path: root/drivers/spi/spi-bcm63xx.c
2016-01-11Merge remote-tracking branches 'spi/topic/bcm63xx', 'spi/topic/butterfly', ↵Mark Brown
'spi/topic/cadence' and 'spi/topic/davinci' into spi-next
2015-11-16spi: bcm63xx: use correct format string for printing a resourceArnd Bergmann
With a 64-bit resource_size_t, we get a build warning on bcm63xx_spi_probe: drivers/spi/spi-bcm63xx.c:565:16: warning: format '%x' expects argument of type 'unsigned int', but argument 3 has type 'resource_size_t {aka long long unsigned int}' [-Wformat=] As we are printing a resource, we can just use the %pr format specifier that pretty-prints the address and avoids the warning. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-11-16spi/bcm63xx: Move default clock configuration to kill compiler warningGeert Uytterhoeven
drivers/spi/spi-bcm63xx.c: In function ‘bcm63xx_spi_setup_transfer’: drivers/spi/spi-bcm63xx.c:207: warning: ‘clk_cfg’ may be used uninitialized in this function While this is a false positive, it can easily be avoided by selecting the default clock configuration first. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-10-23spi/bcm63xx: move register definitions into the driverJonas Gorski
Move all register definitions and structs into the driver. This allows us dropping the platform_data struct and drop any arch specific includes. Make use of different device names to identify the version of the block we have. Since we now have full control over the message width, we can drop the size check, which was broken anyway, since it never set ret to any error code. Also since we now have no arch depedendent resources, we can now allow compiling it for any arch, hidden behind COMPILE_TEST. Signed-off-by: Jonas Gorski <jogo@openwrt.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-10-12spi/bcm63xx: move message control word description to register offsetsJonas Gorski
Make the message control word parameters part of the register offsets array so we have them all in one struct. Signed-off-by: Jonas Gorski <jogo@openwrt.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-10-12spi/bcm63xx: fix standard accessors and compile guardJonas Gorski
Use the correct guard CONFIG_CPU_BIG_ENDIAN and the *be accessors to follow native endianness on big endian systems. Signed-off-by: Jonas Gorski <jogo@openwrt.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-09-14spi/bcm63xx: replace custom io accessors with standard onesJonas Gorski
Replace all bcm_read* with (io)read. Due to this block following system endianness, make sure we match that. Signed-off-by: Jonas Gorski <jogo@openwrt.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-09-14spi/bcm63xx: hardcode busnum to 0Jonas Gorski
We always pass 0 as the spi bus number, so we might as well hard code it. Signed-off-by: Jonas Gorski <jogo@openwrt.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-09-14spi/bcm63xx: always use a fixed number of CSJonas Gorski
We always pass 8 for the number of chip selects, so we can as well hardcode it to this number. Signed-off-by: Jonas Gorski <jogo@openwrt.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-09-14spi/bcm63xx: remove unused rx_tail variableJonas Gorski
Fixes the following warning: drivers/spi/spi-bcm63xx.c:125:5: warning: unused variable 'rx_tail' [-Wunused-variable] u8 rx_tail; ^ Signed-off-by: Jonas Gorski <jogo@openwrt.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-12-22spi: Remove FSF mailing addressesJarkko Nikula
Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-10-20spi: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-04-14spi: Remove unneeded include of linux/workqueue.hAxel Lin
Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-03-30Merge remote-tracking branches 'spi/topic/imx', 'spi/topic/init', ↵Mark Brown
'spi/topic/mpc512x-psc', 'spi/topic/mpc52xx', 'spi/topic/mxs', 'spi/topic/nuc900', 'spi/topic/oc-tiny' and 'spi/topic/octeon' into spi-next
2014-03-30Merge remote-tracking branches 'spi/topic/bus-num', 'spi/topic/cleanup', ↵Mark Brown
'spi/topic/clps711x', 'spi/topic/coldfire', 'spi/topic/completion' and 'spi/topic/davinci' into spi-next
2014-03-25spi: bcm63xx: Remove unused define for PFXAxel Lin
2014-02-10spi: Use reinit_completion at appropriate placesAxel Lin
Calling init_completion() once is enough. For the rest of the iterations, call reinit_completion() instead. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-02-03spi: delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-01-23Merge remote-tracking branches 'spi/topic/bcm2835', 'spi/topic/bcm63xx', ↵Mark Brown
'spi/topic/bcm63xx-hsspi', 'spi/topic/bitbang', 'spi/topic/bpw', 'spi/topic/clps711x', 'spi/topic/coldfire', 'spi/topic/davinci', 'spi/topic/dw' and 'spi/topic/falcon' into spi-linus
2013-12-17spi: bcm63xx: fix reference leak to master in bcm63xx_spi_remove()Wei Yongjun
Once a spi_master_get() call succeeds, we need an additional spi_master_put() call to free the memory, otherwise we will leak a reference to master. Fix by removing the unnecessary spi_master_get() call. Fixes: 247263dba208 ('spi: bcm63xx: use devm_spi_register_master()') Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-12-17spi/bcm63xx: fix pm sleep supportJonas Gorski
Use the correct symbol to guard the callbacks and use appropriate defines for setting up the ops struct. Signed-off-by: Jonas Gorski <jogo@openwrt.org> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-12-17spi/bcm63xx: check return value of clk_prepare_enableJonas Gorski
Ensure we notice if the clock cannot be enabled for any reason and pass the error down. Signed-off-by: Jonas Gorski <jogo@openwrt.org> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-12-17spi/bcm63xx: don't reject reads >= 256 bytesJonas Gorski
The rx_tail register is only 8 bit wide, so it will wrap around after 256 read bytes. This makes it rather meaningless, so drop any usage of it to not treat reads over 256 as failed. Signed-off-by: Jonas Gorski <jogo@openwrt.org> Acked-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-12-17spi: bcm63xx: Use devm_clk_get()Jingoo Han
Use devm_clk_get() to make cleanup paths simpler. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Jonas Gorski <jogo@openwrt.org> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-12-17spi/bcm63xx: don't substract prepend length from total lengthJonas Gorski
The spi command must include the full message length including any prepended writes, else transfers larger than 256 bytes will be incomplete. Signed-off-by: Jonas Gorski <jogo@openwrt.org> Acked-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@vger.kernel.org
2013-11-15spi: bcm63xx: fix reference leak to master in bcm63xx_spi_remove()Wei Yongjun
2013-09-26spi: bcm63xx: use devm_spi_register_master()Jingoo Han
Use devm_spi_register_master() to make cleanup paths simpler, and remove a duplicate put. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-01Merge remote-tracking branch 'spi/topic/qspi' into spi-nextMark Brown
2013-09-01Merge remote-tracking branch 'spi/topic/pdata' into spi-nextMark Brown
2013-08-29spi: Use dev_get_drvdata at appropriate placesAxel Lin
Use dev_get_drvdata() instead of platform_get_drvdata(to_platform_device(dev)). Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-08-29spi: use dev_get_platdata()Jingoo Han
Use the wrapper function for retrieving the platform data instead of accessing dev->platform_data directly. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-08-14spi/spi-{bcm63xx.c,bfin-v3.c}: simplify use of devm_ioremap_resourceJulia Lawall
Remove unneeded error handling on the result of a call to platform_get_resource when the value is passed to devm_ioremap_resource. Move the call to platform_get_resource adjacent to the call to devm_ioremap_resource to make the connection between them more clear. A simplified version of the semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression pdev,res,n,e,e1; expression ret != 0; identifier l; @@ - res = platform_get_resource(pdev, IORESOURCE_MEM, n); ... when != res - if (res == NULL) { ... \(goto l;\|return ret;\) } ... when != res + res = platform_get_resource(pdev, IORESOURCE_MEM, n); e = devm_ioremap_resource(e1, res); // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-07-29spi/bcm63xx: Convert to core runtime PMMark Brown
2013-06-26Merge remote-tracking branch 'spi/topic/core' into spi-nextMark Brown
2013-05-29spi: convert drivers to use bits_per_word_maskStephen Warren
Fill in the recently added spi_master.bits_per_word_mask field in as many drivers as possible. Make related cleanups, such as removing any redundant error-checking, or empty setup callbacks. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-05-13spi: remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure, since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d (device-core: Ensure drvdata = NULL when no driver is bound). Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Grant Likely <grant.likely@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-04-08spi/bcm63xx: remove unused speed_hz variableJonas Gorski
speed_hz is a write only member, so we can safely remove it and its generation. Also fixes the missing clk_put after getting the periph clock. Signed-off-by: Jonas Gorski <jogo@openwrt.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-03-12spi/bcm63xx: use devm_ioremap_resource()Jonas Gorski
Use devm_ioremap_resource() which provides its own error messages. Signed-off-by: Jonas Gorski <jogo@openwrt.org> Acked-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-03-12spi/bcm63xx: inline hz usage in bcm63xx_spi_setup_transferJonas Gorski
bcm63xx_spi_setup_transfer is called from only one place, and that has t always set, to hz will always be t->speed_hz - just use it directly in the two places instead of moving it in a local variable. Signed-off-by: Jonas Gorski <jogo@openwrt.org> Acked-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-03-12spi/bcm63xx: inline bcm63xx_spi_check_transferJonas Gorski
It only does one check, so just do the check directly in the caller. Signed-off-by: Jonas Gorski <jogo@openwrt.org> Acked-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-03-12spi/bcm63xx: remove spi chip select validity checkJonas Gorski
The check would belong in bcm63xx_spi_setup if the spi subsystem weren't already doing the check for us, so just drop it. Signed-off-by: Jonas Gorski <jogo@openwrt.org> Acked-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-03-12spi/bcm63xx: simplify bcm63xx_spi_check_transferJonas Gorski
bcm63xx_spi_check_transfer is only called from one place that has t always set, so directly check the transfer's bits_per_word. Signed-off-by: Jonas Gorski <jogo@openwrt.org> Acked-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-03-12spi/bcm63xx: check spi bits_per_word in spi_setupJonas Gorski
Instead of fixing up the bits_per_word (which the spi subsystem already does for us), check it for supported values. Signed-off-by: Jonas Gorski <jogo@openwrt.org> Acked-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-03-12spi/bcm63xx: remove unused variable bs from bcm63xx_spi_setupJonas Gorski
It is only written, but never read. Signed-off-by: Jonas Gorski <jogo@openwrt.org> Acked-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-03-12spi/bcm63xx: remove unneeded debug messageJonas Gorski
The spi subsystem already provides this info in a more extensive debug print except for the nsecs/bit - which wasn't calculated anyway and fixed to 0. Signed-off-by: Jonas Gorski <jogo@openwrt.org> Acked-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-03-12spi/bcm63xx: remove duplicated mode bits checkJonas Gorski
The spi subsystem already checks the mode bits before calling setup. Signed-off-by: Jonas Gorski <jogo@openwrt.org> Acked-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-03-12spi/bcm63xx: properly prepare clocks before enabling themJonas Gorski
Use proper clk_prepare/unprepare calls in preparation for switching to the generic clock framework. Signed-off-by: Jonas Gorski <jogo@openwrt.org> Acked-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-03-12spi/bcm63xx: don't disable non enabled clocks in probe error pathJonas Gorski
When msg_ctl_width is set to an invalid value we try to disable the clock despite it never being enabled. Fix it by jumping to the correct label. Signed-off-by: Jonas Gorski <jogo@openwrt.org> Acked-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-03-12spi/bcm63xx: Remove unused variableKevin Cernekee
This fixes the following warning: drivers/spi/spi-bcm63xx.c: In function 'bcm63xx_spi_setup': drivers/spi/spi-bcm63xx.c:157:6: warning: unused variable 'ret' Signed-off-by: Kevin Cernekee <cernekee@gmail.com> Acked-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-02-05spi/bcm63xx: work around inability to keep CS upJonas Gorski
This SPI controller does not support keeping CS asserted after sending a transfer. Since messages expected on this SPI controller are rather short, we can work around it for normal use cases by sending all transfers at once in a big full duplex stream. This means that we cannot change the speed between transfers if they require CS to be kept asserted, but these would have been rejected before anyway because of the inability of keeping CS asserted. Signed-off-by: Jonas Gorski <jogo@openwrt.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
