[ Upstream commit a23faea76d4cf5f75decb574491e66f9ecd707e7 ]
Call spi_master_get() holds the reference count to master device, thus
we need an additional spi_master_put() call to reduce the reference
count, otherwise we will leak a reference to master.
This commit fix it by removing the unnecessary spi_master_get().
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
Link: https://lore.kernel.org/r/20210409082954.2906933-1-weiyongjun1@huawei.com
Signed-off-by: Mark Brown <broonie@kernel.org>
SPI core validates both bits_per_word and speed_hz transfer parameters and
defaults to spi->bits_per_word and spi->max_speed_hz in case these per
transfer parameters are not set.
This allows to remove a few if statements around per transfer bits_per_word
and speed_hz tests as they evaluate always to true.
Also defaulting word_len to 8 is needless since spi_setup() has already
made sure spi->bits_per_word is 8 in case it is not set.
Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Currently the omap100k driver uses prepare and unprepare transfer hardware
to enable and disable clocks for the IP block. Since these functions are
called along with runtime PM and end up duplicating its functionality in a
less flexible fashion we are trying to phase them out so convert this
driver to do runtime PM instead.
While doing so add missing error handling and remove a redundant NULL
assignment.
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Remove unused definition which cause the following warnings
drivers/spi/spi-omap-100k.c:73:0: warning: "WRITE" redefined [enabled by default]
include/linux/fs.h:193:0: note: this is the location of the previous definition
drivers/spi/spi-omap-100k.c:74:0: warning: "READ" redefined [enabled by default]
include/linux/fs.h:192:0: note: this is the location of the previous definition
Signed-off-by: Nick Krause <xerofoiffy@gmail.com>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Signed-off-by: Mark Brown <broonie@linaro.org>
Drop call to platform_set_drvdata() as driver data is not used
anywhere in the driver.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
The memory allocated for cs is not freed anywhere.
Convert to use devm_kzalloc to fix the memory leak.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Fix the following checkpatch issues.
ERROR: space prohibited after that open parenthesis '('
ERROR: space required before the open parenthesis '('
ERROR: trailing statements should be on next line
ERROR: space required after that ',' (ctx:VxV)
ERROR: spaces required around that '-=' (ctx:VxV)
WARNING: sizeof *cs should be sizeof(*cs)
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Both *master and state are not really used, remove them.
Remove unused devdata pointer 'spi100k' in function omap1_spi100k_txrx_pio().
Detected by Coverity: CID 1077869.
Signed-off-by: Christian Engelmayer <cengelma@gmx.at>
Reviewed-by: Jingoo Han <jg1.han@samsung.com>
Acked-by: Michal Nazarewicz <mina86@mina86.com>
Commit [8074cf06: use devm_spi_register_master()] removed the last
bit of omap1_spi100k_remove function that had side effects. After
call to spi_unregister_master was removed, the function consisted
of:
2. call to platform_get_drvdata whose return value was only used in:
2. call to spi_master_get_devdata whose return value was not used,
3. an if statement checking if zero was not zero, and
4. call to platform_get_resource whose return value was not used.
Ah, yes, and of course, final return 0. ;)
Since omap1_spi100k_remove no longer does anything, it can be
safely removed.
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
Use devm_spi_register_master() to make cleanup paths simpler.
Use the wrapper function for retrieving the platform data instead of
accessing dev->platform_data directly.
Saves some code duplication and gets us the benefits of any improvements
in the core code.
In preparation for removing the custom workqueue.
Fill in the recently added spi_master.bits_per_word_mask field in as
many drivers as possible. Make related cleanups, such as removing any
redundant error-checking, or empty setup callbacks.
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Use the wrapper functions for getting and setting the driver data using
platform_device instead of using dev_{get,set}_drvdata() with &pdev->dev,
so we can directly pass a struct platform_device.
Some of the spi driver module remove hooks were annotated with __exit
and referenced with __exit_p(). Presumably these were supposed to be
__devinit, __devexit and __devexit_p() since __init/__exit for a
probe/remove hook has never been correct. They also got missed during
the big __devinit/__devexit purge since they didn't match the pattern.
Remove then now to be rid of it.
v2: purge __init also
[Arnd set a patch cleaning up one, and then I found more]
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Bill Pemberton has done most of the legwork on this series. I've used
his script to purge the attributes from the drivers/gpio tree.
Reported-by: Bill Pemberton <wfp5p@virginia.edu>
Remove unnecessary includes of plat/clock.h from the OMAP SPI
controller drivers. These need to be removed to build multi-subarch
ARM kernels which include these drivers.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Cc: Grant Likely <grant.likely@secretlab.ca>
Sort the SPI makefile and enforce the naming convention spi_*.c for
spi drivers.
This change also rolls the contents of atmel_spi.h into the .c file
since there is only one user of that particular include file.
v2: - Use 'spi-' prefix instead of 'spi_' to match what seems to be
be the predominant pattern for subsystem prefixes.
- Clean up filenames in Kconfig and header comment blocks
