commit 794aaf01444d4e765e2b067cba01cc69c1c68ed9 upstream.
We can't rely on the contents of the devres list during
spi_unregister_controller(), as the list is already torn down at the
time we perform devres_find() for devm_spi_release_controller. This
causes devices registered with devm_spi_alloc_{master,slave}() to be
mistakenly identified as legacy, non-devm managed devices and have their
reference counters decremented below 0.
WARNING: CPU: 1 PID: 660 at lib/refcount.c:28 refcount_warn_saturate+0x108/0x174
[<b0396f04>] (refcount_warn_saturate) from [<b03c56a4>] (kobject_put+0x90/0x98)
[<b03c5614>] (kobject_put) from [<b0447b4c>] (put_device+0x20/0x24)
r4:b6700140
[<b0447b2c>] (put_device) from [<b07515e8>] (devm_spi_release_controller+0x3c/0x40)
[<b07515ac>] (devm_spi_release_controller) from [<b045343c>] (release_nodes+0x84/0xc4)
r5:b6700180 r4:b6700100
[<b04533b8>] (release_nodes) from [<b0454160>] (devres_release_all+0x5c/0x60)
r8:b1638c54 r7:b117ad94 r6:b1638c10 r5:b117ad94 r4:b163dc10
[<b0454104>] (devres_release_all) from [<b044e41c>] (__device_release_driver+0x144/0x1ec)
[<b044e2d8>] (__device_release_driver) from [<b044f70c>] (device_driver_detach+0x84/0xa0)
r9:00000000 r8:00000000 r7:b117ad94 r6:b163dc54 r5:b1638c10 r4:b163dc10
[<b044f688>] (device_driver_detach) from [<b044d274>] (unbind_store+0xe4/0xf8)
Instead, determine the devm allocation state as a flag on the
controller which is guaranteed to be stable during cleanup.
Fixes: 5e844cc37a5c ("spi: Introduce device-managed SPI controller allocation")
Signed-off-by: William A. Kennington III <wak@google.com>
Link: https://lore.kernel.org/r/20210407095527.2771582-1-wak@google.com
Signed-off-by: Mark Brown <broonie@kernel.org>
[lukas: backport to v4.4.270]
Signed-off-by: Lukas Wunner <lukas@wunner.de>
commit ddf75be47ca748f8b12d28ac64d624354fddf189 upstream
CONFIG_OF_DYNAMIC and CONFIG_ACPI allow adding SPI devices at runtime
using a DeviceTree overlay or DSDT patch. CONFIG_SPI_SLAVE allows the
same via sysfs.
But there are no precautions to prevent adding a device below a
controller that's being removed. Such a device is unusable and may not
even be able to unbind cleanly as it becomes inaccessible once the
controller has been torn down. E.g. it is then impossible to quiesce
the device's interrupt.
of_spi_notify() and acpi_spi_notify() do hold a ref on the controller,
but otherwise run lockless against spi_unregister_controller().
Fix by holding the spi_add_lock in spi_unregister_controller() and
bailing out of spi_add_device() if the controller has been unregistered
concurrently.
Fixes: ce79d54ae447 ("spi/of: Add OF notifier handler")
Cc: stable@vger.kernel.org # v3.19+
Cc: Geert Uytterhoeven <geert+renesas@glider.be>
Cc: Octavian Purdila <octavian.purdila@intel.com>
Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
Link: https://lore.kernel.org/r/a8c3205088a969dc8410eec1eba9aface60f36af.1596451035.git.lukas@wunner.de
[sudip: adjust context]
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
[ Upstream commit 5e844cc37a5cbaa460e68f9a989d321d63088a89 ]
SPI driver probing currently comprises two steps, whereas removal
comprises only one step:
spi_alloc_master()
spi_register_master()
spi_unregister_master()
That's because spi_unregister_master() calls device_unregister()
instead of device_del(), thereby releasing the reference on the
spi_master which was obtained by spi_alloc_master().
An SPI driver's private data is contained in the same memory allocation
as the spi_master struct. Thus, once spi_unregister_master() has been
called, the private data is inaccessible. But some drivers need to
access it after spi_unregister_master() to perform further teardown
steps.
Introduce devm_spi_alloc_master(), which releases a reference on the
spi_master struct only after the driver has unbound, thereby keeping the
memory allocation accessible. Change spi_unregister_master() to not
release a reference if the spi_master was allocated by the new devm
function.
The present commit is small enough to be backportable to stable.
It allows fixing drivers which use the private data in their ->remove()
hook after it's been freed. It also allows fixing drivers which neglect
to release a reference on the spi_master in the probe error path.
Long-term, most SPI drivers shall be moved over to the devm function
introduced herein. The few that can't shall be changed in a treewide
commit to explicitly release the last reference on the master.
That commit shall amend spi_unregister_master() to no longer release
a reference, thereby completing the migration.
As a result, the behaviour will be less surprising and more consistent
with subsystems such as IIO, which also includes the private data in the
allocation of the generic iio_dev struct, but calls device_del() in
iio_device_unregister().
Link: https://lore.kernel.org/r/272bae2ef08abd21388c98e23729886663d19192.1605121038.git.lukas@wunner.de
We make a mistake while backport 'commit 84855678add8 ("spi: Fix
controller unregister order")'. What we should do is call __unreigster
for each device before spi_destroy_queue. This problem exist in
linux-4.4.y/linux-4.9.y.
Signed-off-by: yangerkun <yangerkun@huawei.com>
[ Upstream commit 84855678add8aba927faf76bc2f130a40f94b6f7 ]
When an SPI controller unregisters, it unbinds all its slave devices.
For this, their drivers may need to access the SPI bus, e.g. to quiesce
interrupts.
However since commit ffbbdd21329f ("spi: create a message queueing
infrastructure"), spi_destroy_queue() is executed before unbinding the
slaves. It sets ctlr->running = false, thereby preventing SPI bus
access and causing unbinding of slave devices to fail.
Fix by unbinding slaves before calling spi_destroy_queue().
Fixes: ffbbdd21329f ("spi: create a message queueing infrastructure")
Cc: stable@vger.kernel.org # v3.4+
Cc: Linus Walleij <linus.walleij@linaro.org>
Link: https://lore.kernel.org/r/8aaf9d44c153fe233b17bc2dec4eb679898d7e7b.1589557526.git.lukas@wunner.de
[ Upstream commit ebc37af5e0a134355ea2b62ed4141458bdbd5389 ]
The device_for_each_child() doesn't require the returned value to be checked.
Thus, drop the dummy variable completely and have no warning anymore:
drivers/spi/spi.c: In function ‘spi_unregister_controller’:
drivers/spi/spi.c:2480:6: warning: variable ‘dummy’ set but not used [-Wunused-but-set-variable]
int dummy;
[ Upstream commit 5442dcaa0d90fc376bdfc179a018931a8f43dea4 ]
This fixes a bug for messages containing both zero length and
unidirectional xfers.
The function spi_map_msg will allocate dummy tx and/or rx buffers
for use with unidirectional transfers when the hardware can only do
a bidirectional transfer. That dummy buffer will be used in place
of a NULL buffer even when the xfer length is 0.
Then in the function __spi_map_msg, if he hardware can dma,
the zero length xfer will have spi_map_buf called on the dummy
buffer.
Eventually, __sg_alloc_table is called and returns -EINVAL
because nents == 0.
This fix prevents the error by not using the dummy buffer when
the xfer length is zero.
Signed-off-by: Chris Lesiak <chris.lesiak@licor.com>
commit ce99319a182fe766be67f96338386f3ec73e321c upstream.
When SPI transfers can be offloaded using DMA, the SPI core need to
build a scatterlist to make sure that the buffer to be transferred is
dma-able.
This patch fixes the scatterlist entry size computation in the case
where the maximum acceptable scatterlist entry supported by the DMA
controller is less than PAGE_SIZE, when the buffer is vmalloced.
For each entry, the actual size is given by the minimum between the
desc_len (which is the max buffer size supported by the DMA controller)
and the remaining buffer length until we cross a page boundary.
Fixes: 65598c13fd66 ("spi: Fix per-page mapping of unaligned vmalloc-ed buffer")
Signed-off-by: Maxime Chevallier <maxime.chevallier@bootlin.com>
Fix parent-device reference leak due to SPI-core taking an unnecessary
reference to the parent when allocating the master structure, a
reference that was never released.
Note that driver core takes its own reference to the parent when the
master device is registered.
Fixes: 49dce689ad4e ("spi doesn't need class_device")
Signed-off-by: Johan Hovold <johan@kernel.org>
'spi/fix/mediatek' and 'spi/fix/pl022' into spi-linus
When submitting an identical spi_message multiple times via spi_sync
the spi_message.frame_length does not get reset to 0 in __spi_validate
before adding up all spi_transfer.len resulting in
frame_length > actual_length on all but the first spi_sync call.
Signed-off-by: Martin Sperl <kernel@martin.sperl.org>
Commit ca5d24854210 ("spi: Add THIS_MODULE to spi_driver in SPI core")
adds the new __spi_register_driver() function, but keeps the kerneldoc
for the spi_register_driver() function in place and forgets to add the
description for the new owner parameter.
Signed-off-by: Thierry Reding <treding@nvidia.com>
'spi/topic/omap-uwire', 'spi/topic/owner', 'spi/topic/pxa' and 'spi/topic/pxa2xx' into spi-next
Add spi_register_driver helper macro that adds THIS_MODULE to
spi_driver for the registering driver. We rename and modify
the existing spi_register_driver to enable this.
Signed-off-by: Andrew F. Davis <afd@ti.com>
SPI controllers may need to be properly setup before chip selects
can be used. Therefore, wait until the spi controller has a chance
to perform their setup procedure before trying to use the chip
select.
This also insures that the chip selects pins are in a good
state before asseting them which otherwise may cause confusion.
Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com>
Tested-by: Grygorii Strashko <grygorii.strashko@ti.com>
Tested-by: Ivan Khoronzhuk <ivan.khoronzhuk@linaro.org>
When building docs with make htmldocs, warnings about not having
a description for the return value are reported, i.e:
warning: No description found for return value of 'spi_register_driver'
Fix these by following the kernel-doc conventions explained in
Documentation/kernel-doc-nano-HOWTO.txt.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi into spi-doc
Check if GPIO pin is valid by API helper function.
Propagate the actual return code of __spi_validate_bits_per_word() in
spi_setup().
Currently the IRQs for SPI client devices, registered via device-tree,
are mapped when the client devices are registered. If the corresponding
irq-chip has not been probed yet, then the probing of the client device
will fail and will not be retried. Resolve this by mapping the IRQ at
probe time and allow the probe to be deferred if the IRQ is not yet
available.
If of_irq_get() returns an error that is not -EPROBE_DEFER, then assume
that the SPI client does not have an IRQ and set the IRQ number to zero
(which is equivalent to irq_of_parse_and_map()).
This is based on some inputs from Thierry Reding <treding@nvidia.com>.
Cc: Thierry Reding <treding@nvidia.com>
Cc: Tomeu Vizoso <tomeu.vizoso@collabora.com>
Signed-off-by: Jon Hunter <jonathanh@nvidia.com>
report transfer sizes as a histogram via the following files:
/sys/class/spi_master/spi*/statistics/transfer_bytes_histo_*
/sys/class/spi_master/spi*/spi*.*/statistics/transfer_bytes_histo_*
Linux 4.3-rc1
Actually, spi_master_put() after spi_alloc_master() must _not_ be followed
by kfree(). The memory is already freed with the call to spi_master_put()
through spi_master_class, which registers a release function. Calling both
spi_master_put() and kfree() results in often nasty (and delayed) crashes
elsewhere in the kernel, often in the networking stack.
This reverts commit eb4af0f5349235df2e4a5057a72fc8962d00308a.
Link to patch and concerns: https://lkml.org/lkml/2012/9/3/269
or
http://lkml.iu.edu/hypermail/linux/kernel/1209.0/00790.html
Alexey Klimov: This revert becomes valid after
94c69f765f1b4a658d96905ec59928e3e3e07e6a when spi-imx.c
has been fixed and there is no need to call kfree() so comment
for spi_alloc_master() should be fixed.
Signed-off-by: Alexey Klimov <alexey.klimov@linaro.org>
'spi/topic/sh-msiof', 'spi/topic/spidev' and 'spi/topic/stats' into spi-next
This allows drivers for devices connected via SPI to check if the
controller supports a given bits_per_word value during setup.
Currently any BPW value is accepted durings setup, and transfers
are rejected later.
Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de>
If a slave appears with no maximum transfer speed specified fall back to
using the maximum for the master instead. It's questionable if we
should let slaves do this but let's be defensive.
For spi without dma channel and use can_dma(), it can
use master->dev for struct device.
Signed-off-by: Leilk Liu <leilk.liu@mediatek.com>
per spi-master statistics accessible as:
/sys/class/spi_master/spi*/statistics/*
per spi-device statistics accessible via:
/sys/class/spi_master/spi*/spi*.*/statistics/*
The following statistics are exposed as separate "files" inside
these directories:
* messages number of spi_messages
* transfers number of spi_transfers
* bytes number of bytes transferred
* bytes_rx number of bytes transmitted
* bytes_tx number of bytes received
* errors number of errors encounterd
* timedout number of messages that have timed out
* spi_async number of spi_messages submitted using spi_async
* spi_sync number of spi_messages submitted using spi_sync
* spi_sync_immediate number of spi_messages submitted using spi_sync,
that are handled immediately without a context switch
to the spi_pump worker-thread
spi_map_buf() processes mapping of vmalloc-ed buffers in a special way,
making mapping of every page separately. However, if the buffer is not
aligned to page boundary (e.g. sub-array in a vmalloc-ed array), it
fills the scatter table with page-size unaligned pieces, that cross
page boundaries. This is incorrect and can, for example, cause memory
corruption and various crashes when working with ubifs on spi-nor chips
(though those drivers are themselves buggy in that they should be
providing DMAable memory to the SPI framework).
Fix this by using proper scatter table size and intra-page buffer lengths,
so that the whole buffer splits into separate scatter table entries on
page boundaries.
Signed-off-by: Andrew Gabbasov <andrew_gabbasov@mentor.com>
The case where spi_master sets the flags SPI_MASTER_MUST_RX/TX while
CONFIG_HAS_DMA is unset (which is unlikley) together with a driver
that reuses spi_messages with rx/tx_buff set to NULL, can result in:
* data disclosure over the SPI (for tx_buf == NULL)
* memory corruption (for rx_buf == NULL)
This happenes when dummy_rx/dummy_tx are changing address due to krealloc
or free and an allocation of the memory by a different part of the kernel.
Fix a race (with some kernel configurations) where a queued
master->pump_messages runs and frees dummy_tx/rx before
spi_unmap_msg is running (or is finished).
This results in the following messages:
BUG: Bad page state in process
page:db7ba030 count:0 mapcount:0 mapping: (null) index:0x0
flags: 0x200(arch_1)
page dumped because: PAGE_FLAGS_CHECK_AT_PREP flag set
Reported-by: Noralf Trønnes <noralf@tronnes.org>
Suggested-by: Noralf Trønnes <noralf@tronnes.org>
Tested-by: Noralf Trønnes <noralf@tronnes.org>
Some spi device drivers use the same tx_buf and rx_buf repeatly for better
performance such as driver/input/touchsreen/ads7846.c, but spi core grab tx_buf
/rx_buf of transfer and set them as dummy_tx/dummy_rx once they are NULL. Thus,
in the second time the tx_buf/rx_buf will be replaced by dummy_tx/dummy_rx and
the data which produced by the last tx or rx may be wrongly sent to the device
or handled by the upper level protocol. This patch just keep the orignal value
of tx_buf/rx_buf if they are NULL after this transfer processed.
Signed-off-by: Robin Gong <b38343@freescale.com>
'spi/topic/omap-uwire', 'spi/topic/pl022', 'spi/topic/pm' and 'spi/topic/pxa2xx' into spi-next
'spi/topic/dw' and 'spi/topic/err' into spi-next
'spi/topic/bcm2835', 'spi/topic/bcm53xx' and 'spi/topic/bitbang' into spi-next
If a driver doesn't implement the master->handle_err() callback and an
SPI transfer fails, the kernel will crash with a NULL pointer
dereference:
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = c0003000
[00000000] *pgd=80000040004003, *pmd=00000000
Internal error: Oops: 80000206 [#1] SMP ARM
Modules linked in:
CPU: 1 PID: 1 Comm: swapper/0 Not tainted 4.0.0-rc7-koelsch-05861-g1fc9fdd4add4f783 #1046
Hardware name: Generic R8A7791 (Flattened Device Tree)
task: eec359c0 ti: eec54000 task.ti: eec54000
PC is at 0x0
LR is at spi_transfer_one_message+0x1cc/0x1f0
Make the master->handle_err() callback optional to avoid the crash.
Also fix a spelling mistake in the callback documentation while we're at
it.
Fixes: b716c4ffc6a2b0bf ("spi: introduce master->handle_err() callback")
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Trying to register an SPI device asynchronously (via async_schedule() call)
results in an ugly complaint from request_module() warning about potential
deadlock (because request_module tries to wait for async works to
complete, the caller is also an async work in this case).
While we could try to switch to using request_module_nowait(), other buses,
as well as SPI itself when not using device tree, do not try to load
modules explicitly, but rather rely on the standard infrastructure (such as
udev) to execute module loading. There is no reason why SPI OF-described
devices should be treated differently.
With spidev the mesg->complete callback points to spidev_complete.
Calling this unblocks spidev_sync and so spidev_sync_write finishes. As
the struct spi_message just read is a local variable in
spidev_sync_write and recording the trace event accesses this message
the recording is better done first. The same can happen for
spidev_sync_read.
This fixes an oops observed on a 3.14-rt system with spidev activity
after
echo 1 > /sys/kernel/debug/tracing/events/spi/enable
Some devices samples state of the chip select signal during power up
and act differently based on this state, so SPI core should ensure
that CS line is driven in non-active state after spi_setup().
Signed-off-by: Ivan T. Ivanov <iivanov@mm-sol.com>
All SPI drivers have been converted from legacy suspend/resume callbacks to
dev_pm_ops. So we can finally remove support for legacy PM from the SPI
core.
Since there aren't any special bus specific things to do during
suspend/resume and since the PM core will automatically fallback directly to
using the device's PM ops if no bus PM ops are specified there is no need to
have any special SPI bus PM ops.
This callback would be useful to handle an error that occurs in the generic
implementation of transfer_one_message(). The good candidate for this is to
drain FIFO and / or to terminate DMA transfers when timeout happened.
'spi/topic/inline', 'spi/topic/meson' and 'spi/topic/mxs' into spi-next
'spi/topic/fsl', 'spi/topic/fsl-dspi' and 'spi/topic/gpio' into spi-next
return type of wait_for_completion_timeout is unsigned long not int, this
patch changes the type of m from int to unsigned long.
Signed-off-by: Nicholas Mc Guire <der.herr@hofr.at>
