivers/spiPaul Gortmaker
We are clipping down the presence of module.h, since it was everywhere. If you really need it, you better call it out, as per this changeset. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-06-06spi: reorganize driversGrant Likely
Sort the SPI makefile and enforce the naming convention spi_*.c for spi drivers. This change also rolls the contents of atmel_spi.h into the .c file since there is only one user of that particular include file. v2: - Use 'spi-' prefix instead of 'spi_' to match what seems to be be the predominant pattern for subsystem prefixes. - Clean up filenames in Kconfig and header comment blocks Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Linus Walleij <linus.walleij@linaro.org>
