[ Upstream commit 378da4a65f3a0390837b38145bb5d8c2d20c2cf7 ]
platform_get_irq() returns an error code, but the spi-bcm63xx-hsspi
driver ignores it and always returns -ENXIO. This is not correct and,
prevents -EPROBE_DEFER from being propagated properly.
Notice that platform_get_irq() no longer returns 0 on error:
https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/?id=e330b9a6bb35dc7097a4f02cb1ae7b6f96df92af
Print and propagate the return value of platform_get_irq on failure.
This issue was detected with the help of Coccinelle.
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
Add support for dual read/writes on spi-bcm63xx-hsspi. This has been
tested with a s25fl129p1 dual read capable spi flash, with a nice speed
improvement:
serial read:
root@OpenWrt:/# time dd if=/dev/mtd4 of=/dev/null bs=8192
2032+0 records in
2032+0 records out
real 0m 4.39s
user 0m 0.00s
sys 0m 1.55s
dual read:
2032+0 records in
2032+0 records out
real 0m 3.09s
user 0m 0.00s
sys 0m 1.56s
Signed-off-by: Jonas Gorski <jogo@openwrt.org>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
'spi/topic/clps711x', 'spi/topic/coldfire', 'spi/topic/completion' and 'spi/topic/davinci' into spi-next
Use SIMPLE_DEV_PM_OPS macro in order to make the code simpler.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Calling init_completion() once is enough.
For the rest of the iterations, call reinit_completion() instead.
Use the right CONFIG symbol to guard, properly (un)preprare clocks on
suspend/resume, and check the result of it.
Simplifies the remove call.
Ensure we notice if the clock cannot be enabled for any reason and pass
the error down.
Use devm_clk_get() to make cleanup paths simpler.
Acked-by: Jonas Gorski <jogo@openwrt.org>
devm_request_and_ioremap() returns NULL on error, it doesn't return an
ERR_PTR(). This patch fixes it by switching to devm_ioremap_resource()
which is the prefered function anyway.
Fixes: 142168eba9dc ('spi: bcm63xx-hsspi: add bcm63xx HSSPI driver')
Add a driver for the High Speed SPI controller found on newer BCM63XX SoCs.
It does feature some new modes like 3-wire or dual spi, but neither of it
is currently implemented.
