[ Upstream commit ee5558a9084584015c8754ffd029ce14a5827fa8 ]
pm_runtime_get_sync will increment pm usage counter even it
failed. Forgetting to pm_runtime_put_noidle will result in
reference leak in img_spfi_resume, so we should fix it.
Fixes: deba25800a12b ("spi: Add driver for IMG SPFI controller")
Signed-off-by: Zhang Qilong <zhangqilong3@huawei.com>
Link: https://lore.kernel.org/r/20201102145651.3875-1-zhangqilong3@huawei.com
Signed-off-by: Mark Brown <broonie@kernel.org>
[ Upstream commit e9a8ba9769a0e354341bc6cc01b98aadcea1dfe9 ]
The channels spfi->tx_ch and spfi->rx_ch are not set to NULL after they
are released. As a result, they will be released again, either on the
error handling branch in the same function or in the corresponding
remove function, i.e. img_spfi_remove(). This patch fixes the bug by
setting the two members to NULL.
Signed-off-by: Pan Bian <bianpan2016@163.com>
Link: https://lore.kernel.org/r/1573007769-20131-1-git-send-email-bianpan2016@163.com
'spi/topic/img-spfi' and 'spi/topic/mpc512x-psc' into spi-next
'spi/fix/img-spfi', 'spi/fix/omap2-mcspi', 'spi/fix/orion' and 'spi/fix/xilinx' into spi-linus
drivers/spi/spi-img-spfi.c: In function 'img_spfi_setup':
drivers/spi/spi-img-spfi.c:446: warning: 'ret' may be used
uninitialized in this function.
Fixes: commit b03ba9e314c1 ("spi: img-spfi: fix multiple calls to request gpio")
Signed-off-by: Sifan Naeem <sifan.naeem@imgtec.com>
Cc: stable@vger.kernel.org
spfi_setup may be called many times by the spi framework, but
gpio_request_one can only be called once without freeing, repeatedly
calling gpio_request_one will cause an error to be thrown, which
causes the request to spi_setup to be marked as failed.
We can have a per-spi_device flag that indicates whether or not the
gpio has been requested. If the gpio has already been requested use
gpio_direction_output to set the direction of the gpio.
Fixes: 8c2c8c03cdcb ("spi: img-spfi: Control CS lines with GPIO")
Calling spfi_wait_all_done is not required if the transfer has timed
out before all data is transferred.
spfi_wait_all_done polls for Alldone interrupt which is triggered to
mark the transfer as complete and to indicate it is now safe to issue
a new transfer.
Fixes: 8c2c8c0 ("spi: img-spfi: Control CS lines with GPIO")
Reviewed-by: Andrew Bresticker <abrestic@chromium.org>
Maximum speed supported by spfi is limited to 1/4 of the spfi clock.
But in some SoCs the maximum speed supported by the spfi block can
be limited to less than 1/4 of the spfi clock. In such cases we have
to define the limit in the device tree so that the driver can pick
it up.
Setting the Same Edge bit indicates to the spfi block to receive and
transmit data on the same edge of the spfi clock, which in turn
doubles the operating frequency of spfi.
The maximum supported frequency is limited to 1/4th of the spfi input
clock, but without this bit set the maximum would be 1/8th of the
input clock.
The current driver calculates the divisor with maximum speed at 1/4th
of the input clock, this would fail if the requested frequency is
higher than 1/8 of the input clock. Any requests for 1/8th of the
input clock would still pass.
Fixes: 8543d0e72d43 ("spi: img-spfi: Limit bit clock to 1/4th of input clock")
Cc: <stable@vger.kernel.org>
When the CONTINUE bit is set, the interrupt status we are polling to
identify if a transaction has finished can be sporadic. Even though
the transfer has finished, the interrupt status may erroneously
indicate that there is still data in the FIFO. This behaviour causes
random timeouts in large PIO transfers.
Instead of using the CONTINUE bit to control the CS lines, use the SPI
core's CS GPIO handling. Also, now that the CONTINUE bit is not being
used, we can poll for the ALLDONE interrupt to indicate transfer
completion.
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@imgtec.com>
Signed-off-by: Andrew Bresticker <abrestic@chromium.org>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi into spi-img-spfi
Imagination has recommended that the SPFI controller be reset after
each message, regardless of success or failure. Do this in an
unprepare_message() callback.
The driver can be greatly simplified by moving the transfer timeout
handling to a handle_err() callback.
Linux 4.0-rc7
Setting the transfer length in the TRANSACTION register after the
CONTROL register is programmed causes intermittent timeout issues in
SPFI transfers when using the SPI framework to control the CS GPIO
lines. To avoid this issue, set transfer length before programming
the CONTROL register.
Although the SPFI BITCLK divider supports a value of up to 255, only
values up to 128 are usable. This results in a maximum possible bit
clock rate of 1/4th the input clock rate.
In preparation for switching to using the SPI core's CS GPIO handling,
move setup of the PORT_STATE register, which must be configured before
CS is asserted, to a prepare_message() callback.
Removing the udelay between setting and clearing the soft reset bit in
the spfi control register as it is not required.
Maximum transfer length supported by SPFI is 65535, this is limited
by the number of bits available in SPFI TSize register to represent
the transfer size.
For transfer requests larger than the maximum supported the driver
will return an invalid argument error.
Since the 32-bit FIFO is deeper (64 bytes) than the 8-bit FIFO (16 bytes),
use the 32-bit FIFO when there are at least 32 bits remaining to be
transferred in PIO mode or when the transfer length is 32-bit aligned
in DMA mode.
A 1-byte burst size is rather inefficient and has been shown to cause
TX issues during testing. Increase the DMA burst size to 4-bytes for
both RX and TX DMA when using the 8-bit FIFO.
It is recommended that the SPFI controller be enabled (i.e. setting
SPFI_EN in SPFI_CONTROL) before TX DMA begins.
A couple of new CONFIG_PM_RUNTIME users have been added recently
in the SPI subsystem.
However, after commit b2b49ccbdd54 (PM: Kconfig: Set PM_RUNTIME if
PM_SLEEP is selected) PM_RUNTIME is always set if PM is set, so
#ifdef blocks depending on CONFIG_PM_RUNTIME may now be changed to
depend on CONFIG_PM.
Replace CONFIG_PM_RUNTIME with CONFIG_PM everywhere under
drivers/spi/ (again).
Acked-by: Mark Brown <broonie@kernel.org>
Add support for the Synchronous Peripheral Flash Interface (SPFI) master
controller found on IMG SoCs. The SPFI controller supports 5 chip-select
lines and single/dual/quad mode SPI transfers.
