path: root/drivers/spi
2015-05-04spi: spidev: fix possible arithmetic overflow for multi-transfer messageIan Abbott
commit f20fbaad7620af2df36a1f9d1c9ecf48ead5b747 upstream. `spidev_message()` sums the lengths of the individual SPI transfers to determine the overall SPI message length. It restricts the total length, returning an error if too long, but it does not check for arithmetic overflow. For example, if the SPI message consisted of two transfers and the first has a length of 10 and the second has a length of (__u32)(-1), the total length would be seen as 9, even though the second transfer is actually very long. If the second transfer specifies a null `rx_buf` and a non-null `tx_buf`, the `copy_from_user()` could overrun the spidev's pre-allocated tx buffer before it reaches an invalid user memory address. Fix it by checking that neither the total nor the individual transfer lengths exceed the maximum allowed value. Thanks to Dan Carpenter for reporting the potential integer overflow. Signed-off-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-04-09spi: pl022: Fix race in giveback() leading to driver lock-upAlexander Sverdlin
commit cd6fa8d2ca53cac3226fdcffcf763be390abae32 upstream. Commit fd316941c ("spi/pl022: disable port when unused") introduced a race, which leads to possible driver lock up (easily reproducible on SMP). The problem happens in giveback() function where the completion of the transfer is signalled to SPI subsystem and then the HW SPI controller is disabled. Another transfer might be setup in between, which brings driver in locked-up state. Exact event sequence on SMP: core0 core1 => pump_transfers() /* message->state == STATE_DONE */ => giveback() => spi_finalize_current_message() => pl022_unprepare_transfer_hardware() => pl022_transfer_one_message => flush() => do_interrupt_dma_transfer() => set_up_next_transfer() /* Enable SSP, turn on interrupts */ writew((readw(SSP_CR1(pl022->virtbase)) | SSP_CR1_MASK_SSE), SSP_CR1(pl022->virtbase)); ... => pl022_interrupt_handler() => readwriter() /* disable the SPI/SSP operation */ => writew((readw(SSP_CR1(pl022->virtbase)) & (~SSP_CR1_MASK_SSE)), SSP_CR1(pl022->virtbase)); Lockup! SPI controller is disabled and the data will never be received. Whole SPI subsystem is waiting for transfer ACK and blocked. So, only signal transfer completion after disabling the controller. Fixes: fd316941c (spi/pl022: disable port when unused) Signed-off-by: Alexander Sverdlin <alexander.sverdlin@nokia.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-08spi/pxa2xx: Clear cur_chip pointer before starting next messageMika Westerberg
commit c957e8f084e0d21febcd6b8a0ea9631eccc92f36 upstream. Once the current message is finished, the driver notifies SPI core about this by calling spi_finalize_current_message(). This function queues next message to be transferred. If there are more messages in the queue, it is possible that the driver is asked to transfer the next message at this point. When spi_finalize_current_message() returns the driver clears the drv_data->cur_chip pointer to NULL. The problem is that if the driver already started the next message clearing drv_data->cur_chip will cause NULL pointer dereference which crashes the kernel like: BUG: unable to handle kernel NULL pointer dereference at 0000000000000048 IP: [<ffffffffa0022bc8>] cs_deassert+0x18/0x70 [spi_pxa2xx_platform] PGD 78bb8067 PUD 37712067 PMD 0 Oops: 0000 [#1] SMP Modules linked in: CPU: 1 PID: 11 Comm: ksoftirqd/1 Tainted: G O 3.18.0-rc4-mjo #5 Hardware name: Intel Corp. VALLEYVIEW B3 PLATFORM/NOTEBOOK, BIOS MNW2CRB1.X64.0071.R30.1408131301 08/13/2014 task: ffff880077f9f290 ti: ffff88007a820000 task.ti: ffff88007a820000 RIP: 0010:[<ffffffffa0022bc8>] [<ffffffffa0022bc8>] cs_deassert+0x18/0x70 [spi_pxa2xx_platform] RSP: 0018:ffff88007a823d08 EFLAGS: 00010202 RAX: 0000000000000008 RBX: ffff8800379a4430 RCX: 0000000000000026 RDX: 0000000000000000 RSI: 0000000000000246 RDI: ffff8800379a4430 RBP: ffff88007a823d18 R08: 00000000ffffffff R09: 000000007a9bc65a R10: 000000000000028f R11: 0000000000000005 R12: ffff880070123e98 R13: ffff880070123de8 R14: 0000000000000100 R15: ffffc90004888000 FS: 0000000000000000(0000) GS:ffff880079a80000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 0000000000000048 CR3: 000000007029b000 CR4: 00000000001007e0 Stack: ffff88007a823d58 ffff8800379a4430 ffff88007a823d48 ffffffffa0022c89 0000000000000000 ffff8800379a4430 0000000000000000 0000000000000006 ffff88007a823da8 ffffffffa0023be0 ffff88007a823dd8 ffffffff81076204 Call Trace: [<ffffffffa0022c89>] giveback+0x69/0xa0 [spi_pxa2xx_platform] [<ffffffffa0023be0>] pump_transfers+0x710/0x740 [spi_pxa2xx_platform] [<ffffffff81076204>] ? pick_next_task_fair+0x744/0x830 [<ffffffff81049679>] tasklet_action+0xa9/0xe0 [<ffffffff81049a0e>] __do_softirq+0xee/0x280 [<ffffffff81049bc0>] run_ksoftirqd+0x20/0x40 [<ffffffff810646df>] smpboot_thread_fn+0xff/0x1b0 [<ffffffff810645e0>] ? SyS_setgroups+0x150/0x150 [<ffffffff81060f9d>] kthread+0xcd/0xf0 [<ffffffff81060ed0>] ? kthread_create_on_node+0x180/0x180 [<ffffffff8187a82c>] ret_from_fork+0x7c/0xb0 Fix this by clearing drv_data->cur_chip before we call spi_finalize_current_message(). Reported-by: Martin Oldfield <m@mjoldfield.com> Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-08spi: dw-mid: fix FIFO sizeAndy Shevchenko
commit 67bf9cda4b498b8cea4a40be67a470afe57d2e88 upstream. The FIFO size is 40 accordingly to the specifications, but this means 0x40, i.e. 64 bytes. This patch fixes the typo and enables FIFO size autodetection for Intel MID devices. Fixes: 7063c0d942a1 (spi/dw_spi: add DMA support) Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-01-26spi: fsl: Fix problem with multi message transfersStefan Roese
commit 4302a59629f7a0bd70fd1605d2b558597517372a upstream. When used via spidev with more than one messages to tranfer via SPI_IOC_MESSAGE the current implementation would return with -EINVAL, since bits_per_word and speed_hz are set in all transfer structs. And in the 2nd loop status will stay at -EINVAL as its not overwritten again via fsl_spi_setup_transfer(). This patch changes this behavious by first checking if one of the messages uses different settings. If this is the case the function will return with -EINVAL. If not, the messages are transferred correctly. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: Esben Haabendal <esbenhaabendal@gmail.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-12-06spi: dw: Fix dynamic speed change.Thor Thayer
commit 0a8727e69778683495058852f783eeda141a754e upstream. An IOCTL call that calls spi_setup() and then dw_spi_setup() will overwrite the persisted last transfer speed. On each transfer, the SPI speed is compared to the last transfer speed to determine if the clock divider registers need to be updated (did the speed change?). This bug was observed with the spidev driver using spi-config to update the max transfer speed. This fix: Don't overwrite the persisted last transaction clock speed when updating the SPI parameters in dw_spi_setup(). On the next transaction, the new speed won't match the persisted last speed and the hardware registers will be updated. On initialization, the persisted last transaction clock speed will be 0 but will be updated after the first SPI transaction. Move zeroed clock divider check into clock change test because chip->clk_div is zero on startup and would cause a divide-by-zero error. The calculation was wrong as well (can't support odd #). Reported-by: Vlastimil Setka <setka@vsis.cz> Signed-off-by: Vlastimil Setka <setka@vsis.cz> Signed-off-by: Thor Thayer <tthayer@opensource.altera.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-11-13spi: pxa2xx: toggle clocks on suspend if not disabled by runtime PMDmitry Eremin-Solenikov
commit 2b9375b91bef65b837bed61a05fb387159b38ddf upstream. If PM_RUNTIME is enabled, it is easy to trigger the following backtrace on pxa2xx hosts: ------------[ cut here ]------------ WARNING: CPU: 0 PID: 1 at /home/lumag/linux/arch/arm/mach-pxa/clock.c:35 clk_disable+0xa0/0xa8() Modules linked in: CPU: 0 PID: 1 Comm: swapper Not tainted 3.17.0-00007-g1b3d2ee-dirty #104 [<c000de68>] (unwind_backtrace) from [<c000c078>] (show_stack+0x10/0x14) [<c000c078>] (show_stack) from [<c001d75c>] (warn_slowpath_common+0x6c/0x8c) [<c001d75c>] (warn_slowpath_common) from [<c001d818>] (warn_slowpath_null+0x1c/0x24) [<c001d818>] (warn_slowpath_null) from [<c0015e80>] (clk_disable+0xa0/0xa8) [<c0015e80>] (clk_disable) from [<c02507f8>] (pxa2xx_spi_suspend+0x2c/0x34) [<c02507f8>] (pxa2xx_spi_suspend) from [<c0200360>] (platform_pm_suspend+0x2c/0x54) [<c0200360>] (platform_pm_suspend) from [<c0207fec>] (dpm_run_callback.isra.14+0x2c/0x74) [<c0207fec>] (dpm_run_callback.isra.14) from [<c0209254>] (__device_suspend+0x120/0x2f8) [<c0209254>] (__device_suspend) from [<c0209a94>] (dpm_suspend+0x50/0x208) [<c0209a94>] (dpm_suspend) from [<c00455ac>] (suspend_devices_and_enter+0x8c/0x3a0) [<c00455ac>] (suspend_devices_and_enter) from [<c0045ad4>] (pm_suspend+0x214/0x2a8) [<c0045ad4>] (pm_suspend) from [<c04b5c34>] (test_suspend+0x14c/0x1dc) [<c04b5c34>] (test_suspend) from [<c000880c>] (do_one_initcall+0x8c/0x1fc) [<c000880c>] (do_one_initcall) from [<c04aecfc>] (kernel_init_freeable+0xf4/0x1b4) [<c04aecfc>] (kernel_init_freeable) from [<c0378078>] (kernel_init+0x8/0xec) [<c0378078>] (kernel_init) from [<c0009590>] (ret_from_fork+0x14/0x24) ---[ end trace 46524156d8faa4f6 ]--- This happens because suspend function tries to disable a clock that is already disabled by runtime_suspend callback. Add if (!pm_runtime_suspended()) checks to suspend/resume path. Fixes: 7d94a505858 (spi/pxa2xx: add support for runtime PM) Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Reported-by: Andrea Adami <andrea.adami@gmail.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-11-13spi: fsl-dspi: Fix CTAR selectionAlexander Stein
commit 5cc7b04740effa5cc0af53f434134b5859d58b73 upstream. There are only 4 CTAR registers (CTAR0 - CTAR3) so we can only use the lower 2 bits of the chip select to select a CTAR register. SPI_PUSHR_CTAS used the lower 3 bits which would result in wrong bit values if the chip selects 4/5 are used. For those chip selects SPI_CTAR even calculated offsets of non-existing registers. Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-11-13spi: pl022: Fix incorrect dma_unmap_sgRay Jui
commit 3ffa6158f002e096d28ede71be4e0ee8ab20baa2 upstream. When mapped RX DMA entries are unmapped in an error condition when DMA is firstly configured in the driver, the number of TX DMA entries was passed in, which is incorrect Signed-off-by: Ray Jui <rjui@broadcom.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-10-31spi: dw-mid: terminate ongoing transfers at exitAndy Shevchenko
commit 8e45ef682cb31fda62ed4eeede5d9745a0a1b1e2 upstream. Do full clean up at exit, means terminate all ongoing DMA transfers. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-10-31spi: dw-mid: check that DMA was inited before exitAndy Shevchenko
commit fb57862ead652454ceeb659617404c5f13bc34b5 upstream. If the driver was compiled with DMA support, but DMA channels weren't acquired by some reason, mid_spi_dma_exit() will crash the kernel. Fixes: 7063c0d942a1 (spi/dw_spi: add DMA support) Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-10-31spi: dw-mid: respect 8 bit modeAndy Shevchenko
commit b41583e7299046abdc578c33f25ed83ee95b9b31 upstream. In case of 8 bit mode and DMA usage we end up with every second byte written as 0. We have to respect bits_per_word settings what this patch actually does. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-10-13spi/omap-mcspi: Fix the spi task hangs waiting dma_rxJorge A. Ventura
commit 3d0763c006f8da1b44a9f5f9a21187f5b8f674f4 upstream. The spi hangs waiting the completion of omap2_mcspi_rx_callback. Signed-off-by: Jorge A. Ventura <jorge.araujo.ventura@gmail.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-17spi/pxa2xx: Add ACPI ID for Intel BraswellAlan Cox
commit aca26364689e00e3b2052072424682231bdae6ae upstream. The SPI host controller is the same as used in Baytrail, only the ACPI ID is different so add this new ID to the list. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-09-17spi: orion: fix incorrect handling of cell-index DT propertyThomas Petazzoni
commit e06871cd2c92e5c65d7ca1d32866b4ca5dd4ac30 upstream. In commit f814f9ac5a81 ("spi/orion: add device tree binding"), Device Tree support was added to the spi-orion driver. However, this commit reads the "cell-index" property, without taking into account the fact that DT properties are big-endian encoded. Since most of the platforms using spi-orion with DT have apparently not used anything but cell-index = <0>, the problem was not visible. But as soon as one starts using cell-index = <1>, the problem becomes clearly visible, as the master->bus_num gets a wrong value (actually it gets the value 0, which conflicts with the first bus that has cell-index = <0>). This commit fixes that by using of_property_read_u32() to read the property value, which does the appropriate endianness conversion when needed. Fixes: f814f9ac5a81 ("spi/orion: add device tree binding") Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-06-09spi: core: Ignore unsupported Dual/Quad Transfer Mode bitsGeert Uytterhoeven
commit 83596fbeb5d28e8cb8878786133945d4dc7c0090 upstream. The availability of SPI Dual or Quad Transfer Mode as indicated by the "spi-tx-bus-width" and "spi-rx-bus-width" properties in the device tree is a hardware property of the SPI master, SPI slave, and board wiring. Hence the SPI core should not reject an SPI slave because an SPI master driver doesn't (yet) support Dual or Quad Transfer Mode. Change the lack of Dual or Quad Transfer Mode support in the SPI master driver from an error condition to a warning condition, and ignore the unsupported mode bits, falling back to Single Transfer Mode, to avoid breakages when running old kernels with new device trees. Fixes: f477b7fb13df (spi: DUAL and QUAD support) Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-05-15spi: efm32: use $vendor,$device scheme for compatible stringUwe Kleine-König
commit 12f6dd860cf8bf036c0bec38c00a53da71bcd43a upstream. Wolfram Sang pointed out that "efm32,$device" is non-standard. So use the common scheme and prefix device with "efm32-". The old compatible string is left in place until arch/arm/boot/dts/efm32* is fixed. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-03-22spi: spi-ath79: fix initial GPIO CS line setupGabor Juhos
commit 61d1cf163c8653934cc8cd5d0b2a562d0990c265 upstream. The 'ath79_spi_setup_cs' function initializes the chip select line of a given SPI device in order to make sure that the device is inactive. If the SPI_CS_HIGH bit is set for a given device, it means that the CS line of that device is active HIGH so it must be set to LOW initially. In case of GPIO CS lines, the 'ath79_spi_setup_cs' function does the opposite of that due to the wrong GPIO flags. Fix the code to use the correct GPIO flags. Reported-by: Ronald Wahl <ronald.wahl@raritan.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-03-22spi: spi-imx: spi_imx_remove: do not disable disabled clocksPhilippe De Muyter
commit fd40dccb1a170ba689664481a3de83617b7194d2 upstream. Currently, at module removal, one gets the following warnings: ------------[ cut here ]------------ WARNING: at drivers/clk/clk.c:780 clk_disable+0x18/0x24() Modules linked in: spi_imx(-) [last unloaded: ev76c560] CPU: 1 PID: 16337 Comm: rmmod Tainted: G W 3.10.17-80548-g90191eb-dirty #33 [<80013b4c>] (unwind_backtrace+0x0/0xf8) from [<800115dc>] (show_stack+0x10/0x14) [<800115dc>] (show_stack+0x10/0x14) from [<800257b8>] (warn_slowpath_common+0x4c/0x68) [<800257b8>] (warn_slowpath_common+0x4c/0x68) from [<800257f0>] (warn_slowpath_null+0x1c/0x24) [<800257f0>] (warn_slowpath_null+0x1c/0x24) from [<803f60ec>] (clk_disable+0x18/0x24) [<803f60ec>] (clk_disable+0x18/0x24) from [<7f02c9cc>] (spi_imx_remove+0x54/0x9c [spi_imx]) [<7f02c9cc>] (spi_imx_remove+0x54/0x9c [spi_imx]) from [<8025868c>] (platform_drv_remove+0x18/0x1c) [<8025868c>] (platform_drv_remove+0x18/0x1c) from [<80256f60>] (__device_release_driver+0x70/0xcc) [<80256f60>] (__device_release_driver+0x70/0xcc) from [<80257770>] (driver_detach+0xcc/0xd0) [<80257770>] (driver_detach+0xcc/0xd0) from [<80256d90>] (bus_remove_driver+0x7c/0xc0) [<80256d90>] (bus_remove_driver+0x7c/0xc0) from [<80068668>] (SyS_delete_module+0x144/0x1f8) [<80068668>] (SyS_delete_module+0x144/0x1f8) from [<8000e080>] (ret_fast_syscall+0x0/0x30) ---[ end trace 1f5df9ad54996300 ]--- ------------[ cut here ]------------ WARNING: at drivers/clk/clk.c:780 clk_disable+0x18/0x24() Modules linked in: spi_imx(-) [last unloaded: ev76c560] CPU: 1 PID: 16337 Comm: rmmod Tainted: G W 3.10.17-80548-g90191eb-dirty #33 [<80013b4c>] (unwind_backtrace+0x0/0xf8) from [<800115dc>] (show_stack+0x10/0x14) [<800115dc>] (show_stack+0x10/0x14) from [<800257b8>] (warn_slowpath_common+0x4c/0x68) [<800257b8>] (warn_slowpath_common+0x4c/0x68) from [<800257f0>] (warn_slowpath_null+0x1c/0x24) [<800257f0>] (warn_slowpath_null+0x1c/0x24) from [<803f60ec>] (clk_disable+0x18/0x24) [<803f60ec>] (clk_disable+0x18/0x24) from [<7f02c9e8>] (spi_imx_remove+0x70/0x9c [spi_imx]) [<7f02c9e8>] (spi_imx_remove+0x70/0x9c [spi_imx]) from [<8025868c>] (platform_drv_remove+0x18/0x1c) [<8025868c>] (platform_drv_remove+0x18/0x1c) from [<80256f60>] (__device_release_driver+0x70/0xcc) [<80256f60>] (__device_release_driver+0x70/0xcc) from [<80257770>] (driver_detach+0xcc/0xd0) [<80257770>] (driver_detach+0xcc/0xd0) from [<80256d90>] (bus_remove_driver+0x7c/0xc0) [<80256d90>] (bus_remove_driver+0x7c/0xc0) from [<80068668>] (SyS_delete_module+0x144/0x1f8) [<80068668>] (SyS_delete_module+0x144/0x1f8) from [<8000e080>] (ret_fast_syscall+0x0/0x30) ---[ end trace 1f5df9ad54996301 ]--- Since commit 9e556dcc55774c9a1032f32baa0e5cfafede8b70, "spi: spi-imx: only enable the clocks when we start to transfer a message", clocks are always disabled except when transmitting messages. There is thus no need to disable them at module removal. Fixes: 9e556dcc55774 (spi: spi-imx: only enable the clocks when we start to transfer a message) Signed-off-by: Philippe De Muyter <phdm@macqel.be> Acked-by: Huang Shijie <b32955@freescale.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-03-22spi: fsl-dspi: Fix getting correct address for masterAxel Lin
commit 017145fef567430789e40f6a22a90ce2a766370b upstream. Current code set platform drvdata to dspi. However, the code in dspi_suspend() and dspi_resume() assumes the drvdata is the address of master. Fix it by setting platform drvdata to master. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-03-22spi: coldfire-qspi: Fix getting correct address for *mcfqspiAxel Lin
commit ee73b4c6e3fc0755a91752ab8eebc8e070038b53 upstream. dev_get_drvdata() returns the address of master rather than mcfqspi. Fixes: af361079 (spi/coldfire-qspi: Drop extra calls to spi_master_get in suspend/resume functions) Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-02-22spi: nuc900: Set SPI_LSB_FIRST for master->mode_bits if hw->pdata->lsb is trueAxel Lin
commit f7db1588d6028c97c098bb6445eaabc56a25fed8 upstream. Otherwise, spi_setup() fails with unsupported mode bits message. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22spi: Fix crash with double message finalisation on error handlingGeert Uytterhoeven
commit 1f802f8249a0da536877842c43c7204064c4de8b upstream. This reverts commit e120cc0dcf2880a4c5c0a6cb27b655600a1cfa1d. It causes a NULL pointer dereference with drivers using the generic spi_transfer_one_message(), which always calls spi_finalize_current_message(), which zeroes master->cur_msg. Drivers implementing transfer_one_message() theirselves must always call spi_finalize_current_message(), even if the transfer failed: * @transfer_one_message: the subsystem calls the driver to transfer a single * message while queuing transfers that arrive in the meantime. When the * driver is finished with this message, it must call * spi_finalize_current_message() so the subsystem can issue the next * transfer Signed-off-by: Geert Uytterhoeven <geert+renesas@linux-m68k.org> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-13spi/pxa2xx: initialize DMA channels to -1 to prevent inadvertent matchMika Westerberg
commit 483c319188c74e82b29a0ed7a7fa7065570f2193 upstream. Commit cddb339badb0 (spi/pxa2xx: convert to dma_request_slave_channel_compat()) converted the driver to use ACPI provided DMA helpers but it forgot to initialize the platform data for the channels to -1. Failing to do so will result inadvertent match in the filter function because 0 is a valid channel number. Prevent this from happening by initializing both platform data channels correctly to -1. Fixes: cddb339badb0 (spi/pxa2xx: convert to dma_request_slave_channel_compat()) Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-13spidev: fix hang when transfer_one_message failsDaniel Santos
commit e120cc0dcf2880a4c5c0a6cb27b655600a1cfa1d upstream. This corrects a problem in spi_pump_messages() that leads to an spi message hanging forever when a call to transfer_one_message() fails. This failure occurs in my MCP2210 driver when the cs_change bit is set on the last transfer in a message, an operation which the hardware does not support. Rationale Since the transfer_one_message() returns an int, we must presume that it may fail. If transfer_one_message() should never fail, it should return void. Thus, calls to transfer_one_message() should properly manage a failure. Fixes: ffbbdd21329f3 (spi: create a message queueing infrastructure) Signed-off-by: Daniel Santos <daniel.santos@pobox.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-13spi/bcm63xx: don't substract prepend length from total lengthJonas Gorski
commit 86b3bde003e6bf60ccb9c09b4115b8a2f533974c upstream. The spi command must include the full message length including any prepended writes, else transfers larger than 256 bytes will be incomplete. Signed-off-by: Jonas Gorski <jogo@openwrt.org> Acked-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-11spi/pxa2xx: add new ACPI IDsMika Westerberg
commit 54acbd9688e6324470671525c7916011f1ff8081 upstream. Newer Intel PCHs with LPSS have the same SPI controllers than Haswell but ACPI IDs are different. Add these IDs to the driver list. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-07Merge remote-tracking branch 'spi/fix/s3c64xx' into spi-linusMark Brown
2013-10-07Merge remote-tracking branch 'spi/fix/pxa' into spi-linusMark Brown
2013-10-07Merge remote-tracking branch 'spi/fix/mpc512x' into spi-linusMark Brown
2013-10-07Merge remote-tracking branch 'spi/fix/hspi' into spi-linusMark Brown
2013-10-07Merge remote-tracking branch 'spi/fix/dspi' into spi-linusMark Brown
2013-10-07Merge remote-tracking branch 'spi/fix/clps711x' into spi-linusMark Brown
2013-10-07spi: atmel: Fix incorrect error pathSachin Kamat
'irq' was not released when clk_prepare_enable failed. Fix it. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-10-03spi/hspi: fixup Runtime PM enable timingKuninori Morimoto
3e00a09d2fbd64f0ad98e7c8c29dbf9e038fc746 (spi/hspi: Convert to core runtime PM) enabled master->auto_runtime_pm. Then, pm_runtime_enable() is required *before* spi_register_master() calling. This patch fixed it up. Kernel will hang up with "spi_master spi0: Failed to power device: -13" message without this patch. Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-27spi/s3c64xx: Ensure runtime PM is enabled prior to registrationMark Brown
Otherwise we may try to start transfers immediately and then fail to runtime resume the device causing us not to have clocks enabled. Signed-off-by: Mark Brown <broonie@linaro.org> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Conflicts: drivers/spi/spi-s3c64xx.c
2013-09-27spi/clps711x: drop clk_put for devm_clk_get in spi_clps711x_probe()Wei Yongjun
devm_clk_get() is used so there is no reason to explicitly call clk_put() in probe or remove functions. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-13Remove GENERIC_HARDIRQ config optionMartin Schwidefsky
After the last architecture switched to generic hard irqs the config options HAVE_GENERIC_HARDIRQS & GENERIC_HARDIRQS and the related code for !CONFIG_GENERIC_HARDIRQS can be removed. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-09-12spi: fix return value check in dspi_probe()Wei Yongjun
In case of error, the function devm_ioremap_resource() returns ERR_PTR() and never returns NULL. The NULL test in the return value check should be replaced with IS_ERR(). Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-12spi: mpc512x: fix error return code in mpc512x_psc_spi_do_probe()Wei Yongjun
Fix to return a negative error code from the error handling case instead of 0, as done elsewhere in this function. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-10spi: clps711x: Don't call kfree() after spi_master_put/spi_unregister_masterAxel Lin
Calling kfree() to clean up the memory obtained from spi_alloc_master() is wrong as this is done in spi_master_release() when spi_master->dev's refcount reaches zero. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-06Merge tag 'dt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC DT updates from Olof Johansson: "Device tree and bindings updates for 3.12. General additions of various on-chip and on-board peripherals on various platforms as support gets added. Some of the bigger changes are: - Addition of (new) PCI-e support on Tegra. - More Tegra4 support, including PMC configuration for Dalmore. - Addition of a new board for Exynos4 (trats2) and more bindings for 4x12 IP. - Addition of Allwinner A20 and A31 SoC and board files. - Move of the ST Ericsson device tree files to now use ste-* prefix. - More move of hardware description of shmobile platforms to DT. - Two new board dts files for Freescale MXs" * tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (177 commits) dts: Rename DW APB timer compatible strings dts: Deprecate ALTR as a vendor prefix of: add vendor prefix for Altera Corp. ARM: at91/dt: sam9x5ek: add sound configuration ARM: at91/dt: sam9x5ek: enable SSC ARM: at91/dt: sam9x5ek: add WM8731 codec ARM: at91/dt: sam9x5: add SSC DMA parameters ARM: at91/dt: add at91rm9200 PQFP package version ARM: at91: at91rm9200: set default mmc0 pinctrl-names ARM: at91: at91sam9n12: correct pin number of gpio-key ARM: at91: at91sam9n12: add qt1070 support ARM: at91: at91sam9n12: add pinctrl of TWI ARM: at91: Add PMU support for sama5d3 ARM: at91: at91sam9260: add missing pinctrl-names on mmc ARM: tegra: configure power off for Dalmore ARM: DT: binding fixup to align with vendor-prefixes.txt (DT) ARM: dts: add sdio blocks to bcm28155-ap board ARM: dts: align sdio numbers to HW definition ARM: sun7i: Add Olimex A20-Olinuxino-Micro support ARM: sun7i: Add Allwinner A20 DTSI ...
2013-09-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "The usual trivial updates all over the tree -- mostly typo fixes and documentation updates" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (52 commits) doc: Documentation/cputopology.txt fix typo treewide: Convert retrun typos to return Fix comment typo for init_cma_reserved_pageblock Documentation/trace: Correcting and extending tracepoint documentation mm/hotplug: fix a typo in Documentation/memory-hotplug.txt power: Documentation: Update s2ram link doc: fix a typo in Documentation/00-INDEX Documentation/printk-formats.txt: No casts needed for u64/s64 doc: Fix typo "is is" in Documentations treewide: Fix printks with 0x%# zram: doc fixes Documentation/kmemcheck: update kmemcheck documentation doc: documentation/hwspinlock.txt fix typo PM / Hibernate: add section for resume options doc: filesystems : Fix typo in Documentations/filesystems scsi/megaraid fixed several typos in comments ppc: init_32: Fix error typo "CONFIG_START_KERNEL" treewide: Add __GFP_NOWARN to k.alloc calls with v.alloc fallbacks page_isolation: Fix a comment typo in test_pages_isolated() doc: fix a typo about irq affinity ...
2013-09-04Merge tag 'PTR_RET-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull PTR_RET() removal patches from Rusty Russell: "PTR_RET() is a weird name, and led to some confusing usage. We ended up with PTR_ERR_OR_ZERO(), and replacing or fixing all the usages. This has been sitting in linux-next for a whole cycle" [ There are still some PTR_RET users scattered about, with some of them possibly being new, but most of them existing in Rusty's tree too. We have that #define PTR_RET(p) PTR_ERR_OR_ZERO(p) thing in <linux/err.h>, so they continue to work for now - Linus ] * tag 'PTR_RET-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: GFS2: Replace PTR_RET with PTR_ERR_OR_ZERO Btrfs: volume: Replace PTR_RET with PTR_ERR_OR_ZERO drm/cma: Replace PTR_RET with PTR_ERR_OR_ZERO sh_veu: Replace PTR_RET with PTR_ERR_OR_ZERO dma-buf: Replace PTR_RET with PTR_ERR_OR_ZERO drivers/rtc: Replace PTR_RET with PTR_ERR_OR_ZERO mm/oom_kill: remove weird use of ERR_PTR()/PTR_ERR(). staging/zcache: don't use PTR_RET(). remoteproc: don't use PTR_RET(). pinctrl: don't use PTR_RET(). acpi: Replace weird use of PTR_RET. s390: Replace weird use of PTR_RET. PTR_RET is now PTR_ERR_OR_ZERO(): Replace most. PTR_RET is now PTR_ERR_OR_ZERO
2013-09-04spi/pxa2xx: check status register as well to determine if the device is offMika Westerberg
The current interrupt handler calls pm_runtime_suspended() to check if the device is suspended or not. However, runtime PM status of the device is only set to suspended once all PM runtime suspend hooks have executed. In case of Intel Lynxpoint we have the device bound to the ACPI power domain and its runtime suspend hook will put the device to D3hot (or D3cold if possible). This means that the device is powered off before its state is set to runtime suspended. While in this state the device might get an interrupt that is meant for another device (as the interrupt line is shared), and because the device is powered off accessing its registers will return 0xffffffff that the driver misinterprets as an invalid state. When this happens user will see messages like below on the console: pxa2xx-spi INT33C0:00: bad message state in interrupt handler Fix this by checking the status register for ~0 and returning IRQ_NONE in that case. Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-09-03Merge branch 'socfpga/dt' into next/dtOlof Johansson
SoCFPGA DT changes from Dinh Nguyen. * socfpga/dt: dts: Rename DW APB timer compatible strings dts: Deprecate ALTR as a vendor prefix of: add vendor prefix for Altera Corp. Signed-off-by: Olof Johansson <olof@lixom.net>
2013-09-01Merge remote-tracking branch 'spi/topic/txx9' into spi-nextMark Brown
2013-09-01Merge remote-tracking branch 'spi/topic/topcliff' into spi-nextMark Brown
2013-09-01Merge remote-tracking branch 'spi/topic/tel62x0' into spi-nextMark Brown
2013-09-01Merge remote-tracking branch 'spi/topic/tegra' into spi-nextMark Brown
