SPI core validates the transfer speed and defaults to spi->max_speed_hz in
case the transfer speed is not set so code here won't use the
chip->baud value (which is derived from spi->max_speed_hz).
Please note driver uses chip->baud at the beginning of message transmission
by calling the bfin_sport_spi_restore_state() but then programs per
transfer speed in bfin_sport_spi_pump_transfers(). I'm not familiar with
the HW so I don't know would it be possible to remove chip->baud completely
by either using constant value in bfin_sport_spi_restore_state() or by
removing the tclkdiv register write there.
Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
Signed-off-by: Mark Brown <broonie@linaro.org>
Instead of using legacy suspend/resume methods, using newer
dev_pm_ops structure allows better control over power management.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Use the wrapper function for retrieving the platform data instead of
accessing dev->platform_data directly.
Fill in the recently added spi_master.bits_per_word_mask field in as
many drivers as possible. Make related cleanups, such as removing any
redundant error-checking, or empty setup callbacks.
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
The driver core clears the driver data to NULL after device_release
or on probe failure, since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d
(device-core: Ensure drvdata = NULL when no driver is bound).
Thus, it is not needed to manually clear the device driver data to NULL.
Acked-by: Grant Likely <grant.likely@linaro.org>
The spi core make sure that each transfer structure have the proper
setting for bits_per_word before calling low level transfer APIs.
Hence it is no more require to check again in low level driver for
this field whether this is set correct or not. Removing such code
from low level driver.
The txx9 change also removes a test for bits_per_word set to 0, and
forcing it to 8 in that case. This can also be removed now since
spi_setup() ensures spi->bits_per_word is not zero.
if (!spi->bits_per_word)
spi->bits_per_word = 8;
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Bill Pemberton has done most of the legwork on this series. I've used
his script to purge the attributes from the drivers/gpio tree.
Reported-by: Bill Pemberton <wfp5p@virginia.edu>
Correct spelling typo in drivers/spi
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Since the member was dropped from the common Blackfin header, we need
to stop using it in the SPORT driver too.
Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com>
Each transfer may have its own bits per word.
For simple modules that contain a single platform_driver without any
additional setup code then ends up being a block of duplicated
boilerplate. This patch adds a new macro, module_platform_driver(),
which replaces the module_init()/module_exit() registrations with
template functions.
Reviewed-by: Magnus Damm <magnus.damm@gmail.com>
Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
Sort the SPI makefile and enforce the naming convention spi_*.c for
spi drivers.
This change also rolls the contents of atmel_spi.h into the .c file
since there is only one user of that particular include file.
v2: - Use 'spi-' prefix instead of 'spi_' to match what seems to be
be the predominant pattern for subsystem prefixes.
- Clean up filenames in Kconfig and header comment blocks
