path: root/drivers/spi/spi-sh.c
2016-07-11spi: spi-sh: Remove deprecated create_singlethread_workqueueBhaktipriya Shridhar
The workqueue has a single workitem(&ss->ws) and hence doesn't require ordering. Also, it is not being used on a memory reclaim path. Hence, the singlethreaded workqueue has been replaced with the use of system_wq. System workqueues have been able to handle high level of concurrency for a long time now and hence it's not required to have a singlethreaded workqueue just to gain concurrency. Unlike a dedicated per-cpu workqueue created with create_singlethread_workqueue(), system_wq allows multiple work items to overlap executions even on the same CPU; however, a per-cpu workqueue doesn't have any CPU locality or global ordering guarantee unless the target CPU is explicitly specified and thus the increase of local concurrency shouldn't make any difference. Work item has been flushed in spi_sh_remove() to ensure that there are no pending tasks while disconnecting the driver. Signed-off-by: Bhaktipriya Shridhar <bhaktipriya96@gmail.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-12-22spi: Remove FSF mailing addressesJarkko Nikula
Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-10-20spi: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-07-07spi/spi-sh: Use devm_ioremapHimangi Saraogi
This patch introduces the use of devm_ioremap and removes the iounmaps in the probe and remove functions. Also, the labels are renamed to preserve ordering. Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-04-03spi: Always check complete callback before calling itAxel Lin
Since commit 1e25cd4729bd "spi: Do not require a completion", this checking is required to prevent NULL pointer dereference. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-01-23Merge remote-tracking branches 'spi/topic/pxa2xx', 'spi/topic/qspi', ↵Mark Brown
'spi/topic/s3c24xx', 'spi/topic/s3c64xx', 'spi/topic/sh', 'spi/topic/tegra114', 'spi/topic/tegra20-sflash', 'spi/topic/tegra20-slink', 'spi/topic/txx9' and 'spi/topic/xcomm' into spi-linus
2014-01-17spi: Remove duplicate code to set default bits_per_word settingAxel Lin
The implementation in spi_setup() already set spi->bits_per_word = 8 when spi->bits_per_word is 0 before calling spi->master->setup. So we don't need to do it again in setup() callback. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Barry Song <Baohua.Song@csr.com> Acked-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-01-13spi: sh: Use spi_sh_clear_bit() instead of open-codedAxel Lin
We have a spi_sh_clear_bit() function, there's no reason not to use it. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-05-23spi: use platform_{get,set}_drvdata()Jingoo Han
Use the wrapper functions for getting and setting the driver data using platform_device instead of using dev_{get,set}_drvdata() with &pdev->dev, so we can directly pass a struct platform_device. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-12-07spi: Remove HOTPLUG section attributesGrant Likely
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Bill Pemberton has done most of the legwork on this series. I've used his script to purge the attributes from the drivers/gpio tree. Reported-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-03-07spi/spi-sh: add IORESOURCE_MEM_TYPE_MASK decoding for access sizeShimoda, Yoshihiro
This SPI controller's access size is 32, or 8-bit. The previous driver supported 32-bit only. So, this patch adds IORESOURCE_MEM_TYPE_MASK decoding, an then, the driver can handle the SPI controller of 8-bit. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-10-25drivercore: Add helper macro for platform_driver boilerplateGrant Likely
For simple modules that contain a single platform_driver without any additional setup code then ends up being a block of duplicated boilerplate. This patch adds a new macro, module_platform_driver(), which replaces the module_init()/module_exit() registrations with template functions. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Reviewed-by: Magnus Damm <magnus.damm@gmail.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
2011-10-24spi: irq: Remove IRQF_DISABLEDYong Zhang
Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled], We run all interrupt handlers with interrupts disabled and we even check and yell when an interrupt handler returns with interrupts enabled (see commit [b738a50a: genirq: Warn when handler enables interrupts]). So now this flag is a NOOP and can be removed. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-06spi: reorganize driversGrant Likely
Sort the SPI makefile and enforce the naming convention spi_*.c for spi drivers. This change also rolls the contents of atmel_spi.h into the .c file since there is only one user of that particular include file. v2: - Use 'spi-' prefix instead of 'spi_' to match what seems to be be the predominant pattern for subsystem prefixes. - Clean up filenames in Kconfig and header comment blocks Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Linus Walleij <linus.walleij@linaro.org>
