path: root/drivers/spi/spi-sh-hspi.c
2014-12-22spi: Remove FSF mailing addressesJarkko Nikula
Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-10-20spi: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-06-06spi: sh-hspi: Make of_device_id array constJingoo Han
Make of_device_id array const, because all OF functions handle it as const. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-04-14spi: sh-hspi: Do not specifically request shyway_clk clockSimon Horman
Rather than requesting the shyway_clk call clk_get with the device and a NULL con_id. This is in keeping with the way that clk_get() is called on other drivers used by Renesas Gen 1 SoCs. And I believe it is compatible with supplying clocks via DT, unlike the current code. It appears to me that the two uses of this driver are the r8a7778 and r8a7779 SoCs. The r8a7779 already has clocks setup to allow this driver to continue to work with this change applied. The r8a7778 has clocks incorrectly setup to allow this driver to continue to work with this change applied. This problem is addressed in "ARM: shmobile: r8a7778: Use clks as MSTP007 parent" which is thus a pre-requisite of this patch. Signed-off-by: Simon Horman <horms+renesas@verge.net.au> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-03-30Merge remote-tracking branches 'spi/topic/s3c64xx', 'spi/topic/sc18is602', ↵Mark Brown
'spi/topic/sh-hspi', 'spi/topic/sh-msiof', 'spi/topic/sh-sci', 'spi/topic/sirf' and 'spi/topic/spidev' into spi-next
2014-03-11spi: sh-hspi: Add missing call to pm_runtime_disable() in failure pathGeert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert+renesas@linux-m68k.org> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-03-03spi: sh-hspi: Remove duplicate code to set default transfer speedAxel Lin
In the implementation of __spi_validate(), spi core will use spi device's max speed as default transfer speed if it is not set for this transfer. So we can remove the same logic in hspi_hw_setup(). Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-02-27spi: sh-hspi: Remove hspi_cleanup functionAxel Lin
hspi_cleanup() is doing nothing except print a non-useful debug message, so remove it. Also remove unused hspi2info macro. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-02-23spi: sh-hspi: Convert to let spi core validate bits_per_wordAxel Lin
Set bits_per_word_mask so spi core will reject transfers that attempt to use an unsupported bits_per_word value. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-02-16spi: Remove explictly set bus_num and num_chipselect to default settingAxel Lin
The purpose of commit 1e8a52e18cfb "spi: By default setup spi_masters with 1 chipselect and dynamics bus number" is to avoid setting default value for bus_num and num_chipselect in spi master drivers. So let's remove the duplicate code. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-By: David Daney <david.daney@cavium.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-01-23Merge remote-tracking branches 'spi/topic/fsl-espi', 'spi/topic/gpio', ↵Mark Brown
'spi/topic/hspi', 'spi/topic/mpc512x', 'spi/topic/msiof', 'spi/topic/nuc900', 'spi/topic/oc-tiny', 'spi/topic/omap', 'spi/topic/orion' and 'spi/topic/pci' into spi-linus
2014-01-13spi: sh-hspi: Spelling s/recive/receive/Geert Uytterhoeven
2014-01-08spi: sh-hspi: Fix modalias for sh-hspiAxel Lin
Make the modalias matches the driver name. Seems the MODULE_ALIAS is copied from drivers/spi/spi-sh-spi.c. So both spi-sh.ko and spi-sh-hspi.ko have the same alias. Fix it. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-10-25Merge remote-tracking branch 'spi/topic/hspi' into spi-nextMark Brown
2013-10-25Merge remote-tracking branch 'spi/topic/bfin' into spi-nextMark Brown
2013-10-25spi/hspi: add device tree supportKuninori Morimoto
Support for loading the Renesas HSPI driver via devicetree. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-10-15spi: sh-hspi: Fix checkpatch issueJingoo Han
Fix the following checkpatch warning. WARNING: space prohibited before semicolon Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-10-03spi/hspi: fixup Runtime PM enable timingKuninori Morimoto
3e00a09d2fbd64f0ad98e7c8c29dbf9e038fc746 (spi/hspi: Convert to core runtime PM) enabled master->auto_runtime_pm. Then, pm_runtime_enable() is required *before* spi_register_master() calling. This patch fixed it up. Kernel will hang up with "spi_master spi0: Failed to power device: -13" message without this patch. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-26spi: sh-hspi: use devm_spi_register_master()Jingoo Han
Use devm_spi_register_master() to make cleanup paths simpler. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-01Merge remote-tracking branch 'spi/topic/sh-hspi' into spi-nextMark Brown
2013-07-29spi/hspi: Convert to core runtime PMMark Brown
2013-07-28spi/sh-hspi: Remove noisy printMark Brown
This adds no meaningful value. Signed-off-by: Mark Brown <broonie@linaro.org>
2013-06-26Merge remote-tracking branch 'spi/topic/pdata' into spi-nextMark Brown
2013-06-04spi: hspi: fixup long delay timeKuninori Morimoto
Current HSPI driver is using msleep(20) on hspi_status_check_timeout(), but it was too long delay for SPI device. Bock-W board SPI access was too slow without this patch. This patch uses udelay(10) for it. Tested-by: Yusuke Goda <yusuke.goda.sx@renesas.com> Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-05-23spi: use platform_{get,set}_drvdata()Jingoo Han
Use the wrapper functions for getting and setting the driver data using platform_device instead of using dev_{get,set}_drvdata() with &pdev->dev, so we can directly pass a struct platform_device. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-12-19spi/sh-hspi: fix return value check in hspi_probe().Cyril Roelandt
According to its documentation, clk_get() returns a "valid IS_ERR() condition containing errno", so we should call IS_ERR() rather than a NULL check. Signed-off-by: Cyril Roelandt <tipecaml@gmail.com> Acked-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-12-07spi: Remove HOTPLUG section attributesGrant Likely
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Bill Pemberton has done most of the legwork on this series. I've used his script to purge the attributes from the drivers/gpio tree. Reported-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-11-23spi/sh-hspi: add CS manual control supportPhil Edworthy
The current HSPI driver used automatic CS control, leading to CS active for each byte transmitted. This patch changes the driver to manual CS control, and ensures CS is active thoughout a whole message. Additionally, it uses the cs_change field to determine if CS is disabled between transfers in the message. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-09-06spi: spi-sh-hspi: drop frees of devm_ alloc'd dataJulia Lawall
devm free functions should not have to be explicitly used. A semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ @@ ( * devm_kfree(...); | * devm_free_irq(...); | * devm_iounmap(...); | * devm_release_region(...); | * devm_release_mem_region(...); ) // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-03-15spi: sh-hspi: modify write/read methodKuninori Morimoto
Current sh-hspi had wrong write/read method which was not linux standard. If spi_transfer requests tx[2], rx[2] len=2, then, driver should run tx[0], rx[0], tx[1], rx[1]. But current sh-hspi runs tx[0], tx[1], rx[0], rx[1]. This patch fixes it up. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-03-15spi: sh-hspi: control spi clock more correctlyKuninori Morimoto
Current sh-hspi had used platform-specific speed. This patch remove it, and use spi_transfer specific speed. It removes unnecessary flags from struct sh_hspi_info, but struct sh_hspi_info is still exist, since sh-hspi needs platform info in the future. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-03-15spi: sh-hspi: convert to using core message queueKuninori Morimoto
2012-03-09spi: Add SuperH HSPI prototype driverKuninori Morimoto
This patch adds SuperH HSPI driver. It is still prototype driver, but has enough function at this point. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
