[ Upstream commit 763eab7074f6e71babd85d796156f05a675f9510 ]
pm_runtime_get_sync will increment pm usage counter even it
failed. Forgetting to pm_runtime_put_noidle will result in
reference leak in two callers(tegra_slink_setup and
tegra_slink_resume), so we should fix it.
Fixes: dc4dc36056392 ("spi: tegra: add spi driver for SLINK controller")
Signed-off-by: Zhang Qilong <zhangqilong3@huawei.com>
Link: https://lore.kernel.org/r/20201103141345.6188-1-zhangqilong3@huawei.com
Signed-off-by: Mark Brown <broonie@kernel.org>
[ Upstream commit 04358e40ba96d687c0811c21d9dede73f5244a98 ]
The driver misses calling clk_unprepare in probe failure and remove.
Add the calls to fix it.
Signed-off-by: Chuhong Yuan <hslester96@gmail.com>
Link: https://lore.kernel.org/r/20191115083122.12278-1-hslester96@gmail.com
commit 7001cab1dabc0b72b2b672ef58a90ab64f5e2343 upstream.
Depending on the SPI instance one may get an interrupt storm upon
requesting resp. interrupt unless the clock is explicitly enabled
beforehand. This has been observed trying to bring up instance 4 on
T20.
Cc: stable@vger.kernel.org
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Make of_device_id array const, because all OF functions
handle it as const.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
'spi/topic/mpc512x-psc', 'spi/topic/mpc52xx', 'spi/topic/mxs', 'spi/topic/nuc900', 'spi/topic/oc-tiny' and 'spi/topic/octeon' into spi-next
'spi/topic/clps711x', 'spi/topic/coldfire', 'spi/topic/completion' and 'spi/topic/davinci' into spi-next
The purpose of commit 1e8a52e18cfb
"spi: By default setup spi_masters with 1 chipselect and dynamics bus number"
is to avoid setting default value for bus_num and num_chipselect in spi master
drivers. So let's remove the duplicate code.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Acked-By: David Daney <david.daney@cavium.com>
In spi_add_device(), we have the code to validate spi->chip_select.
So remove the duplicate code in various drivers.
Use master->max_speed_hz instead of tspi->spi_max_frequency, so spi core will
handle checking transfer speed.
In additional, since commit 052eb2d49006 'spi: core: Set max_speed_hz of
spi_device default to max_speed_hz of controller',
spi core will also set default spi->max_speed_hz if it is not set.
So remove the duplicate code in tegra_slink_setup.
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi
Pull spi updates from Mark Brown:
"A respun version of the merges for the pull request previously sent
with a few additional fixes. The last two merges were fixed up by
hand since the branches have moved on and currently have the prior
merge in them.
Quite a busy release for the SPI subsystem, mostly in cleanups big and
small scattered through the stack rather than anything else:
- New driver for the Broadcom BC63xx HSSPI controller
- Fix duplicate device registration for ACPI
- Conversion of s3c64xx to DMAEngine (this pulls in platform and DMA
changes upon which the transiton depends)
- Some small optimisations to reduce the amount of time we hold locks
in the datapath, eliminate some redundant checks and the size of a
spi_transfer
- Lots of fixes, cleanups and general enhancements to drivers,
especially the rspi and Atmel drivers"
* tag 'spi-v3.14-2' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi: (112 commits)
spi: core: Fix transfer failure when master->transfer_one returns positive value
spi: Correct set_cs() documentation
spi: Clarify transfer_one() w.r.t. spi_finalize_current_transfer()
spi: Spelling s/finised/finished/
spi: sc18is602: Convert to use bits_per_word_mask
spi: Remove duplicate code to set default bits_per_word setting
spi/pxa2xx: fix compilation warning when !CONFIG_PM_SLEEP
spi: clps711x: Add MODULE_ALIAS to support module auto-loading
spi: rspi: Add missing clk_disable() calls in error and cleanup paths
spi: rspi: Spelling s/transmition/transmission/
spi: rspi: Add support for specifying CPHA/CPOL
spi/pxa2xx: initialize DMA channels to -1 to prevent inadvertent match
spi: rspi: Add more QSPI register documentation
spi: rspi: Add more RSPI register documentation
spi: rspi: Remove dependency on DMAE for SHMOBILE
spi/s3c64xx: Correct indentation
spi: sh: Use spi_sh_clear_bit() instead of open-coded
spi: bitbang: Grammar s/make to make/to make/
spi: sh-hspi: Spelling s/recive/receive/
spi: core: Improve tx/rx_nbits check comments
dma_request_slave_channel() returns NULL on error and not ERR_PTRs.
I've fixed this by using dma_request_slave_channel_reason() which does
return ERR_PTRs.
Fixes: a915d150f68d ('spi: tegra: convert to standard DMA DT bindings')
By using dma_request_slave_channel_or_err(), the DMA slave ID can be
looked up from standard DT properties, and squirrelled away during
channel allocation. Hence, there's no need to use a custom DT property
to store the slave ID.
Acked-by: Mark Brown <broonie@linaro.org>
Tegra's clock driver now provides an implementation of the common
reset API (include/linux/reset.h). Use this instead of the old Tegra-
specific API; that will soon be removed.
Reviewed-by: Thierry Reding <treding@nvidia.com>
Previously used “unsigned long” may lead to confusion should the code
be compiled for 64-bit machine.
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
Use this new function to make code more comprehensible, since we are
reinitialzing the completion, not initializing.
[akpm@linux-foundation.org: linux-next resyncs]
Acked-by: Linus Walleij <linus.walleij@linaro.org> (personally at LCE13)
This is more idiomatic for the factored out message processing and gives a
small simplification of the code since we always set the per-transfer
parameters in the same fashion.
This is a half done conversion with minimal code reorganisation provided
for bisection purposes. A further patch will move the first transfer
preparation into tegra_slink_prepare_message().
The cs_change and udelay handling is removed, these should be
implemented by the framework and in any case are buggy - the two fields
should not be related and the cs_change handling appears to at best only
work the first time it's used in a message.
Fix the following checkpatch warning.
WARNING: space prohibited before semicolon
Currently transfer_one_message() checks to see if the message consists of
a single spi_transfer and tells _start_transfer_one() but it just ignores
this. Don't bother.
Acked-by: Laxman Dewangan <ldewangan@nvidia.com>
Use devm_spi_register_master() to make cleanup paths simpler.
This also makes the intention more clear.
Currently the tegra slink driver acquires a runtime PM reference for the
duration of each transfer. This may result in the IP being powered down
between transfers which would be at best wasteful. Instead it is better
to do this in the callbacks that are generated before and after starting
a series of transfers, keeping the IP powered throughout.
Use the wrapper functions for getting and setting the driver data using
platform_device instead of using dev_{get,set}_drvdata() with &pdev->dev,
so we can directly pass a struct platform_device.
Neither tegra20_spi_cdata nor tegra30_spi_cdata are used outside this
file so they can, and should, be static.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Reviewed-by: Thierry Reding <thierry.reding@avionic-design.de>
Tegra only supports, and always enables, device tree. Remove all ifdefs
and runtime checks for DT support from the driver. Platform data is
therefore no longer required. Rework the driver to parse the device tree
directly into struct tegra_slink_data.
There is no code to set spi->controller_data, and hence the HW CS logic
can never trigger. Remove the unused code.
This reverts commit faa98f7ea6c720beec8a800c9ac6975f760467e2 which was
applied in error due to discussion ending up in the wrong thread.
Spi starts transfer using dma with DMA_CTRL_ACK which is not require
becasue spi driver does not use completed dma_desc after transfer
done and so it does not ack the dma descriptor. Removing the
DMA_CTRL_ACK flag to avoid memory leak in dma driver.
The variable bits_per_word is initialized but never used
otherwise, so remove the unused variable.
Acked-By: Laxman Dewangan <ldewangan@nvidia.com>
The prepare_transfer_hardware() is called in atomic context and
calling synchronous runtime pm calls can create scheduling deadlock.
Therefore, in place of calling runtime PM calls from prepare/unprepare
message transfer, calling this in transfer_one_message().
Pull ARM SoC-specific updates from Arnd Bergmann:
"This is a larger set of new functionality for the existing SoC
families, including:
- vt8500 gains support for new CPU cores, notably the Cortex-A9 based
wm8850
- prima2 gains support for the "marco" SoC family, its SMP based
cousin
- tegra gains support for the new Tegra4 (Tegra114) family
- socfpga now supports a newer version of the hardware including SMP
- i.mx31 and bcm2835 are now using DT probing for their clocks
- lots of updates for sh-mobile
- OMAP updates for clocks, power management and USB
- i.mx6q and tegra now support cpuidle
- kirkwood now supports PCIe hot plugging
- tegra clock support is updated
- tegra USB PHY probing gets implemented diffently"
* tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (148 commits)
ARM: prima2: remove duplicate v7_invalidate_l1
ARM: shmobile: r8a7779: Correct TMU clock support again
ARM: prima2: fix __init section for cpu hotplug
ARM: OMAP: Consolidate OMAP USB-HS platform data (part 3/3)
ARM: OMAP: Consolidate OMAP USB-HS platform data (part 1/3)
arm: socfpga: Add SMP support for actual socfpga harware
arm: Add v7_invalidate_l1 to cache-v7.S
arm: socfpga: Add entries to enable make dtbs socfpga
arm: socfpga: Add new device tree source for actual socfpga HW
ARM: tegra: sort Kconfig selects for Tegra114
ARM: tegra: enable ARCH_REQUIRE_GPIOLIB for Tegra114
ARM: tegra: Fix build error w/ ARCH_TEGRA_114_SOC w/o ARCH_TEGRA_3x_SOC
ARM: tegra: Fix build error for gic update
ARM: tegra: remove empty tegra_smp_init_cpus()
ARM: shmobile: Register ARM architected timer
ARM: MARCO: fix the build issue due to gic-vic-to-irqchip move
ARM: mxs_defconfig: Select CONFIG_DEVTMPFS_MOUNT
ARM: mxs: decrease mxs_clockevent_device.min_delta_ns to 2 clock cycles
ARM: mxs: use apbx bus clock to drive the timers on timrotv2
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core patches from Greg Kroah-Hartman:
"Here is the big driver core merge for 3.9-rc1
There are two major series here, both of which touch lots of drivers
all over the kernel, and will cause you some merge conflicts:
- add a new function called devm_ioremap_resource() to properly be
able to check return values.
- remove CONFIG_EXPERIMENTAL
Other than those patches, there's not much here, some minor fixes and
updates"
Fix up trivial conflicts
* tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits)
base: memory: fix soft/hard_offline_page permissions
drivercore: Fix ordering between deferred_probe and exiting initcalls
backlight: fix class_find_device() arguments
TTY: mark tty_get_device call with the proper const values
driver-core: constify data for class_find_device()
firmware: Ignore abort check when no user-helper is used
firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER
firmware: Make user-mode helper optional
firmware: Refactoring for splitting user-mode helper code
Driver core: treat unregistered bus_types as having no devices
watchdog: Convert to devm_ioremap_resource()
thermal: Convert to devm_ioremap_resource()
spi: Convert to devm_ioremap_resource()
power: Convert to devm_ioremap_resource()
mtd: Convert to devm_ioremap_resource()
mmc: Convert to devm_ioremap_resource()
mfd: Convert to devm_ioremap_resource()
media: Convert to devm_ioremap_resource()
iommu: Convert to devm_ioremap_resource()
drm: Convert to devm_ioremap_resource()
SPI core make sure that all transfer has proper speed set
before calling low level spi transfer. Hence, it is not
require to have check in spi driver.
Remove the check for speed validity from transfer and use it directly.
The spi core make sure that each transfer structure have the proper
setting for bits_per_word before calling low level transfer APIs.
Hence it is no more require to check again in low level driver for
this field whether this is set correct or not. Removing such code
from low level driver.
The txx9 change also removes a test for bits_per_word set to 0, and
forcing it to 8 in that case. This can also be removed now since
spi_setup() ensures spi->bits_per_word is not zero.
if (!spi->bits_per_word)
spi->bits_per_word = 8;
Since Tegra spi devices do not have multiple clocks, no need to use
clock name to get the clock.
Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Migrate Tegra clock support to drivers/clk/tegra, this involves
moving:
1. definition of tegra_cpu_car_ops to clk.c
2. definition of reset functions to clk-peripheral.c
3. change parent of cpu clock.
4. Remove legacy clock initialization.
5. Initialize clocks using DT.
6. Remove all instance of mach/clk.h
[swarren: use to_clk_periph_gate().]
Convert all uses of devm_request_and_ioremap() to the newly introduced
devm_ioremap_resource() which provides more consistent error handling.
devm_ioremap_resource() provides its own error messages so all explicit
error messages can be removed from the failure code paths.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
Cc: Grant Likely <grant.likely@secretlab.ca>
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Bill Pemberton has done most of the legwork on this series. I've used
his script to purge the attributes from the drivers/gpio tree.
Reported-by: Bill Pemberton <wfp5p@virginia.edu>
Sequence compatible list for tegra20-slink driver to first
look for Tegra30 and then Tegra20. Tegra30 have additional
feature in HW which need to be utilize if it is provided from DT.
When spi client does the spi transfer and does not sets
the bits_per_word for each transfer then set it as default
of spi device in spi core before calling low level transfer.
Removing the similar code from spi-tegra20-slink driver as
it is not required.
Tegra20/Tegra30 supports the spi interface through its SLINK
controller. Add spi driver for SLINK controller.
