path: root/drivers/spi/spi-fsl-cpm.c
2015-12-22QE: Move QE from arch/powerpc to drivers/socZhao Qiang
ls1 has qe and ls1 has arm cpu. move qe from arch/powerpc to drivers/soc/fsl to adapt to powerpc and arm Signed-off-by: Zhao Qiang <qiang.zhao@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2015-04-24spi: fsl-spi: fix devm_ioremap_resource() error caseChristophe Leroy
devm_ioremap_resource() doesn't return NULL but an ERR_PTR on error. Reported-by: Jonas Gorsky <jogo@openwrt.org> Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-04-22spi: fsl-spi: use devm_ioremap_resource() to map parameter ram on CPM1Christophe Leroy
On CPM2, the SPI parameter RAM is dynamically allocated in the dualport RAM whereas in CPM1, it is statically allocated to a default address with capability to relocate it somewhere else via the use of CPM micropatch. The address of the parameter RAM is given by the boot loader and expected to be mapped via devm_ioremap_resource() In the current implementation, in function fsl_spi_cpm_get_pram() there is a confusion between the SPI_BASE register and the base of the SPI parameter RAM. Fortunatly, it is working properly with MPC866 and MPC885 because they do set SPI_BASE, but on MPC860 and other old MPC8xx that doesn't set SPI_BASE, pram_ofs is not properly set. Also, the parameter RAM is not properly mapped with devm_ioremap_resource() as it should but still gets accessible by chance through the full RAM which is mapped from somewhere else. This patch applies to the SPI driver the same principle as for the CPM UART: when the CPM is of type CPM1, we simply do an devm_ioremap_resource() of the area provided via the device tree. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-01-06spi: fsl-(e)spi: Support compile as moduleEsben Haabendal
Signed-off-by: Esben Haabendal <eha@deif.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-11-21spi: fsl-spi: Don't use cpm_command on CPM1Christophe Leroy
On CPM1, when the SPI parameter RAM is relocated to somewhere else than the default location, in accordance with freescale documentation (refer micropatch SPI application note EB662), init RX/TX params command shall not be used because it doesn't take into account the new location, and overwrites data that is in original location of SPI param ram at addresses SCC2 param base + (u32*)0x88 (u16*)0x90 (u32*)0x98 (u16*)0xA0, hence breaking activity on SCC2 if SCC2 is used in a mode like QMC for instance. Therefore, the action shall be done manually as described by freescale and as was already partly done by the driver. Reported-by: Patrick Vasseur <patrick.vasseur@c-s.fr> Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Tested-by: Patrick Vasseur <patrick.vasseur@c-s.fr> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-09-29spi: fsl: Sort include headers alphabeticallyXiubo Li
Sort all the include headers alphabetically for the freescale spi drivers. If the inlcude headers sorted out of order, maybe the best logical choice is to append new ones after the exist ones, while this may create a lot of potential for duplicates and conflicts for each diffenent changes will add new headers in the same location. Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2013-11-12Merge tag 'devicetree-for-3.13' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull devicetree updates from Rob Herring: "DeviceTree updates for 3.13. This is a bit larger pull request than usual for this cycle with lots of clean-up. - Cross arch clean-up and consolidation of early DT scanning code. - Clean-up and removal of arch prom.h headers. Makes arch specific prom.h optional on all but Sparc. - Addition of interrupts-extended property for devices connected to multiple interrupt controllers. - Refactoring of DT interrupt parsing code in preparation for deferred probe of interrupts. - ARM cpu and cpu topology bindings documentation. - Various DT vendor binding documentation updates" * tag 'devicetree-for-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (82 commits) powerpc: add missing explicit OF includes for ppc dt/irq: add empty of_irq_count for !OF_IRQ dt: disable self-tests for !OF_IRQ of: irq: Fix interrupt-map entry matching MIPS: Netlogic: replace early_init_devtree() call of: Add Panasonic Corporation vendor prefix of: Add Chunghwa Picture Tubes Ltd. vendor prefix of: Add AU Optronics Corporation vendor prefix of/irq: Fix potential buffer overflow of/irq: Fix bug in interrupt parsing refactor. of: set dma_mask to point to coherent_dma_mask of: add vendor prefix for PHYTEC Messtechnik GmbH DT: sort vendor-prefixes.txt of: Add vendor prefix for Cadence of: Add empty for_each_available_child_of_node() macro definition arm/versatile: Fix versatile irq specifications. of/irq: create interrupts-extended property microblaze/pci: Drop PowerPC-ism from irq parsing of/irq: Create of_irq_parse_and_map_pci() to consolidate arch code. of/irq: Use irq_of_parse_and_map() ...
2013-10-16spi: Add missing newline to dev_ prints in driversJarkko Nikula
Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-10-09drivers: clean-up prom.h implicit includesRob Herring
Powerpc is a mess of implicit includes by prom.h. Add the necessary explicit includes to drivers in preparation of prom.h cleanup. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Grant Likely <grant.likely@linaro.org>
2013-04-07spi/spi-fsl-spi: Make driver usable in CPU mode outside of an FSL_SOC ↵Andreas Larsson
environment This makes the spi-fsl-spi driver usable in CPU mode outside of an FSL_SOC and even an powerpc environment by moving CPM mode functionality to a separate file that is only compiled and linked in an FSL_SOC environment and adding some ifdefs to hide types and functions or provide alternatives. For devicetree probing a "clock-frequency" property is used for clock frequency instead of calls to FSL_SOC-specific functions. Acked-by: Anton Vorontsov <anton@enomsg.org> Signed-off-by: Andreas Larsson <andreas@gaisler.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
