-enable warnings as errors compilation flag
-handle error of uninitialised variable
bug 949219
Change-Id: I9e754b1cbf086f99433d47aef793a8635185a25e
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
Reviewed-on: http://git-master/r/118239
GVS: Gerrit_Virtual_Submit
Reviewed-by: Sanjay Singh Rawat <srawat@nvidia.com>
Tested-by: Sanjay Singh Rawat <srawat@nvidia.com>
To terminate request from dma, use the tegra_dma_cancel() inplace of
tegra_dma_dequeue().
The api tegra_dma_dequeue() is getting to be obsolete.
Change-Id: I297e67433a2118377ecb9b028dcf8fa82e09f0e2
Reviewed-on: http://git-master/r/91752
Reviewed-by: Ashwini Ghuge <aghuge@nvidia.com>
Tested-by: Ashwini Ghuge <aghuge@nvidia.com>
Fixing the logic to clear/set spi cs level on default command
register.
Change-Id: I55e130ecb02dae6e11ad7048730ed11df9848e94
Reviewed-on: http://git-master/r/86888
Reviewed-by: Rakesh Goyal <rgoyal@nvidia.com>
The dma client should use the tegra_dma_dequeue_req() for
dequeue the dma request.
Change-Id: I1f433c85ffec997d8c608e08509c48c72b27120a
Reviewed-on: http://git-master/r/77804
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Fixed warning message
Bug ID: 912669
Change-Id: I3090c35a5d0725102c101b10a99914510a272fa4
Reviewed-on: http://git-master/r/69444
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Change-Id: If544ad6382b8321f8c5e94e0a8a7679d36c48b67
Reviewed-on: http://git-master/r/52239
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Tested-by: Amlan Kundu <akundu@nvidia.com>
Reviewed-on: http://git-master/r/62044
Reviewed-by: Manoj Chourasia <mchourasia@nvidia.com>
Reviewed-by: Sandeep Trasi <strasi@nvidia.com>
Rebase-Id: Rc0e69778b981cba9a5dfd1b55ece16d5f43cf22e
Exporting with GPL flag of the api spi_tegra_register_callback()
for registering for callback.
Original-Change-Id: Ic3cbbca226071002824f1b6089dc2ccec796cc07
Reviewed-on: http://git-master/r/49663
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Rebase-Id: R0c7ce298c123e380398c512effe0b6b20685fdd9
Providing the different clock source option through platform data
to select best clock source based on required interface frequency.
bug 851642
Original-Change-Id: I18bf817b63cf1afac7db3969f266cc5fcaeee81e
Reviewed-on: http://git-master/r/41226
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Rebase-Id: Ra4e4573414ef2c4e72cdcb4cd5625e242cfb4ec6
Change SOC conditionals to make them more forward-looking.
Original-Change-Id: Ib60db4e690c2f396afdec962616d735548b5a8a9
Reviewed-on: http://git-master/r/32706
Reviewed-by: Niket Sirsi <nsirsi@nvidia.com>
Tested-by: Niket Sirsi <nsirsi@nvidia.com>
Rebase-Id: Ra0885f203904e0bd4bdd06c23b6aa7e03e7ec3bc
By changing the dma allocation API to take the client name, it is easy
to track who is allocated the DMA channels when we run out of the
DMA channels.
Original-Change-Id: I016011cfd74089fed0da1bc0f121800017ce124a
Reviewed-on: http://git-master/r/28031
Original-Change-Id: I048bcb87f95ee6d8ad2fdce993a1758dc5071666
Rebase-Id: R29b9645ecbe209f571018c6e707bfdd9cd65ad5d
Adding spi slave driver for tegra socs.
The interface is same as the master spi but spi controller
will work in slave mode.
Original-Change-Id: Ibf00e9d16e7bac675dd431a35e866bf56030f033
Reviewed-on: http://git-master/r/27605
Reviewed-by: Ramachandrudu Kandhala <rkandhala@nvidia.com>
Original-Change-Id: I1d770ae52371bae5869b03c69f86c06fb9cdc9fa
Rebase-Id: R6d1726c2b899437eed4dd8681403ed0f63f53265
