[ Upstream commit d853b3406903a7dc5b14eb5bada3e8cd677f66a2 ]
Clang warns:
drivers/spi/spi-bcm2835aux.c:532:50: warning: variable 'err' is
uninitialized when used here [-Wuninitialized]
dev_err(&pdev->dev, "could not get clk: %d\n", err);
./include/linux/dev_printk.h:112:32: note: expanded from macro 'dev_err'
_dev_err(dev, dev_fmt(fmt), ##__VA_ARGS__)
drivers/spi/spi-bcm2835aux.c:495:9: note: initialize the variable 'err'
to silence this warning
int err;
= 0
1 warning generated.
Restore the assignment so that the error value can be used in the
dev_err statement and there is no uninitialized memory being leaked.
Fixes: e13ee6cc4781 ("spi: bcm2835aux: Fix use-after-free on unbind")
Link: https://github.com/ClangBuiltLinux/linux/issues/1199
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
Link: https://lore.kernel.org/r/20201113180701.455541-1-natechancellor@gmail.com
Signed-off-by: Mark Brown <broonie@kernel.org>
[lukas: backport to 4.19-stable, add stable designation]
Signed-off-by: Lukas Wunner <lukas@wunner.de>
Cc: <stable@vger.kernel.org> # v4.4+: e13ee6cc4781: spi: bcm2835aux: Fix use-after-free on unbind
[ Upstream commit e13ee6cc4781edaf8c7321bee19217e3702ed481 ]
bcm2835aux_spi_remove() accesses the driver's private data after calling
spi_unregister_master() even though that function releases the last
reference on the spi_master and thereby frees the private data.
Fix by switching over to the new devm_spi_alloc_master() helper which
keeps the private data accessible until the driver has unbound.
Fixes: b9dd3f6d4172 ("spi: bcm2835aux: Fix controller unregister order")
Cc: <stable@vger.kernel.org> # v4.4+: 5e844cc37a5c: spi: Introduce device-managed SPI controller allocation
Cc: <stable@vger.kernel.org> # v4.4+: b9dd3f6d4172: spi: bcm2835aux: Fix controller unregister order
Link: https://lore.kernel.org/r/b290b06357d0c0bdee9cecc539b840a90630f101.1605121038.git.lukas@wunner.de
commit b9dd3f6d417258ad0beeb292a1bc74200149f15d upstream.
The BCM2835aux SPI driver uses devm_spi_register_master() on bind.
As a consequence, on unbind, __device_release_driver() first invokes
bcm2835aux_spi_remove() before unregistering the SPI controller via
devres_release_all().
This order is incorrect: bcm2835aux_spi_remove() turns off the SPI
controller, including its interrupts and clock. The SPI controller
is thus no longer usable.
When the SPI controller is subsequently unregistered, it unbinds all
its slave devices. If their drivers need to access the SPI bus,
e.g. to quiesce their interrupts, unbinding will fail.
As a rule, devm_spi_register_master() must not be used if the
->remove() hook performs teardown steps which shall be performed
after unbinding of slaves.
Fix by using the non-devm variant spi_register_master(). Note that the
struct spi_master as well as the driver-private data are not freed until
after bcm2835aux_spi_remove() has finished, so accessing them is safe.
Fixes: 1ea29b39f4c8 ("spi: bcm2835aux: add bcm2835 auxiliary spi device driver")
Cc: stable@vger.kernel.org # v4.4+
Cc: Martin Sperl <kernel@martin.sperl.org>
Link: https://lore.kernel.org/r/32f27f4d8242e4d75f9a53f7e8f1f77483b08669.1589557526.git.lukas@wunner.de
[ Upstream commit 509c583620e9053e43d611bf1614fc3d3abafa96 ]
The original driver by default defines num_chipselects as -1.
This actually allicates an array of 65535 entries in
of_spi_register_master.
There is a side-effect for buggy device trees that (contrary to
dt-binding documentation) have no cs-gpio defined.
This mode was never supported by the driver due to limitations
of native cs and additional code complexity and is explicitly
not stated to be implemented.
To keep backwards compatibility with such buggy DTs we limit
the number of chip_selects to 1, as for all practical purposes
it is only ever realistic to use a single chip select in
native cs mode without negative side-effects.
Fixes: 1ea29b39f4c812ec ("spi: bcm2835aux: add bcm2835 auxiliary spi device...")
Signed-off-by: Martin Sperl <kernel@martin.sperl.org>
Acked-by: Stefan Wahren <stefan.wahren@i2se.com>
[ Upstream commit 73b114ee7db1750c0b535199fae383b109bd61d0 ]
On long running tests with a mcp2517fd can controller it showed that
on rare occations the data read shows corruptions for longer spi transfers.
Example of a 22 byte transfer:
expected (as captured on logic analyzer):
FF FF 78 00 00 00 08 06 00 00 91 20 77 56 84 85 86 87 88 89 8a 8b
read by the driver:
FF FF 78 00 00 00 08 06 00 00 91 20 77 56 84 88 89 8a 00 00 8b 9b
To fix this use BCM2835_AUX_SPI_STAT_RX_LVL to determine when we may
read data from the fifo reliably without any corruption.
Surprisingly the only values ever empirically read in
BCM2835_AUX_SPI_STAT_RX_LVL are 0x00, 0x10, 0x20 and 0x30.
So whenever the mask is not 0 we can read from the fifo in a safe manner.
The patch has now been tested intensively and we are no longer
able to reproduce the "RX" issue any longer.
Reported-by: Hubert Denkmair <h.denkmair@intence.de>
[ Upstream commit c7de8500fd8ecbb544846dd5f11dca578c3777e1 ]
This read of the fifo is a potential candidate for a race condition
as the spi transfer is not necessarily finished and so can lead to
an early read of the fifo that still misses data.
So it has been removed.
Suggested-by: Hubert Denkmair <h.denkmair@intence.de>
[ Upstream commit 7188a6f0eee3f1fae5d826cfc6d569657ff950ec ]
Sharing more code between polling and interrupt-driven mode.
[ Upstream commit bc519d9574618e47a0c788000fb78da95e18d953 ]
The BCM2835 AUX SPI has a shared interrupt line (with AUX UART).
Downstream fixes this with an AUX irqchip to demux the IRQ sources and a
DT change which breaks compatibility with older kernels. The AUX irqchip
was already rejected for upstream[1] and the DT change would break
working systems if the DTB is updated to a newer one. The latter issue
was brought to my attention by Alex Graf.
The root cause however is a bug in the shared handler. Shared handlers
must check that interrupts are actually enabled before servicing the
interrupt. Add a check that the TXEMPTY or IDLE interrupts are enabled.
[1] https://patchwork.kernel.org/patch/9781221/
Cc: Alexander Graf <agraf@suse.de>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Mark Brown <broonie@kernel.org>
Cc: Eric Anholt <eric@anholt.net>
Cc: Stefan Wahren <stefan.wahren@i2se.com>
Cc: Florian Fainelli <f.fainelli@gmail.com>
Cc: Ray Jui <rjui@broadcom.com>
Cc: Scott Branden <sbranden@broadcom.com>
Cc: bcm-kernel-feedback-list@broadcom.com
Cc: linux-spi@vger.kernel.org
Cc: linux-rpi-kernel@lists.infradead.org
Signed-off-by: Rob Herring <robh@kernel.org>
Reviewed-by: Eric Anholt <eric@anholt.net>
Change the initialization order of the HW so that the interrupt
is only requested after the HW is initialized
Also the use of irq_of_parse_and_map is replaced by platform_get_irq.
There are strange issues with the auxiliary spi device that result
in "lost" data in the RX path if the fifo is filled by too much
(even though the status register is checked if new data can get filled
in).
This has been observed primarily for the interrupt case.
Polling works fine, probably because the RX fifo is pulled immediately
when in the tight polling loop.
For that reason we have to limit the pending bytes to less than 15
when filling the fifo in interrupt mode.
There also was an issue returning the "wrong" last 1/2 bytes
of a transfer when the transfer is not a multiple of 3 bytes.
(this impacted polling and interrupt modes)
Also fixed an overflow in the estimation of the transfer time used
to decide if we run in interrupt or polling mode (found with the
spi-bcm2835.c driver originally).
Reported-by: Georgii Staroselskii <georgii.staroselskii@emlid.com>
The bcm2835 has 2 auxiliary spi bus masters spi1 and spi2.
This implements the driver to enable these devices.
The driver does not implement native chip-selects but uses
the aribtrary GPIO-chip-selects provided by the spi-chipselect.
Note that this driver relies on the fact that
the clock is implemented by the clk-bcm2835-aux driver,
which enables/disables the HW block when requesting/releasing
the clock.
Acked-by: Eric Anholt <eric@anholt.net>
