path: root/drivers/spi/spi-tegra20-sflash.c
2014-10-20spi: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-09-03spi: tegra20-sflash: Fix checkpatch issueJingoo Han
Fix the following checkpatch warnings. WARNING: macros should not use a trailing semicolon WARNING: Missing a blank line after declarations Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-05-07spi: tegra20-sflash: Make of_device_id array constJingoo Han
Make of_device_id array const, because all OF functions handle it as const. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-03-30Merge remote-tracking branches 'spi/topic/imx', 'spi/topic/init', ↵Mark Brown
'spi/topic/mpc512x-psc', 'spi/topic/mpc52xx', 'spi/topic/mxs', 'spi/topic/nuc900', 'spi/topic/oc-tiny' and 'spi/topic/octeon' into spi-next
2014-03-30Merge remote-tracking branches 'spi/topic/bus-num', 'spi/topic/cleanup', ↵Mark Brown
'spi/topic/clps711x', 'spi/topic/coldfire', 'spi/topic/completion' and 'spi/topic/davinci' into spi-next
2014-02-16spi: Remove explictly set bus_num and num_chipselect to default settingAxel Lin
The purpose of commit 1e8a52e18cfb "spi: By default setup spi_masters with 1 chipselect and dynamics bus number" is to avoid setting default value for bus_num and num_chipselect in spi master drivers. So let's remove the duplicate code. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-By: David Daney <david.daney@cavium.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-02-11spi: tegra20-sflash: Convert to use master->max_speed_hzAxel Lin
Use master->max_speed_hz instead of tspi->spi_max_frequency, so spi core will handle checking transfer speed. In additional, since commit 052eb2d49006 'spi: core: Set max_speed_hz of spi_device default to max_speed_hz of controller', spi core will also set default spi->max_speed_hz if it is not set. So remove tegra_sflash_setup(). Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-02-03spi: delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-01-25Merge tag 'spi-v3.14-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi Pull spi updates from Mark Brown: "A respun version of the merges for the pull request previously sent with a few additional fixes. The last two merges were fixed up by hand since the branches have moved on and currently have the prior merge in them. Quite a busy release for the SPI subsystem, mostly in cleanups big and small scattered through the stack rather than anything else: - New driver for the Broadcom BC63xx HSSPI controller - Fix duplicate device registration for ACPI - Conversion of s3c64xx to DMAEngine (this pulls in platform and DMA changes upon which the transiton depends) - Some small optimisations to reduce the amount of time we hold locks in the datapath, eliminate some redundant checks and the size of a spi_transfer - Lots of fixes, cleanups and general enhancements to drivers, especially the rspi and Atmel drivers" * tag 'spi-v3.14-2' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi: (112 commits) spi: core: Fix transfer failure when master->transfer_one returns positive value spi: Correct set_cs() documentation spi: Clarify transfer_one() w.r.t. spi_finalize_current_transfer() spi: Spelling s/finised/finished/ spi: sc18is602: Convert to use bits_per_word_mask spi: Remove duplicate code to set default bits_per_word setting spi/pxa2xx: fix compilation warning when !CONFIG_PM_SLEEP spi: clps711x: Add MODULE_ALIAS to support module auto-loading spi: rspi: Add missing clk_disable() calls in error and cleanup paths spi: rspi: Spelling s/transmition/transmission/ spi: rspi: Add support for specifying CPHA/CPOL spi/pxa2xx: initialize DMA channels to -1 to prevent inadvertent match spi: rspi: Add more QSPI register documentation spi: rspi: Add more RSPI register documentation spi: rspi: Remove dependency on DMAE for SHMOBILE spi/s3c64xx: Correct indentation spi: sh: Use spi_sh_clear_bit() instead of open-coded spi: bitbang: Grammar s/make to make/to make/ spi: sh-hspi: Spelling s/recive/receive/ spi: core: Improve tx/rx_nbits check comments ...
2013-12-11spi: tegra: use reset frameworkStephen Warren
Tegra's clock driver now provides an implementation of the common reset API (include/linux/reset.h). Use this instead of the old Tegra- specific API; that will soon be removed. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Mark Brown <broonie@linaro.org> Reviewed-by: Thierry Reding <treding@nvidia.com>
2013-12-09spi: tegra20-sflash: use u32 for 32-bit register valuesMichal Nazarewicz
Previously used “unsigned long” may lead to confusion should the code be compiled for 64-bit machine. Signed-off-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-11-15tree-wide: use reinit_completion instead of INIT_COMPLETIONWolfram Sang
Use this new function to make code more comprehensible, since we are reinitialzing the completion, not initializing. [akpm@linux-foundation.org: linux-next resyncs] Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Linus Walleij <linus.walleij@linaro.org> (personally at LCE13) Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-25Merge remote-tracking branch 'spi/topic/tegra' into spi-nextMark Brown
2013-09-26spi: tegra20-sflash: use devm_spi_register_master()Jingoo Han
Use devm_spi_register_master() to make cleanup paths simpler. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-17spi: tegra: Use DIV_ROUND_UP instead of open codedAxel Lin
This also makes the intention more clear. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-07-29spi/tegra20-sflash: Use core runtime PMMark Brown
Signed-off-by: Mark Brown <broonie@linaro.org> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-07-29spi/tegra-sflash: Factor runtime PM out into transfer prepare/unprepareMark Brown
Currently the tegra sflash driver acquires a runtime PM reference for the duration of each transfer. This may result in the IP being powered down between transfers which would be at best wasteful. Instead it is better to do this in the callbacks that are generated before and after starting a series of transfers, keeping the IP powered throughout. Signed-off-by: Mark Brown <broonie@linaro.org> Acked-by: Laxman Dewangan <ldewangan@nvidia.com>
2013-05-23spi: use platform_{get,set}_drvdata()Jingoo Han
Use the wrapper functions for getting and setting the driver data using platform_device instead of using dev_{get,set}_drvdata() with &pdev->dev, so we can directly pass a struct platform_device. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-05-18drivers/spi: don't check resource with devm_ioremap_resourceWolfram Sang
devm_ioremap_resource does sanity checks on the given resource. No need to duplicate this in the driver. Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Stephen Warren <swarren@nvidia.com>
2013-04-07spi/tegra-sflash: assume CONFIG_OF, remove platform dataStephen Warren
Tegra only supports, and always enables, device tree. Remove all ifdefs and runtime checks for DT support from the driver. Platform data is therefore no longer required. Rework the driver to parse the device tree directly into struct tegra_sflash_data. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2013-02-21Merge tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC-specific updates from Arnd Bergmann: "This is a larger set of new functionality for the existing SoC families, including: - vt8500 gains support for new CPU cores, notably the Cortex-A9 based wm8850 - prima2 gains support for the "marco" SoC family, its SMP based cousin - tegra gains support for the new Tegra4 (Tegra114) family - socfpga now supports a newer version of the hardware including SMP - i.mx31 and bcm2835 are now using DT probing for their clocks - lots of updates for sh-mobile - OMAP updates for clocks, power management and USB - i.mx6q and tegra now support cpuidle - kirkwood now supports PCIe hot plugging - tegra clock support is updated - tegra USB PHY probing gets implemented diffently" * tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (148 commits) ARM: prima2: remove duplicate v7_invalidate_l1 ARM: shmobile: r8a7779: Correct TMU clock support again ARM: prima2: fix __init section for cpu hotplug ARM: OMAP: Consolidate OMAP USB-HS platform data (part 3/3) ARM: OMAP: Consolidate OMAP USB-HS platform data (part 1/3) arm: socfpga: Add SMP support for actual socfpga harware arm: Add v7_invalidate_l1 to cache-v7.S arm: socfpga: Add entries to enable make dtbs socfpga arm: socfpga: Add new device tree source for actual socfpga HW ARM: tegra: sort Kconfig selects for Tegra114 ARM: tegra: enable ARCH_REQUIRE_GPIOLIB for Tegra114 ARM: tegra: Fix build error w/ ARCH_TEGRA_114_SOC w/o ARCH_TEGRA_3x_SOC ARM: tegra: Fix build error for gic update ARM: tegra: remove empty tegra_smp_init_cpus() ARM: shmobile: Register ARM architected timer ARM: MARCO: fix the build issue due to gic-vic-to-irqchip move ARM: shmobile: r8a7779: Correct TMU clock support ARM: mxs_defconfig: Select CONFIG_DEVTMPFS_MOUNT ARM: mxs: decrease mxs_clockevent_device.min_delta_ns to 2 clock cycles ARM: mxs: use apbx bus clock to drive the timers on timrotv2 ...
2013-02-21Merge tag 'driver-core-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg Kroah-Hartman: "Here is the big driver core merge for 3.9-rc1 There are two major series here, both of which touch lots of drivers all over the kernel, and will cause you some merge conflicts: - add a new function called devm_ioremap_resource() to properly be able to check return values. - remove CONFIG_EXPERIMENTAL Other than those patches, there's not much here, some minor fixes and updates" Fix up trivial conflicts * tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits) base: memory: fix soft/hard_offline_page permissions drivercore: Fix ordering between deferred_probe and exiting initcalls backlight: fix class_find_device() arguments TTY: mark tty_get_device call with the proper const values driver-core: constify data for class_find_device() firmware: Ignore abort check when no user-helper is used firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER firmware: Make user-mode helper optional firmware: Refactoring for splitting user-mode helper code Driver core: treat unregistered bus_types as having no devices watchdog: Convert to devm_ioremap_resource() thermal: Convert to devm_ioremap_resource() spi: Convert to devm_ioremap_resource() power: Convert to devm_ioremap_resource() mtd: Convert to devm_ioremap_resource() mmc: Convert to devm_ioremap_resource() mfd: Convert to devm_ioremap_resource() media: Convert to devm_ioremap_resource() iommu: Convert to devm_ioremap_resource() drm: Convert to devm_ioremap_resource() ...
2013-02-05spi/tegra: remove checks for valid speedLaxman Dewangan
SPI core make sure that all transfer has proper speed set before calling low level spi transfer. Hence, it is not require to have check in spi driver. Remove the check for speed validity from transfer and use it directly. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2013-01-28spi: tegra: do not use clock name to get clockPrashant Gaikwad
Since Tegra spi devices do not have multiple clocks, no need to use clock name to get the clock. Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-01-28ARM: tegra: migrate to new clock codePrashant Gaikwad
Migrate Tegra clock support to drivers/clk/tegra, this involves moving: 1. definition of tegra_cpu_car_ops to clk.c 2. definition of reset functions to clk-peripheral.c 3. change parent of cpu clock. 4. Remove legacy clock initialization. 5. Initialize clocks using DT. 6. Remove all instance of mach/clk.h Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com> [swarren: use to_clk_periph_gate().] Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-01-25spi: Convert to devm_ioremap_resource()Thierry Reding
Convert all uses of devm_request_and_ioremap() to the newly introduced devm_ioremap_resource() which provides more consistent error handling. devm_ioremap_resource() provides its own error messages so all explicit error messages can be removed from the failure code paths. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-07spi: Remove HOTPLUG section attributesGrant Likely
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Bill Pemberton has done most of the legwork on this series. I've used his script to purge the attributes from the drivers/gpio tree. Reported-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-11-14spi: tegra: add spi driver for sflash controllerLaxman Dewangan
NVIDIA's Tegra20 have the SPI (SFLASH) controller to interface with spi flash device which is used for system boot. Add the spi driver for this controller. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
