path: root/drivers/spi/spi-efm32.c
2014-10-20spi: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-07-11spi: efm32: correct namespacing of location propertyUwe Kleine-König
Olof Johansson pointed out that usually the company name is picked as namespace prefix to specific properties. So expect "energymicro,location" but fall back to the previously introduced name "efm32,location". Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-03-30Merge remote-tracking branches 'spi/topic/drivers', 'spi/topic/dw', ↵Mark Brown
'spi/topic/efm32', 'spi/topic/ep93xx', 'spi/topic/fsl', 'spi/topic/fsl-dspi', 'spi/topic/fsl-espi' and 'spi/topic/gpio' into spi-next
2014-03-30Merge remote-tracking branches 'spi/topic/bus-num', 'spi/topic/cleanup', ↵Mark Brown
'spi/topic/clps711x', 'spi/topic/coldfire', 'spi/topic/completion' and 'spi/topic/davinci' into spi-next
2014-03-25spi: efm32: use $vendor,$device scheme for compatible stringUwe Kleine-König
Wolfram Sang pointed out that "efm32,$device" is non-standard. So use the common scheme and prefix device with "efm32-". The old compatible string is left in place until arch/arm/boot/dts/efm32* is fixed. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@vger.kernel.org
2014-03-14spi: efm32: properly namespace location propertyUwe Kleine-König
While reviewing an i2c driver for efm32 that needs a similar property Wolfram Sang pointed out that "location" is a too generic name for something that is efm32 specific. So add an appropriate namespace and fall back to the generic name in case of failure. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-03-12spi: efm32: Clean up non-DT pathsAxel Lin
This is a DT-only driver, so remove all non-DT paths. of_gpio_named_count() may fail, thus also add checking it's return value. efm32_spi_probe_dt() never fails, make it return void. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-02-16spi: Remove explictly set bus_num and num_chipselect to default settingAxel Lin
The purpose of commit 1e8a52e18cfb "spi: By default setup spi_masters with 1 chipselect and dynamics bus number" is to avoid setting default value for bus_num and num_chipselect in spi master drivers. So let's remove the duplicate code. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-By: David Daney <david.daney@cavium.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-02-10spi: Use reinit_completion at appropriate placesAxel Lin
Calling init_completion() once is enough. For the rest of the iterations, call reinit_completion() instead. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-10-09spi: efm32: drop unused struct and fix size checkUwe Kleine-König
The variable efm32_spi_pdata_default origins from an earlier revision of the patch introducing the driver, its use was dropped because of review comments but I forgot to also drop the variable itself. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-10-07spi: efm32: add spi_bitbang_stop to device remove callbackUwe Kleine-König
This call is needed to cleanup the resources requested by spi_bitbang_start in the probe callback. Noticed-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-10-07Merge remote-tracking branch 'spi/topic/bitbang' into HEADMark Brown
2013-10-07spi: bitbang: Let spi_bitbang_start() take a reference to masterAxel Lin
Many drivers that use bitbang library have a leak on probe error paths. This is because once a spi_master_get() call succeeds, we need an additional spi_master_put() call to free the memory. Fix this issue by moving the code taking a reference to master to spi_bitbang_start(), so spi_bitbang_start() will take a reference to master on success. With this change, the caller is responsible for calling spi_bitbang_stop() to decrement the reference and spi_master_put() as counterpart of spi_alloc_master() to prevent a memory leak. So now we have below patten for drivers using bitbang library: probe: spi_alloc_master -> Init reference count to 1 spi_bitbang_start -> Increment reference count remove: spi_bitbang_stop -> Decrement reference count spi_master_put -> Decrement reference count (reference count reaches 0) Fixup all users accordingly. Signed-off-by: Axel Lin <axel.lin@ingics.com> Suggested-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de> Acked-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-23spi: efm32: Don't call kfree() after spi_master_put()Axel Lin
Calling kfree() to clean up the memory obtained from spi_alloc_master() is wrong as this is done in spi_master_release() when spi_master->dev's refcount reaches zero. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-08-31spi: efm32: Fix build errorAxel Lin
Obviously the of_device_id table name is wrong. Fix below build error: CC [M] drivers/spi/spi-efm32.o drivers/spi/spi-efm32.c:499:1: error: '__mod_of_device_table' aliased to undefined symbol 'efm32_uart_dt_ids' make[2]: *** [drivers/spi/spi-efm32.o] Error 1 make[1]: *** [drivers/spi] Error 2 make: *** [drivers] Error 2 Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-08-22spi: spi-efm32: remove redundant dev_err call in efm32_spi_probe()Wei Yongjun
There is a error message within devm_ioremap_resource already, so remove the dev_err call to avoid redundant error message. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-08-09spi: new controller driver for efm32 SoCsUwe Kleine-König
