path: root/drivers/spi/spi-oc-tiny.c
2015-09-16spi: oc-tiny: Use of_property_read_u32 instead of open-coding itTobias Klauser
Use of_property_read_u32 instead of of_get_property with return value checks and endianness conversion. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-10-20spi: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-03-30Merge remote-tracking branches 'spi/topic/imx', 'spi/topic/init', ↵Mark Brown
'spi/topic/mpc512x-psc', 'spi/topic/mpc52xx', 'spi/topic/mxs', 'spi/topic/nuc900', 'spi/topic/oc-tiny' and 'spi/topic/octeon' into spi-next
2014-03-13spi: oc-tiny: Remove unneeded NULL checking for hw->bitbang.masterAxel Lin
We already has NULL test for master after calling spi_alloc_master(). Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-02-03spi: delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-01-09spi: oc-tiny: Simplify tiny_spi_txrx_bufs implementation when irq is not usedAxel Lin
Currently we have similar code for (txp && rxp), (txp && !rxp), (!rxp & txp), and (!txp && !rxp) cases. This patch refactors the code a bit to avoid duplicate similar code. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-17spi: bitbang: Let spi_bitbang_start() take a reference to masterAxel Lin
Many drivers that use bitbang library have a leak on probe error paths. This is because once a spi_master_get() call succeeds, we need an additional spi_master_put() call to free the memory. Fix this issue by moving the code taking a reference to master to spi_bitbang_start(), so spi_bitbang_start() will take a reference to master on success. With this change, the caller is responsible for calling spi_bitbang_stop() to decrement the reference and spi_master_put() as counterpart of spi_alloc_master() to prevent a memory leak. So now we have below patten for drivers using bitbang library: probe: spi_alloc_master -> Init reference count to 1 spi_bitbang_start -> Increment reference count remove: spi_bitbang_stop -> Decrement reference count spi_master_put -> Decrement reference count (reference count reaches 0) Fixup all users accordingly. Signed-off-by: Axel Lin <axel.lin@ingics.com> Suggested-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de> Acked-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-01Merge remote-tracking branch 'spi/topic/pdata' into spi-nextMark Brown
2013-08-29spi: use dev_get_platdata()Jingoo Han
Use the wrapper function for retrieving the platform data instead of accessing dev->platform_data directly. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-08-29spi: simplify devm_request_mem_region/devm_ioremapJulia Lawall
Convert the composition of devm_request_mem_region and devm_ioremap to a single call to devm_ioremap_resource. The associated call to platform_get_resource is also simplified and moved next to the new call to devm_ioremap_resource. This was done using a combination of the semantic patches devm_ioremap_resource.cocci and devm_request_and_ioremap.cocci, found in the scripts/coccinelle/api directory. This patch also removes the label exit_busy, to use the error code returned by the failing operation, rather than always -EBUSY. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-05-13spi: remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure, since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d (device-core: Ensure drvdata = NULL when no driver is bound). Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Grant Likely <grant.likely@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-04-01spi: spi-oc-tiny: Use of_match_ptr() macroSachin Kamat
This eliminates having an #ifdef returning NULL for the case when OF is disabled. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Acked-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-02-13gpio: Make of_count_named_gpios() use new of_count_phandle_with_args()Grant Likely
This patch replaces the horribly coded of_count_named_gpios() with a call to of_count_phandle_with_args() which is far more efficient. This also changes the return value of of_gpio_count() & of_gpio_named_count() from 'unsigned int' to 'int' so that it can return an error code. All the users of that function are fixed up to correctly handle a negative return value. v2: Split GPIO portion into a separate patch Tested-by: Andreas Larsson <andreas@gaisler.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Rob Herring <rob.herring@calxeda.com>
2012-12-07spi: Remove HOTPLUG section attributesGrant Likely
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Bill Pemberton has done most of the legwork on this series. I've used his script to purge the attributes from the drivers/gpio tree. Reported-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-09-01spi: fix comment/printk typos in spiMasanari Iida
Correct spelling typo in drivers/spi Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-10-31spi: Add module.h to implicit users in drivers/spiPaul Gortmaker
We are clipping down the presence of module.h, since it was everywhere. If you really need it, you better call it out, as per this changeset. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-25drivercore: Add helper macro for platform_driver boilerplateGrant Likely
For simple modules that contain a single platform_driver without any additional setup code then ends up being a block of duplicated boilerplate. This patch adds a new macro, module_platform_driver(), which replaces the module_init()/module_exit() registrations with template functions. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Reviewed-by: Magnus Damm <magnus.damm@gmail.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
2011-06-06spi: reorganize driversGrant Likely
Sort the SPI makefile and enforce the naming convention spi_*.c for spi drivers. This change also rolls the contents of atmel_spi.h into the .c file since there is only one user of that particular include file. v2: - Use 'spi-' prefix instead of 'spi_' to match what seems to be be the predominant pattern for subsystem prefixes. - Clean up filenames in Kconfig and header comment blocks Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Linus Walleij <linus.walleij@linaro.org>
